ZSE43 Zooz Vibration/Tilt sensor does not sense vibrations (Binary Sensor)
  • Platform information:
    • Hardware: Synology DS920+
    • OS: DSM 7.1.1-42962 Update 1
    • Java Runtime Environment: Docker
    • openHAB version: 3.4.1
  • Issue of the topic: ZSE43 Vibration Sensor Not properly detecting vibrations. When the device is added to my stick and I create an item for the Binary sensor it has a state of non-triggered and normal vibrations will not trigger it. I can get it to trigger if I play around with it and reinitialize it on the device page a few times however this may just be an anomaly and have little to do to help the issue…
    I have posted my config and trimmed down the log files as best I could to just show node 150’s (the ZSE43) Binary sensor activity. These logs were generated after I excluded and factory reset the device. I hope I did not exclude anything that may help. I do have the entire log saved. Currently, the device is in a triggered state. I did notice that it indicated that the sensor type was unknown.
    Paper UI Config:
label: Dryer Sensor
thingTypeUID: zwave:zooz_zse43_00_000
configuration:
  wakeup_interval: 21600
  group_1:
    - controller
  group_3:
    - controller
  group_2: []
  config_1_1: 3
  config_2_1: 5
  action_reinit: false
  config_7_1: 2
  wakeup_node: 1
  config_5_4: 0
  config_6_3: 0
  config_8_1: 3
  config_9_1: 3
  config_3_1: 20
  config_4_1: 0
  node_id: 150
bridgeUID: zwave:serial_zstick:5eab90482f
Zwave Config:
  <homeId>0xe2bc20fb</homeId>
  <nodeId>150</nodeId>
  <version>4</version>
  <manufacturer>0x27a</manufacturer>
  <deviceId>0xe003</deviceId>
  <deviceType>0x7000</deviceType>
  <listening>false</listening>
  <frequentlyListening>false</frequentlyListening>
  <routing>true</routing>
  <security>false</security>
  <beaming>true</beaming>
  <maxBaudRate>40000</maxBaudRate>
  <sleepDelay>500</sleepDelay>
  <nodeInformationFrame>
    <commandClass>COMMAND_CLASS_ZWAVEPLUS_INFO</commandClass>
    <commandClass>COMMAND_CLASS_ASSOCIATION</commandClass>
    <commandClass>COMMAND_CLASS_MULTI_CHANNEL_ASSOCIATION</commandClass>
    <commandClass>COMMAND_CLASS_ASSOCIATION_GRP_INFO</commandClass>
    <commandClass>COMMAND_CLASS_TRANSPORT_SERVICE</commandClass>
    <commandClass>COMMAND_CLASS_VERSION</commandClass>
    <commandClass>COMMAND_CLASS_MANUFACTURER_SPECIFIC</commandClass>
    <commandClass>COMMAND_CLASS_DEVICE_RESET_LOCALLY</commandClass>
    <commandClass>COMMAND_CLASS_POWERLEVEL</commandClass>
    <commandClass>COMMAND_CLASS_BATTERY</commandClass>
    <commandClass>COMMAND_CLASS_SECURITY_2</commandClass>
    <commandClass>COMMAND_CLASS_ALARM</commandClass>
    <commandClass>COMMAND_CLASS_INDICATOR</commandClass>
    <commandClass>COMMAND_CLASS_SENSOR_BINARY</commandClass>
    <commandClass>COMMAND_CLASS_CONFIGURATION</commandClass>
    <commandClass>COMMAND_CLASS_WAKE_UP</commandClass>
    <commandClass>COMMAND_CLASS_SUPERVISION</commandClass>
    <commandClass>COMMAND_CLASS_FIRMWARE_UPDATE_MD</commandClass>
  </nodeInformationFrame>
  <associationGroups class="concurrent-hash-map">
    <entry>
      <int>1</int>
      <associationGroup>
        <index>1</index>
        <maxNodes>0</maxNodes>
        <name>Lifeline</name>
        <profile1>0x0</profile1>
        <profile2>0x1</profile2>
        <commands>
        </commands>
        <associations>
          <associationMember>
            <node>1</node>
          </associationMember>
        </associations>
      </associationGroup>
    </entry>
    <entry>
      <int>2</int>
      <associationGroup>
        <index>2</index>
        <name>Basic Set for contact sensor</name>
        <profile1>0x71</profile1>
        <profile2>0x6</profile2>
        <commands>
          <commandClass>COMMAND_CLASS_BASIC</commandClass>
        </commands>
        <associations/>
      </associationGroup>
    </entry>
    <entry>
      <int>3</int>
      <associationGroup>
        <index>3</index>
        <name>Basic Set for shock sensor</name>
        <profile2>0x7</profile2>
        <commands>
        </commands>
        <associations>
          <associationMember>
            <node>1</node>
        </associations>
      </associationGroup>
    </entry>
  </associationGroups>
  <endpoints class="concurrent-hash-map">
    <entry>
      <int>0</int>
      <endPoint>
        <deviceClass>
          <basicDeviceClass>BASIC_TYPE_ROUTING_SLAVE</basicDeviceClass>
          <genericDeviceClass>GENERIC_TYPE_SENSOR_NOTIFICATION</genericDeviceClass>
          <specificDeviceClass>SPECIFIC_TYPE_NOTIFICATION_SENSOR</specificDeviceClass>
        </deviceClass>
        <endpointId>0</endpointId>
        <secureCommandClasses/>
        <supportedCommandClasses class="concurrent-hash-map">
          <entry>
            <commandClass>COMMAND_CLASS_NO_OPERATION</commandClass>
            <COMMAND__CLASS__NO__OPERATION>
              <version>1</version>
              <instances>1</instances>
              <control>false</control>
              <versionSupported>1</versionSupported>
            </COMMAND__CLASS__NO__OPERATION>
          </entry>
          <entry>
            <COMMAND__CLASS__BASIC>
              <version>0</version>
              <versionSupported>0</versionSupported>
              <isGetSupported>true</isGetSupported>
            </COMMAND__CLASS__BASIC>
          </entry>
          <entry>
            <COMMAND__CLASS__SENSOR__BINARY>
              <version>2</version>
              <versionSupported>2</versionSupported>
              <types>
                <binarySensorType>TAMPER</binarySensorType>
              </types>
            </COMMAND__CLASS__SENSOR__BINARY>
          </entry>
          <entry>
            <COMMAND__CLASS__ASSOCIATION__GRP__INFO>
              <versionSupported>3</versionSupported>
              <autoSubscribeGroups>
                <int>1</int>
              </autoSubscribeGroups>
            </COMMAND__CLASS__ASSOCIATION__GRP__INFO>
          </entry>
          <entry>
            <COMMAND__CLASS__DEVICE__RESET__LOCALLY>
            </COMMAND__CLASS__DEVICE__RESET__LOCALLY>
          </entry>
          <entry>
