Zodiac
Since using OH3 the Astro Binding, gives a Wrong zodiac.
Welcome @Tonysweb
it would be helpfull if you would give some more context to your question.
  • How your thing- / item-configuration looks like?
  • What is the expected and what is the current output of the astro zodiac channel?
  • Did you set-up your geo-location?
It works fine here.
Dear,
I see ā€œPiscesā€ and it should be ā€œCapricornā€
The geo-location is set see pictures:
Best regards,
Tony
Ok, I see - you can fix this by using the Astro Sun Data Thing Type instead of Astro Moon Data.
Even after reading a bit about the differences between the sun- and moon-sign, I don’t get it. But I don’t want to, to be honest. :smiley:
If you’re interested in this, you can find a calculator for your moon-sign here
Dear,
When I reassign the item to the zodiac thing (12:55:59) I get de correct zodiac, but only for 5 minutes until 13:00:30 then it goes back to the wrong zodiac and stay there.
Groetjes.
Tony
Dear,
I changed it several times between sun and moon, but the same result on both.
Groetjes.
Tony
Dear,
Same problem with the Moon_Age it switches every 5 minutes automatically.
2021-01-17 13:05:30.628 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item ā€˜Moon_Age’ changed from 52.21384382481341 to 4
2021-01-17 13:05:30.633 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item ā€˜Moon_Age’ changed from 4 to 52.25609238135474
2021-01-17 13:05:30.637 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item ā€˜Moon_Illum’ changed from 19.659581797286872 to 19.687262616851285
2021-01-17 13:05:58.341 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item ā€˜NTPServer_Date’ changed from 2021-01-17T13:04:58.324+0100 to 2021-01-17T13:05:58.327+0100
2021-01-17 13:06:58.343 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item ā€˜NTPServer_Date’ changed from 2021-01-17T13:05:58.327+0100 to 2021-01-17T13:06:58.330+0100
2021-01-17 13:07:58.347 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item ā€˜NTPServer_Date’ changed from 2021-01-17T13:06:58.330+0100 to 2021-01-17T13:07:58.333+0100
2021-01-17 13:08:58.350 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item ā€˜NTPServer_Date’ changed from 2021-01-17T13:07:58.333+0100 to 2021-01-17T13:08:58.336+0100
2021-01-17 13:09:58.352 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item ā€˜NTPServer_Date’ changed from 2021-01-17T13:08:58.336+0100 to 2021-01-17T13:09:58.339+0100
2021-01-17 13:10:30.594 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item ā€˜Moon_Age’ changed from 52.25609238135474 to 4
2021-01-17 13:10:30.599 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item ā€˜Moon_Age’ changed from 4 to 52.29833896634277
Groetjes.
Tony
It seems, you’ve used the UI to install and set-up the astro binding, right?
So you have 2 things in your Things overview, like this - one for the moon, and one for the sun-data?
Click on the Thing for the sun-data and switch to the Channels tab → scroll down to the zodiac group and open the channel zodiac#sign
Is your item linked there?
right I’ve used the UI to install and set-up the astro binding
the moon, and the sun-data are online like your picture
and my item is linked to the zodiac_sun
it stay’s right for 5 minutes and then it switches to pisces
2021-01-17 15:26:31.333 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item ā€˜Zodiac_Sign’ changed from PISCES to CAPRICORN
2021-01-17 15:26:58.968 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item ā€˜NTPServer_Date’ changed from 2021-01-17T15:25:58.946+0100 to 2021-01-17T15:26:58.949+0100
2021-01-17 15:27:58.971 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item ā€˜NTPServer_Date’ changed from 2021-01-17T15:26:58.949+0100 to 2021-01-17T15:27:58.952+0100
2021-01-17 15:28:58.974 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item ā€˜NTPServer_Date’ changed from 2021-01-17T15:27:58.952+0100 to 2021-01-17T15:28:58.955+0100
2021-01-17 15:29:58.977 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item ā€˜NTPServer_Date’ changed from 2021-01-17T15:28:58.955+0100 to 2021-01-17T15:29:58.958+0100
2021-01-17 15:30:58.979 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item ā€˜NTPServer_Date’ changed from 2021-01-17T15:29:58.958+0100 to 2021-01-17T15:30:58.960+0100
2021-01-17 15:31:13.570 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item ā€˜Moon_Age’ changed from 53.445080411209695 to 4
2021-01-17 15:31:13.575 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item ā€˜Moon_Age’ changed from 4 to 53.48732615124631
2021-01-17 15:31:13.579 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item ā€˜Moon_Illum’ changed from 20.471157167465925 to 20.49918058729942
2021-01-17 15:31:13.583 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item ā€˜Zodiac_Sign’ changed from CAPRICORN to PISCES
Best regards
Tony
Hmm, maybe this is some caching issue - maybe try to restart openhab and clear your browser cache.
Directly on startup it changes to the wrong zodiac after startup and clear cache from my browser.
