I do look forward to the fun time in figuring out the dryer rule but I first need a working sensor.
I do not see a time factor as a paramter for association group 3 (There is one for group 2). Plus to get the push notification, Iâm not sure how sending a basic set to another zwave device will help. I use a text in a dsl rule to notify about water like this.
rule "Water in Water Heater Bucket"
when Item WaterHeaterLeak61_Alarmflood changed to ON
getActions("mail","mail:smtp:zzzzzzzz").sendMail("zzzzzzzzz@vtext.com","Water","Water Heater Alarm On")
Perhaps this will help everyone (alarm_buglar) with current binding with zSE43:
Alarm_Tamper modification- Note how short the device stays in Alarm (maybe 4 seconds)
Why? Why would you do that when the device should be sending more descriptive alarms to the controller anyway? Itâs normally a bad idea to add the controller into multiple groups as it can (likely) cause problems in OH when multiple messages are received.
Also, if thatâs the case, then they are not being received - at least not in the log above.
Easily accomplished with a wall plug that measures energy.
Curious if you have any suggestions for that wall plug that measures energy? Dryers use a lot of current so it would have to be a higher power device.
I have an Electric Dryer and it uses a special plug and runs on 220 volts.
Most options I have found for this are far more expensive than this sensor.
As far as the rule goes I have one for my motion sensors (that I adapted from a post on this forum) where every time it senses motion a timer is started and that timer is reset every time motion is detected. Eventually, when no motion is detected and the timer reaches zero it turns the light off. I was figuring I could use that one but instead of motion use vibration and set the timer for around 5 minutes. The end result I hope is the push notification (using sendBroadcastNotification) being pushed to my phone around 5 minutes after the dryer is done.
It may depend on your region, of course. Iâm in the U.S. and I use a Fibaro FGWPB-121. When running the dryer draws about 350 watts (average). Amazon description calls out gas dryer, so you may need something different for electric dryer.
Itâs a good plan. Watch for âwrinkle protectâ setting that runs the dryer every few minutes after the main cycle. Youâll get a bunch of broadcast messages. If you are ok with that, no issues. I used a slight variation in power draw when dryer is in wrinkle protect mode to control a proxy which acts as a condition for the broadcast rule.
Not Z-Wave, but cheap: Page Not Found - Aliexpress.com
Add a Zigbee coordinator: https://itead.cc/product/zigbee-3-0-usb-dongle/
Total cost: < 30 EUR - add 10 EUR per additonal wall plug.
Thank all for the help. So the changes look like they are available in OH-Snapshot.
So I downloaded the docker version of the snapshot and installed it.
My Openhab is now 4.0.0 Build #3330 and my Zwave Binding is now 4.0.0 Snapshot.
Since I know some big changes were occuring in this build I was a little nervios but for the most part, this change was painless for me and with a few exceptions around the Alexa binding (voice commands works but there are a bunch of issues with the interface) and MQTT (one of my things remains in a not ready state), and of course this sensor.
Focusing back on the Sensor as that is my biggest issue it is still not reporting Vibrations.
After installing the openhab snapshot I removed the node and re added it to my hub.
After that I ran the log on Debug for a while and put it in the log viewer:
configurations:
<node>
<homeId>0xe2bc20fb</homeId>
<nodeId>150</nodeId>
<version>4</version>
<manufacturer>0x27a</manufacturer>
<deviceId>0xe003</deviceId>
<deviceType>0x7000</deviceType>
<listening>false</listening>
<frequentlyListening>false</frequentlyListening>
<routing>true</routing>
<security>false</security>
<beaming>true</beaming>
<maxBaudRate>40000</maxBaudRate>
<sleepDelay>500</sleepDelay>
<nodeInformationFrame>
<commandClass>COMMAND_CLASS_ZWAVEPLUS_INFO</commandClass>
<commandClass>COMMAND_CLASS_ASSOCIATION</commandClass>
<commandClass>COMMAND_CLASS_MULTI_CHANNEL_ASSOCIATION</commandClass>
<commandClass>COMMAND_CLASS_ASSOCIATION_GRP_INFO</commandClass>
<commandClass>COMMAND_CLASS_TRANSPORT_SERVICE</commandClass>
<commandClass>COMMAND_CLASS_VERSION</commandClass>
<commandClass>COMMAND_CLASS_MANUFACTURER_SPECIFIC</commandClass>
<commandClass>COMMAND_CLASS_DEVICE_RESET_LOCALLY</commandClass>
<commandClass>COMMAND_CLASS_POWERLEVEL</commandClass>
<commandClass>COMMAND_CLASS_BATTERY</commandClass>
<commandClass>COMMAND_CLASS_SECURITY_2</commandClass>
<commandClass>COMMAND_CLASS_ALARM</commandClass>
<commandClass>COMMAND_CLASS_INDICATOR</commandClass>
<commandClass>COMMAND_CLASS_SENSOR_BINARY</commandClass>
<commandClass>COMMAND_CLASS_CONFIGURATION</commandClass>
<commandClass>COMMAND_CLASS_WAKE_UP</commandClass>
<commandClass>COMMAND_CLASS_SUPERVISION</commandClass>
<commandClass>COMMAND_CLASS_FIRMWARE_UPDATE_MD</commandClass>
</nodeInformationFrame>
<associationGroups class="concurrent-hash-map">
<entry>
<int>1</int>
<associationGroup>
<index>1</index>
<maxNodes>0</maxNodes>
<name>Lifeline</name>
<profile1>0x0</profile1>
<profile2>0x1</profile2>
<commands>
</commands>
<associations>
<associationMember>
<node>1</node>
</associationMember>
</associations>
</associationGroup>
</entry>
<entry>
<int>2</int>
<associationGroup>
<index>2</index>
<name>Basic Set for contact sensor</name>
<profile1>0x71</profile1>
<profile2>0x6</profile2>
<commands>
<commandClass>COMMAND_CLASS_BASIC</commandClass>
</commands>
<associations/>
</associationGroup>
</entry>
<entry>
<int>3</int>
<associationGroup>
<index>3</index>
<name>Basic Set for shock sensor</name>
<profile2>0x7</profile2>
<commands>
</commands>
<associations>
<associationMember>
<node>1</node>
</associations>
</associationGroup>
</entry>
</associationGroups>
<endpoints class="concurrent-hash-map">
<entry>
<int>0</int>
<endPoint>
<deviceClass>
<basicDeviceClass>BASIC_TYPE_ROUTING_SLAVE</basicDeviceClass>
<genericDeviceClass>GENERIC_TYPE_SENSOR_NOTIFICATION</genericDeviceClass>
<specificDeviceClass>SPECIFIC_TYPE_NOTIFICATION_SENSOR</specificDeviceClass>
</deviceClass>
<endpointId>0</endpointId>
<secureCommandClasses/>
<supportedCommandClasses class="concurrent-hash-map">
<entry>
<commandClass>COMMAND_CLASS_NO_OPERATION</commandClass>
<COMMAND__CLASS__NO__OPERATION>
<version>1</version>
<instances>1</instances>
<control>false</control>
<versionSupported>1</versionSupported>
</COMMAND__CLASS__NO__OPERATION>
</entry>
<entry>
<COMMAND__CLASS__BASIC>
<version>0</version>
<versionSupported>0</versionSupported>
<isGetSupported>true</isGetSupported>
</COMMAND__CLASS__BASIC>
</entry>
<entry>
<COMMAND__CLASS__SENSOR__BINARY>
<version>2</version>
<versionSupported>2</versionSupported>
<types>
<binarySensorType>TAMPER</binarySensorType>
</types>
</COMMAND__CLASS__SENSOR__BINARY>
</entry>
<entry>
<COMMAND__CLASS__ASSOCIATION__GRP__INFO>
<versionSupported>3</versionSupported>
<autoSubscribeGroups>
<int>1</int>
</autoSubscribeGroups>
</COMMAND__CLASS__ASSOCIATION__GRP__INFO>
</entry>
<entry>
<COMMAND__CLASS__DEVICE__RESET__LOCALLY>
</COMMAND__CLASS__DEVICE__RESET__LOCALLY>
</entry>
<entry>
<COMMAND__CLASS__ZWAVEPLUS__INFO>
<zwPlusVersion>2</zwPlusVersion>
<zwPlusRole>ROLE_TYPE_SLAVE_SLEEPING_REPORTING</zwPlusRole>
<zwPlusNodeType>NODE_TYPE_ZWAVEPLUS_NODE</zwPlusNodeType>
</COMMAND__CLASS__ZWAVEPLUS__INFO>
</entry>
<entry>
<COMMAND__CLASS__CONFIGURATION>
<versionSupported>4</versionSupported>
<configParameters>
<entry>
<int>1</int>
<configurationParameter>
<index>1</index>
<size>1</size>
<value>3</value>
<readOnly>false</readOnly>
<writeOnly>false</writeOnly>
</configurationParameter>
</entry>
<entry>
<int>3</int>
<index>3</index>
<size>1</size>
