ZMNHHD Mini Dimmer Node is not communicating with controller
I added a ZMNHHD Mini Dimmer to my z-wave Stick.
All other zwave devices in the network are working without a problem.
I switched from FHEM to OpenHAB.
The dimmer is working in FHEM.
I´m able to switch the light on and off from FHEM
But if I connect the stick (aeontec 5Gen+) to OpenHAB the dimmer is found in the inbox.
But if I add it to my Things the following message is displayed:
How could I find and fix the problem?
From the description you added the mini-dimmer to the Aeotec using something other than OH? Sometimes that can cause issues. One thing to try is after adding the node (and getting the message), restart either OH or just the ZW binding with the stick plugged in. If just restarting the binding, put ZW into debug mode on the UI settings page. Either post the log or use the Zwave debug log viewer to analyze. Another thing to try with Debug is to activate the device manually from the switch.
I have tried my old installation of FHEM with the same stick like on OH.
On FHEM the dimmer ist working.
14:06:50.817	32
CONFIGURATION UPDATE config_30_1 0 (BigDecimal)
14:06:50.822	32
CONFIGURATION UPDATE config_65_1 1 (BigDecimal)
14:06:50.826	32
CONFIGURATION UPDATE config_21_1 0 (BigDecimal)
14:06:50.830	32
CONFIGURATION UPDATE config_74_1 10 (BigDecimal)
14:06:50.834	32
CONFIGURATION UPDATE config_42_2 0 (BigDecimal)
14:06:50.838	32
CONFIGURATION UPDATE config_61_1 1 (BigDecimal)
14:06:50.842	32
CONFIGURATION UPDATE config_72_1 2 (BigDecimal)
14:06:50.845	32
CONFIGURATION UPDATE config_73_1 0 (BigDecimal)
14:06:50.849	32
CONFIGURATION UPDATE config_40_1 10 (BigDecimal)
14:06:50.854	32
CONFIGURATION UPDATE config_60_1 0 (BigDecimal)
14:06:50.857	32
CONFIGURATION UPDATE config_70_2 200 (BigDecimal)
14:06:50.861	32
CONFIGURATION UPDATE config_71_1 1 (BigDecimal)
14:06:50.865	32
CONFIGURATION UPDATE action_heal false (Boolean)
14:06:50.869	32
CONFIGURATION UPDATE config_1_1 0 (BigDecimal)
14:06:50.901	32
TX REQ SendData 114 CONFIGURATION_SET PARAM_1  ACK AUTO_ROUTE EXPLORE
14:06:50.916	32
RX RES SendData 114 ACCEPTED BY CONTROLLER 0 /128
14:06:50.928	32
CONFIGURATION UPDATE config_12_2 0 (BigDecimal)
14:06:50.932	32
CONFIGURATION UPDATE config_11_2 0 (BigDecimal)
14:06:50.935	32
CONFIGURATION UPDATE config_5_1 0 (BigDecimal)
14:06:50.939	32
CONFIGURATION UPDATE config_66_2 3 (BigDecimal)
14:06:50.942	32
CONFIGURATION UPDATE config_67_1 0 (BigDecimal)
14:06:50.946	32
CONFIGURATION UPDATE node_id 32 (BigDecimal)
14:06:50.949	32
CONFIGURATION UPDATE config_68_1 0 (BigDecimal)
14:06:55.049	32
RX REQ SendData 114 NO ACK after 4148ms 0 /128
14:06:55.083	32
TX REQ SendData 115 CONFIGURATION_SET PARAM_1  ACK AUTO_ROUTE EXPLORE
14:06:55.098	32
RX RES SendData 115 ACCEPTED BY CONTROLLER 0 /128
14:06:59.263	32
RX REQ SendData 115 NO ACK after 4180ms 0 /128
14:06:59.335	32
TX REQ SendData 116 CONFIGURATION_SET PARAM_1  ACK AUTO_ROUTE EXPLORE
14:06:59.350	32
RX RES SendData 116 ACCEPTED BY CONTROLLER 0 /128
14:07:03.439	32
RX REQ SendData 116 NO ACK after 4104ms 0 /128
14:07:03.459	32
Message timeout!