            <COMMAND__CLASS__ZWAVEPLUS__INFO>
              <zwPlusVersion>2</zwPlusVersion>
              <zwPlusRole>ROLE_TYPE_SLAVE_SLEEPING_REPORTING</zwPlusRole>
              <zwPlusNodeType>NODE_TYPE_ZWAVEPLUS_NODE</zwPlusNodeType>
            </COMMAND__CLASS__ZWAVEPLUS__INFO>
          </entry>
          <entry>
            <COMMAND__CLASS__CONFIGURATION>
              <versionSupported>4</versionSupported>
              <configParameters>
                <entry>
                  <int>1</int>
                  <configurationParameter>
                    <index>1</index>
                    <size>1</size>
                    <value>3</value>
                    <readOnly>false</readOnly>
                    <writeOnly>false</writeOnly>
                  </configurationParameter>
                </entry>
                <entry>
                  <int>3</int>
                    <index>3</index>
                    <size>1</size>
                    <value>20</value>
                </entry>
                <entry>
                  <int>4</int>
                    <index>4</index>
                    <size>1</size>
                    <value>0</value>
                </entry>
                <entry>
                  <int>5</int>
                    <index>5</index>
                    <size>2</size>
                    <value>0</value>
                </entry>
                <entry>
                  <int>6</int>
                    <index>6</index>
                    <size>2</size>
                    <value>0</value>
                </entry>
                <entry>
                  <int>7</int>
                    <index>7</index>
                    <size>1</size>
                    <value>2</value>
                </entry>
                <entry>
                  <int>8</int>
                    <index>8</index>
                    <size>1</size>
                    <value>3</value>
                </entry>
                <entry>
                  <int>9</int>
                    <index>9</index>
                    <size>1</size>
                    <value>3</value>
                </entry>
              </configParameters>
            </COMMAND__CLASS__CONFIGURATION>
          </entry>
          <entry>
            <COMMAND__CLASS__ALARM>
              <version>8</version>
              <versionSupported>8</versionSupported>
              <alarms>
                <entry>
                  <alarmType>ACCESS_CONTROL</alarmType>
                  <alarmState>
                    <reportedEvents>
                      <int>22</int>
                      <int>23</int>
                    </reportedEvents>
                    <outer-class reference="../../../.."/>
                  </alarmState>
                </entry>
                <entry>
                  <alarmType>BURGLAR</alarmType>
                  <alarmState>
                    <reportedEvents>
                      <int>3</int>
                    </reportedEvents>
                  </alarmState>
                </entry>
              </alarms>
              <v1Supported>true</v1Supported>
            </COMMAND__CLASS__ALARM>
          </entry>
          <entry>
            <COMMAND__CLASS__MANUFACTURER__SPECIFIC>
              <initSerialNumber>false</initSerialNumber>
              <deviceManufacturer>634</deviceManufacturer>
              <deviceType>28672</deviceType>
              <deviceId>57347</deviceId>
            </COMMAND__CLASS__MANUFACTURER__SPECIFIC>
          </entry>
          <entry>
            <COMMAND__CLASS__POWERLEVEL>
              <powerLevel>0</powerLevel>
              <powerTimeout>0</powerTimeout>
            </COMMAND__CLASS__POWERLEVEL>
          </entry>
          <entry>
            <COMMAND__CLASS__FIRMWARE__UPDATE__MD>
              <versionSupported>5</versionSupported>
            </COMMAND__CLASS__FIRMWARE__UPDATE__MD>
          </entry>
          <entry>
            <COMMAND__CLASS__BATTERY>
              <batteryLevel>69</batteryLevel>
              <batteryLow>false</batteryLow>
            </COMMAND__CLASS__BATTERY>
          </entry>
          <entry>
            <COMMAND__CLASS__WAKE__UP>
              <targetNodeId>1</targetNodeId>
              <interval>21600</interval>
              <minInterval>3600</minInterval>
              <maxInterval>86400</maxInterval>
              <defaultInterval>21600</defaultInterval>
              <intervalStep>60</intervalStep>
            </COMMAND__CLASS__WAKE__UP>
          </entry>
          <entry>
            <COMMAND__CLASS__ASSOCIATION>
              <maxGroups>3</maxGroups>
            </COMMAND__CLASS__ASSOCIATION>
          </entry>
          <entry>
            <COMMAND__CLASS__VERSION>
              <libraryType>LIB_SLAVE_ENHANCED</libraryType>
              <protocolVersion>7.13</protocolVersion>
              <applicationVersion>1.20</applicationVersion>
              <hardwareVersion>1</hardwareVersion>
            </COMMAND__CLASS__VERSION>
          </entry>
          <entry>
            <COMMAND__CLASS__INDICATOR>
              <version>3</version>
              <supportedIndicatorsInitialised>true</supportedIndicatorsInitialised>
              <supportedIndicators>
                <ZWaveIndicator>
                  <type>NODE_IDENTIFY</type>
                </ZWaveIndicator>
              </supportedIndicators>
            </COMMAND__CLASS__INDICATOR>
          </entry>
          <entry>
            <COMMAND__CLASS__MULTI__CHANNEL__ASSOCIATION>
            </COMMAND__CLASS__MULTI__CHANNEL__ASSOCIATION>
          </entry>
        </supportedCommandClasses>
      </endPoint>
    </entry>
  </endpoints>
  <nodeNeighbors/>
  <lastReceived>2023-02-11 01:04:40.434 UTC</lastReceived>
</node>
  • Iogs were generated please post these here using code fences:
    Events Log:
{2023-02-11 00:58:50.167 [INFO ] [openhab.event.InboxAddedEvent       ] - Discovery Result with UID 'zwave:device:5eab90482f:node150' has been added.
2023-02-11 00:59:13.669 [INFO ] [openhab.event.InboxRemovedEvent     ] - Discovery Result with UID 'zwave:device:5eab90482f:node150' has been removed.
