I’m playing around with some Zipato Mini Keypads. After several attempts I managed to include them in Openhab 2.5.
If press “Home” and enter the correct code, I get the following logs:
13:49:57.719 [DEBUG] [nding.zwave.handler.ZWaveThingHandler] - NODE 25: Updating channel state zwave:device:ad9c65cb:node25:notification_access_control to 0 [DecimalType]
13:49:57.724 [DEBUG] [rnal.protocol.ZWaveTransactionManager] - NODE 25: Commands processed 1.
13:49:57.730 [DEBUG] [rnal.protocol.ZWaveTransactionManager] - NODE 25: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@63c22a.
13:49:57.733 [INFO ] [smarthome.event.ItemStateChangedEvent] - Garderobe_Tastenfeld_Benachrichtigung changed from 255 to 0
But if I press “Home” again followed by entering the correct code, I just get
13:50:27.915 [DEBUG] [nding.zwave.handler.ZWaveThingHandler] - NODE 25: Updating channel state zwave:device:ad9c65cb:node25:notification_access_control to 0 [DecimalType]
and the linked item is not updated.
So my actual question is: Is there a way to define a rule which reacts on this channel update?
Many thanks in advance.
Kind regards,
Christian