14:07:03.468	32
TX REQ SendData 117 CONFIGURATION_GET PARAM_1  ACK AUTO_ROUTE EXPLORE
14:07:03.482	32
RX RES SendData 117 ACCEPTED BY CONTROLLER 0 /128
14:07:07.602	32
RX REQ SendData 117 NO ACK after 4134ms 0 /128
14:07:07.660	32
TX REQ SendData 118 CONFIGURATION_GET PARAM_1  ACK AUTO_ROUTE EXPLORE
14:07:07.675	32
RX RES SendData 118 ACCEPTED BY CONTROLLER 0 /128
14:07:11.809	32
RX REQ SendData 118 NO ACK after 4149ms 0 /128
14:07:11.841	32
TX REQ SendData 119 CONFIGURATION_GET PARAM_1  ACK AUTO_ROUTE EXPLORE
14:07:11.855	32
RX RES SendData 119 ACCEPTED BY CONTROLLER 0 /128
14:07:15.974	32
RX REQ SendData 119 NO ACK after 4133ms 0 /128
14:07:16.014	32
Message timeout!
14:16:09.703	32
14:16:09.704	32
14:16:09.705	32
14:16:09.705	32
14:16:09.706	32
14:16:09.707	32
14:16:09.708	32
14:16:09.709	32
14:16:09.710	32
14:16:09.710	32
14:16:09.711	32
14:16:09.712	32
14:16:09.713	32
14:16:09.713	32
CONFIGURATION UPDATE config_1_1 1 (BigDecimal)
14:16:09.721	32
TX REQ SendData 120 CONFIGURATION_SET PARAM_1  ACK AUTO_ROUTE EXPLORE
14:16:09.730	32
14:16:09.731	32
14:16:09.732	32
14:16:09.732	32
14:16:09.733	32
14:16:09.734	32
14:16:09.735	32
14:16:09.735	32
RX RES SendData 120 ACCEPTED BY CONTROLLER 0 /128
14:16:13.822	32
RX REQ SendData 120 NO ACK after 4101ms 0 /128
14:16:13.826	32
TX REQ SendData 121 CONFIGURATION_SET PARAM_1  ACK AUTO_ROUTE EXPLORE
14:16:13.839	32
RX RES SendData 121 ACCEPTED BY CONTROLLER 0 /128
14:16:17.959	32
RX REQ SendData 121 NO ACK after 4133ms 0 /128
14:16:17.969	32
TX REQ SendData 122 CONFIGURATION_SET PARAM_1  ACK AUTO_ROUTE EXPLORE
14:16:17.982	32
RX RES SendData 122 ACCEPTED BY CONTROLLER 0 /128
14:16:22.147	32
RX REQ SendData 122 NO ACK after 4178ms 0 /128
14:16:22.156	32
Message timeout!
14:16:22.160	32
TX REQ SendData 123 CONFIGURATION_GET PARAM_1  ACK AUTO_ROUTE EXPLORE
14:16:22.173	32
RX RES SendData 123 ACCEPTED BY CONTROLLER 0 /128
14:16:22.361	32
14:16:22.362	32
14:16:22.363	32
14:16:22.364	32
14:16:22.364	32
14:16:22.365	32
14:16:22.365	32
14:16:22.366	32
14:16:22.366	32
14:16:22.367	32
14:16:22.367	32
14:16:22.368	32
14:16:22.368	32
14:16:22.369	32
14:16:22.369	32
14:16:22.370	32
14:16:22.370	32
14:16:22.371	32
14:16:22.371	32
14:16:22.372	32
14:16:22.372	32
14:16:26.290	32
RX REQ SendData 123 NO ACK after 4130ms 0 /128
14:16:26.294	32
TX REQ SendData 124 CONFIGURATION_GET PARAM_1  ACK AUTO_ROUTE EXPLORE
14:16:26.306	32
RX RES SendData 124 ACCEPTED BY CONTROLLER 0 /128
14:16:30.441	32
RX REQ SendData 124 NO ACK after 4147ms 0 /128
14:16:30.452	32
TX REQ SendData 125 CONFIGURATION_GET PARAM_1  ACK AUTO_ROUTE EXPLORE
14:16:30.465	32
RX RES SendData 125 ACCEPTED BY CONTROLLER 0 /128
14:16:34.568	32
RX REQ SendData 125 NO ACK after 4116ms 0 /128
14:16:34.571	32
Message timeout!
