Hi there,
I bought recently Zooz ZSE09 Motion and Luminance mini Sensor. I was able to connect it to OpenHab2.3-SNAPSHOT. Motion alarm works fine as well as battery report but luminance item always equal to NULL.
in the log I see
2018-01-28 18:31:27.660 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 3: Incoming command class SENSOR_MULTILEVEL 2018-01-28 18:31:27.673 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 3: Received COMMAND_CLASS_SENSOR_MULTILEVEL command V7 2018-01-28 18:31:27.687 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 3: Sensor Multi Level REPORT received 2018-01-28 18:31:27.699 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 3: Sensor Type = Luminance(3), Scale = 1 2018-01-28 18:31:27.713 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 3: Sensor Value = 64 2018-01-28 18:31:27.723 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveMultiLevelSensorValueEvent 2018-01-28 18:31:27.738 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 3: Got an event from Z-Wave network: ZWaveMultiLevelSensorValueEvent 2018-01-28 18:31:27.754 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 3: Got a value event from Z-Wave network, endpoint = 0, command class = SENSOR_MULTILEVEL, value = 64 2018-01-28 18:31:27.781 [DEBUG] [erter.ZWaveMultiLevelSensorConverter] - NODE 3:
No sensorType set for channel zwave:device:c49fa6aa:node3:sensor_luminance
All items were added from Paper UI. Does anyone has luminance sensor working in OH?
Thanks,
Roman
