- Platform information:
- Hardware: Synology DS920+
- OS: DSM 7.1.1-42962 Update 1
- Java Runtime Environment: Docker
- openHAB version: 3.4.1
- Issue of the topic: ZSE43 Vibration Sensor Not properly detecting vibrations. When the device is added to my stick and I create an item for the Binary sensor it has a state of non-triggered and normal vibrations will not trigger it. I can get it to trigger if I play around with it and reinitialize it on the device page a few times however this may just be an anomaly and have little to do to help the issue…
I have posted my config and trimmed down the log files as best I could to just show node 150’s (the ZSE43) Binary sensor activity. These logs were generated after I excluded and factory reset the device. I hope I did not exclude anything that may help. I do have the entire log saved. Currently, the device is in a triggered state. I did notice that it indicated that the sensor type was unknown. - Please post configurations (if applicable):
Paper UI Config:
label: Dryer Sensor
thingTypeUID: zwave:zooz_zse43_00_000
configuration:
wakeup_interval: 21600
group_1:
- controller
group_3:
- controller
group_2: []
config_1_1: 3
config_2_1: 5
action_reinit: false
config_7_1: 2
wakeup_node: 1
config_5_4: 0
config_6_3: 0
config_8_1: 3
config_9_1: 3
config_3_1: 20
config_4_1: 0
node_id: 150
bridgeUID: zwave:serial_zstick:5eab90482f
Zwave Config:
<homeId>0xe2bc20fb</homeId>
<nodeId>150</nodeId>
<version>4</version>
<manufacturer>0x27a</manufacturer>
<deviceId>0xe003</deviceId>
<deviceType>0x7000</deviceType>
<listening>false</listening>
<frequentlyListening>false</frequentlyListening>
<routing>true</routing>
<security>false</security>
<beaming>true</beaming>
<maxBaudRate>40000</maxBaudRate>
<sleepDelay>500</sleepDelay>
<nodeInformationFrame>
<commandClass>COMMAND_CLASS_ZWAVEPLUS_INFO</commandClass>
<commandClass>COMMAND_CLASS_ASSOCIATION</commandClass>
<commandClass>COMMAND_CLASS_MULTI_CHANNEL_ASSOCIATION</commandClass>
<commandClass>COMMAND_CLASS_ASSOCIATION_GRP_INFO</commandClass>
<commandClass>COMMAND_CLASS_TRANSPORT_SERVICE</commandClass>
<commandClass>COMMAND_CLASS_VERSION</commandClass>
<commandClass>COMMAND_CLASS_MANUFACTURER_SPECIFIC</commandClass>
<commandClass>COMMAND_CLASS_DEVICE_RESET_LOCALLY</commandClass>
<commandClass>COMMAND_CLASS_POWERLEVEL</commandClass>
<commandClass>COMMAND_CLASS_BATTERY</commandClass>
<commandClass>COMMAND_CLASS_SECURITY_2</commandClass>
<commandClass>COMMAND_CLASS_ALARM</commandClass>
<commandClass>COMMAND_CLASS_INDICATOR</commandClass>
<commandClass>COMMAND_CLASS_SENSOR_BINARY</commandClass>
<commandClass>COMMAND_CLASS_CONFIGURATION</commandClass>
<commandClass>COMMAND_CLASS_WAKE_UP</commandClass>
<commandClass>COMMAND_CLASS_SUPERVISION</commandClass>
<commandClass>COMMAND_CLASS_FIRMWARE_UPDATE_MD</commandClass>
</nodeInformationFrame>
<associationGroups class="concurrent-hash-map">
<entry>
<int>1</int>
<associationGroup>
