Has anyone managed to successfully connect to version 1.32.3 of ZoneMinder using the binding shipped out with version 2.5 of OH?
The included binding will not work with 1.32. You will need to downgrade to 1.29 and use the included binding or upgrade to 1.34 and use this binding:
I will assume you are running Zoneminder on a raspberry pi. You can upgrade to 1.34 with these steps:
Add the repo
sudo nano /etc/apt/sources.list
Add the following line to the end of the file
deb https://zmrepo.zoneminder.com/debian/release-1.34/buster/
CTRL+o then [Enter] to save
CTRL+x to exit
sudo apt update
Update the database with
sudo zmupdate.pl
Restart the Zoneminder box and youāre there. You will then need to remove your existing Zoneminder binding and add the new one manually.
Tried to follow your steps to upgrade but ended up with this error message:
pi@zoneminder:~ $ sudo apt update
Hit:1 http://archive.raspberrypi.org/debian buster InRelease
Ign:2 https://zmrepo.zoneminder.com/debian/release-1.34 buster/ InRelease
Get:3 https://zmrepo.zoneminder.com/debian/release-1.34 buster/ Release [1,184 B]
Get:4 https://zmrepo.zoneminder.com/debian/release-1.34 buster/ Release.gpg [516 B]
Ign:4 https://zmrepo.zoneminder.com/debian/release-1.34 buster/ Release.gpg
Reading package lists⦠Done
W: GPG error: https://zmrepo.zoneminder.com/debian/release-1.34 buster/ Release: The following signatures couldnāt be verified because the public key is not available: NO_PUBKEY E79BFCE5B2268263
E: The repository āhttps://zmrepo.zoneminder.com/debian/release-1.34 buster/ Releaseā is not signed.
N: Updating from such a repository canāt be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
pi@zoneminder:~ $
I also tried
sudo apt-get update --allow-unauthenticated
but without success. Any idea how I can fix this error?
Try this:
Install the following and retrieve the key from the repro
sudo apt install apt-transport-https gnupg
wget -O - https://zmrepo.zoneminder.com/debian/archive-keyring.gpg | sudo apt-key add -
Important - Make sure the above āwgetā process completes without error! If it does not complete you will not get the most recent Zoneminder version this procedure is written for.
I tried and retrieved the key from the repro but ended up with following result:
Hit:3 https://zmrepo.zoneminder.com/debian/release-1.34 buster/ Release
Building dependency tree
Reading state information⦠Done
2 packages can be upgraded. Run āapt list --upgradableā to see them.
pi@zoneminder:~ $ sudo apt upgrade
Calculating upgrade⦠Done
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
So, no error but no upgrade either.
I got the instructions from:
https://wiki.zoneminder.com/Debian_10_Buster_with_Zoneminder_1.34.x_from_ZM_Repo
I think the next step would be to go to the
Install Zoneminder
line and follow from there.