2023-02-11 00:59:13.673 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:5eab90482f:node150' changed from UNINITIALIZED to INITIALIZING
2023-02-11 00:59:13.676 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:5eab90482f:node150' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2023-02-11 00:59:13.786 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:5eab90482f:node150' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to UNINITIALIZED
2023-02-11 00:59:13.793 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:5eab90482f:node150' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2023-02-11 00:59:13.814 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:5eab90482f:node150' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
2023-02-11 00:59:13.817 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:5eab90482f:node150' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2023-02-11 00:59:13.817 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:5eab90482f:node150' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
2023-02-11 01:00:14.784 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Dryer_Sensor_Binary_Sensor' changed from NULL to ON
2023-02-11 01:00:16.753 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Dryer_Sensor_Alarm_burglar' changed from NULL to OFF
2023-02-11 01:00:17.820 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Dryer_Sensor_Door_State' changed from NULL to OPEN
2023-02-11 01:00:19.160 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Dryer_Sensor_Battery_Level' changed from NULL to 77.0
2023-02-11 01:02:28.448 [INFO ] [openhab.event.ConfigStatusInfoEvent ] - ConfigStatusInfo [configStatusMessages=[ConfigStatusMessage [parameterName=group_3, type=PENDING, messageKey=null, arguments=null, message=null, statusCode=null]]]
2023-02-11 01:03:15.690 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:5eab90482f:node150' changed from ONLINE to ONLINE: Node initialising: EMPTYNODE
2023-02-11 01:03:15.734 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:5eab90482f:node150' changed from ONLINE: Node initialising: EMPTYNODE to ONLINE: Node initialising: IDENTIFY_NODE
2023-02-11 01:03:15.768 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:5eab90482f:node150' changed from ONLINE: Node initialising: IDENTIFY_NODE to ONLINE: Node initialising: REQUEST_NIF
2023-02-11 01:03:17.308 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:5eab90482f:node150' changed from ONLINE: Node initialising: REQUEST_NIF to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2023-02-11 01:03:17.310 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:5eab90482f:node150' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
2023-02-11 01:03:21.394 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:5eab90482f:node150' changed from ONLINE to ONLINE: Node initialising: SECURITY_REPORT
2023-02-11 01:03:21.395 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:5eab90482f:node150' changed from ONLINE: Node initialising: SECURITY_REPORT to ONLINE: Node initialising: MANUFACTURER
2023-02-11 01:03:27.858 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:5eab90482f:node150' changed from ONLINE: Node initialising: MANUFACTURER to ONLINE: Node initialising: APP_VERSION
2023-02-11 01:03:27.930 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:5eab90482f:node150' changed from ONLINE: Node initialising: APP_VERSION to ONLINE: Node initialising: DISCOVERY_COMPLETE
2023-02-11 01:03:27.931 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:5eab90482f:node150' changed from ONLINE: Node initialising: DISCOVERY_COMPLETE to ONLINE: Node initialising: VERSION
2023-02-11 01:04:02.381 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:5eab90482f:node150' changed from ONLINE: Node initialising: VERSION to ONLINE: Node initialising: ENDPOINTS
2023-02-11 01:04:02.383 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:5eab90482f:node150' changed from ONLINE: Node initialising: ENDPOINTS to ONLINE: Node initialising: UPDATE_DATABASE
2023-02-11 01:04:02.388 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:5eab90482f:node150' changed from ONLINE: Node initialising: UPDATE_DATABASE to ONLINE: Node initialising: STATIC_VALUES
2023-02-11 01:04:04.912 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:5eab90482f:node150' changed from ONLINE: Node initialising: STATIC_VALUES to ONLINE: Node initialising: ASSOCIATIONS
2023-02-11 01:04:07.494 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:5eab90482f:node150' changed from ONLINE: Node initialising: ASSOCIATIONS to ONLINE: Node initialising: SET_WAKEUP
2023-02-11 01:04:07.495 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:5eab90482f:node150' changed from ONLINE: Node initialising: SET_WAKEUP to ONLINE: Node initialising: SET_ASSOCIATION
2023-02-11 01:04:07.760 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:5eab90482f:node150' changed from ONLINE: Node initialising: SET_ASSOCIATION to ONLINE: Node initialising: SET_LIFELINE
2023-02-11 01:04:08.175 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:5eab90482f:node150' changed from ONLINE: Node initialising: SET_LIFELINE to ONLINE: Node initialising: GET_CONFIGURATION
2023-02-11 01:04:39.494 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Dryer_Sensor_Door_State' changed from OPEN to CLOSED
2023-02-11 01:04:40.438 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Dryer_Sensor_Binary_Sensor' changed from ON to OFF
2023-02-11 01:04:40.476 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:5eab90482f:node150' changed from ONLINE: Node initialising: GET_CONFIGURATION to ONLINE
2023-02-11 01:04:59.782 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Dryer_Sensor_Door_State' changed from CLOSED to OPEN
2023-02-11 01:05:51.343 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Dryer_Sensor_Battery_Level' changed from 69 to 39
2023-02-11 01:07:12.016 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Dryer_Sensor_Door_State' changed from OPEN to CLOSED
2023-02-11 01:08:03.954 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Dryer_Sensor_Door_State' changed from CLOSED to OPEN
Openhab log added node:
{2023-02-11 00:58:48.561 [DEBUG] [ol.serialmessage.AddNodeMessageClass] - NODE 150: Adding slave.
2023-02-11 00:58:48.561 [DEBUG] [al.protocol.ZWaveInclusionController] - Inclusion event: Current state IncludeStart, new event IncludeSlaveFound
2023-02-11 00:58:48.562 [DEBUG] [al.protocol.ZWaveInclusionController] - NODE 150: Including node.
2023-02-11 00:58:48.562 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2023-02-11 00:58:48.562 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2023-02-11 00:58:50.106 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 07 00 4A BE 05 96 00 9F
2023-02-11 00:58:50.106 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=AddNodeToNetwork[74], type=Request[0], dest=5, callback=190, payload=BE 05 96 00
2023-02-11 00:58:50.106 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=AddNodeToNetwork[74], type=Request[0], dest=5, callback=190, payload=BE 05 96 00
2023-02-11 00:58:50.106 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2023-02-11 00:58:50.106 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 0
2023-02-11 00:58:50.106 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: null
2023-02-11 00:58:50.107 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=AddNodeToNetwork[74], type=Request[0], dest=5, callback=190, payload=BE 05 96 00
2023-02-11 00:58:50.107 [DEBUG] [ol.serialmessage.AddNodeMessageClass] - NODE 150: Add Node: Protocol done.
2023-02-11 00:58:50.107 [DEBUG] [al.protocol.ZWaveInclusionController] - Inclusion event: Current state IncludeSlaveFound, new event IncludeProtocolDone
2023-02-11 00:58:50.107 [DEBUG] [ol.serialmessage.AddNodeMessageClass] - Ending INCLUSION mode.
2023-02-11 00:58:50.107 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 255: Added 339 to queue - size 1
2023-02-11 00:58:50.107 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2023-02-11 00:58:50.107 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 05 00 4A 05 C9 7C
2023-02-11 00:58:50.107 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 255: Sending REQUEST Message = 01 05 00 4A 05 C9 7C
2023-02-11 00:58:50.108 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - Message SENT
2023-02-11 00:58:50.108 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage started: TID 339: [WAIT_REQUEST] priority=Controller, requiresResponse=true, callback: 201
2023-02-11 00:58:50.108 [DEBUG] [al.protocol.ZWaveInclusionController] - NODE 150: Inclusion protocol completed.
2023-02-11 00:58:50.108 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 150: Creating new instance of command class COMMAND_CLASS_NO_OPERATION
2023-02-11 00:58:50.108 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 06
2023-02-11 00:58:50.108 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 150: Command class COMMAND_CLASS_NO_OPERATION, endpoint 0 created
2023-02-11 00:58:50.108 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2023-02-11 00:58:50.108 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 150: Version = 1, version set. Enabling extra functionality.
2023-02-11 00:58:50.108 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 150: Adding command class COMMAND_CLASS_NO_OPERATION to the list of supported command classes.
2023-02-11 00:58:50.108 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 150: Creating new instance of command class COMMAND_CLASS_BASIC
2023-02-11 00:58:50.109 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 150: Command class COMMAND_CLASS_BASIC, endpoint 0 created
2023-02-11 00:58:50.109 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 150: Adding command class COMMAND_CLASS_BASIC to the list of supported command classes.
2023-02-11 00:58:50.109 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 150: Creating new instance of command class COMMAND_CLASS_ZWAVEPLUS_INFO
2023-02-11 00:58:50.109 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 150: Command class COMMAND_CLASS_ZWAVEPLUS_INFO, endpoint 0 created
2023-02-11 00:58:50.109 [DEBUG] [al.protocol.ZWaveInclusionController] - NODE 150: Inclusion is adding command class COMMAND_CLASS_ZWAVEPLUS_INFO.
2023-02-11 00:58:50.109 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 150: Adding command class COMMAND_CLASS_ZWAVEPLUS_INFO to the list of supported command classes.