<value>20</value>
</entry>
<entry>
<int>4</int>
<index>4</index>
<size>1</size>
<value>0</value>
</entry>
<entry>
<int>5</int>
<index>5</index>
<size>2</size>
<value>0</value>
</entry>
<entry>
<int>6</int>
<index>6</index>
<size>2</size>
<value>0</value>
</entry>
<entry>
<int>7</int>
<index>7</index>
<size>1</size>
<value>2</value>
</entry>
<entry>
<int>8</int>
<index>8</index>
<size>1</size>
<value>3</value>
</entry>
<entry>
<int>9</int>
<index>9</index>
<size>1</size>
<value>3</value>
</entry>
</configParameters>
</COMMAND__CLASS__CONFIGURATION>
</entry>
<entry>
<COMMAND__CLASS__ALARM>
<version>8</version>
<versionSupported>8</versionSupported>
<alarms>
<entry>
<alarmType>ACCESS_CONTROL</alarmType>
<alarmState>
<reportedEvents>
<int>22</int>
<int>23</int>
</reportedEvents>
<outer-class reference="../../../.."/>
</alarmState>
</entry>
<entry>
<alarmType>BURGLAR</alarmType>
<alarmState>
<reportedEvents>
<int>3</int>
</reportedEvents>
</alarmState>
</entry>
</alarms>
<v1Supported>true</v1Supported>
</COMMAND__CLASS__ALARM>
</entry>
<entry>
<COMMAND__CLASS__MANUFACTURER__SPECIFIC>
<initSerialNumber>false</initSerialNumber>
<deviceManufacturer>634</deviceManufacturer>
<deviceType>28672</deviceType>
<deviceId>57347</deviceId>
</COMMAND__CLASS__MANUFACTURER__SPECIFIC>
</entry>
<entry>
<COMMAND__CLASS__POWERLEVEL>
<powerLevel>0</powerLevel>
<powerTimeout>0</powerTimeout>
</COMMAND__CLASS__POWERLEVEL>
</entry>
<entry>
<COMMAND__CLASS__FIRMWARE__UPDATE__MD>
<versionSupported>5</versionSupported>
</COMMAND__CLASS__FIRMWARE__UPDATE__MD>
</entry>
<entry>
<COMMAND__CLASS__BATTERY>
<batteryLevel>69</batteryLevel>
<batteryLow>false</batteryLow>
</COMMAND__CLASS__BATTERY>
</entry>
<entry>
<COMMAND__CLASS__WAKE__UP>
<targetNodeId>1</targetNodeId>
<interval>21600</interval>
<minInterval>3600</minInterval>
<maxInterval>86400</maxInterval>
<defaultInterval>21600</defaultInterval>
<intervalStep>60</intervalStep>
</COMMAND__CLASS__WAKE__UP>
</entry>
<entry>
<COMMAND__CLASS__ASSOCIATION>
<maxGroups>3</maxGroups>
</COMMAND__CLASS__ASSOCIATION>
</entry>
<entry>
<COMMAND__CLASS__VERSION>
<libraryType>LIB_SLAVE_ENHANCED</libraryType>
<protocolVersion>7.13</protocolVersion>
<applicationVersion>1.20</applicationVersion>
<hardwareVersion>1</hardwareVersion>
</COMMAND__CLASS__VERSION>
</entry>
<entry>
<COMMAND__CLASS__INDICATOR>
<version>3</version>
<supportedIndicatorsInitialised>true</supportedIndicatorsInitialised>
<supportedIndicators>
<ZWaveIndicator>
<type>NODE_IDENTIFY</type>
</ZWaveIndicator>
</supportedIndicators>
</COMMAND__CLASS__INDICATOR>
</entry>
<entry>
<COMMAND__CLASS__MULTI__CHANNEL__ASSOCIATION>
</COMMAND__CLASS__MULTI__CHANNEL__ASSOCIATION>
</entry>
</supportedCommandClasses>
</endPoint>
</entry>
</endpoints>
<nodeNeighbors/>
<lastReceived>2023-02-11 01:04:40.434 UTC</lastReceived>
</node>
Here is the config from paperui
"zwave:device:5eab90482f:node153": {
"class": "org.openhab.core.thing.internal.ThingStorageEntity",
"value": {
"isBridge": false,
"channels": [
"uid": "zwave:device:5eab90482f:node153:sensor_binary",
"id": "sensor_binary",
"channelTypeUID": "zwave:sensor_binary",
"itemType": "Switch",
"kind": "STATE",
"label": "Binary Sensor",
"description": "Indicates if a sensor has triggered",
"defaultTags": [],
"properties": {
"binding:*:OnOffType": "COMMAND_CLASS_SENSOR_BINARY"
"configuration": {}
"uid": "zwave:device:5eab90482f:node153:alarm_access",
"id": "alarm_access",
"channelTypeUID": "zwave:alarm_access",
"kind": "STATE",
"label": "Alarm (access)",
"description": "Indicates if the access control alarm is triggered",
"defaultTags": [],
"properties": {
"binding:*:OnOffType": "COMMAND_CLASS_ALARM;type\u003dACCESS_CONTROL"
"configuration": {}
"uid": "zwave:device:5eab90482f:node153:battery-level",
"id": "battery-level",
"channelTypeUID": "system:battery-level",
"itemType": "Number",
"kind": "STATE",
"label": "Battery Level",
"description": "Battery level as a percentage (0-100%)",
"defaultTags": [
"Energy",
"Measurement"
"properties": {
"binding:*:PercentType": "COMMAND_CLASS_BATTERY"
"configuration": {}
"uid": "zwave:device:5eab90482f:node153:alarm_burglar",
"id": "alarm_burglar",
"channelTypeUID": "zwave:alarm_burglar",
"kind": "STATE",
"label": "Alarm (burglar)",
"description": "Indicates if the burglar alarm is triggered",
"defaultTags": [],
"properties": {
"binding:*:OnOffType": "COMMAND_CLASS_ALARM;type\u003dBURGLAR"
"configuration": {}
"uid": "zwave:device:5eab90482f:node153:sensor_door",
"id": "sensor_door",
"channelTypeUID": "zwave:sensor_door",
"itemType": "Contact",
"kind": "STATE",
"label": "Door State",
"description": "Indicates if the door/window is open or closed",
"defaultTags": [],
"properties": {
"binding:*:OpenClosedType": "COMMAND_CLASS_ALARM"
"configuration": {}
"label": "Dryer Sensor",
"bridgeUID": "zwave:serial_zstick:5eab90482f",
"configuration": {
"config_1_1": 3,
"config_2_1": 5,
"config_3_1": 20,
"config_4_1": 0,
"config_5_4": 0,
"config_6_3": 0,
"config_7_1": 2,
"config_8_1": 3,
"config_9_1": 3,
"group_1": [
"controller"
"group_2": [],
"group_3": [
"controller"
"node_id": 153,
"wakeup_interval": 3600,
"wakeup_node": 1
"properties": {
"dbReference": "1481",
"defaultAssociations": "1",
"manufacturerId": "027A",
"manufacturerRef": "7000:E003",
"modelId": "ZSE43",
"vendor": "Zooz",
"zwave_beaming": "true",
"zwave_class_basic": "BASIC_TYPE_ROUTING_SLAVE",
"zwave_class_generic": "GENERIC_TYPE_SENSOR_NOTIFICATION",
"zwave_class_specific": "SPECIFIC_TYPE_NOTIFICATION_SENSOR",
"zwave_deviceid": "57347",
"zwave_devicetype": "28672",
"zwave_frequent": "false",
"zwave_lastwakeup": "2023-02-25T17:32:51Z",
"zwave_listening": "false",
"zwave_manufacturer": "634",
"zwave_neighbours": "",
"zwave_nodeid": "153",
"zwave_plus_devicetype": "NODE_TYPE_ZWAVEPLUS_NODE",
"zwave_plus_roletype": "ROLE_TYPE_SLAVE_SLEEPING_REPORTING",
"zwave_routing": "true",
"zwave_secure": "false",
"zwave_version": "1.20"
"UID": "zwave:device:5eab90482f:node153",
"thingTypeUID": "zwave:zooz_zse43_00_000"
Here is the Opehnab Log:
2023-02-25 17:05:01.225 [DEBUG] [ol.serialmessage.AddNodeMessageClass] - NODE 153: Adding slave.
2023-02-25 17:05:01.225 [DEBUG] [al.protocol.ZWaveInclusionController] - Inclusion event: Current state IncludeStart, new event IncludeSlaveFound
2023-02-25 17:05:01.225 [DEBUG] [al.protocol.ZWaveInclusionController] - NODE 153: Including node.
2023-02-25 17:05:01.226 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2023-02-25 17:05:01.226 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2023-02-25 17:05:05.798 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=AddNodeToNetwork[74], type=Request[0], dest=5, callback=101, payload=65 05 99 00
2023-02-25 17:05:05.798 [DEBUG] [ol.serialmessage.AddNodeMessageClass] - NODE 153: Add Node: Protocol done.
2023-02-25 17:05:05.798 [DEBUG] [al.protocol.ZWaveInclusionController] - Inclusion event: Current state IncludeSlaveFound, new event IncludeProtocolDone
2023-02-25 17:05:05.798 [DEBUG] [ol.serialmessage.AddNodeMessageClass] - Ending INCLUSION mode.
2023-02-25 17:05:05.798 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 255: Added 237 to queue - size 1
2023-02-25 17:05:05.798 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2023-02-25 17:05:05.798 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 05 00 4A 05 67 D2
2023-02-25 17:05:05.799 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 255: Sending REQUEST Message = 01 05 00 4A 05 67 D2
2023-02-25 17:05:05.799 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - Message SENT
2023-02-25 17:05:05.799 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage started: TID 237: [WAIT_REQUEST] priority=Controller, requiresResponse=true, callback: 103
2023-02-25 17:05:05.799 [DEBUG] [al.protocol.ZWaveInclusionController] - NODE 153: Inclusion protocol completed.