<index>1</index>
<maxNodes>0</maxNodes>
<name>Lifeline</name>
<profile1>0x0</profile1>
<profile2>0x1</profile2>
<commands>
</commands>
<associations>
<associationMember>
<node>1</node>
</associationMember>
</associations>
</associationGroup>
</entry>
<entry>
<int>2</int>
<associationGroup>
<index>2</index>
<name>Basic Set for contact sensor</name>
<profile1>0x71</profile1>
<profile2>0x6</profile2>
<commands>
<commandClass>COMMAND_CLASS_BASIC</commandClass>
</commands>
<associations/>
</associationGroup>
</entry>
<entry>
<int>3</int>
<associationGroup>
<index>3</index>
<name>Basic Set for shock sensor</name>
<profile2>0x7</profile2>
<commands>
</commands>
<associations>
<associationMember>
<node>1</node>
</associations>
</associationGroup>
</entry>
</associationGroups>
<endpoints class="concurrent-hash-map">
<entry>
<int>0</int>
<endPoint>
<deviceClass>
<basicDeviceClass>BASIC_TYPE_ROUTING_SLAVE</basicDeviceClass>
<genericDeviceClass>GENERIC_TYPE_SENSOR_NOTIFICATION</genericDeviceClass>
<specificDeviceClass>SPECIFIC_TYPE_NOTIFICATION_SENSOR</specificDeviceClass>
</deviceClass>
<endpointId>0</endpointId>
<secureCommandClasses/>
<supportedCommandClasses class="concurrent-hash-map">
<entry>
<commandClass>COMMAND_CLASS_NO_OPERATION</commandClass>
<COMMAND__CLASS__NO__OPERATION>
<version>1</version>
<instances>1</instances>
<control>false</control>
<versionSupported>1</versionSupported>
</COMMAND__CLASS__NO__OPERATION>
</entry>
<entry>
<COMMAND__CLASS__BASIC>
<version>0</version>
<versionSupported>0</versionSupported>
<isGetSupported>true</isGetSupported>
</COMMAND__CLASS__BASIC>
</entry>
<entry>
<COMMAND__CLASS__SENSOR__BINARY>
<version>2</version>
<versionSupported>2</versionSupported>
<types>
<binarySensorType>TAMPER</binarySensorType>
</types>
</COMMAND__CLASS__SENSOR__BINARY>
</entry>
<entry>
<COMMAND__CLASS__ASSOCIATION__GRP__INFO>
<versionSupported>3</versionSupported>
<autoSubscribeGroups>
<int>1</int>
</autoSubscribeGroups>
</COMMAND__CLASS__ASSOCIATION__GRP__INFO>
</entry>
<entry>
<COMMAND__CLASS__DEVICE__RESET__LOCALLY>
</COMMAND__CLASS__DEVICE__RESET__LOCALLY>
</entry>
<entry>
<COMMAND__CLASS__ZWAVEPLUS__INFO>
<zwPlusVersion>2</zwPlusVersion>
<zwPlusRole>ROLE_TYPE_SLAVE_SLEEPING_REPORTING</zwPlusRole>
<zwPlusNodeType>NODE_TYPE_ZWAVEPLUS_NODE</zwPlusNodeType>
</COMMAND__CLASS__ZWAVEPLUS__INFO>
</entry>
<entry>
<COMMAND__CLASS__CONFIGURATION>
<versionSupported>4</versionSupported>
<configParameters>
<entry>
<int>1</int>
<configurationParameter>
<index>1</index>
<size>1</size>
<value>3</value>
<readOnly>false</readOnly>
<writeOnly>false</writeOnly>
</configurationParameter>
</entry>
<entry>
<int>3</int>
<index>3</index>
<size>1</size>
<value>20</value>
</entry>
<entry>
<int>4</int>
<index>4</index>
<size>1</size>
<value>0</value>
</entry>
<entry>
<int>5</int>
<index>5</index>
<size>2</size>
<value>0</value>
</entry>
<entry>
<int>6</int>
<index>6</index>
<size>2</size>
<value>0</value>
