I have two ZMNHAD Flush 1 relay’s. One is an older one with firmware 1.1 and the other one is newer with firmware 6.10. The older one is working as expected, but on the newer one the relay switch is inverted. (ON means OFF and OFF means ON) Both devices have the same configuration (I2 and I3 set to binary switch)
This is the zwave xml file of the newer device:
<node>
<homeId>0xcd9d1ae4</homeId>
<nodeId>89</nodeId>
<version>4</version>
<manufacturer>0x159</manufacturer>
<deviceId>0x52</deviceId>
<deviceType>0x2</deviceType>
<listening>true</listening>
<frequentlyListening>false</frequentlyListening>
<routing>true</routing>
<security>false</security>
<beaming>true</beaming>
<maxBaudRate>40000</maxBaudRate>
<sleepDelay>1000</sleepDelay>
<nodeInformationFrame>
<commandClass>COMMAND_CLASS_ZWAVEPLUS_INFO</commandClass>
<commandClass>COMMAND_CLASS_DEVICE_RESET_LOCALLY</commandClass>
<commandClass>COMMAND_CLASS_POWERLEVEL</commandClass>
<commandClass>COMMAND_CLASS_VERSION</commandClass>
<commandClass>COMMAND_CLASS_MANUFACTURER_SPECIFIC</commandClass>
<commandClass>COMMAND_CLASS_SWITCH_ALL</commandClass>
<commandClass>COMMAND_CLASS_SWITCH_BINARY</commandClass>
<commandClass>COMMAND_CLASS_SENSOR_BINARY</commandClass>
<commandClass>COMMAND_CLASS_METER</commandClass>
<commandClass>COMMAND_CLASS_ALARM</commandClass>
<commandClass>COMMAND_CLASS_MULTI_CHANNEL</commandClass>
<commandClass>COMMAND_CLASS_ASSOCIATION</commandClass>
<commandClass>COMMAND_CLASS_MULTI_CHANNEL_ASSOCIATION</commandClass>
<commandClass>COMMAND_CLASS_ASSOCIATION_GRP_INFO</commandClass>
<commandClass>COMMAND_CLASS_CONFIGURATION</commandClass>
</nodeInformationFrame>
<associationGroups class="concurrent-hash-map">
<entry>
<int>1</int>
<associationGroup>
<index>1</index>
<maxNodes>0</maxNodes>
<associations>
<associationMember>
<node>1</node>
<endpoint>1</endpoint>
</associationMember>
</associations>
</associationGroup>
</entry>
<entry>
<int>2</int>
<associationGroup>
<index>2</index>
<associations>
<associationMember>
<node>1</node>
</associations>
</associationGroup>
</entry>
<entry>
<int>3</int>
<associationGroup>
<index>3</index>
<associations>
<associationMember>
<node>1</node>
</associations>
</associationGroup>
</entry>
<entry>
<int>4</int>
<associationGroup>
<index>4</index>
<associations/>
</associationGroup>
</entry>
<entry>
<int>5</int>
<associationGroup>
<index>5</index>
<associations/>
</associationGroup>
</entry>
<entry>
<int>6</int>
<associationGroup>
<index>6</index>
<associations>
<associationMember>
<node>1</node>
</associations>
</associationGroup>
</entry>
<entry>
<int>7</int>
<associationGroup>
<index>7</index>
<associations/>
</associationGroup>
</entry>
<entry>
<int>8</int>
<associationGroup>
<index>8</index>
<associations/>
</associationGroup>
</entry>
<entry>
<int>9</int>
<associationGroup>
<index>9</index>
<associations/>
</associationGroup>
</entry>
</associationGroups>
<endpoints class="concurrent-hash-map">
<entry>
<int>0</int>
<endPoint>
<deviceClass>
<basicDeviceClass>BASIC_TYPE_ROUTING_SLAVE</basicDeviceClass>
<genericDeviceClass>GENERIC_TYPE_SWITCH_BINARY</genericDeviceClass>
<specificDeviceClass>SPECIFIC_TYPE_POWER_SWITCH_BINARY</specificDeviceClass>
</deviceClass>
<endpointId>0</endpointId>