2023-02-25 17:05:05.799 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 153: Creating new instance of command class COMMAND_CLASS_NO_OPERATION
2023-02-25 17:05:05.799 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 153: Command class COMMAND_CLASS_NO_OPERATION, endpoint 0 created
2023-02-25 17:05:05.800 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 153: Version = 1, version set. Enabling extra functionality.
2023-02-25 17:05:05.800 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 153: Adding command class COMMAND_CLASS_NO_OPERATION to the list of supported command classes.
2023-02-25 17:05:05.800 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 0D 00 04 10 8B 05 25 03 00 00 00 C7 00 89
2023-02-25 17:05:05.800 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=139, callback=16, payload=10 8B 05 25 03 00 00 00 C7 00
2023-02-25 17:05:05.800 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 153: Creating new instance of command class COMMAND_CLASS_BASIC
2023-02-25 17:05:05.801 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 153: Command class COMMAND_CLASS_BASIC, endpoint 0 created
2023-02-25 17:05:05.801 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 153: Adding command class COMMAND_CLASS_BASIC to the list of supported command classes.
2023-02-25 17:05:05.801 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 18
2023-02-25 17:05:05.801 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 1<>127 : Message: class=null[0], type=CAN[4], dest=255, callback=0, payload=
2023-02-25 17:05:05.802 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 153: Creating new instance of command class COMMAND_CLASS_ZWAVEPLUS_INFO
2023-02-25 17:05:05.802 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 153: Command class COMMAND_CLASS_ZWAVEPLUS_INFO, endpoint 0 created
2023-02-25 17:05:05.802 [DEBUG] [al.protocol.ZWaveInclusionController] - NODE 153: Inclusion is adding command class COMMAND_CLASS_ZWAVEPLUS_INFO.
2023-02-25 17:05:05.802 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 153: Adding command class COMMAND_CLASS_ZWAVEPLUS_INFO to the list of supported command classes.
2023-02-25 17:05:05.802 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 153: Creating new instance of command class COMMAND_CLASS_ASSOCIATION
2023-02-25 17:05:05.802 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 153: Command class COMMAND_CLASS_ASSOCIATION, endpoint 0 created
2023-02-25 17:05:05.802 [DEBUG] [al.protocol.ZWaveInclusionController] - NODE 153: Inclusion is adding command class COMMAND_CLASS_ASSOCIATION.
2023-02-25 17:05:05.802 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 153: Adding command class COMMAND_CLASS_ASSOCIATION to the list of supported command classes.
2023-02-25 17:05:05.803 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 153: Creating new instance of command class COMMAND_CLASS_MULTI_CHANNEL_ASSOCIATION
2023-02-25 17:05:05.803 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 153: Command class COMMAND_CLASS_MULTI_CHANNEL_ASSOCIATION, endpoint 0 created
2023-02-25 17:05:05.803 [DEBUG] [al.protocol.ZWaveInclusionController] - NODE 153: Inclusion is adding command class COMMAND_CLASS_MULTI_CHANNEL_ASSOCIATION.
2023-02-25 17:05:05.803 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 153: Adding command class COMMAND_CLASS_MULTI_CHANNEL_ASSOCIATION to the list of supported command classes.
2023-02-25 17:05:05.803 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 153: Creating new instance of command class COMMAND_CLASS_ASSOCIATION_GRP_INFO
2023-02-25 17:05:05.803 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 153: Command class COMMAND_CLASS_ASSOCIATION_GRP_INFO, endpoint 0 created
2023-02-25 17:05:05.803 [DEBUG] [al.protocol.ZWaveInclusionController] - NODE 153: Inclusion is adding command class COMMAND_CLASS_ASSOCIATION_GRP_INFO.
2023-02-25 17:05:05.803 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 153: Adding command class COMMAND_CLASS_ASSOCIATION_GRP_INFO to the list of supported command classes.
2023-02-25 17:05:05.803 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 153: Unsupported command class COMMAND_CLASS_TRANSPORT_SERVICE
2023-02-25 17:05:05.803 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 153: Creating new instance of command class COMMAND_CLASS_VERSION
2023-02-25 17:05:05.804 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 153: Command class COMMAND_CLASS_VERSION, endpoint 0 created
2023-02-25 17:05:05.804 [DEBUG] [al.protocol.ZWaveInclusionController] - NODE 153: Inclusion is adding command class COMMAND_CLASS_VERSION.
2023-02-25 17:05:05.804 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 153: Adding command class COMMAND_CLASS_VERSION to the list of supported command classes.
2023-02-25 17:05:05.804 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 153: Creating new instance of command class COMMAND_CLASS_MANUFACTURER_SPECIFIC
2023-02-25 17:05:05.804 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 153: Command class COMMAND_CLASS_MANUFACTURER_SPECIFIC, endpoint 0 created
2023-02-25 17:05:05.804 [DEBUG] [al.protocol.ZWaveInclusionController] - NODE 153: Inclusion is adding command class COMMAND_CLASS_MANUFACTURER_SPECIFIC.
2023-02-25 17:05:05.804 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 153: Adding command class COMMAND_CLASS_MANUFACTURER_SPECIFIC to the list of supported command classes.
2023-02-25 17:05:05.804 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 153: Creating new instance of command class COMMAND_CLASS_DEVICE_RESET_LOCALLY
2023-02-25 17:05:05.804 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 153: Command class COMMAND_CLASS_DEVICE_RESET_LOCALLY, endpoint 0 created
2023-02-25 17:05:05.804 [DEBUG] [al.protocol.ZWaveInclusionController] - NODE 153: Inclusion is adding command class COMMAND_CLASS_DEVICE_RESET_LOCALLY.
2023-02-25 17:05:05.804 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 153: Adding command class COMMAND_CLASS_DEVICE_RESET_LOCALLY to the list of supported command classes.
2023-02-25 17:05:05.804 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 153: Creating new instance of command class COMMAND_CLASS_POWERLEVEL
2023-02-25 17:05:05.805 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 153: Command class COMMAND_CLASS_POWERLEVEL, endpoint 0 created
2023-02-25 17:05:05.805 [DEBUG] [al.protocol.ZWaveInclusionController] - NODE 153: Inclusion is adding command class COMMAND_CLASS_POWERLEVEL.
2023-02-25 17:05:05.805 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 153: Adding command class COMMAND_CLASS_POWERLEVEL to the list of supported command classes.
2023-02-25 17:05:05.805 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 153: Creating new instance of command class COMMAND_CLASS_BATTERY
2023-02-25 17:05:05.805 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 153: Command class COMMAND_CLASS_BATTERY, endpoint 0 created
2023-02-25 17:05:05.805 [DEBUG] [al.protocol.ZWaveInclusionController] - NODE 153: Inclusion is adding command class COMMAND_CLASS_BATTERY.
2023-02-25 17:05:05.805 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 153: Adding command class COMMAND_CLASS_BATTERY to the list of supported command classes.
2023-02-25 17:05:05.805 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 153: Creating new instance of command class COMMAND_CLASS_SECURITY
2023-02-25 17:05:05.805 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 153: Command class COMMAND_CLASS_SECURITY, endpoint 0 created
2023-02-25 17:05:05.805 [DEBUG] [al.protocol.ZWaveInclusionController] - NODE 153: Inclusion is adding command class COMMAND_CLASS_SECURITY_2.
2023-02-25 17:05:05.806 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 153: Adding command class COMMAND_CLASS_SECURITY to the list of supported command classes.
2023-02-25 17:05:05.806 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 153: Creating new instance of command class COMMAND_CLASS_ALARM
2023-02-25 17:05:05.806 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 153: Command class COMMAND_CLASS_ALARM, endpoint 0 created
2023-02-25 17:05:05.806 [DEBUG] [al.protocol.ZWaveInclusionController] - NODE 153: Inclusion is adding command class COMMAND_CLASS_ALARM.
2023-02-25 17:05:05.806 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 153: Adding command class COMMAND_CLASS_ALARM to the list of supported command classes.
2023-02-25 17:05:05.806 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 153: Creating new instance of command class COMMAND_CLASS_INDICATOR
2023-02-25 17:05:05.806 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 153: Command class COMMAND_CLASS_INDICATOR, endpoint 0 created
2023-02-25 17:05:05.806 [DEBUG] [al.protocol.ZWaveInclusionController] - NODE 153: Inclusion is adding command class COMMAND_CLASS_INDICATOR.
2023-02-25 17:05:05.806 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 153: Adding command class COMMAND_CLASS_INDICATOR to the list of supported command classes.
2023-02-25 17:05:05.806 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 153: Creating new instance of command class COMMAND_CLASS_SENSOR_BINARY
2023-02-25 17:05:05.806 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 153: Command class COMMAND_CLASS_SENSOR_BINARY, endpoint 0 created
2023-02-25 17:05:05.807 [DEBUG] [al.protocol.ZWaveInclusionController] - NODE 153: Inclusion is adding command class COMMAND_CLASS_SENSOR_BINARY.
2023-02-25 17:05:05.807 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 153: Adding command class COMMAND_CLASS_SENSOR_BINARY to the list of supported command classes.
2023-02-25 17:05:05.807 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 153: Creating new instance of command class COMMAND_CLASS_CONFIGURATION
2023-02-25 17:05:05.807 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 153: Command class COMMAND_CLASS_CONFIGURATION, endpoint 0 created
2023-02-25 17:05:05.807 [DEBUG] [al.protocol.ZWaveInclusionController] - NODE 153: Inclusion is adding command class COMMAND_CLASS_CONFIGURATION.
2023-02-25 17:05:05.807 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 153: Adding command class COMMAND_CLASS_CONFIGURATION to the list of supported command classes.