2023-02-11 00:58:50.109 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 150: Creating new instance of command class COMMAND_CLASS_ASSOCIATION
2023-02-11 00:58:50.109 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 150: Command class COMMAND_CLASS_ASSOCIATION, endpoint 0 created
2023-02-11 00:58:50.109 [DEBUG] [al.protocol.ZWaveInclusionController] - NODE 150: Inclusion is adding command class COMMAND_CLASS_ASSOCIATION.
2023-02-11 00:58:50.110 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 150: Adding command class COMMAND_CLASS_ASSOCIATION to the list of supported command classes.
2023-02-11 00:58:50.110 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 150: Creating new instance of command class COMMAND_CLASS_MULTI_CHANNEL_ASSOCIATION
2023-02-11 00:58:50.110 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 150: Command class COMMAND_CLASS_MULTI_CHANNEL_ASSOCIATION, endpoint 0 created
2023-02-11 00:58:50.110 [DEBUG] [al.protocol.ZWaveInclusionController] - NODE 150: Inclusion is adding command class COMMAND_CLASS_MULTI_CHANNEL_ASSOCIATION.
2023-02-11 00:58:50.110 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 150: Adding command class COMMAND_CLASS_MULTI_CHANNEL_ASSOCIATION to the list of supported command classes.
2023-02-11 00:58:50.110 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 150: Creating new instance of command class COMMAND_CLASS_ASSOCIATION_GRP_INFO
2023-02-11 00:58:50.110 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 150: Command class COMMAND_CLASS_ASSOCIATION_GRP_INFO, endpoint 0 created
2023-02-11 00:58:50.110 [DEBUG] [al.protocol.ZWaveInclusionController] - NODE 150: Inclusion is adding command class COMMAND_CLASS_ASSOCIATION_GRP_INFO.
2023-02-11 00:58:50.110 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 150: Adding command class COMMAND_CLASS_ASSOCIATION_GRP_INFO to the list of supported command classes.
2023-02-11 00:58:50.111 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 150: Unsupported command class COMMAND_CLASS_TRANSPORT_SERVICE
2023-02-11 00:58:50.111 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 150: Creating new instance of command class COMMAND_CLASS_VERSION
2023-02-11 00:58:50.111 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 150: Command class COMMAND_CLASS_VERSION, endpoint 0 created
2023-02-11 00:58:50.111 [DEBUG] [al.protocol.ZWaveInclusionController] - NODE 150: Inclusion is adding command class COMMAND_CLASS_VERSION.
2023-02-11 00:58:50.111 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 150: Adding command class COMMAND_CLASS_VERSION to the list of supported command classes.
2023-02-11 00:58:50.111 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 150: Creating new instance of command class COMMAND_CLASS_MANUFACTURER_SPECIFIC
2023-02-11 00:58:50.111 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 150: Command class COMMAND_CLASS_MANUFACTURER_SPECIFIC, endpoint 0 created
2023-02-11 00:58:50.111 [DEBUG] [al.protocol.ZWaveInclusionController] - NODE 150: Inclusion is adding command class COMMAND_CLASS_MANUFACTURER_SPECIFIC.
2023-02-11 00:58:50.111 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 150: Adding command class COMMAND_CLASS_MANUFACTURER_SPECIFIC to the list of supported command classes.
2023-02-11 00:58:50.111 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 150: Creating new instance of command class COMMAND_CLASS_DEVICE_RESET_LOCALLY
2023-02-11 00:58:50.111 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 150: Command class COMMAND_CLASS_DEVICE_RESET_LOCALLY, endpoint 0 created
2023-02-11 00:58:50.112 [DEBUG] [al.protocol.ZWaveInclusionController] - NODE 150: Inclusion is adding command class COMMAND_CLASS_DEVICE_RESET_LOCALLY.
2023-02-11 00:58:50.112 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 150: Adding command class COMMAND_CLASS_DEVICE_RESET_LOCALLY to the list of supported command classes.
2023-02-11 00:58:50.112 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 150: Creating new instance of command class COMMAND_CLASS_POWERLEVEL
2023-02-11 00:58:50.112 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 150: Command class COMMAND_CLASS_POWERLEVEL, endpoint 0 created
2023-02-11 00:58:50.112 [DEBUG] [al.protocol.ZWaveInclusionController] - NODE 150: Inclusion is adding command class COMMAND_CLASS_POWERLEVEL.
2023-02-11 00:58:50.112 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 150: Adding command class COMMAND_CLASS_POWERLEVEL to the list of supported command classes.
2023-02-11 00:58:50.112 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 150: Creating new instance of command class COMMAND_CLASS_BATTERY
2023-02-11 00:58:50.112 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 150: Command class COMMAND_CLASS_BATTERY, endpoint 0 created
2023-02-11 00:58:50.112 [DEBUG] [al.protocol.ZWaveInclusionController] - NODE 150: Inclusion is adding command class COMMAND_CLASS_BATTERY.
2023-02-11 00:58:50.112 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 150: Adding command class COMMAND_CLASS_BATTERY to the list of supported command classes.
2023-02-11 00:58:50.112 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 150: Creating new instance of command class COMMAND_CLASS_SECURITY
2023-02-11 00:58:50.113 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 150: Command class COMMAND_CLASS_SECURITY, endpoint 0 created
2023-02-11 00:58:50.113 [DEBUG] [al.protocol.ZWaveInclusionController] - NODE 150: Inclusion is adding command class COMMAND_CLASS_SECURITY_2.
2023-02-11 00:58:50.113 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 150: Adding command class COMMAND_CLASS_SECURITY to the list of supported command classes.
2023-02-11 00:58:50.113 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 150: Creating new instance of command class COMMAND_CLASS_ALARM
2023-02-11 00:58:50.113 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 150: Command class COMMAND_CLASS_ALARM, endpoint 0 created
2023-02-11 00:58:50.113 [DEBUG] [al.protocol.ZWaveInclusionController] - NODE 150: Inclusion is adding command class COMMAND_CLASS_ALARM.
2023-02-11 00:58:50.113 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 150: Adding command class COMMAND_CLASS_ALARM to the list of supported command classes.
2023-02-11 00:58:50.113 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 150: Creating new instance of command class COMMAND_CLASS_INDICATOR
2023-02-11 00:58:50.113 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 150: Command class COMMAND_CLASS_INDICATOR, endpoint 0 created
2023-02-11 00:58:50.113 [DEBUG] [al.protocol.ZWaveInclusionController] - NODE 150: Inclusion is adding command class COMMAND_CLASS_INDICATOR.
2023-02-11 00:58:50.113 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 150: Adding command class COMMAND_CLASS_INDICATOR to the list of supported command classes.
2023-02-11 00:58:50.114 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 150: Creating new instance of command class COMMAND_CLASS_SENSOR_BINARY
2023-02-11 00:58:50.114 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 150: Command class COMMAND_CLASS_SENSOR_BINARY, endpoint 0 created
2023-02-11 00:58:50.114 [DEBUG] [al.protocol.ZWaveInclusionController] - NODE 150: Inclusion is adding command class COMMAND_CLASS_SENSOR_BINARY.
2023-02-11 00:58:50.114 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 150: Adding command class COMMAND_CLASS_SENSOR_BINARY to the list of supported command classes.