</entry>
<entry>
<int>7</int>
<index>7</index>
<size>1</size>
<value>2</value>
</entry>
<entry>
<int>8</int>
<index>8</index>
<size>1</size>
<value>3</value>
</entry>
<entry>
<int>9</int>
<index>9</index>
<size>1</size>
<value>3</value>
</entry>
</configParameters>
</COMMAND__CLASS__CONFIGURATION>
</entry>
<entry>
<COMMAND__CLASS__ALARM>
<version>8</version>
<versionSupported>8</versionSupported>
<alarms>
<entry>
<alarmType>ACCESS_CONTROL</alarmType>
<alarmState>
<reportedEvents>
<int>22</int>
<int>23</int>
</reportedEvents>
<outer-class reference="../../../.."/>
</alarmState>
</entry>
<entry>
<alarmType>BURGLAR</alarmType>
<alarmState>
<reportedEvents>
<int>3</int>
</reportedEvents>
</alarmState>
</entry>
</alarms>
<v1Supported>true</v1Supported>
</COMMAND__CLASS__ALARM>
</entry>
<entry>
<COMMAND__CLASS__MANUFACTURER__SPECIFIC>
<initSerialNumber>false</initSerialNumber>
<deviceManufacturer>634</deviceManufacturer>
<deviceType>28672</deviceType>
<deviceId>57347</deviceId>
</COMMAND__CLASS__MANUFACTURER__SPECIFIC>
</entry>
<entry>
<COMMAND__CLASS__POWERLEVEL>
<powerLevel>0</powerLevel>
<powerTimeout>0</powerTimeout>
</COMMAND__CLASS__POWERLEVEL>
</entry>
<entry>
<COMMAND__CLASS__FIRMWARE__UPDATE__MD>
<versionSupported>5</versionSupported>
</COMMAND__CLASS__FIRMWARE__UPDATE__MD>
</entry>
<entry>
<COMMAND__CLASS__BATTERY>
<batteryLevel>69</batteryLevel>
<batteryLow>false</batteryLow>
</COMMAND__CLASS__BATTERY>
</entry>
<entry>
<COMMAND__CLASS__WAKE__UP>
<targetNodeId>1</targetNodeId>
<interval>21600</interval>
<minInterval>3600</minInterval>
<maxInterval>86400</maxInterval>
<defaultInterval>21600</defaultInterval>
<intervalStep>60</intervalStep>
</COMMAND__CLASS__WAKE__UP>
</entry>
<entry>
<COMMAND__CLASS__ASSOCIATION>
<maxGroups>3</maxGroups>
</COMMAND__CLASS__ASSOCIATION>
</entry>
<entry>
<COMMAND__CLASS__VERSION>
<libraryType>LIB_SLAVE_ENHANCED</libraryType>
<protocolVersion>7.13</protocolVersion>
<applicationVersion>1.20</applicationVersion>
<hardwareVersion>1</hardwareVersion>
</COMMAND__CLASS__VERSION>
</entry>
<entry>
<COMMAND__CLASS__INDICATOR>
<version>3</version>
<supportedIndicatorsInitialised>true</supportedIndicatorsInitialised>
<supportedIndicators>
<ZWaveIndicator>
<type>NODE_IDENTIFY</type>
</ZWaveIndicator>
</supportedIndicators>
</COMMAND__CLASS__INDICATOR>
</entry>
<entry>
<COMMAND__CLASS__MULTI__CHANNEL__ASSOCIATION>
</COMMAND__CLASS__MULTI__CHANNEL__ASSOCIATION>
</entry>
</supportedCommandClasses>
</endPoint>
</entry>
</endpoints>
<nodeNeighbors/>
<lastReceived>2023-02-11 01:04:40.434 UTC</lastReceived>
</node>
- Iogs were generated please post these here using code fences:
Events Log:
{2023-02-11 00:58:50.167 [INFO ] [openhab.event.InboxAddedEvent ] - Discovery Result with UID 'zwave:device:5eab90482f:node150' has been added.
2023-02-11 00:59:13.669 [INFO ] [openhab.event.InboxRemovedEvent ] - Discovery Result with UID 'zwave:device:5eab90482f:node150' has been removed.