2023-02-25 17:05:05.807 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 153: Creating new instance of command class COMMAND_CLASS_WAKE_UP
2023-02-25 17:05:05.807 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 153: Command class COMMAND_CLASS_WAKE_UP, endpoint 0 created
2023-02-25 17:05:05.807 [DEBUG] [al.protocol.ZWaveInclusionController] - NODE 153: Inclusion is adding command class COMMAND_CLASS_WAKE_UP.
2023-02-25 17:05:05.807 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 153: Adding command class COMMAND_CLASS_WAKE_UP to the list of supported command classes.
2023-02-25 17:05:05.807 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 153: Unsupported command class COMMAND_CLASS_SUPERVISION
2023-02-25 17:05:05.807 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 153: Creating new instance of command class COMMAND_CLASS_FIRMWARE_UPDATE_MD
2023-02-25 17:05:05.808 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 153: Command class COMMAND_CLASS_FIRMWARE_UPDATE_MD, endpoint 0 created
2023-02-25 17:05:05.808 [DEBUG] [al.protocol.ZWaveInclusionController] - NODE 153: Inclusion is adding command class COMMAND_CLASS_FIRMWARE_UPDATE_MD.
2023-02-25 17:05:05.808 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 153: Adding command class COMMAND_CLASS_FIRMWARE_UPDATE_MD to the list of supported command classes.
2023-02-25 17:05:05.808 [DEBUG] [ve.internal.protocol.ZWaveController] - NODE 153: ZWaveController include node
2023-02-25 17:05:05.808 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 153: Starting initialisation from INCLUSION_START
2023-02-25 17:05:05.809 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (1): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=139, callback=16, payload=10 8B 05 25 03 00 00 00 C7 00
2023-02-25 17:05:05.809 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 153: Node advancer: Node just included (742908)
2023-02-25 17:05:05.809 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 237: [WAIT_REQUEST] priority=Controller, requiresResponse=true, callback: 103
2023-02-25 17:05:05.809 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 153: Node advancer - advancing to IDENTIFY_NODE
2023-02-25 17:05:06.109 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 1
2023-02-25 17:05:06.109 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2023-02-25 17:05:06.109 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2023-02-25 17:05:06.121 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 07 00 4A 67 06 99 00 4A
2023-02-25 17:05:06.121 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=AddNodeToNetwork[74], type=Request[0], dest=6, callback=103, payload=67 06 99 00
2023-02-25 17:05:06.121 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=AddNodeToNetwork[74], type=Request[0], dest=6, callback=103, payload=67 06 99 00
2023-02-25 17:05:06.121 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 237: [WAIT_REQUEST] priority=Controller, requiresResponse=true, callback: 103
2023-02-25 17:05:06.121 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 1
2023-02-25 17:05:06.121 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: TID 237: [WAIT_REQUEST] priority=Controller, requiresResponse=true, callback: 103
2023-02-25 17:05:06.121 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking TID 237: (Callback 103)
2023-02-25 17:05:06.122 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Callback match!
2023-02-25 17:05:06.122 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Correlated to TID 237: callback 103
2023-02-25 17:05:06.122 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=AddNodeToNetwork[74], type=Request[0], dest=6, callback=103, payload=67 06 99 00
2023-02-25 17:05:06.122 [DEBUG] [ol.serialmessage.AddNodeMessageClass] - Add Node: Done.
2023-02-25 17:05:06.122 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 153: Device discovered
2023-02-25 17:05:06.124 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 0D 00 04 10 8B 05 25 03 00 00 00 CA 00 84
2023-02-25 17:05:06.124 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing 'zwave:device:5eab90482f:node153' to inbox.
2023-02-25 17:05:06.124 [DEBUG] [al.protocol.ZWaveInclusionController] - Inclusion event: Current state IncludeProtocolDone, new event IncludeDone
2023-02-25 17:05:06.124 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=139, callback=16, payload=10 8B 05 25 03 00 00 00 CA 00
2023-02-25 17:05:06.124 [DEBUG] [ol.serialmessage.AddNodeMessageClass] - Ending INCLUSION mode.
2023-02-25 17:05:06.124 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 255: Added 240 to queue - size 2
2023-02-25 17:05:06.124 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2023-02-25 17:05:06.124 [DEBUG] [al.protocol.ZWaveInclusionController] - ZWave controller end exclusion
2023-02-25 17:05:06.125 [DEBUG] [ve.internal.protocol.ZWaveController] - ZWaveController include done
2023-02-25 17:05:06.125 [DEBUG] [nal.protocol.ZWaveTransactionManager] - TID 237: Advanced to DONE
2023-02-25 17:05:06.125 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 255: Response processed after 62ms
2023-02-25 17:05:06.125 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 255: TID 237: Transaction completed
2023-02-25 17:05:06.125 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 255: notifyTransactionResponse TID:237 DONE
2023-02-25 17:05:06.125 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=139, callback=16, payload=10 8B 05 25 03 00 00 00 CA 00
2023-02-25 17:05:06.125 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2023-02-25 17:05:06.130 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=IdentifyNode[65], type=Response[1], dest=255, callback=0, payload=53 9C 01 04 07 01
2023-02-25 17:05:06.130 [DEBUG] [rialmessage.IdentifyNodeMessageClass] - NODE 153: ProtocolInfo
2023-02-25 17:05:06.130 [DEBUG] [rialmessage.IdentifyNodeMessageClass] - NODE 153: Listening = false
2023-02-25 17:05:06.130 [DEBUG] [rialmessage.IdentifyNodeMessageClass] - NODE 153: Routing = true
2023-02-25 17:05:06.130 [DEBUG] [rialmessage.IdentifyNodeMessageClass] - NODE 153: Beaming = true
2023-02-25 17:05:06.130 [DEBUG] [rialmessage.IdentifyNodeMessageClass] - NODE 153: Version = 4
2023-02-25 17:05:06.130 [DEBUG] [rialmessage.IdentifyNodeMessageClass] - NODE 153: FLIRS = false
2023-02-25 17:05:06.130 [DEBUG] [rialmessage.IdentifyNodeMessageClass] - NODE 153: Security = false
2023-02-25 17:05:06.131 [DEBUG] [rialmessage.IdentifyNodeMessageClass] - NODE 153: Max Baud = 40000
2023-02-25 17:05:06.131 [DEBUG] [rialmessage.IdentifyNodeMessageClass] - NODE 153: Basic = BASIC_TYPE_ROUTING_SLAVE
2023-02-25 17:05:06.131 [DEBUG] [rialmessage.IdentifyNodeMessageClass] - NODE 153: Generic = GENERIC_TYPE_SENSOR_NOTIFICATION
2023-02-25 17:05:06.131 [DEBUG] [rialmessage.IdentifyNodeMessageClass] - NODE 153: Specific = SPECIFIC_TYPE_NOTIFICATION_SENSOR
2023-02-25 17:05:06.131 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 153: Creating new instance of command class COMMAND_CLASS_NO_OPERATION
2023-02-25 17:05:06.131 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 153: Command class COMMAND_CLASS_NO_OPERATION, endpoint 0 created
2023-02-25 17:05:06.131 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 153: Version = 1, version set. Enabling extra functionality.
2023-02-25 17:05:06.131 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 153: Adding command class COMMAND_CLASS_NO_OPERATION to the list of supported command classes.
2023-02-25 17:05:06.131 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 153: Creating new instance of command class COMMAND_CLASS_BASIC
2023-02-25 17:05:06.131 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 153: Command class COMMAND_CLASS_BASIC, endpoint 0 created
2023-02-25 17:05:06.131 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 153: Adding command class COMMAND_CLASS_BASIC to the list of supported command classes.
