Using Openhab to monitor and control the technical aspects of your home is a good idea. Monitoring Openhab system’s health is also a good idea.
I use the system binding to monitor the CPU temperature, load, memory and heap size on my small Raspberry pi 3B+. It comes at a cost: you need to define items and ideally also some charts. And you have to interpret the figures yourself.
There is a new ‘The Doctor Binding’ from @matt1, that has another approach. It gives you a warning in the log if something is getting wrong. Easier to use as it tells you if something is good or bad and why.
In the topic, @mstormi suggested to add some monitoring for zram. This would be a good idea.
Meanwhile you can check the zram status with the command
zramctl --output-all
Here is what I see:
NAME DISKSIZE DATA COMPR ALGORITHM STREAMS ZERO-PAGES TOTAL MEM-LIMIT MEM-USED MIGRATED MOUNTPOINT
/dev/zram2 75M 43.4M 6.3M zstd 4 5758 7.2M 25M 7.3M 0B /opt/zram/zram2
/dev/zram1 150M 105.8M 14.8M lzo-rle 4 1475 16.2M 50M 16.2M 0B /opt/zram/zram1
/dev/zram0 375M 73.9M 30.8M lzo-rle 4 368 35.8M 150M 62.8M 3.4K [SWAP]
The result is hard to evaluate.
Two ratio’s seem important:
DATA / DISKSIZE: uncompressed used data vs. uncompressed limit
MEM-USED / MEM-LIMIT: compressed data vs. compressed limit
These two ratio’s should remain smaller than one.
I wrote a rule with a javascript script that calculates these ratio’s. I let it execute every hour. To use it, I first defined 6 items:
zram0Compressed and zram0UnCompressed: swap
zram1Compressed and zram1UnCompressed: persistence files
zram2Compressed and zram2UnCompressed: log
Script code:
// zramctlRead
// Read zram memory settings with zramctl
// execute zramctl
command = 'zramctl --output NAME,DISKSIZE,DATA,MEM-LIMIT,MEM-USED';
result = actions.Exec.executeCommandLine(time.Duration.ofSeconds(5),'/bin/sh', '-c',command).trim();
// split in lines with regex
lines = result.split(/\r?\n/);
// are there any lines with values?
if (lines.length > 1){
// process lines with values
for (i=1; i < lines.length; i++){
result = processLine(lines[i]);
function processLine(line){
values = line.split(/[ ]+/);
name = values[0];
diskSize = convertToBytes(values[1]);
data = convertToBytes(values[2]);
memLimit = convertToBytes(values[3]);
memUsed = convertToBytes(values[4]);
// index = last character of name
index = name.slice(-1);
// calculate and post ratio's
items.getItem('zram' + index + 'UnCompressed').postUpdate((data / diskSize).toFixed(2));
// mem_limit is an optional setting in /etc/ztab; setting it to 0 disables it.
if ( memLimit > 0) {
items.getItem('zram' + index + 'Compressed').postUpdate((memUsed / memLimit).toFixed(2));
function convertToBytes(value){
// split value in number and unit
unit = value.slice(-1);
number = value.slice(0,value.length - 1);
// calculate number of bytes
switch(unit){
case 'B':
bytes = number;
break;
case 'K':
bytes = number * 1024;
break;
case 'M':
bytes = number * 1024 * 1024;
break;
case 'G':
bytes = number * 1024 * 1024 * 1024;
break;
return bytes;
You can see the evolution in a chart:
You could also define limits for the ratio’s, although I am not sure where to set safe limits: 0.5, 0.75, …? Something for The Doctor?
Edit:
- Corrected an error: switched compressed and uncompressed in the script
- According to the zram-config documentation here mem_limit is an optional setting. It can be disabled by setting it to 0. In this case you don’t need to define the zram?Compressed items.