2023-02-11 00:59:13.673 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:5eab90482f:node150' changed from UNINITIALIZED to INITIALIZING
2023-02-11 00:59:13.676 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:5eab90482f:node150' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2023-02-11 00:59:13.786 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:5eab90482f:node150' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to UNINITIALIZED
2023-02-11 00:59:13.793 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:5eab90482f:node150' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2023-02-11 00:59:13.814 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:5eab90482f:node150' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
2023-02-11 00:59:13.817 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:5eab90482f:node150' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2023-02-11 00:59:13.817 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:5eab90482f:node150' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
2023-02-11 01:00:14.784 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Dryer_Sensor_Binary_Sensor' changed from NULL to ON
2023-02-11 01:00:16.753 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Dryer_Sensor_Alarm_burglar' changed from NULL to OFF
2023-02-11 01:00:17.820 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Dryer_Sensor_Door_State' changed from NULL to OPEN
2023-02-11 01:00:19.160 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Dryer_Sensor_Battery_Level' changed from NULL to 77.0
2023-02-11 01:02:28.448 [INFO ] [openhab.event.ConfigStatusInfoEvent ] - ConfigStatusInfo [configStatusMessages=[ConfigStatusMessage [parameterName=group_3, type=PENDING, messageKey=null, arguments=null, message=null, statusCode=null]]]
2023-02-11 01:03:15.690 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:5eab90482f:node150' changed from ONLINE to ONLINE: Node initialising: EMPTYNODE
2023-02-11 01:03:15.734 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:5eab90482f:node150' changed from ONLINE: Node initialising: EMPTYNODE to ONLINE: Node initialising: IDENTIFY_NODE
2023-02-11 01:03:15.768 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:5eab90482f:node150' changed from ONLINE: Node initialising: IDENTIFY_NODE to ONLINE: Node initialising: REQUEST_NIF
2023-02-11 01:03:17.308 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:5eab90482f:node150' changed from ONLINE: Node initialising: REQUEST_NIF to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2023-02-11 01:03:17.310 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:5eab90482f:node150' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
2023-02-11 01:03:21.394 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:5eab90482f:node150' changed from ONLINE to ONLINE: Node initialising: SECURITY_REPORT
2023-02-11 01:03:21.395 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:5eab90482f:node150' changed from ONLINE: Node initialising: SECURITY_REPORT to ONLINE: Node initialising: MANUFACTURER
2023-02-11 01:03:27.858 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:5eab90482f:node150' changed from ONLINE: Node initialising: MANUFACTURER to ONLINE: Node initialising: APP_VERSION
2023-02-11 01:03:27.930 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:5eab90482f:node150' changed from ONLINE: Node initialising: APP_VERSION to ONLINE: Node initialising: DISCOVERY_COMPLETE
2023-02-11 01:03:27.931 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:5eab90482f:node150' changed from ONLINE: Node initialising: DISCOVERY_COMPLETE to ONLINE: Node initialising: VERSION
2023-02-11 01:04:02.381 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:5eab90482f:node150' changed from ONLINE: Node initialising: VERSION to ONLINE: Node initialising: ENDPOINTS
2023-02-11 01:04:02.383 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:5eab90482f:node150' changed from ONLINE: Node initialising: ENDPOINTS to ONLINE: Node initialising: UPDATE_DATABASE
2023-02-11 01:04:02.388 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:5eab90482f:node150' changed from ONLINE: Node initialising: UPDATE_DATABASE to ONLINE: Node initialising: STATIC_VALUES