2023-02-25 17:05:06.132 [DEBUG] [e.internal.protocol.ZWaveTransaction] - TID 238: Transaction COMPLETED
2023-02-25 17:05:06.132 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 255: Response processed after 5ms
2023-02-25 17:05:06.132 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 255: TID 238: Transaction completed
2023-02-25 17:05:06.132 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 255: notifyTransactionResponse TID:238 DONE
2023-02-25 17:05:06.132 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2023-02-25 17:05:06.132 [DEBUG] [nal.protocol.ZWaveTransactionManager] - TID 238: Transaction event listener: DONE: DONE -> UNINTIALIZED
2023-02-25 17:05:06.132 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2023-02-25 17:05:06.132 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 05 00 4A 05 00 B5
2023-02-25 17:05:06.132 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 153: Node Init response (0) org.openhab.binding.zwave.internal.protocol.ZWaveTransactionResponse@708f9c59
2023-02-25 17:05:06.132 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 255: Sending REQUEST Message = 01 05 00 4A 05 00 B5
2023-02-25 17:05:06.132 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 153: Node Init transaction completed with response COMPLETE
2023-02-25 17:05:07.134 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 153: Is awake with 0 messages in the queue, state IDENTIFY_NODE
2023-02-25 17:05:07.134 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - awakeMax for this Timer Task 20 in 0.5 second intervals
2023-02-25 17:05:07.134 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 153: Start sleep timer with 500ms interval
2023-02-25 17:05:07.135 [DEBUG] [ve.internal.protocol.ZWaveController] - NODE 153: Node Status event - Node is AWAKE
2023-02-25 17:05:07.135 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 153: Node advancer - advancing to SECURITY_REPORT
2023-02-25 17:05:07.135 [DEBUG] [mmandclass.ZWaveSecurityCommandClass] - NODE 153: Updated networkKey
2023-02-25 17:05:07.135 [DEBUG] [mmandclass.ZWaveSecurityCommandClass] - NODE 153: setupNetworkKey useSchemeZero=false
2023-02-25 17:05:07.136 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 153: Skipping secure inclusion
2023-02-25 17:05:07.136 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 153: Node advancer - advancing to MANUFACTURER
2023-02-25 17:05:07.136 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 153: Node advancer: MANUFACTURER - send ManufacturerSpecific
2023-02-25 17:05:07.136 [DEBUG] [WaveManufacturerSpecificCommandClass] - NODE 153: Creating new message for command MANUFACTURER_SPECIFIC_GET
2023-02-25 17:05:07.136 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 153: ZWaveCommandClassTransactionPayload - send to node
2023-02-25 17:05:07.136 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 153: SECURITY NOT required on COMMAND_CLASS_MANUFACTURER_SPECIFIC
2023-02-25 17:05:07.136 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 153: Command Class COMMAND_CLASS_MANUFACTURER_SPECIFIC is NOT required to be secured
2023-02-25 17:05:07.136 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 153: sendTransaction org.openhab.binding.zwave.internal.protocol.transaction.ZWaveCommandClassTransactionPayload@c96251
2023-02-25 17:05:07.137 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 153: Bump transaction 241 priority from Config to Immediate
2023-02-25 17:05:07.137 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 153: Adding to device queue
2023-02-25 17:05:07.137 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 153: Added 241 to queue - size 37
2023-02-25 17:05:07.137 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2023-02-25 17:05:07.635 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 153: WakeupTimerTask 1 Messages waiting, state MANUFACTURER count 1
2023-02-25 17:05:08.135 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 153: WakeupTimerTask 1 Messages waiting, state MANUFACTURER count 2
2023-02-25 17:05:08.635 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 153: WakeupTimerTask 1 Messages waiting, state MANUFACTURER count 3
2023-02-25 17:05:09.135 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 153: WakeupTimerTask 1 Messages waiting, state MANUFACTURER count 4
2023-02-25 17:05:09.136 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2023-02-25 17:05:09.636 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 153: WakeupTimerTask 1 Messages waiting, state MANUFACTURER count 5
2023-02-25 17:05:10.136 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 153: WakeupTimerTask 1 Messages waiting, state MANUFACTURER count 6
2023-02-25 17:05:10.635 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 153: WakeupTimerTask 1 Messages waiting, state MANUFACTURER count 7
2023-02-25 17:05:11.133 [DEBUG] [sactionManager$ZWaveTransactionTimer] - NODE 255: TID 240: Timeout at state WAIT_REQUEST. 3 retries remaining.
2023-02-25 17:05:11.133 [DEBUG] [sactionManager$ZWaveTransactionTimer] - TID 240: Transaction is current transaction, so clearing!!!!!
2023-02-25 17:05:11.133 [DEBUG] [e.internal.protocol.ZWaveTransaction] - TID 240: Transaction CANCELLED
2023-02-25 17:05:11.133 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 255: notifyTransactionResponse TID:240 CANCELLED
2023-02-25 17:05:11.134 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2023-02-25 17:05:11.134 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 09 00 13 99 02 72 04 25 69 44
2023-02-25 17:05:11.134 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 153: Sending REQUEST Message = 01 09 00 13 99 02 72 04 25 69 44
2023-02-25 17:05:11.136 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - Message SENT
2023-02-25 17:05:11.136 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 06
2023-02-25 17:05:11.136 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage started: TID 241: [WAIT_RESPONSE] priority=Immediate, requiresResponse=true, callback: 105
2023-02-25 17:05:11.136 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2023-02-25 17:05:11.136 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 153: WakeupTimerTask 1 Messages waiting, state MANUFACTURER count 8
2023-02-25 17:05:11.136 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2023-02-25 17:05:11.136 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 241: [WAIT_RESPONSE] priority=Immediate, requiresResponse=true, callback: 105
2023-02-25 17:05:11.136 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg: ACK
2023-02-25 17:05:11.136 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2023-02-25 17:05:11.136 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2023-02-25 17:05:11.143 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 04 01 13 01 E8
2023-02-25 17:05:11.143 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2023-02-25 17:05:11.143 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2023-02-25 17:05:11.144 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 241: [WAIT_RESPONSE] priority=Immediate, requiresResponse=true, callback: 105
2023-02-25 17:05:11.144 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 1
2023-02-25 17:05:11.144 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: TID 241: [WAIT_RESPONSE] priority=Immediate, requiresResponse=true, callback: 105
2023-02-25 17:05:11.144 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2023-02-25 17:05:11.144 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 153: sentData successfully placed on stack.
2023-02-25 17:05:11.144 [DEBUG] [nal.protocol.ZWaveTransactionManager] - TID 241: Advanced to WAIT_REQUEST
2023-02-25 17:05:11.144 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 153: TID 241: Transaction not completed
2023-02-25 17:05:11.144 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2023-02-25 17:05:11.144 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2023-02-25 17:05:11.159 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 18 00 13 69 00 00 02 00 BE 7F 7F 7F 7F 00 00 04 00 00 00 00 03 01 00 00 27
2023-02-25 17:05:11.160 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=SendData[19], type=Request[0], dest=0, callback=105, payload=69 00 00 02 00 BE 7F 7F 7F 7F 00 00 04 00 00 00 00 03 01 00 00
2023-02-25 17:05:11.160 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=SendData[19], type=Request[0], dest=0, callback=105, payload=69 00 00 02 00 BE 7F 7F 7F 7F 00 00 04 00 00 00 00 03 01 00 00
2023-02-25 17:05:11.160 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 241: [WAIT_REQUEST] priority=Immediate, requiresResponse=true, callback: 105
2023-02-25 17:05:11.160 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 1
2023-02-25 17:05:11.160 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: TID 241: [WAIT_REQUEST] priority=Immediate, requiresResponse=true, callback: 105
2023-02-25 17:05:11.160 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking TID 241: (Callback 105)
2023-02-25 17:05:11.160 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Callback match!
2023-02-25 17:05:11.160 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Correlated to TID 241: callback 105
2023-02-25 17:05:11.160 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=SendData[19], type=Request[0], dest=0, callback=105, payload=69 00 00 02 00 BE 7F 7F 7F 7F 00 00 04 00 00 00 00 03 01 00 00
2023-02-25 17:05:11.161 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 153: SendData Request. CallBack ID = 105, Status = Transmission complete and ACK received(0)
2023-02-25 17:05:11.161 [DEBUG] [nal.protocol.ZWaveTransactionManager] - TID 241: Advanced to WAIT_DATA
2023-02-25 17:05:11.161 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 153: TID 241: Transaction not completed
2023-02-25 17:05:11.161 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2023-02-25 17:05:11.161 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2023-02-25 17:05:11.171 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 10 00 04 00 99 08 72 05 02 7A 70 00 E0 03 BE 00 58
2023-02-25 17:05:11.171 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=153, callback=0, payload=00 99 08 72 05 02 7A 70 00 E0 03 BE 00
2023-02-25 17:05:11.172 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=153, callback=0, payload=00 99 08 72 05 02 7A 70 00 E0 03 BE 00
2023-02-25 17:05:11.172 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2023-02-25 17:05:11.172 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 153: Application Command Request (ALIVE:MANUFACTURER)
2023-02-25 17:05:11.172 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 153: Incoming command class COMMAND_CLASS_MANUFACTURER_SPECIFIC, endpoint 0
2023-02-25 17:05:11.172 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 153: SECURITY NOT required on COMMAND_CLASS_MANUFACTURER_SPECIFIC
2023-02-25 17:05:11.172 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 153: Received COMMAND_CLASS_MANUFACTURER_SPECIFIC V0 MANUFACTURER_SPECIFIC_REPORT
2023-02-25 17:05:11.172 [DEBUG] [WaveManufacturerSpecificCommandClass] - NODE 153: Manufacturer ID = 0x27a
2023-02-25 17:05:11.172 [DEBUG] [WaveManufacturerSpecificCommandClass] - NODE 153: Device Type = 0x7000
2023-02-25 17:05:11.172 [DEBUG] [WaveManufacturerSpecificCommandClass] - NODE 153: Device ID = 0xe003
2023-02-25 17:05:11.173 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 153: Commands processed 1.
2023-02-25 17:05:11.173 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 153: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@58b6ac17.
2023-02-25 17:05:11.173 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 153: Command verified org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@58b6ac17.
2023-02-25 17:05:11.173 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 153: notifyTransactionResponse TID:241 DONE
2023-02-25 17:05:11.173 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 1
2023-02-25 17:05:11.173 [DEBUG] [nal.protocol.ZWaveTransactionManager] - TID 241: Transaction event listener: DONE: DONE -> UNINTIALIZED
2023-02-25 17:05:11.173 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2023-02-25 17:05:11.173 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2023-02-25 17:05:11.173 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 153: Node Init response (0) org.openhab.binding.zwave.internal.protocol.ZWaveTransactionResponse@7439e04e
2023-02-25 17:05:11.173 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 153: Node Init transaction completed with response COMPLETE
2023-02-25 17:05:11.173 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 153: Node advancer - advancing to APP_VERSION
2023-02-25 17:05:11.174 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 153: Node advancer: APP_VERSION - send VersionMessage
2023-02-25 17:05:11.174 [DEBUG] [ommandclass.ZWaveVersionCommandClass] - NODE 153: Creating new message for command VERSION_GET
2023-02-25 17:05:11.174 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 153: ZWaveCommandClassTransactionPayload - send to node
2023-02-25 17:05:11.174 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 153: SECURITY NOT required on COMMAND_CLASS_VERSION
2023-02-25 17:05:11.174 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 153: Command Class COMMAND_CLASS_VERSION is NOT required to be secured
2023-02-25 17:05:11.174 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 153: sendTransaction org.openhab.binding.zwave.internal.protocol.transaction.ZWaveCommandClassTransactionPayload@519d692d
2023-02-25 17:05:11.174 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 153: Bump transaction 243 priority from Config to Immediate
2023-02-25 17:05:11.174 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2023-02-25 17:05:11.175 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 09 00 13 20 02 25 02 25 6A AF
2023-02-25 17:05:11.229 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: TID 243: [WAIT_RESPONSE] priority=Immediate, requiresResponse=true, callback: 107
2023-02-25 17:05:11.229 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2023-02-25 17:05:11.229 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 153: sentData successfully placed on stack.
