Hi!
I have a problem with my Zoneminder Server binding.
I have tested it on a Virtual box (ubuntu server), and there is all OK,
but on my “Real” ubuntu-server there is a error:
**CONFIGURATION_ERROR**
Can't get version information
The complete setup was the same as in the Virtual box.
The first thing the binding does is call the ZoneMinder API to get the ZoneMinder version. If this fails, then that suggests there’s some connectivity issue between OH and ZM.
Yes thats clear, but where is the problem.
From the outside = Virtualbox i can connect.
Maybe the problem is that my Openhab and Zoneminder server are the same PC…
Is this a “nat” problem??
Is there a possibility to check this in terminal?
I am experiencing the same issue, but my browser returns what it is supposed to…
version "1.32.3"
apiversion "1.0"
All the other parameters that I enter are : ip address (leave the port blank as it is default) and and authentication username and password (the default ones). So where can I find the connectivity issue?
According to the binding documentation here, you need to be running Zoneminder 1.34.0 and API version 2.0.
Installation
The binding requires ZoneMinder version 1.34.0 or greater and API version 2.0 or greater. It also requires
that you enable the OPT_USE_API parameter in the ZoneMinder configuration.