<secureCommandClasses/>
<supportedCommandClasses class="concurrent-hash-map">
<entry>
<COMMAND__CLASS__ZWAVEPLUS__INFO>
<version>1</version>
<instances>1</instances>
<control>false</control>
<versionSupported>2</versionSupported>
<zwPlusVersion>1</zwPlusVersion>
<zwPlusRole>ROLE_TYPE_SLAVE_ALWAYS_ON</zwPlusRole>
<zwPlusNodeType>NODE_TYPE_ZWAVEPLUS_NODE</zwPlusNodeType>
<isGetSupported>true</isGetSupported>
</COMMAND__CLASS__ZWAVEPLUS__INFO>
</entry>
<entry>
<commandClass>COMMAND_CLASS_BASIC</commandClass>
<COMMAND__CLASS__BASIC>
<versionSupported>1</versionSupported>
</COMMAND__CLASS__BASIC>
</entry>
<entry>
<COMMAND__CLASS__SWITCH__BINARY>
</COMMAND__CLASS__SWITCH__BINARY>
</entry>
<entry>
<COMMAND__CLASS__ALARM>
<version>5</version>
<versionSupported>5</versionSupported>
<alarms>
<entry>
<alarmType>POWER_MANAGEMENT</alarmType>
<alarmState>
<reportedEvents/>
<outer-class reference="../../../.."/>
</alarmState>
</entry>
</alarms>
<v1Supported>true</v1Supported>
</COMMAND__CLASS__ALARM>
</entry>
<entry>
<COMMAND__CLASS__METER>
<version>3</version>
<versionSupported>4</versionSupported>
<meterType>ELECTRIC</meterType>
<meterScales>
<meterScale>E_W</meterScale>
<meterScale>E_KWh</meterScale>
</meterScales>
<canReset>true</canReset>
<isSupportRequestSupported>true</isSupportRequestSupported>
</COMMAND__CLASS__METER>
</entry>
<entry>
<COMMAND__CLASS__MANUFACTURER__SPECIFIC>
<initSerialNumber>false</initSerialNumber>
<deviceManufacturer>345</deviceManufacturer>
<deviceType>2</deviceType>
<deviceId>82</deviceId>
</COMMAND__CLASS__MANUFACTURER__SPECIFIC>
</entry>
<entry>
<COMMAND__CLASS__VERSION>
<version>2</version>
<libraryType>LIB_SLAVE_ENHANCED</libraryType>
<protocolVersion>4.38</protocolVersion>
<applicationVersion>6.10</applicationVersion>
<hardwareVersion>1</hardwareVersion>
</COMMAND__CLASS__VERSION>
</entry>
<entry>
<COMMAND__CLASS__DEVICE__RESET__LOCALLY>
</COMMAND__CLASS__DEVICE__RESET__LOCALLY>
</entry>
<entry>
<COMMAND__CLASS__POWERLEVEL>
<powerLevel>0</powerLevel>
<powerTimeout>0</powerTimeout>
</COMMAND__CLASS__POWERLEVEL>
</entry>
<entry>
<COMMAND__CLASS__CONFIGURATION>
<configParameters>
<entry>
<int>1</int>
<configurationParameter>
<index>1</index>
<size>1</size>
<value>1</value>
<readOnly>false</readOnly>
<writeOnly>false</writeOnly>
</configurationParameter>
</entry>
<entry>
<int>2</int>
<index>2</index>
<size>1</size>
<value>0</value>
</entry>
<entry>
<int>3</int>
<index>3</index>
<size>1</size>
<value>0</value>
</entry>
<entry>
<int>100</int>
<index>100</index>
<size>1</size>
<value>9</value>
</entry>
<entry>
<int>101</int>
<index>101</index>
<size>1</size>
<value>9</value>
</entry>
<entry>
<int>40</int>
<index>40</index>
<size>1</size>
<value>10</value>
</entry>
<entry>
<int>10</int>
<index>10</index>
<size>2</size>
<value>255</value>
</entry>
<entry>
<int>42</int>
<index>42</index>
<size>2</size>
<value>300</value>
</entry>
<entry>
<int>11</int>
<index>11</index>
<size>2</size>
<value>0</value>
</entry>
<entry>
<int>12</int>
<index>12</index>
<size>2</size>
<value>0</value>
</entry>
<entry>
<int>110</int>
<index>110</index>
<size>2</size>
<value>32536</value>
</entry>
<entry>
<int>15</int>
<index>15</index>
<size>1</size>
<value>0</value>
</entry>
<entry>