2023-02-11 00:58:50.114 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 150: Creating new instance of command class COMMAND_CLASS_CONFIGURATION
2023-02-11 00:58:50.114 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 150: Command class COMMAND_CLASS_CONFIGURATION, endpoint 0 created
2023-02-11 00:58:50.114 [DEBUG] [al.protocol.ZWaveInclusionController] - NODE 150: Inclusion is adding command class COMMAND_CLASS_CONFIGURATION.
2023-02-11 00:58:50.114 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 150: Adding command class COMMAND_CLASS_CONFIGURATION to the list of supported command classes.
2023-02-11 00:58:50.114 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 150: Creating new instance of command class COMMAND_CLASS_WAKE_UP
2023-02-11 00:58:50.114 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 150: Command class COMMAND_CLASS_WAKE_UP, endpoint 0 created
2023-02-11 00:58:50.115 [DEBUG] [al.protocol.ZWaveInclusionController] - NODE 150: Inclusion is adding command class COMMAND_CLASS_WAKE_UP.
2023-02-11 00:58:50.115 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 150: Adding command class COMMAND_CLASS_WAKE_UP to the list of supported command classes.
2023-02-11 00:58:50.115 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 150: Unsupported command class COMMAND_CLASS_SUPERVISION
2023-02-11 00:58:50.115 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 150: Creating new instance of command class COMMAND_CLASS_FIRMWARE_UPDATE_MD
2023-02-11 00:58:50.115 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 150: Command class COMMAND_CLASS_FIRMWARE_UPDATE_MD, endpoint 0 created
2023-02-11 00:58:50.115 [DEBUG] [al.protocol.ZWaveInclusionController] - NODE 150: Inclusion is adding command class COMMAND_CLASS_FIRMWARE_UPDATE_MD.
2023-02-11 00:58:50.115 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 150: Adding command class COMMAND_CLASS_FIRMWARE_UPDATE_MD to the list of supported command classes.
2023-02-11 00:58:50.115 [DEBUG] [ve.internal.protocol.ZWaveController] - NODE 150: ZWaveController include node
2023-02-11 00:58:50.115 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 150: Starting initialisation from INCLUSION_START
2023-02-11 00:58:50.116 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2023-02-11 00:58:50.116 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 339: [WAIT_REQUEST] priority=Controller, requiresResponse=true, callback: 201
2023-02-11 00:58:50.116 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 150: Node advancer: Node just included (808308)
2023-02-11 00:58:50.116 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg: ACK
2023-02-11 00:58:50.116 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 150: Node advancer - advancing to IDENTIFY_NODE
2023-02-11 00:58:50.116 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2023-02-11 00:58:50.116 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2023-02-11 00:58:50.116 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 150: Node advancer: Initialisation starting from inclusion
2023-02-11 00:58:50.116 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 255: sendTransaction org.openhab.binding.zwave.internal.protocol.ZWaveSerialPayload@1fc6ae9f
2023-02-11 00:58:50.117 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 255: Added 340 to queue - size 1
2023-02-11 00:58:50.117 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2023-02-11 00:58:50.162 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 07 00 4A C9 06 96 00 EB
2023-02-11 00:58:50.163 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=AddNodeToNetwork[74], type=Request[0], dest=6, callback=201, payload=C9 06 96 00
2023-02-11 00:58:50.164 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=AddNodeToNetwork[74], type=Request[0], dest=6, callback=201, payload=C9 06 96 00
2023-02-11 00:58:50.164 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 339: [WAIT_REQUEST] priority=Controller, requiresResponse=true, callback: 201
2023-02-11 00:58:50.164 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 1
2023-02-11 00:58:50.164 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: TID 339: [WAIT_REQUEST] priority=Controller, requiresResponse=true, callback: 201
2023-02-11 00:58:50.164 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking TID 339: (Callback 201)
2023-02-11 00:58:50.164 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Callback match!
2023-02-11 00:58:50.164 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Correlated to TID 339: callback 201
2023-02-11 00:58:50.164 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=AddNodeToNetwork[74], type=Request[0], dest=6, callback=201, payload=C9 06 96 00
2023-02-11 00:58:50.164 [DEBUG] [ol.serialmessage.AddNodeMessageClass] - Add Node: Done.
2023-02-11 00:58:50.165 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 150: Device discovered
2023-02-11 00:58:50.167 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing 'zwave:device:5eab90482f:node150' to inbox.
2023-02-11 00:58:50.168 [DEBUG] [al.protocol.ZWaveInclusionController] - Inclusion event: Current state IncludeProtocolDone, new event IncludeDone
2023-02-11 00:58:50.168 [DEBUG] [ol.serialmessage.AddNodeMessageClass] - Ending INCLUSION mode.
2023-02-11 00:58:50.168 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 255: Added 341 to queue - size 2
2023-02-11 00:58:50.168 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2023-02-11 00:58:50.168 [DEBUG] [al.protocol.ZWaveInclusionController] - ZWave controller end exclusion
2023-02-11 00:58:50.168 [DEBUG] [ve.internal.protocol.ZWaveController] - ZWaveController include done
2023-02-11 00:58:50.168 [DEBUG] [nal.protocol.ZWaveTransactionManager] - TID 339: Advanced to DONE
2023-02-11 00:58:50.168 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 255: Response processed after 60ms
2023-02-11 00:58:50.168 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 255: TID 339: Transaction completed
2023-02-11 00:58:50.169 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 255: notifyTransactionResponse TID:339 DONE
2023-02-11 00:58:50.169 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2023-02-11 00:58:50.169 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2023-02-11 00:58:50.169 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 04 00 41 96 2C
2023-02-11 00:58:50.169 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 255: Sending REQUEST Message = 01 04 00 41 96 2C
2023-02-11 00:58:50.169 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - Message SENT
2023-02-11 00:58:50.169 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage started: TID 340: [WAIT_RESPONSE] priority=Controller, requiresResponse=true, callback: 0
2023-02-11 00:58:50.170 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 06
2023-02-11 00:58:50.170 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2023-02-11 00:58:50.170 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2023-02-11 00:58:50.170 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 340: [WAIT_RESPONSE] priority=Controller, requiresResponse=true, callback: 0
2023-02-11 00:58:50.170 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg: ACK
2023-02-11 00:58:50.170 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2023-02-11 00:58:50.171 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2023-02-11 00:58:50.171 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 09 01 41 53 9C 01 04 07 01 7A
2023-02-11 00:58:50.171 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=IdentifyNode[65], type=Response[1], dest=255, callback=0, payload=53 9C 01 04 07 01
2023-02-11 00:58:50.171 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=IdentifyNode[65], type=Response[1], dest=255, callback=0, payload=53 9C 01 04 07 01
2023-02-11 00:58:50.171 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 340: [WAIT_RESPONSE] priority=Controller, requiresResponse=true, callback: 0
2023-02-11 00:58:50.171 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 1
2023-02-11 00:58:50.171 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: TID 340: [WAIT_RESPONSE] priority=Controller, requiresResponse=true, callback: 0
2023-02-11 00:58:50.171 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=IdentifyNode[65], type=Response[1], dest=255, callback=0, payload=53 9C 01 04 07 01
2023-02-11 00:58:50.172 [DEBUG] [rialmessage.IdentifyNodeMessageClass] - NODE 150: ProtocolInfo
2023-02-11 00:58:50.172 [DEBUG] [rialmessage.IdentifyNodeMessageClass] - NODE 150: Listening = false
2023-02-11 00:58:50.172 [DEBUG] [rialmessage.IdentifyNodeMessageClass] - NODE 150: Routing   = true
2023-02-11 00:58:50.172 [DEBUG] [rialmessage.IdentifyNodeMessageClass] - NODE 150: Beaming   = true
2023-02-11 00:58:50.172 [DEBUG] [rialmessage.IdentifyNodeMessageClass] - NODE 150: Version   = 4
2023-02-11 00:58:50.172 [DEBUG] [rialmessage.IdentifyNodeMessageClass] - NODE 150: FLIRS     = false
2023-02-11 00:58:50.172 [DEBUG] [rialmessage.IdentifyNodeMessageClass] - NODE 150: Security  = false
2023-02-11 00:58:50.172 [DEBUG] [rialmessage.IdentifyNodeMessageClass] - NODE 150: Max Baud  = 40000
2023-02-11 00:58:50.172 [DEBUG] [rialmessage.IdentifyNodeMessageClass] - NODE 150: Basic    = BASIC_TYPE_ROUTING_SLAVE
2023-02-11 00:58:50.172 [DEBUG] [rialmessage.IdentifyNodeMessageClass] - NODE 150: Generic  = GENERIC_TYPE_SENSOR_NOTIFICATION
2023-02-11 00:58:50.172 [DEBUG] [rialmessage.IdentifyNodeMessageClass] - NODE 150: Specific = SPECIFIC_TYPE_NOTIFICATION_SENSOR
2023-02-11 00:58:50.172 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 150: Creating new instance of command class COMMAND_CLASS_NO_OPERATION
2023-02-11 00:58:50.173 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 150: Command class COMMAND_CLASS_NO_OPERATION, endpoint 0 created
2023-02-11 00:58:50.173 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 150: Version = 1, version set. Enabling extra functionality.
