Aren’t door sensors normally contacts?
I’ve been updating my old CR123 powered door sensors with new 700 series CR2032 powered sensors from Zooz. These new sensors are much smaller and much nicer looking. The ZSE43 tilt sensors work well and they have a contact channel as one would expect for a door sensor. These ZSE41s paired nicely but the door sensor is a switch. Shouldn’t it be a contact?
Here are my logs
21:44:22.632 84
RX REQ ApplicationCommandHandler BASIC_SET 0 /128
21:44:22.802 84
RX REQ ApplicationCommandHandler ALARM_REPORT V1 UNKNOWN[00] V1LEVEL=0 ACCESS_CONTROL EVENT=22 0 /128
21:44:22.964 84
RX REQ ApplicationCommandHandler SENSOR_BINARY_REPORT::255(10) = 202 0 /128
21:44:22.971 84
STATE UPDATE zwave:device:ZWave:node84:sensor_binary ON [OnOffType]
21:44:24.159 84
21:44:24.330 84
RX REQ ApplicationCommandHandler ALARM_REPORT V1 UNKNOWN[00] V1LEVEL=0 ACCESS_CONTROL EVENT=23 0 /128
21:44:24.491 84
RX REQ ApplicationCommandHandler SENSOR_BINARY_REPORT::UNKNOWN(10) = 202 0 /128
21:44:24.498 84
STATE UPDATE zwave:device:ZWave:node84:sensor_binary OFF [OnOffType]
Here is the XML file
<node>
<homeId>0xf67d3453</homeId>
<nodeId>84</nodeId>
<version>4</version>
<manufacturer>0x27a</manufacturer>
<deviceId>0xe001</deviceId>
<deviceType>0x7000</deviceType>
<listening>false</listening>
<frequentlyListening>false</frequentlyListening>
<routing>true</routing>
<security>false</security>
<beaming>true</beaming>
<maxBaudRate>40000</maxBaudRate>
<sleepDelay>500</sleepDelay>
<nodeInformationFrame>
<commandClass>COMMAND_CLASS_ZWAVEPLUS_INFO</commandClass>
<commandClass>COMMAND_CLASS_ASSOCIATION</commandClass>
<commandClass>COMMAND_CLASS_MULTI_CHANNEL_ASSOCIATION</commandClass>
<commandClass>COMMAND_CLASS_ASSOCIATION_GRP_INFO</commandClass>
<commandClass>COMMAND_CLASS_TRANSPORT_SERVICE</commandClass>
<commandClass>COMMAND_CLASS_VERSION</commandClass>
<commandClass>COMMAND_CLASS_MANUFACTURER_SPECIFIC</commandClass>
<commandClass>COMMAND_CLASS_DEVICE_RESET_LOCALLY</commandClass>
<commandClass>COMMAND_CLASS_POWERLEVEL</commandClass>
<commandClass>COMMAND_CLASS_BATTERY</commandClass>
<commandClass>COMMAND_CLASS_SECURITY_2</commandClass>
<commandClass>COMMAND_CLASS_ALARM</commandClass>
<commandClass>COMMAND_CLASS_INDICATOR</commandClass>
<commandClass>COMMAND_CLASS_SENSOR_BINARY</commandClass>
<commandClass>COMMAND_CLASS_CONFIGURATION</commandClass>
<commandClass>COMMAND_CLASS_WAKE_UP</commandClass>
<commandClass>COMMAND_CLASS_SUPERVISION</commandClass>
<commandClass>COMMAND_CLASS_FIRMWARE_UPDATE_MD</commandClass>
</nodeInformationFrame>
<associationGroups class="concurrent-hash-map">
<entry>
<int>1</int>
<associationGroup>
<index>1</index>
<maxNodes>0</maxNodes>
<name>Lifeline</name>
<profile1>0x0</profile1>
<profile2>0x1</profile2>
<commands>
</commands>
<associations>
<associationMember>
<node>1</node>
</associationMember>
</associations>
</associationGroup>
</entry>
<entry>
<int>2</int>
<associationGroup>
<index>2</index>
<name>Basic Set</name>
<profile1>0x71</profile1>
<profile2>0x6</profile2>
<commands/>
<associations>
<associationMember>
<node>1</node>
</associations>
</associationGroup>
</entry>
</associationGroups>
<endpoints class="concurrent-hash-map">
<entry>
<int>0</int>
<endPoint>
<deviceClass>
<basicDeviceClass>BASIC_TYPE_ROUTING_SLAVE</basicDeviceClass>
<genericDeviceClass>GENERIC_TYPE_SENSOR_NOTIFICATION</genericDeviceClass>
<specificDeviceClass>SPECIFIC_TYPE_NOTIFICATION_SENSOR</specificDeviceClass>
</deviceClass>
<endpointId>0</endpointId>
<secureCommandClasses/>
<supportedCommandClasses class="concurrent-hash-map">
<entry>
<commandClass>COMMAND_CLASS_NO_OPERATION</commandClass>
<COMMAND__CLASS__NO__OPERATION>
<version>1</version>
<instances>1</instances>
<control>false</control>
<versionSupported>1</versionSupported>
</COMMAND__CLASS__NO__OPERATION>
</entry>