2023-02-25 17:05:11.229 [DEBUG] [nal.protocol.ZWaveTransactionManager] - TID 243: Advanced to WAIT_REQUEST
2023-02-25 17:05:11.230 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 153: TID 243: Transaction not completed
2023-02-25 17:05:11.230 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2023-02-25 17:05:11.230 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2023-02-25 17:05:11.245 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 18 00 13 6B 00 00 02 00 BE 7F 7F 7F 7F 00 00 03 00 00 00 00 03 01 00 00 22
2023-02-25 17:05:11.246 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=SendData[19], type=Request[0], dest=0, callback=107, payload=6B 00 00 02 00 BE 7F 7F 7F 7F 00 00 03 00 00 00 00 03 01 00 00
2023-02-25 17:05:11.246 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=SendData[19], type=Request[0], dest=0, callback=107, payload=6B 00 00 02 00 BE 7F 7F 7F 7F 00 00 03 00 00 00 00 03 01 00 00
2023-02-25 17:05:11.246 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 243: [WAIT_REQUEST] priority=Immediate, requiresResponse=true, callback: 107
2023-02-25 17:05:11.246 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 1
2023-02-25 17:05:11.246 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: TID 243: [WAIT_REQUEST] priority=Immediate, requiresResponse=true, callback: 107
2023-02-25 17:05:11.246 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking TID 243: (Callback 107)
2023-02-25 17:05:11.246 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Callback match!
2023-02-25 17:05:11.247 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Correlated to TID 243: callback 107
2023-02-25 17:05:11.247 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=SendData[19], type=Request[0], dest=0, callback=107, payload=6B 00 00 02 00 BE 7F 7F 7F 7F 00 00 03 00 00 00 00 03 01 00 00
2023-02-25 17:05:11.247 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 153: SendData Request. CallBack ID = 107, Status = Transmission complete and ACK received(0)
2023-02-25 17:05:11.247 [DEBUG] [nal.protocol.ZWaveTransactionManager] - TID 243: Advanced to WAIT_DATA
2023-02-25 17:05:11.247 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 153: TID 243: Transaction not completed
2023-02-25 17:05:11.247 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2023-02-25 17:05:11.247 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2023-02-25 17:05:11.257 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 11 00 04 00 99 09 86 12 03 07 0D 01 14 01 00 BE 00 4D
2023-02-25 17:05:11.258 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=153, callback=0, payload=00 99 09 86 12 03 07 0D 01 14 01 00 BE 00
2023-02-25 17:05:11.258 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=153, callback=0, payload=00 99 09 86 12 03 07 0D 01 14 01 00 BE 00
2023-02-25 17:05:11.258 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2023-02-25 17:05:11.258 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 153: Application Command Request (ALIVE:APP_VERSION)
2023-02-25 17:05:11.258 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 153: Incoming command class COMMAND_CLASS_VERSION, endpoint 0
2023-02-25 17:05:11.258 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 153: SECURITY NOT required on COMMAND_CLASS_VERSION
2023-02-25 17:05:11.258 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 153: Received COMMAND_CLASS_VERSION V0 VERSION_REPORT
2023-02-25 17:05:11.258 [DEBUG] [ommandclass.ZWaveVersionCommandClass] - NODE 153: Process Version Report
2023-02-25 17:05:11.259 [DEBUG] [ommandclass.ZWaveVersionCommandClass] - NODE 153: Library Type = 3 (Slave Enhanced)
2023-02-25 17:05:11.259 [DEBUG] [ommandclass.ZWaveVersionCommandClass] - NODE 153: Protocol Version = 7.13
2023-02-25 17:05:11.259 [DEBUG] [ommandclass.ZWaveVersionCommandClass] - NODE 153: Application Version = 1.20
2023-02-25 17:05:11.259 [DEBUG] [ommandclass.ZWaveVersionCommandClass] - NODE 153: Hardware Version = 1
2023-02-25 17:05:11.259 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 153: Commands processed 1.
2023-02-25 17:05:11.259 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 153: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@184fdf2b.
2023-02-25 17:05:11.259 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 153: Command verified org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@184fdf2b.
2023-02-25 17:05:11.259 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 153: notifyTransactionResponse TID:243 DONE
2023-02-25 17:05:11.259 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 1
2023-02-25 17:05:11.260 [DEBUG] [nal.protocol.ZWaveTransactionManager] - TID 243: Transaction event listener: DONE: DONE -> UNINTIALIZED
2023-02-25 17:05:11.260 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2023-02-25 17:05:11.260 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2023-02-25 17:05:11.260 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2023-02-25 17:05:11.260 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 153: Node Init response (0) org.openhab.binding.zwave.internal.protocol.ZWaveTransactionResponse@1fad8fd5
2023-02-25 17:05:11.260 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 153: Node Init transaction completed with response COMPLETE
2023-02-25 17:05:11.260 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 0A 00 13 6F 03 32 01 18 25 6C E8
2023-02-25 17:05:11.260 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 153: Node advancer - advancing to DISCOVERY_COMPLETE
2023-02-25 17:05:11.260 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 153: Device discovery completed
2023-02-25 17:05:11.260 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - Message SENT
2023-02-25 17:05:11.260 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage started: TID 242: [WAIT_RESPONSE] priority=Get, requiresResponse=true, callback: 108
2023-02-25 17:05:11.260 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 153: Device discovery resolved to thingType zwave:zooz_zse43_00_000
2023-02-25 17:05:11.261 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 06
2023-02-25 17:05:11.261 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2023-02-25 17:05:11.262 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2023-02-25 17:05:11.262 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 242: [WAIT_RESPONSE] priority=Get, requiresResponse=true, callback: 108
2023-02-25 17:05:11.262 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg: ACK
2023-02-25 17:05:11.262 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2023-02-25 17:05:11.262 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2023-02-25 17:05:11.263 [DEBUG] [l.initialization.ZWaveNodeSerializer] - NODE 153: Serialise aborted as static stages not complete
2023-02-25 17:05:11.264 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 153: Node advancer - advancing to VERSION
2023-02-25 17:05:11.264 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 153: Node advancer: VERSION - checking COMMAND_CLASS_ASSOCIATION_GRP_INFO, version is 0
2023-02-25 17:05:11.264 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 153: Node advancer: VERSION - queued COMMAND_CLASS_ASSOCIATION_GRP_INFO
2023-02-25 17:05:11.264 [DEBUG] [ommandclass.ZWaveVersionCommandClass] - NODE 153: Creating new message for application command VERSION_COMMAND_CLASS_GET command class COMMAND_CLASS_ASSOCIATION_GRP_INFO
2023-02-25 17:05:11.264 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 153: ZWaveCommandClassTransactionPayload - send to node
2023-02-25 17:05:11.264 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 153: SECURITY NOT required on COMMAND_CLASS_VERSION
2023-02-25 17:05:11.264 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 153: Command Class COMMAND_CLASS_VERSION is NOT required to be secured
2023-02-25 17:05:11.265 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 153: sendTransaction org.openhab.binding.zwave.internal.protocol.transaction.ZWaveCommandClassTransactionPayload@54bdbd9b
2023-02-25 17:05:11.265 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 153: Bump transaction 245 priority from Config to Immediate
2023-02-25 17:05:11.265 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 153: Adding to device queue
2023-02-25 17:05:11.265 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 153: Added 245 to queue - size 37
2023-02-25 17:05:11.265 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2023-02-25 17:05:11.267 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 04 01 13 01 E8
2023-02-25 17:05:11.268 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2023-02-25 17:05:11.268 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2023-02-25 17:05:11.268 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 242: [WAIT_RESPONSE] priority=Get, requiresResponse=true, callback: 108
2023-02-25 17:05:11.268 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 1
2023-02-25 17:05:11.268 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: TID 242: [WAIT_RESPONSE] priority=Get, requiresResponse=true, callback: 108
2023-02-25 17:05:11.268 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2023-02-25 17:05:11.269 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 111: sentData successfully placed on stack.
2023-02-25 17:05:11.269 [DEBUG] [nal.protocol.ZWaveTransactionManager] - TID 242: Advanced to WAIT_REQUEST
2023-02-25 17:05:11.269 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 111: TID 242: Transaction not completed
2023-02-25 17:05:11.269 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2023-02-25 17:05:11.269 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2023-02-25 17:05:11.290 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 18 00 13 6C 00 00 03 00 C6 7F 7F 7F 7F 00 00 03 00 00 00 00 03 01 00 00 5C
2023-02-25 17:05:11.290 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=SendData[19], type=Request[0], dest=0, callback=108, payload=6C 00 00 03 00 C6 7F 7F 7F 7F 00 00 03 00 00 00 00 03 01 00 00
2023-02-25 17:05:11.290 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=SendData[19], type=Request[0], dest=0, callback=108, payload=6C 00 00 03 00 C6 7F 7F 7F 7F 00 00 03 00 00 00 00 03 01 00 00
2023-02-25 17:05:11.290 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 242: [WAIT_REQUEST] priority=Get, requiresResponse=true, callback: 108
2023-02-25 17:05:11.290 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 1
2023-02-25 17:05:11.291 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: TID 242: [WAIT_REQUEST] priority=Get, requiresResponse=true, callback: 108
2023-02-25 17:05:11.291 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking TID 242: (Callback 108)
2023-02-25 17:05:11.291 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Callback match!