2023-02-11 00:58:50.173 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 150: Adding command class COMMAND_CLASS_NO_OPERATION to the list of supported command classes.
2023-02-11 00:58:50.173 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 150: Creating new instance of command class COMMAND_CLASS_BASIC
2023-02-11 00:58:50.173 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 150: Command class COMMAND_CLASS_BASIC, endpoint 0 created
2023-02-11 00:58:50.173 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 150: Adding command class COMMAND_CLASS_BASIC to the list of supported command classes.
2023-02-11 00:58:50.173 [DEBUG] [e.internal.protocol.ZWaveTransaction] - TID 340: Transaction COMPLETED
2023-02-11 00:58:50.173 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 255: Response processed after 4ms
2023-02-11 00:58:50.173 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 255: TID 340: Transaction completed
2023-02-11 00:58:50.173 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 255: notifyTransactionResponse TID:340 DONE
2023-02-11 00:58:50.174 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2023-02-11 00:58:50.174 [DEBUG] [nal.protocol.ZWaveTransactionManager] - TID 340: Transaction event listener: DONE: DONE -> UNINTIALIZED
2023-02-11 00:58:50.174 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2023-02-11 00:58:50.174 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 150: Node Init response (0) org.openhab.binding.zwave.internal.protocol.ZWaveTransactionResponse@153ec5ef
2023-02-11 00:58:50.174 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 05 00 4A 05 00 B5
2023-02-11 00:58:50.174 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 150: Node Init transaction completed with response COMPLETE
2023-02-11 00:58:50.174 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 255: Sending REQUEST Message = 01 05 00 4A 05 00 B5
2023-02-11 00:58:50.174 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - Message SENT
2023-02-11 00:58:50.174 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage started: TID 341: [WAIT_REQUEST] priority=Controller, requiresResponse=true, callback: 0
2023-02-11 00:58:50.175 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 06
2023-02-11 00:58:50.175 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2023-02-11 00:58:50.175 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2023-02-11 00:58:50.175 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 341: [WAIT_REQUEST] priority=Controller, requiresResponse=true, callback: 0
2023-02-11 00:58:50.175 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg: ACK
2023-02-11 00:58:50.175 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2023-02-11 00:58:50.175 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2023-02-11 00:58:51.175 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2023-02-11 00:58:51.176 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 150: Is awake with 0 messages in the queue, state IDENTIFY_NODE
2023-02-11 00:58:51.177 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - awakeMax for this Timer Task 20 in 0.5 second intervals
2023-02-11 00:58:51.177 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 150: Start sleep timer with 500ms interval
2023-02-11 00:58:51.177 [DEBUG] [ve.internal.protocol.ZWaveController] - NODE 150: Node Status event - Node is AWAKE
2023-02-11 00:58:51.177 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 150: Node advancer - advancing to SECURITY_REPORT
2023-02-11 00:58:51.178 [DEBUG] [mmandclass.ZWaveSecurityCommandClass] - NODE 150: Updated networkKey
2023-02-11 00:58:51.178 [DEBUG] [mmandclass.ZWaveSecurityCommandClass] - NODE 150: setupNetworkKey useSchemeZero=false
2023-02-11 00:58:51.178 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 150: Skipping secure inclusion
2023-02-11 00:58:51.178 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 150: Node advancer - advancing to MANUFACTURER
2023-02-11 00:58:51.178 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 150: Node advancer: MANUFACTURER - send ManufacturerSpecific
2023-02-11 00:58:51.179 [DEBUG] [WaveManufacturerSpecificCommandClass] - NODE 150: Creating new message for command MANUFACTURER_SPECIFIC_GET
2023-02-11 00:58:51.179 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 150: ZWaveCommandClassTransactionPayload - send to node
2023-02-11 00:58:51.179 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 150: SECURITY NOT required on COMMAND_CLASS_MANUFACTURER_SPECIFIC
2023-02-11 00:58:51.179 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 150: Command Class COMMAND_CLASS_MANUFACTURER_SPECIFIC is NOT required to be secured
2023-02-11 00:58:51.179 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 150: sendTransaction org.openhab.binding.zwave.internal.protocol.transaction.ZWaveCommandClassTransactionPayload@2d4ea3c
2023-02-11 00:58:51.179 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 150: Bump transaction 342 priority from Config to Immediate
2023-02-11 00:58:51.179 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 150: Adding to device queue
2023-02-11 00:58:51.179 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 150: Added 342 to queue - size 14
2023-02-11 00:58:51.180 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2023-02-11 00:58:51.677 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 150: WakeupTimerTask 1 Messages waiting, state MANUFACTURER count 1
2023-02-11 00:58:52.177 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 150: WakeupTimerTask 1 Messages waiting, state MANUFACTURER count 2
2023-02-11 00:58:52.677 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 150: WakeupTimerTask 1 Messages waiting, state MANUFACTURER count 3
2023-02-11 00:58:53.178 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 150: WakeupTimerTask 1 Messages waiting, state MANUFACTURER count 4
2023-02-11 00:58:53.178 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2023-02-11 00:58:53.231 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 12 00 04 00 93 0A 32 02 21 74 00 00 00 00 00 00 BC 00 A9
2023-02-11 00:58:53.231 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=147, callback=0, payload=00 93 0A 32 02 21 74 00 00 00 00 00 00 BC 00
Part of log where It indicates sensor type unknown
{2023-02-11 00:58:57.664 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 150: Application Command Request (ALIVE:DYNAMIC_VALUES)
2023-02-11 00:58:57.664 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 150: Incoming command class COMMAND_CLASS_SENSOR_BINARY, endpoint 0
2023-02-11 00:58:57.664 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 150: SECURITY not supported
2023-02-11 00:58:57.664 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 150: Received COMMAND_CLASS_SENSOR_BINARY V2 SENSOR_BINARY_REPORT
2023-02-11 00:58:57.664 [DEBUG] [dclass.ZWaveBinarySensorCommandClass] - Processing Sensor Type 0
2023-02-11 00:58:57.664 [DEBUG] [dclass.ZWaveBinarySensorCommandClass] - Sensor Type is UNKNOWN
2023-02-11 00:58:57.665 [DEBUG] [dclass.ZWaveBinarySensorCommandClass] - NODE 150: Sensor Binary report, type=Unknown, value=0
2023-02-11 00:58:57.665 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 150: Commands processed 1.