<entry>
<commandClass>COMMAND_CLASS_BASIC</commandClass>
<COMMAND__CLASS__BASIC>
<version>0</version>
<instances>0</instances>
<versionSupported>0</versionSupported>
<isGetSupported>true</isGetSupported>
</COMMAND__CLASS__BASIC>
</entry>
<entry>
<COMMAND__CLASS__SENSOR__BINARY>
<version>2</version>
<versionSupported>2</versionSupported>
<types>
<binarySensorType>DOORWINDOW</binarySensorType>
</types>
</COMMAND__CLASS__SENSOR__BINARY>
</entry>
<entry>
<COMMAND__CLASS__ASSOCIATION__GRP__INFO>
<versionSupported>3</versionSupported>
<autoSubscribeGroups>
<int>1</int>
</autoSubscribeGroups>
</COMMAND__CLASS__ASSOCIATION__GRP__INFO>
</entry>
<entry>
<COMMAND__CLASS__DEVICE__RESET__LOCALLY>
</COMMAND__CLASS__DEVICE__RESET__LOCALLY>
</entry>
<entry>
<COMMAND__CLASS__ZWAVEPLUS__INFO>
<zwPlusVersion>2</zwPlusVersion>
<zwPlusRole>ROLE_TYPE_SLAVE_SLEEPING_REPORTING</zwPlusRole>
<zwPlusNodeType>NODE_TYPE_ZWAVEPLUS_NODE</zwPlusNodeType>
</COMMAND__CLASS__ZWAVEPLUS__INFO>
</entry>
<entry>
<COMMAND__CLASS__CONFIGURATION>
<versionSupported>4</versionSupported>
<configParameters>
<entry>
<int>1</int>
<configurationParameter>
<index>1</index>
<size>1</size>
<value>1</value>
<readOnly>false</readOnly>
<writeOnly>false</writeOnly>
</configurationParameter>
</entry>
<entry>
<int>3</int>
<index>3</index>
<size>1</size>
<value>10</value>
</entry>
<entry>
<int>4</int>
<index>4</index>
<size>1</size>
<value>20</value>
</entry>
<entry>
<int>5</int>
<index>5</index>
<size>1</size>
<value>0</value>
</entry>
<entry>
<int>6</int>
<index>6</index>
<size>4</size>
<value>0</value>
</entry>
<entry>
<int>7</int>
<index>7</index>
<size>4</size>
<value>0</value>
</entry>
</configParameters>
</COMMAND__CLASS__CONFIGURATION>
</entry>
<entry>
<COMMAND__CLASS__ALARM>
<version>8</version>
<versionSupported>8</versionSupported>
<alarms>
<entry>
<alarmType>ACCESS_CONTROL</alarmType>
<alarmState>
<reportedEvents/>
<outer-class reference="../../../.."/>
</alarmState>
</entry>
</alarms>
<v1Supported>true</v1Supported>
</COMMAND__CLASS__ALARM>
</entry>
<entry>
<COMMAND__CLASS__MANUFACTURER__SPECIFIC>
<initSerialNumber>false</initSerialNumber>
<deviceManufacturer>634</deviceManufacturer>
<deviceType>28672</deviceType>
<deviceId>57345</deviceId>
</COMMAND__CLASS__MANUFACTURER__SPECIFIC>
</entry>
<entry>
<COMMAND__CLASS__POWERLEVEL>
<powerLevel>0</powerLevel>
<powerTimeout>0</powerTimeout>
</COMMAND__CLASS__POWERLEVEL>
</entry>
<entry>
<COMMAND__CLASS__FIRMWARE__UPDATE__MD>
<versionSupported>5</versionSupported>
</COMMAND__CLASS__FIRMWARE__UPDATE__MD>
</entry>
<entry>
<COMMAND__CLASS__BATTERY>
<batteryLevel>71</batteryLevel>
<batteryLow>false</batteryLow>
</COMMAND__CLASS__BATTERY>
</entry>
<entry>
<COMMAND__CLASS__WAKE__UP>
<targetNodeId>1</targetNodeId>
<interval>43200</interval>
<minInterval>3600</minInterval>
<maxInterval>86400</maxInterval>
<defaultInterval>43200</defaultInterval>
<intervalStep>60</intervalStep>
</COMMAND__CLASS__WAKE__UP>
</entry>
<entry>
<COMMAND__CLASS__ASSOCIATION>
<maxGroups>2</maxGroups>
</COMMAND__CLASS__ASSOCIATION>
</entry>
<entry>
<COMMAND__CLASS__VERSION>
<libraryType>LIB_SLAVE_ENHANCED</libraryType>
<protocolVersion>7.13</protocolVersion>
<applicationVersion>1.30</applicationVersion>
<hardwareVersion>1</hardwareVersion>
</COMMAND__CLASS__VERSION>
</entry>
<entry>
<COMMAND__CLASS__INDICATOR>
<version>3</version>
<supportedIndicatorsInitialised>true</supportedIndicatorsInitialised>
<supportedIndicators>
<ZWaveIndicator>
<type>NODE_IDENTIFY</type>
</ZWaveIndicator>
</supportedIndicators>
</COMMAND__CLASS__INDICATOR>
</entry>
<entry>
<COMMAND__CLASS__MULTI__CHANNEL__ASSOCIATION>
</COMMAND__CLASS__MULTI__CHANNEL__ASSOCIATION>
</entry>
</supportedCommandClasses>
</endPoint>
</entry>
</endpoints>
<nodeNeighbors/>
<lastReceived>2022-12-13 02:29:02.416 UTC</lastReceived>
</node>
Thank you in advance!