<int>120</int>
<index>120</index>
<size>1</size>
<value>5</value>
</entry>
<entry>
<int>30</int>
<index>30</index>
<size>1</size>
<value>0</value>
</entry>
<entry>
<int>63</int>
<index>63</index>
<size>1</size>
<value>1</value>
</entry>
</configParameters>
</COMMAND__CLASS__CONFIGURATION>
</entry>
<entry>
<commandClass>COMMAND_CLASS_SECURITY</commandClass>
<COMMAND__CLASS__SECURITY>
</COMMAND__CLASS__SECURITY>
</entry>
<entry>
<COMMAND__CLASS__SWITCH__ALL>
<mode>SWITCH_ALL_INCLUDE_ON_OFF</mode>
</COMMAND__CLASS__SWITCH__ALL>
</entry>
<entry>
<COMMAND__CLASS__MULTI__CHANNEL>
<useDestEndpointAsSource>false</useDestEndpointAsSource>
<endpointsAreTheSameDeviceClass>false</endpointsAreTheSameDeviceClass>
</COMMAND__CLASS__MULTI__CHANNEL>
</entry>
<entry>
<COMMAND__CLASS__SENSOR__BINARY>
<types/>
</COMMAND__CLASS__SENSOR__BINARY>
</entry>
<entry>
<COMMAND__CLASS__ASSOCIATION>
<maxGroups>9</maxGroups>
</COMMAND__CLASS__ASSOCIATION>
</entry>
<entry>
<commandClass>COMMAND_CLASS_NO_OPERATION</commandClass>
<COMMAND__CLASS__NO__OPERATION>
</COMMAND__CLASS__NO__OPERATION>
</entry>
<entry>
<COMMAND__CLASS__MULTI__CHANNEL__ASSOCIATION>
<versionSupported>3</versionSupported>
</COMMAND__CLASS__MULTI__CHANNEL__ASSOCIATION>
</entry>
<entry>
<COMMAND__CLASS__ASSOCIATION__GRP__INFO>
<autoSubscribeGroups/>
</COMMAND__CLASS__ASSOCIATION__GRP__INFO>
</entry>
</supportedCommandClasses>
</endPoint>
</entry>
<entry>
<int>1</int>
<endPoint>
<deviceClass>
</deviceClass>
<endpointId>1</endpointId>
<entry>
<endpoint reference="../../../.."/>
</entry>
<entry>
<version>0</version>
<instances>0</instances>
<versionSupported>0</versionSupported>
</entry>
<entry>
</entry>
<entry>
</entry>
<entry>
<alarms>
<entry>
<alarmState>
<reportedEvents/>
</alarmState>
</entry>
</alarms>
</entry>
<entry>
<maxGroups>2</maxGroups>
</entry>
<entry>
<meterScales>
</meterScales>
</entry>
<entry>
</entry>
<entry>
</entry>
</endPoint>
</entry>
<entry>
<int>2</int>
<endPoint>
<deviceClass>
<genericDeviceClass>GENERIC_TYPE_SENSOR_NOTIFICATION</genericDeviceClass>
<specificDeviceClass>SPECIFIC_TYPE_NOTIFICATION_SENSOR</specificDeviceClass>
</deviceClass>
<endpointId>2</endpointId>
<entry>
</entry>
<entry>
</entry>
<entry>
<alarms>
<entry>
<alarmType>SMOKE</alarmType>
<alarmState>
<reportedEvents/>
</alarmState>
</entry>
<entry>
<alarmType>BURGLAR</alarmType>
<alarmState>
<reportedEvents/>
</alarmState>
</entry>
</alarms>
</entry>
<entry>
<types/>
</entry>
<entry>
<maxGroups>4</maxGroups>
</entry>
<entry>
</entry>
<entry>
</entry>
</endPoint>
</entry>
<entry>
<int>3</int>
<endPoint>
<deviceClass>
<genericDeviceClass>GENERIC_TYPE_SENSOR_BINARY</genericDeviceClass>
<specificDeviceClass>SPECIFIC_TYPE_NOT_USED</specificDeviceClass>
</deviceClass>
<endpointId>3</endpointId>
<entry>
</entry>
<entry>
</entry>
<entry>
<alarms>
<entry>
<alarmType>SYSTEM</alarmType>
<alarmState>
<reportedEvents/>
</alarmState>
</entry>
<entry>
<alarmState>
<reportedEvents/>
</alarmState>
</entry>
</alarms>
</entry>
<entry>
<types/>
</entry>
<entry>
</entry>
<entry>
</entry>
<entry>
</entry>
</endPoint>
</entry>
</endpoints>
<nodeNeighbors/>
<lastReceived>2020-03-10 23:35:57.255 UTC</lastReceived>
</node>
Any ideas why the switch is inverted on the newer device?