2023-02-11 00:58:57.665 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 150: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@3d58aa55.
2023-02-11 00:58:57.665 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 150: Command verified org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@3d58aa55.
2023-02-11 00:58:57.665 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 150: notifyTransactionResponse TID:403 DONE
2023-02-11 00:58:57.665 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 1
2023-02-11 00:58:57.665 [DEBUG] [nal.protocol.ZWaveTransactionManager] - TID 403: Transaction event listener: DONE: DONE -> UNINTIALIZED
2023-02-11 00:58:57.665 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2023-02-11 00:58:57.665 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2023-02-11 00:58:57.665 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2023-02-11 00:58:57.665 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 150: Node Init response (0) org.openhab.binding.zwave.internal.protocol.ZWaveTransactionResponse@3c5b2c0d
2023-02-11 00:58:57.666 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 150: Node Init transaction completed with response COMPLETE
2023-02-11 00:58:57.666 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 150: Node advancer: DYNAMIC_VALUES - checking COMMAND_CLASS_ALARM
2023-02-11 00:58:57.666 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 150: Found 1 instances of COMMAND_CLASS_ALARM for endpoint 0
2023-02-11 00:58:57.666 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 150: Node advancer: DYNAMIC_VALUES - checking COMMAND_CLASS_WAKE_UP
2023-02-11 00:58:57.666 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 150: Node advancer: DYNAMIC_VALUES - checking COMMAND_CLASS_ZWAVEPLUS_INFO
2023-02-11 00:58:57.666 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 150: Node advancer: DYNAMIC_VALUES - checking COMMAND_CLASS_NO_OPERATION
2023-02-11 00:58:57.666 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 150: Node advancer: DYNAMIC_VALUES - checking COMMAND_CLASS_MULTI_CHANNEL_ASSOCIATION
2023-02-11 00:58:57.666 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 150: Node advancer: Initialisation complete!
2023-02-11 00:58:57.666 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 150: Node advancer - advancing to DYNAMIC_END
2023-02-11 00:58:57.666 [DEBUG] [l.initialization.ZWaveNodeSerializer] - NODE 150: Serializing to file /openhab/userdata/zwave/network_e2bc20fb__node_150.xml
2023-02-11 00:58:57.669 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 150: Node advancer - advancing to DONE
2023-02-11 00:58:57.669 [DEBUG] [l.initialization.ZWaveNodeSerializer] - NODE 150: Serializing to file /openhab/userdata/zwave/network_e2bc20fb__node_150.xml
2023-02-11 00:58:57.677 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 150: WakeupTimerTask 0 Messages waiting, state DONE count 13
2023-02-11 00:58:57.677 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 150: Go back to sleep, state DONE, count 13 messages 0
2023-02-11 00:58:57.677 [DEBUG] [commandclass.ZWaveWakeUpCommandClass] - NODE 150: Creating new message for application command WAKE_UP_NO_MORE_INFORMATION
2023-02-11 00:58:57.677 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 150: SECURITY not supported
2023-02-11 00:58:57.677 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 150: Command Class COMMAND_CLASS_WAKE_UP is NOT required to be secured
2023-02-11 00:58:57.678 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 150: sendTransaction org.openhab.binding.zwave.internal.protocol.transaction.ZWaveCommandClassTransactionPayload@7677e793
2023-02-11 00:58:57.678 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 150: Bump transaction 404 priority from Immediate to Immediate
2023-02-11 00:58:57.678 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 150: Adding to device queue
2023-02-11 00:58:57.678 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 150: Added 404 to queue - size 14
2023-02-11 00:58:57.678 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2023-02-11 00:58:57.678 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 09 00 13 96 02 84 08 25 0B D3
2023-02-11 00:58:57.678 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 150: Sending REQUEST Message = 01 09 00 13 96 02 84 08 25 0B D3
2023-02-11 00:58:57.678 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - Message SENT
2023-02-11 00:58:57.679 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage started: TID 404: [WAIT_RESPONSE] priority=Immediate, requiresResponse=true, callback: 11
2023-02-11 00:58:57.679 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 06
2023-02-11 00:58:57.679 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2023-02-11 00:58:57.679 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2023-02-11 00:58:57.680 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 404: [WAIT_RESPONSE] priority=Immediate, requiresResponse=true, callback: 11
2023-02-11 00:58:57.680 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg: ACK
2023-02-11 00:58:57.680 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2023-02-11 00:58:57.680 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2023-02-11 00:58:57.683 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 04 01 13 01 E8
2023-02-11 00:58:57.683 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2023-02-11 00:58:57.683 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2023-02-11 00:58:57.683 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 404: [WAIT_RESPONSE] priority=Immediate, requiresResponse=true, callback: 11
2023-02-11 00:58:57.684 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 1
2023-02-11 00:58:57.684 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: TID 404: [WAIT_RESPONSE] priority=Immediate, requiresResponse=true, callback: 11
2023-02-11 00:58:57.684 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2023-02-11 00:58:57.684 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 150: sentData successfully placed on stack.
2023-02-11 00:58:57.684 [DEBUG] [nal.protocol.ZWaveTransactionManager] - TID 404: Advanced to WAIT_REQUEST
2023-02-11 00:58:57.684 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 150: TID 404: Transaction not completed
2023-02-11 00:58:57.684 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2023-02-11 00:58:57.684 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2023-02-11 00:58:57.700 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 18 00 13 0B 00 00 01 00 B9 7F 7F 7F 7F 01 01 03 00 00 00 00 02 01 00 00 47
2023-02-11 00:58:57.700 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=SendData[19], type=Request[0], dest=0, callback=11, payload=0B 00 00 01 00 B9 7F 7F 7F 7F 01 01 03 00 00 00 00 02 01 00 00
2023-02-11 00:58:57.701 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=SendData[19], type=Request[0], dest=0, callback=11, payload=0B 00 00 01 00 B9 7F 7F 7F 7F 01 01 03 00 00 00 00 02 01 00 00
2023-02-11 00:58:57.701 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 404: [WAIT_REQUEST] priority=Immediate, requiresResponse=true, callback: 11
2023-02-11 00:58:57.701 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 1
2023-02-11 00:58:57.701 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: TID 404: [WAIT_REQUEST] priority=Immediate, requiresResponse=true, callback: 11
2023-02-11 00:58:57.701 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking TID 404: (Callback 11)
2023-02-11 00:58:57.701 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Callback match!
