Hi all,
So I am extremely new to openHAB, but I just got a few things hooked up and running. I’m using the HUSBZB-1 stick, and have Z-Wave bindings working (still fiddling with Zigbee on the USB stick). It’s running on a Raspberry Pi 3 on OpenHabian, with OpenHAB 2.1.
I’m having some trouble with a Zooz ZEN06 Plus Plug, which has energy monitoring. It seems to report properly, but only when something triggers a manual refresh, and not automatically on the timing cycle (30 sec for Watts, 300 sec for KWh). I can switch power on/off on the device, and everything appears to operate correctly aside from the auto-update of the energy usage.
If I use HABmin, in the device description I can manually refresh and it updates to the UI (and propagates to the phone openhab app), but until then it will not. Is there a simple step I’m missing? Any suggestions would be much appreciated.
