hello people
I have tried to make this qubino termostat working with no luck yet… i think i manage to do something correct, but its not working so obvius i to something wrong…
item file:
Number Meter_FF_GulvYtre "Meter gulv ytre [%s]" (Temperature,GF_Ytregang) { zwave="6:command=METER" } Number Meter_FF_Power "Effekt Gulvvarme [%s W]" (Temperature,GF_Ytregang,Lights) { zwave="6:command=meter,meter_scale=E_W,refresh_interval=60" } Number Meter_FF_PowerT "Total energy ytre [%.2f KWh]" (Temperature,GF_Ytregang,Lights){ zwave="6:command=meter,meter_scale=E_KWh,refresh_interval=60" } Number Temperature_GF_GangYtre "Temperatur [%.1f °C]" (Temperature,GF_Ytregang) { zwave="6:command=sensor_multilevel,sensor_ype=1" } Number Status_GF_GangYtre "status GangYtre [%s]" (Temperature,GF_Ytregang) { zwave="6:command=THERMOSTAT_MODE" } Number Setpoint_GangYtre "Setpoint GangYtre [%s]" (Temperature,GF_Ytregang) { zwave="6:command=THERMOSTAT_SETPOINT" }
sitemap:
Selection item=Status_GF_GangYtre mappings=[0="OFF",11="Normal",2="blue",3="Auto"] Setpoint item=Setpoint_GangYtre icon="heating" minValue=0 maxValue=25 step=0.5
in the openhab.log i get no error message when changing between off and auto… if i try “blue” it get an error message but thats correct becuse module not support the value 2
I do not manage to change setpoint it just returns to 0 for some reason…
The temprature readling is working… 11.8 C in the floor now…
The mode looks like working… hard to test when setpoint is 0…
But setpoint is 0 and stays 0
Her is the events.log output:
2015-10-20 19:33:25 - Setpoint_GangYtre received command 0.5 2015-10-20 19:33:25 - Setpoint_GangYtre state updated to 0.5 2015-10-20 19:33:25 - Setpoint_GangYtre state updated to 0
I have a heatit termostat to, and that work perfect with the same commands.
What can i try to make a progress with this?
Regards
Christian