2023-02-11 01:04:04.912 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:5eab90482f:node150' changed from ONLINE: Node initialising: STATIC_VALUES to ONLINE: Node initialising: ASSOCIATIONS
2023-02-11 01:04:07.494 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:5eab90482f:node150' changed from ONLINE: Node initialising: ASSOCIATIONS to ONLINE: Node initialising: SET_WAKEUP
2023-02-11 01:04:07.495 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:5eab90482f:node150' changed from ONLINE: Node initialising: SET_WAKEUP to ONLINE: Node initialising: SET_ASSOCIATION
2023-02-11 01:04:07.760 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:5eab90482f:node150' changed from ONLINE: Node initialising: SET_ASSOCIATION to ONLINE: Node initialising: SET_LIFELINE
2023-02-11 01:04:08.175 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:5eab90482f:node150' changed from ONLINE: Node initialising: SET_LIFELINE to ONLINE: Node initialising: GET_CONFIGURATION
2023-02-11 01:04:39.494 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Dryer_Sensor_Door_State' changed from OPEN to CLOSED
2023-02-11 01:04:40.438 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Dryer_Sensor_Binary_Sensor' changed from ON to OFF
2023-02-11 01:04:40.476 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:5eab90482f:node150' changed from ONLINE: Node initialising: GET_CONFIGURATION to ONLINE
2023-02-11 01:04:59.782 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Dryer_Sensor_Door_State' changed from CLOSED to OPEN
2023-02-11 01:05:51.343 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Dryer_Sensor_Battery_Level' changed from 69 to 39
2023-02-11 01:07:12.016 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Dryer_Sensor_Door_State' changed from OPEN to CLOSED
2023-02-11 01:08:03.954 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Dryer_Sensor_Door_State' changed from CLOSED to OPEN
Openhab log added node:
{2023-02-11 00:58:48.561 [DEBUG] [ol.serialmessage.AddNodeMessageClass] - NODE 150: Adding slave.
2023-02-11 00:58:48.561 [DEBUG] [al.protocol.ZWaveInclusionController] - Inclusion event: Current state IncludeStart, new event IncludeSlaveFound
2023-02-11 00:58:48.562 [DEBUG] [al.protocol.ZWaveInclusionController] - NODE 150: Including node.
2023-02-11 00:58:48.562 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2023-02-11 00:58:48.562 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2023-02-11 00:58:50.106 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 07 00 4A BE 05 96 00 9F
2023-02-11 00:58:50.106 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=AddNodeToNetwork[74], type=Request[0], dest=5, callback=190, payload=BE 05 96 00
2023-02-11 00:58:50.106 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=AddNodeToNetwork[74], type=Request[0], dest=5, callback=190, payload=BE 05 96 00
2023-02-11 00:58:50.106 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2023-02-11 00:58:50.106 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 0
2023-02-11 00:58:50.106 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: null
2023-02-11 00:58:50.107 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=AddNodeToNetwork[74], type=Request[0], dest=5, callback=190, payload=BE 05 96 00
2023-02-11 00:58:50.107 [DEBUG] [ol.serialmessage.AddNodeMessageClass] - NODE 150: Add Node: Protocol done.
2023-02-11 00:58:50.107 [DEBUG] [al.protocol.ZWaveInclusionController] - Inclusion event: Current state IncludeSlaveFound, new event IncludeProtocolDone
2023-02-11 00:58:50.107 [DEBUG] [ol.serialmessage.AddNodeMessageClass] - Ending INCLUSION mode.
2023-02-11 00:58:50.107 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 255: Added 339 to queue - size 1
2023-02-11 00:58:50.107 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2023-02-11 00:58:50.107 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 05 00 4A 05 C9 7C
2023-02-11 00:58:50.107 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 255: Sending REQUEST Message = 01 05 00 4A 05 C9 7C
2023-02-11 00:58:50.108 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - Message SENT
2023-02-11 00:58:50.108 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage started: TID 339: [WAIT_REQUEST] priority=Controller, requiresResponse=true, callback: 201
2023-02-11 00:58:50.108 [DEBUG] [al.protocol.ZWaveInclusionController] - NODE 150: Inclusion protocol completed.