2023-02-25 17:05:11.291 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Correlated to TID 242: callback 108
2023-02-25 17:05:11.291 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=SendData[19], type=Request[0], dest=0, callback=108, payload=6C 00 00 03 00 C6 7F 7F 7F 7F 00 00 03 00 00 00 00 03 01 00 00
2023-02-25 17:05:11.291 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 111: SendData Request. CallBack ID = 108, Status = Transmission complete and ACK received(0)
2023-02-25 17:05:11.291 [DEBUG] [nal.protocol.ZWaveTransactionManager] - TID 242: Advanced to WAIT_DATA
2023-02-25 17:05:11.291 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 111: TID 242: Transaction not completed
2023-02-25 17:05:11.291 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2023-02-25 17:05:11.291 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2
2023-02-25 17:05:59.953 [DEBUG] [ve.internal.protocol.ZWaveController] - Event listener added.
2023-02-25 17:05:59.953 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 153: Initialising Thing Node...
2023-02-25 17:05:59.953 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 153: Initialising cmd channel zwave:device:5eab90482f:node153:sensor_binary for OnOffType
2023-02-25 17:05:59.953 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 153: Initialising state channel zwave:device:5eab90482f:node153:sensor_binary for OnOffType
2023-02-25 17:05:59.954 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 153: Initialising cmd channel zwave:device:5eab90482f:node153:alarm_access for OnOffType
2023-02-25 17:05:59.954 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 153: Initialising state channel zwave:device:5eab90482f:node153:alarm_access for OnOffType
2023-02-25 17:05:59.954 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 153: Initialising cmd channel zwave:device:5eab90482f:node153:battery-level for PercentType
2023-02-25 17:05:59.954 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 153: Initialising state channel zwave:device:5eab90482f:node153:battery-level for PercentType
2023-02-25 17:05:59.954 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 153: Initialising cmd channel zwave:device:5eab90482f:node153:alarm_burglar for OnOffType
2023-02-25 17:05:59.954 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 153: Initialising state channel zwave:device:5eab90482f:node153:alarm_burglar for OnOffType
2023-02-25 17:05:59.954 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 153: Initialising cmd channel zwave:device:5eab90482f:node153:sensor_door for OpenClosedType
2023-02-25 17:05:59.954 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 153: Initialising state channel zwave:device:5eab90482f:node153:sensor_door for OpenClosedType
2023-02-25 17:05:59.954 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 153: Polling initialised at 86400 seconds - start in 79315200 milliseconds.
2023-02-25 17:05:59.954 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 153: Device initialisation complete.
2023-02-25 17:06:18.532 [WARN ] [core.thing.internal.ThingManagerImpl] - A thing handler factory claims to support 'mqtt:homeassistant_34151343d677' for thing 'mqtt:homeassistant_34151343d677:748306a9d9:34151343d677' for more than 120s, but the thing type can't be found in the registry. This should be fixed in the binding.
2023-02-25 17:07:46.924 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 153: Application Command Request (ALIVE:STATIC_VALUES)
2023-02-25 17:07:46.924 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 153: Incoming command class COMMAND_CLASS_ALARM, endpoint 0
2023-02-25 17:07:46.924 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 153: SECURITY not supported
2023-02-25 17:07:46.924 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 153: Received COMMAND_CLASS_ALARM V8 NOTIFICATION_SUPPORTED_REPORT
2023-02-25 17:07:46.924 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 153: NOTIFICATION_SUPPORTED_REPORT reports V1 ALARM support
2023-02-25 17:07:46.925 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 153: Adding new alarm type ACCESS_CONTROL(6)
2023-02-25 17:07:46.925 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 153: Adding new alarm type BURGLAR(7)
2023-02-25 17:07:46.925 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 153: Commands processed 1.
2023-02-25 17:07:46.925 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 153: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@16feca3d.
2023-02-25 17:07:46.925 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 153: Command verified org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@16feca3d.
2023-02-25 17:07:46.925 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 153: notifyTransactionResponse TID:354 DONE
2023-02-25 17:07:46.925 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 153: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2023-02-25 17:07:46.925 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 1
2023-02-25 17:07:46.925 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2023-02-25 17:07:46.926 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2023-02-25 17:07:46.926 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2023-02-25 17:07:46.926 [DEBUG] [nal.protocol.ZWaveTransactionManager] - TID 354: Transaction event listener: DONE: DONE -> UNINTIALIZED
2023-02-25 17:07:46.926 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 0A 00 13 99 03 8E 02 02 25 DD 0A
2023-02-25 17:07:46.926 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 153: Node Init response (0) org.openhab.binding.zwave.internal.protocol.ZWaveTransactionResponse@5a826020
2023-02-25 17:07:46.926 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 153: Node Init transaction completed with response COMPLETE
2023-02-25 17:07:46.926 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 153: Sending REQUEST Message = 01 0A 00 13 99 03 8E 02 02 25 DD 0A
2023-02-25 17:07:46.926 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 153: Node advancer: STATIC_VALUES - checking COMMAND_CLASS_VERSION
2023-02-25 17:07:46.926 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 153: Node advancer: STATIC_VALUES - checking COMMAND_CLASS_FIRMWARE_UPDATE_MD
2023-02-25 17:07:46.926 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - Message SENT
2023-02-25 17:07:46.926 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 153: Node advancer: STATIC_VALUES - checking COMMAND_CLASS_ZWAVEPLUS_INFO
2023-02-25 17:07:46.926 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage started: TID 355: [WAIT_RESPONSE] priority=Immediate, requiresResponse=true, callback: 221
2023-02-25 17:07:46.927 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 153: Found 1 instances of COMMAND_CLASS_ZWAVEPLUS_INFO for endpoint 0
2023-02-25 17:07:46.927 [DEBUG] [ass.impl.CommandClassZwaveplusInfoV1] - Creating command message ZWAVEPLUS_INFO_GET version 1
2023-02-25 17:07:46.928 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 06
2023-02-25 17:07:46.928 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2023-02-25 17:07:46.928 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 153: SECURITY not supported
2023-02-25 17:07:46.928 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2023-02-25 17:07:46.928 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 153: Command Class COMMAND_CLASS_ZWAVEPLUS_INFO is NOT required to be secured
2023-02-25 17:07:46.928 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 355: [WAIT_RESPONSE] priority=Immediate, requiresResponse=true, callback: 221
2023-02-25 17:07:46.928 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 153: ZWaveCommandClassTransactionPayload - send to node
2023-02-25 17:07:46.928 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg: ACK
2023-02-25 17:07:46.928 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2023-02-25 17:07:46.928 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2023-02-25 17:07:46.928 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 153: sendTransaction org.openhab.binding.zwave.internal.protocol.transaction.ZWaveCommandClassTransactionPayload@38dee9d
2023-02-25 17:07:46.928 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 153: Bump transaction 356 priority from Config to Immediate
2023-02-25 17:07:46.929 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 153: Adding to device queue
2023-02-25 17:07:46.929 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 153: Added 356 to queue - size 15
2023-02-25 17:07:46.929 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2023-02-25 17:07:46.934 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 04 01 13 01 E8
2023-02-25 17:07:46.934 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2023-02-25 17:07:46.934 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2023-02-25 17:07:46.935 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 355: [WAIT_RESPONSE] priority=Immediate, requiresResponse=true, callback: 221
2023-02-25 17:07:46.935 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 1
2023-02-25 17:07:46.935 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: TID 355: [WAIT_RESPONSE] priority=Immediate, requiresResponse=true, callback: 221
2023-02-25 17:07:46.935 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2023-02-25 17:07:46.935 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 153: sentData successfully placed on stack.
2023-02-25 17:07:46.935 [DEBUG] [nal.protocol.ZWaveTransactionManager] - TID 355: Advanced to WAIT_REQUEST
2023-02-25 17:07:46.935 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 153: TID 355: Transaction not completed
2023-02-25 17:08:28.773 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2023-02-25 17:08:36.229 [ERROR] [.automation.jrule.internal.JRuleUtil] - [JRuleUtil] Error creating jar
2023-02-25 17:08:36.303 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 153: Channel zwave:device:5eab90482f:node153:sensor_binary linked - polling started.
2023-02-25 17:08:36.319 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 153: Channel zwave:device:5eab90482f:node153:battery-level linked - polling started.
2023-02-25 17:08:36.327 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 153: Channel zwave:device:5eab90482f:node153:sensor_door linked - polling started.
2023-02-25 17:08:36.336 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 153: Channel zwave:device:5eab90482f:node153:alarm_access linked - polling started.
2023-02-25 17:08:36.345 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 153: Channel zwave:device:5eab90482f:node153:alarm_burglar linked - polling started.