2021-01-17 16:02:08.110 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing ā€˜darksky:weather-and-forecast:83eebd1078:09427cb8d1’ changed from UNINITIALIZED to UNINITIALIZED (BRIDGE_UNINITIALIZED)
2021-01-17 16:02:08.273 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing ā€˜darksky:weather-api:83eebd1078’ changed from UNINITIALIZED to INITIALIZING
2021-01-17 16:02:08.291 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item ā€˜Zodiac_Sign’ changed from NULL to CAPRICORN
2021-01-17 16:02:08.311 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item ā€˜Season_Name’ changed from NULL to WINTER
2021-01-17 16:02:08.396 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing ā€˜darksky:weather-api:83eebd1078’ changed from INITIALIZING to UNKNOWN
2021-01-17 16:02:08.814 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing ā€˜astro:moon:local’ changed from UNINITIALIZED to INITIALIZING
2021-01-17 16:02:08.823 [INFO ] [openhab.event.InboxAddedEvent ] - Discovery Result with UID ā€˜darksky:weather-and-forecast:83eebd1078:local’ has been added.
2021-01-17 16:02:08.878 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing ā€˜astro:moon:local’ changed from INITIALIZING to ONLINE
2021-01-17 16:02:09.274 [INFO ] [o.internal.handler.AstroThingHandler] - Scheduled Positional job astro:moon:local every 300 seconds
2021-01-17 16:02:09.091 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item ā€˜Moonrise_Time’ changed from NULL to 2021-01-17T11:04:00.000+0100
2021-01-17 16:02:09.108 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item ā€˜Moonset_Time’ changed from NULL to 2021-01-17T22:03:00.000+0100
2021-01-17 16:02:09.320 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item ā€˜Moon_Age’ changed from 53.69856400506971 to 4
2021-01-17 16:02:09.325 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item ā€˜Moon_Age’ changed from 4 to 53.74862864385298
2021-01-17 16:02:09.330 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item ā€˜Moon_Illum’ changed from 20.639477607107885 to 20.672771057607097
2021-01-17 16:02:09.335 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item ā€˜Moon_Phase_Name’ changed from NULL to WAXING_CRESCENT
2021-01-17 16:02:09.340 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item ā€˜Zodiac_Sign’ changed from CAPRICORN to PISCES
2021-01-17 16:02:09.485 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item ā€˜Moon_Age’ changed from 53.74862864385298 to 4
2021-01-17 16:02:09.556 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item ā€˜Moon_Age’ changed from 4 to 53.74867075059851
2021-01-17 16:02:09.571 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing ā€˜darksky:weather-and-forecast:83eebd1078:09427cb8d1’ changed from UNINITIALIZED (BRIDGE_UNINITIALIZED) to INITIALIZING
2021-01-17 16:02:09.576 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item ā€˜Moon_Illum’ changed from 20.672771057607097 to 20.672799063216445
2021-01-17 16:02:11.615 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing ā€˜darksky:weather-and-forecast:83eebd1078:09427cb8d1’ changed from INITIALIZING to UNKNOWN
Groetjes.
Tony
I changed the zodiac item to text in the etc/openHAB/items/default.items file with the following parameters:
String Zodiac_Sign ā€œSterrenbeeld [MAP(zodiac.map):%s]ā€ { channel=ā€œastro:sun:local:zodiac#signā€ }
The result is the same:
2021-01-17 16:39:55.998 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item ā€˜Zodiac_Sign’ changed from NULL to CAPRICORN
2021-01-17 16:40:06.674 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item ā€˜NTPServer_Date’ changed from 2021-01-17T16:39:06.646+0100 to 2021-01-17T16:40:06.650+0100
2021-01-17 16:41:06.676 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item ā€˜NTPServer_Date’ changed from 2021-01-17T16:40:06.650+0100 to 2021-01-17T16:41:06.654+0100
2021-01-17 16:42:06.678 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item ā€˜NTPServer_Date’ changed from 2021-01-17T16:41:06.654+0100 to 2021-01-17T16:42:06.658+0100
2021-01-17 16:42:09.414 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item ā€˜Moon_Age’ changed from 54.04440233769891 to 4
2021-01-17 16:42:09.447 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item ā€˜Moon_Age’ changed from 4 to 54.08664976763836
2021-01-17 16:42:09.452 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item ā€˜Moon_Illum’ changed from 20.869791391431153 to 20.897978794203105
2021-01-17 16:42:09.457 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item ā€˜Zodiac_Sign’ changed from CAPRICORN to PISCES
2021-01-17 16:43:06.684 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item ā€˜NTPServer_Date’ changed from 2021-01-17T16:42:06.658+0100 to 2021-01-17T16:43:06.665+0100
The only deference I can see with your parameters is:
My things are ā€œastro:sun:localā€ yours are ā€œastro:sun:lhomeā€
Groetjes.
Tony
This sounds contradictory to me - did you used the UI AND the textual definition to set up your files? This shouldn’t be done, at least not for the same binding, as it could confuse the system and might produce doubled values which could lead to the behaviour you describe.
Maybe it would be a good idea to wipe the current configuration and start from scratch with this binding with only one approch - either the user-interface OR textual-definitions.
After that, I’m out of ideas, what could be wrong in your setup.
No I just made 1 item in the items file for testing, before everything was configured in the UI.
Thanks for your time, I will try to find out what’s wrong.
Groetjes.
Tony
Dear,
Complete new installation of openhabian 3, problem solved.
So we will never find a reason.
Best Regards
Tony
Hello, I habe the same Problem. Since using OH3 the Astro Binding, gives a Wrong zodiac. I can not solve the Problem .
I solved the problem with a complete new installation of openhabian.