2023-02-11 00:58:50.108 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 150: Creating new instance of command class COMMAND_CLASS_NO_OPERATION
2023-02-11 00:58:50.108 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 06
2023-02-11 00:58:50.108 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 150: Command class COMMAND_CLASS_NO_OPERATION, endpoint 0 created
2023-02-11 00:58:50.108 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2023-02-11 00:58:50.108 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 150: Version = 1, version set. Enabling extra functionality.
2023-02-11 00:58:50.108 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 150: Adding command class COMMAND_CLASS_NO_OPERATION to the list of supported command classes.
2023-02-11 00:58:50.108 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 150: Creating new instance of command class COMMAND_CLASS_BASIC
2023-02-11 00:58:50.109 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 150: Command class COMMAND_CLASS_BASIC, endpoint 0 created
2023-02-11 00:58:50.109 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 150: Adding command class COMMAND_CLASS_BASIC to the list of supported command classes.
2023-02-11 00:58:50.109 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 150: Creating new instance of command class COMMAND_CLASS_ZWAVEPLUS_INFO
2023-02-11 00:58:50.109 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 150: Command class COMMAND_CLASS_ZWAVEPLUS_INFO, endpoint 0 created
2023-02-11 00:58:50.109 [DEBUG] [al.protocol.ZWaveInclusionController] - NODE 150: Inclusion is adding command class COMMAND_CLASS_ZWAVEPLUS_INFO.
2023-02-11 00:58:50.109 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 150: Adding command class COMMAND_CLASS_ZWAVEPLUS_INFO to the list of supported command classes.
2023-02-11 00:58:50.109 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 150: Creating new instance of command class COMMAND_CLASS_ASSOCIATION
2023-02-11 00:58:50.109 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 150: Command class COMMAND_CLASS_ASSOCIATION, endpoint 0 created
2023-02-11 00:58:50.109 [DEBUG] [al.protocol.ZWaveInclusionController] - NODE 150: Inclusion is adding command class COMMAND_CLASS_ASSOCIATION.
2023-02-11 00:58:50.110 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 150: Adding command class COMMAND_CLASS_ASSOCIATION to the list of supported command classes.
2023-02-11 00:58:50.110 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 150: Creating new instance of command class COMMAND_CLASS_MULTI_CHANNEL_ASSOCIATION
2023-02-11 00:58:50.110 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 150: Command class COMMAND_CLASS_MULTI_CHANNEL_ASSOCIATION, endpoint 0 created
2023-02-11 00:58:50.110 [DEBUG] [al.protocol.ZWaveInclusionController] - NODE 150: Inclusion is adding command class COMMAND_CLASS_MULTI_CHANNEL_ASSOCIATION.
2023-02-11 00:58:50.110 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 150: Adding command class COMMAND_CLASS_MULTI_CHANNEL_ASSOCIATION to the list of supported command classes.
2023-02-11 00:58:50.110 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 150: Creating new instance of command class COMMAND_CLASS_ASSOCIATION_GRP_INFO
2023-02-11 00:58:50.110 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 150: Command class COMMAND_CLASS_ASSOCIATION_GRP_INFO, endpoint 0 created
2023-02-11 00:58:50.110 [DEBUG] [al.protocol.ZWaveInclusionController] - NODE 150: Inclusion is adding command class COMMAND_CLASS_ASSOCIATION_GRP_INFO.
2023-02-11 00:58:50.110 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 150: Adding command class COMMAND_CLASS_ASSOCIATION_GRP_INFO to the list of supported command classes.
2023-02-11 00:58:50.111 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 150: Unsupported command class COMMAND_CLASS_TRANSPORT_SERVICE
2023-02-11 00:58:50.111 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 150: Creating new instance of command class COMMAND_CLASS_VERSION
2023-02-11 00:58:50.111 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 150: Command class COMMAND_CLASS_VERSION, endpoint 0 created
2023-02-11 00:58:50.111 [DEBUG] [al.protocol.ZWaveInclusionController] - NODE 150: Inclusion is adding command class COMMAND_CLASS_VERSION.