2023-02-25 17:08:37.910 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 11 00 04 00 99 09 71 05 00 00 00 FF 07 03 00 BE 00 4B
2023-02-25 17:08:37.910 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=153, callback=0, payload=00 99 09 71 05 00 00 00 FF 07 03 00 BE 00
2023-02-25 17:08:37.910 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=153, callback=0, payload=00 99 09 71 05 00 00 00 FF 07 03 00 BE 00
2023-02-25 17:08:37.911 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2023-02-25 17:08:37.911 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 153: Application Command Request (ALIVE:DYNAMIC_VALUES)
2023-02-25 17:08:37.911 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 153: Incoming command class COMMAND_CLASS_ALARM, endpoint 0
2023-02-25 17:08:37.911 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 153: SECURITY not supported
2023-02-25 17:08:37.911 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 153: Received COMMAND_CLASS_ALARM V8 NOTIFICATION_REPORT
2023-02-25 17:08:37.911 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 153: NOTIFICATION report - 0 = 0, event=3, status=255, plen=0
2023-02-25 17:08:37.911 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 153: Alarm Type = BURGLAR (0)
2023-02-25 17:08:37.911 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 153: Got an event from Z-Wave network: ZWaveAlarmValueEvent
2023-02-25 17:08:37.911 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 153: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_ALARM, value=255
2023-02-25 17:08:37.912 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 153: Alarm converter processing NOTIFICATION
2023-02-25 17:08:37.912 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 153: Alarm converter NOTIFICATION event is 3, type OnOffType
2023-02-25 17:08:37.912 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 153: Alarm converter NOTIFICATION event is 3, channel alarm_access is not implemented.
2023-02-25 17:08:37.912 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 153: Alarm converter NOTIFICATION event is 3, type OpenClosedType
2023-02-25 17:08:37.912 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 153: Commands processed 1.
2023-02-25 17:08:37.912 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 153: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@16dbd7c1.
2023-02-25 17:08:37.912 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2023-02-25 17:08:37.912 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2023-02-25 17:08:37.913 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2023-02-25 17:08:41.799 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 11 00 04 00 99 09 71 05 00 00 00 FF 07 00 00 BB 00 4D
2023-02-25 17:08:41.799 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=153, callback=0, payload=00 99 09 71 05 00 00 00 FF 07 00 00 BB 00
2023-02-25 17:08:41.799 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=153, callback=0, payload=00 99 09 71 05 00 00 00 FF 07 00 00 BB 00
2023-02-25 17:08:41.800 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2023-02-25 17:08:41.800 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 153: Application Command Request (ALIVE:DYNAMIC_VALUES)
2023-02-25 17:08:41.800 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 153: Incoming command class COMMAND_CLASS_ALARM, endpoint 0
2023-02-25 17:08:41.800 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 153: SECURITY not supported
2023-02-25 17:08:41.800 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 153: Received COMMAND_CLASS_ALARM V8 NOTIFICATION_REPORT
2023-02-25 17:08:41.800 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 153: NOTIFICATION report - 0 = 0, event=0, status=255, plen=0
2023-02-25 17:08:41.800 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 153: Alarm Type = BURGLAR (0)
2023-02-25 17:08:41.800 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 153: Got an event from Z-Wave network: ZWaveAlarmValueEvent
2023-02-25 17:08:41.800 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 153: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_ALARM, value=255
2023-02-25 17:08:41.800 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 153: Alarm converter processing NOTIFICATION
2023-02-25 17:08:41.801 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 153: Alarm converter NOTIFICATION event is 0, type OnOffType
2023-02-25 17:08:41.801 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 153: Alarm converter NOTIFICATION event is 0, channel alarm_access is not implemented.
2023-02-25 17:08:41.801 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 153: Alarm converter processing NOTIFICATION
2023-02-25 17:08:41.801 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 153: Updating channel state zwave:device:5eab90482f:node153:alarm_burglar to OFF [OnOffType]
2023-02-25 17:08:41.801 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 153: Alarm converter NOTIFICATION event is 0, type OpenClosedType
2023-02-25 17:08:41.802 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 153: Commands processed 1.
2023-02-25 17:08:41.802 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 153: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@45dcd03.
2023-02-25 17:08:41.802 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2023-02-25 17:08:41.802 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2023-02-25 17:08:41.802 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2023-02-25 17:08:44.859 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 0B 00 04 00 8A 03 20 01 00 D0 00 88
2023-02-25 17:08:44.859 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=138, callback=0, payload=00 8A 03 20 01 00 D0 00
2023-02-25 17:08:44.859 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=138, callback=0, payload=00 8A 03 20 01 00 D0 00
2023-02-25 17:08:44.860 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2023-02-25 17:09:53.413 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2023-02-25 17:09:58.109 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 11 00 04 00 99 09 71 05 00 00 00 FF 07 03 00 BC 00 49
2023-02-25 17:09:58.110 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=153, callback=0, payload=00 99 09 71 05 00 00 00 FF 07 03 00 BC 00
2023-02-25 17:09:58.110 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=153, callback=0, payload=00 99 09 71 05 00 00 00 FF 07 03 00 BC 00
2023-02-25 17:09:58.110 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2023-02-25 17:09:58.110 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 153: Application Command Request (ALIVE:DYNAMIC_VALUES)
2023-02-25 17:09:58.110 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 153: Incoming command class COMMAND_CLASS_ALARM, endpoint 0
2023-02-25 17:09:58.110 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 153: SECURITY not supported
2023-02-25 17:09:58.111 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 153: Received COMMAND_CLASS_ALARM V8 NOTIFICATION_REPORT
2023-02-25 17:09:58.111 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 153: NOTIFICATION report - 0 = 0, event=3, status=255, plen=0
2023-02-25 17:09:58.111 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 153: Alarm Type = BURGLAR (0)
2023-02-25 17:09:58.111 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 153: Got an event from Z-Wave network: ZWaveAlarmValueEvent
2023-02-25 17:09:58.111 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 153: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_ALARM, value=255
2023-02-25 17:09:58.111 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 153: Alarm converter processing NOTIFICATION
2023-02-25 17:09:58.111 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 153: Alarm converter NOTIFICATION event is 3, type OnOffType
2023-02-25 17:09:58.111 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 153: Alarm converter NOTIFICATION event is 3, channel alarm_access is not implemented.
2023-02-25 17:09:58.112 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 153: Alarm converter NOTIFICATION event is 3, type OpenClosedType
2023-02-25 17:09:58.112 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 153: Commands processed 1.
2023-02-25 17:09:58.112 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 153: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@2fccdd11.
2023-02-25 17:09:58.112 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2023-02-25 17:09:58.112 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2023-02-25 17:09:58.112 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2023-02-25 17:09:58.771 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 12 00 04 00 93 0A 32 02 21 74 00 00 00 00 00 00 C9 00 DC
2023-02-25 17:09:58.771 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=147, callback=0, payload=00 93 0A 32 02 21 74 00 00 00 00 00 00 C9 00
2023-02-25 17:09:58.771 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=147, callback=0, payload=00 93 0A 32 02 21 74 00 00 00 00 00 00 C9 00
2023-02-25 17:09:58.773 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2023-02-25 17:10:03.169 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 11 00 04 00 99 09 71 05 00 00 00 FF 07 00 00 BB 00 4D
2023-02-25 17:10:03.170 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=153, callback=0, payload=00 99 09 71 05 00 00 00 FF 07 00 00 BB 00
2023-02-25 17:10:03.170 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=153, callback=0, payload=00 99 09 71 05 00 00 00 FF 07 00 00 BB 00
2023-02-25 17:10:03.170 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2023-02-25 17:10:03.170 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 153: Application Command Request (ALIVE:DYNAMIC_VALUES)
2023-02-25 17:10:03.170 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 153: Incoming command class COMMAND_CLASS_ALARM, endpoint 0
2023-02-25 17:10:03.170 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 153: SECURITY not supported
2023-02-25 17:10:03.171 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 153: Received COMMAND_CLASS_ALARM V8 NOTIFICATION_REPORT
2023-02-25 17:10:03.171 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 153: NOTIFICATION report - 0 = 0, event=0, status=255, plen=0
2023-02-25 17:10:03.171 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 153: Alarm Type = BURGLAR (0)
2023-02-25 17:10:03.171 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 153: Got an event from Z-Wave network: ZWaveAlarmValueEvent
2023-02-25 17:10:03.171 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 153: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_ALARM, value=255
2023-02-25 17:10:03.171 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 153: Alarm converter processing NOTIFICATION
2023-02-25 17:10:03.171 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 153: Alarm converter NOTIFICATION event is 0, type OnOffType
2023-02-25 17:10:03.171 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 153: Alarm converter NOTIFICATION event is 0, channel alarm_access is not implemented.
2023-02-25 17:10:03.171 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 153: Updating channel state zwave:device:5eab90482f:node153:alarm_burglar to OFF [OnOffType]
2023-02-25 17:10:03.172 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 153: Alarm converter processing NOTIFICATION
2023-02-25 17:10:03.172 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 153: Alarm converter NOTIFICATION event is 0, type OpenClosedType
2023-02-25 17:10:03.172 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 153: Commands processed 1.
2023-02-25 17:10:03.172 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 153: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@648a1f56.
2023-02-25 17:10:03.172 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2023-02-25 17:10:03.172 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2023-02-25 17:10:03.172 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2023-02-25 17:10:13.752 [INFO ] [port.EventAdminConfigurationNotifier] - Sending Event Admin notification (configuration successful) to org/ops4j/pax/logging/Configuration
Did you delete the thing (device) not exclude and then rescan? That is usually needed to pick up new channels. There should be an alarm tamper channel, not alarm burglar.
Edit: Read log now your zwave jar does not have the fix. You need the one with #1851 try tomorrow. It was just merged
Thank you for your help and updating the database. I just updated my docker image to the current snapshot again today and the device is now detecting vibrations!