14:16:45.813	32
14:16:45.815	32
14:16:45.816	32
14:16:45.820	32
14:16:45.821	32
14:16:45.822	32
14:16:45.823	32
14:16:45.824	32
14:16:45.825	32
14:16:45.826	32
14:16:45.826	32
14:16:45.827	32
14:16:45.828	32
CONFIGURATION UPDATE action_heal true (Boolean)
14:16:45.830	32
14:16:45.831	32
14:16:45.832	32
14:16:45.833	32
14:16:45.834	32
14:16:45.834	32
14:16:45.835	32
14:16:45.836	32
14:17:51.292	32
14:17:51.293	32
14:17:51.294	32
14:17:51.294	32
14:17:51.295	32
14:17:51.296	32
14:17:51.297	32
14:17:51.297	32
14:17:51.298	32
14:17:51.298	32
14:17:51.299	32
14:17:51.300	32
14:17:51.301	32
14:17:51.303	32
14:17:51.303	32
14:17:51.304	32
14:17:51.305	32
14:17:51.305	32
14:17:51.306	32
14:17:51.307	32
14:17:51.307	32
14:23:19.815	32
TX REQ SendData 126 VERSION_COMMAND_CLASS_GET DEVICE_RESET_LOCALLY  ACK AUTO_ROUTE EXPLORE
14:23:19.828	32
RX RES SendData 126 ACCEPTED BY CONTROLLER 0 /128
14:23:23.903	32
RX REQ SendData 126 NO ACK after 4088ms 0 /128
14:23:23.913	32
TX REQ SendData 127 VERSION_COMMAND_CLASS_GET DEVICE_RESET_LOCALLY  ACK AUTO_ROUTE EXPLORE
14:23:23.926	32
RX RES SendData 127 ACCEPTED BY CONTROLLER 0 /128
14:23:28.061	32
RX REQ SendData 127 NO ACK after 4148ms 0 /128
14:23:28.072	32
TX REQ SendData 128 VERSION_COMMAND_CLASS_GET DEVICE_RESET_LOCALLY  ACK AUTO_ROUTE EXPLORE
14:23:28.085	32
RX RES SendData 128 ACCEPTED BY CONTROLLER 0 /128
14:23:32.249	32
RX REQ SendData 128 NO ACK after 4177ms 0 /128
14:23:32.256	32
Message timeout!
15:18:07.793	32
TX REQ SendData 145 VERSION_COMMAND_CLASS_GET ALARM  ACK AUTO_ROUTE EXPLORE
15:18:07.807	32
RX RES SendData 145 ACCEPTED BY CONTROLLER 0 /128
15:18:11.968	32
RX REQ SendData 145 NO ACK after 4175ms 0 /128
15:18:11.973	32
TX REQ SendData 146 VERSION_COMMAND_CLASS_GET ALARM  ACK AUTO_ROUTE EXPLORE
15:18:11.985	32
RX RES SendData 146 ACCEPTED BY CONTROLLER 0 /128
15:18:16.089	32
RX REQ SendData 146 NO ACK after 4116ms 0 /128
15:18:16.099	32
TX REQ SendData 147 VERSION_COMMAND_CLASS_GET ALARM  ACK AUTO_ROUTE EXPLORE
15:18:16.112	32
RX RES SendData 147 ACCEPTED BY CONTROLLER 0 /128
15:18:20.184	32
RX REQ SendData 147 NO ACK after 4085ms 0 /128
15:18:20.207	32
Message timeout!
15:33:39.375	32
TX REQ SendData 148 VERSION_COMMAND_CLASS_GET ALARM  ACK AUTO_ROUTE EXPLORE
15:33:39.391	32
RX RES SendData 148 ACCEPTED BY CONTROLLER 0 /128
15:33:43.480	32
RX REQ SendData 148 NO ACK after 4105ms 0 /128
15:33:43.513	32
TX REQ SendData 149 VERSION_COMMAND_CLASS_GET ALARM  ACK AUTO_ROUTE EXPLORE
15:33:43.527	32
RX RES SendData 149 ACCEPTED BY CONTROLLER 0 /128
15:33:47.646	32
RX REQ SendData 149 NO ACK after 4133ms 0 /128
15:33:47.689	32
TX REQ SendData 150 VERSION_COMMAND_CLASS_GET ALARM  ACK AUTO_ROUTE EXPLORE
15:33:47.703	32
RX RES SendData 150 ACCEPTED BY CONTROLLER 0 /128
15:33:51.776	32
RX REQ SendData 150 NO ACK after 4087ms 0 /128
15:33:51.803	32
Message timeout!
That’s what I get from the Zwave Debug viewer.
I don´t know what I have done.
After restarting the OpenHAB server the dimmer works.
I have done it serveral times bevor.
