Zip error after doing a clean cache
Hello all,
I have openHAB 4.2.1 install on raspbian.
I’ve use the “openhab-cli clean-cache” trying to solve a binding problem.
But now Openhab doesn’t start anymore with a bunch of error like this:
2025-05-06 22:16:36.908 [ERROR] [Events.Framework                    ] - FrameworkEvent ERROR
java.util.zip.ZipException: Exception in opening zip file: /var/lib/openhab/cache/org.eclipse.osgi/213/0/bundleFile
        at org.eclipse.osgi.framework.util.SecureAction.getZipFile(SecureAction.java:356) ~[org.eclipse.osgi-3.18.0.jar:?]
        at org.eclipse.osgi.storage.bundlefile.ZipBundleFile.doOpen(ZipBundleFile.java:51) ~[org.eclipse.osgi-3.18.0.jar:?]
        at org.eclipse.osgi.storage.bundlefile.CloseableBundleFile.internalOpen(CloseableBundleFile.java:140) ~[org.eclipse.osgi-3.18.0.jar:?]
        at org.eclipse.osgi.storage.bundlefile.CloseableBundleFile.lockOpen(CloseableBundleFile.java:78) ~[org.eclipse.osgi-3.18.0.jar:?]
        at org.eclipse.osgi.storage.bundlefile.CloseableBundleFile.getEntry(CloseableBundleFile.java:274) ~[org.eclipse.osgi-3.18.0.jar:?]
        at org.eclipse.osgi.storage.BundleInfo$Generation.getEntry(BundleInfo.java:425) ~[org.eclipse.osgi-3.18.0.jar:?]
        at org.eclipse.osgi.internal.framework.EquinoxBundle.getEntry(EquinoxBundle.java:703) ~[org.eclipse.osgi-3.18.0.jar:?]
        at org.glassfish.hk2.osgiresourcelocator.ServiceLoaderImpl.addProviders(ServiceLoaderImpl.java:248) ~[?:?]
        at org.glassfish.hk2.osgiresourcelocator.ServiceLoaderImpl.trackBundles(ServiceLoaderImpl.java:82) ~[?:?]
        at org.glassfish.hk2.osgiresourcelocator.Activator.start(Activator.java:31) ~[?:?]
        at org.eclipse.osgi.internal.framework.BundleContextImpl$2.run(BundleContextImpl.java:818) ~[org.eclipse.osgi-3.18.0.jar:?]
        at org.eclipse.osgi.internal.framework.BundleContextImpl$2.run(BundleContextImpl.java:1) ~[org.eclipse.osgi-3.18.0.jar:?]
        at java.security.AccessController.doPrivileged(AccessController.java:569) ~[?:?]
        at org.eclipse.osgi.internal.framework.BundleContextImpl.startActivator(BundleContextImpl.java:810) ~[org.eclipse.osgi-3.18.0.jar:?]
        at org.eclipse.osgi.internal.framework.BundleContextImpl.start(BundleContextImpl.java:767) [org.eclipse.osgi-3.18.0.jar:?]
        at org.eclipse.osgi.internal.framework.EquinoxBundle.startWorker0(EquinoxBundle.java:1032) ~[org.eclipse.osgi-3.18.0.jar:?]
        at org.eclipse.osgi.internal.framework.EquinoxBundle$EquinoxModule.startWorker(EquinoxBundle.java:371) ~[org.eclipse.osgi-3.18.0.jar:?]
        at org.eclipse.osgi.container.Module.doStart(Module.java:605) ~[org.eclipse.osgi-3.18.0.jar:?]
        at org.eclipse.osgi.container.Module.start(Module.java:468) ~[org.eclipse.osgi-3.18.0.jar:?]
        at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel$2.run(ModuleContainer.java:1847) ~[org.eclipse.osgi-3.18.0.jar:?]
        at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor$1$1.execute(EquinoxContainerAdaptor.java:136) ~[org.eclipse.osgi-3.18.0.jar:?]
        at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1840) ~[org.eclipse.osgi-3.18.0.jar:?]
        at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1783) ~[org.eclipse.osgi-3.18.0.jar:?]
        at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1745) ~[org.eclipse.osgi-3.18.0.ja$
        at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1667) ~[org.eclipse.osgi-3.18.0.jar:?]
        at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1) ~[org.eclipse.osgi-3.18.0.jar:?]
        at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:234) [org.eclipse.osgi-3.18.0.jar:?]
        at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:345) [org.eclipse.osgi-3.18.0.jar:?]
Caused by: java.util.zip.ZipException: invalid CEN header (bad signature)
        at java.util.zip.ZipFile$Source.zerror(ZipFile.java:1728) ~[?:?]
        at java.util.zip.ZipFile$Source.checkAndAddEntry(ZipFile.java:1190) ~[?:?]
        at java.util.zip.ZipFile$Source.initCEN(ZipFile.java:1667) ~[?:?]
        at java.util.zip.ZipFile$Source.<init>(ZipFile.java:1445) ~[?:?]
        at java.util.zip.ZipFile$Source.get(ZipFile.java:1407) ~[?:?]
        at java.util.zip.ZipFile$CleanableResource.<init>(ZipFile.java:716) ~[?:?]
        at java.util.zip.ZipFile.<init>(ZipFile.java:250) ~[?:?]
        at java.util.zip.ZipFile.<init>(ZipFile.java:179) ~[?:?]
        at java.util.zip.ZipFile.<init>(ZipFile.java:193) ~[?:?]
        at org.eclipse.osgi.framework.util.SecureAction.getZipFile(SecureAction.java:342) ~[org.eclipse.osgi-3.18.0.jar:?]
        ... 27 more
Anyone know what could be the problem ?