2023-02-11 00:58:57.701 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Correlated to TID 404: callback 11
2023-02-11 00:58:57.701 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=SendData[19], type=Request[0], dest=0, callback=11, payload=0B 00 00 01 00 B9 7F 7F 7F 7F 01 01 03 00 00 00 00 02 01 00 00
2023-02-11 00:58:57.701 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 150: SendData Request. CallBack ID = 11, Status = Transmission complete and ACK received(0)
2023-02-11 00:58:57.701 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 150: resetResendCount initComplete=true isDead=false
2023-02-11 00:58:57.702 [DEBUG] [e.internal.protocol.ZWaveTransaction] - TID 404: Transaction COMPLETED
2023-02-11 00:58:57.702 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 150: Response processed after 23ms
2023-02-11 00:58:57.702 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 150: TID 404: Transaction completed
2023-02-11 00:58:57.702 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 150: notifyTransactionResponse TID:404 DONE
2023-02-11 00:58:57.702 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2023-02-11 00:58:57.702 [DEBUG] [nal.protocol.ZWaveTransactionManager] - TID 404: Transaction event listener: DONE: DONE -> UNINTIALIZED
2023-02-11 00:58:57.702 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2023-02-11 00:58:57.702 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 150: Went to sleep COMPLETE
2023-02-11 00:58:57.835 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 0B 00 04 00 81 03 20 01 FF BC 00 10
2023-02-11 00:58:57.835 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=129, callback=0, payload=00 81 03 20 01 FF BC 00
2023-02-11 00:58:57.835 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=129, callback=0, payload=00 81 03 20 01 FF BC 00
2023-02-11 00:58:57.836 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
Any help with this would be great.
Check
channels for reactions to vibrations. IIRC, the Door State channel corresponds to tilt state.
Thanks for your fast reply but I am not sure that they are the same channel as when I vibrate the sensor the door state channel does not change. In fact next to nothing changes when I vibrate the sensor which is my main issue. I can coax the binary state channel to change by reinitializing the device a few times while activating it manually by pressing its zwave button but that is clearly not functioning as intended.
Based on my research I think that it ā€œShould beā€:
Door State = Tilt State
Binary State = Vibration/Shock
I think the COMMAN_CLASS_SENSOR_BINARY_V2 is for vibrations or at least it should be.
When I create things from them there is how they appear:
Binary Sensor: Please note while it says triggered it has not changed from this state since yesterday.
Tilt Sensor: This item works and if I tilt this item updates.
After looking at a few more logs using the log viewer I came across two sections where I managed to get the channel to do something…
Got the binary sensor to give a sensor_binary_report but no state update:
Got the binary sensor to give a sensor_binary_report which lead to a state update:
I was also looking at the setup for the channel I think one of the command classes is set up wrong. Where it says Basic it is currently set to false and I think this may need to be true.
This is because of how I interpret the config documentation (granted I am not an expert at this) In this image references Basic Set commands. I am assuming this is in reference to the basic setting shown above which is set to false.
Does that make sense?
Makes sense if
  1. your Z-Wave controller is in association group #3,
  2. your assumption that the vibration sensor is coupled to the binary sensor is right,
  3. your assumption that Basic: True catches the vibration events sent via association group #3 (as BASIC_SET commands) is right.
Ad #2: Ask Zooz support.
Ad #3: Maybe @chris can confirm your assumption or open a Z-Wave database ticket to have your assumption confirmed.
If your assumptions are confirmed:
Modify the Z-Wave database entry, request a review, wait for a new snapshot, install snapshot, …
What assumption? Is it the one that the Basic should be ticked?
If so, so far I don’t see a need for that based on the log. From what I can see, there aren’t any BASIC commands being sent from the device, so ticking this will not make any difference.
If I’ve misunderstood the exam question, please let me know :slight_smile:
Sure, if the device doesn’t live up to its specification and doesn’t send any BASIC_SET command, it doesn’t make much sense to fiddle with the Z-Wave database entry …
I’m not sure it’s a case of the device doesn’t meet the spec. In the above comment, there is configuration that states that group 3 can receive a basic set command. But that’s generally not needed for the binding.
The binding will use other commands that are normally sent for software like OH - such as the binary sensor etc. BASIC commands are normally used to directly command other devices such as lights etc - and not HA software.
I happen to have one of these in the drawer (I do not like the battery life, even after a zooz firmware upgrade). I also never used the vibration feature.
Anyway I reactivated one and checked with a zniffer to see what is going on. Basically they send only alarms (no basic). One is Access; either (06 16) or (06 17) for open close. The other is Home Security (07 03) or (07 00) for alarm or OK. I changed the alarm_burglar to alarm_tamper and everything works fine. made the change in the DB also.
As above, from what I can see if you want the BASIC commands, you need to add devices to group 3 and enable this functionality. Maybe I’m wrong, and I’ve not read much about this, but that’s what I read in the information pasted above.
I think that is right also.
edit: for clarity; the changes in the channel will result in an Alarm notification (of vibration) that is not appearing today with the current configuration, not a basic set (to any device)
Correct, this is how OP had set up his device and how he wanted to solve the problem - if the problem can be solved by changing the alarm mapping - all the better.
Typically other devices will not know about alarm/notification messages, which is why the BASIC commands are used. If you’re controlling other devices as I understand from your comment here, then you will need to use the BASIC command, but changing the database will not help with that as it’s a direct command between the two devices.
First, thank you all for your help with this. My ultimate goal is to use this device to monitor my dryer for vibrations and then send a push notification when it stops vibrating.
Since I got this device I have been learning more about commands in an attempt to figure out what is wrong so I am fairly new to this part of the configuration.
Any further guidance is appreciated or if I can provide anything else please let me know.
I am doing my best to learn but have a hard time finding the right documentation.
So let’s assume that the ZSE43 does live up to its specification and it is configured to send a BASIC_SET to the Z-Wave controller in response to vibration: What will happen at the Z-Wave binding level? Does it depend on the setting of the Command Class Parameter ā€˜Basic’?
That is going to be tricky. Even with the corrected alarm_tamper config the device only stays in ā€œalarmā€ mode for a few seconds. You are going to need a rule (using your favorite scripting language (DSL, Blocky. JS etc) to trigger a message (text, email) after a sustained period of the alarm being OFF.
No - that has no impact at all. The binding will use the ALARM notifications that I assume are sent to group 1. If group 3 is configured with another device to receive the BASIC commands, then only that device will receive the BASIC commands - not the binding.
The device in group 3 is the Z-Wave controller to which the binding is connected.
Based on the documentation group 3 is supposed to be the shock sensor. which is why I went down that path originally. However, it does work as is, and understand that sometimes things must stray from the documentation.
ā€œThe XS Sensor supports Group 1 for Lifeline communication, Group 2 (tilt sensor reports), and Group 3 (shock sensor reports) with up to 5 devices for Basic Set on/off control of the associated devices. The value of the basic set command sent to Group 2 and Group 3 can be adjusted in the advanced settings to customize the sensor’s behavior.ā€