2023-02-11 00:58:50.111 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 150: Adding command class COMMAND_CLASS_VERSION to the list of supported command classes.
2023-02-11 00:58:50.111 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 150: Creating new instance of command class COMMAND_CLASS_MANUFACTURER_SPECIFIC
2023-02-11 00:58:50.111 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 150: Command class COMMAND_CLASS_MANUFACTURER_SPECIFIC, endpoint 0 created
2023-02-11 00:58:50.111 [DEBUG] [al.protocol.ZWaveInclusionController] - NODE 150: Inclusion is adding command class COMMAND_CLASS_MANUFACTURER_SPECIFIC.
2023-02-11 00:58:50.111 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 150: Adding command class COMMAND_CLASS_MANUFACTURER_SPECIFIC to the list of supported command classes.
2023-02-11 00:58:50.111 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 150: Creating new instance of command class COMMAND_CLASS_DEVICE_RESET_LOCALLY
2023-02-11 00:58:50.111 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 150: Command class COMMAND_CLASS_DEVICE_RESET_LOCALLY, endpoint 0 created
2023-02-11 00:58:50.112 [DEBUG] [al.protocol.ZWaveInclusionController] - NODE 150: Inclusion is adding command class COMMAND_CLASS_DEVICE_RESET_LOCALLY.
2023-02-11 00:58:50.112 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 150: Adding command class COMMAND_CLASS_DEVICE_RESET_LOCALLY to the list of supported command classes.
2023-02-11 00:58:50.112 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 150: Creating new instance of command class COMMAND_CLASS_POWERLEVEL
2023-02-11 00:58:50.112 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 150: Command class COMMAND_CLASS_POWERLEVEL, endpoint 0 created
2023-02-11 00:58:50.112 [DEBUG] [al.protocol.ZWaveInclusionController] - NODE 150: Inclusion is adding command class COMMAND_CLASS_POWERLEVEL.
2023-02-11 00:58:50.112 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 150: Adding command class COMMAND_CLASS_POWERLEVEL to the list of supported command classes.
2023-02-11 00:58:50.112 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 150: Creating new instance of command class COMMAND_CLASS_BATTERY
2023-02-11 00:58:50.112 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 150: Command class COMMAND_CLASS_BATTERY, endpoint 0 created
2023-02-11 00:58:50.112 [DEBUG] [al.protocol.ZWaveInclusionController] - NODE 150: Inclusion is adding command class COMMAND_CLASS_BATTERY.
2023-02-11 00:58:50.112 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 150: Adding command class COMMAND_CLASS_BATTERY to the list of supported command classes.
2023-02-11 00:58:50.112 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 150: Creating new instance of command class COMMAND_CLASS_SECURITY
2023-02-11 00:58:50.113 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 150: Command class COMMAND_CLASS_SECURITY, endpoint 0 created
2023-02-11 00:58:50.113 [DEBUG] [al.protocol.ZWaveInclusionController] - NODE 150: Inclusion is adding command class COMMAND_CLASS_SECURITY_2.
2023-02-11 00:58:50.113 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 150: Adding command class COMMAND_CLASS_SECURITY to the list of supported command classes.
2023-02-11 00:58:50.113 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 150: Creating new instance of command class COMMAND_CLASS_ALARM
2023-02-11 00:58:50.113 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 150: Command class COMMAND_CLASS_ALARM, endpoint 0 created
2023-02-11 00:58:50.113 [DEBUG] [al.protocol.ZWaveInclusionController] - NODE 150: Inclusion is adding command class COMMAND_CLASS_ALARM.
2023-02-11 00:58:50.113 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 150: Adding command class COMMAND_CLASS_ALARM to the list of supported command classes.
2023-02-11 00:58:50.113 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 150: Creating new instance of command class COMMAND_CLASS_INDICATOR
2023-02-11 00:58:50.113 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 150: Command class COMMAND_CLASS_INDICATOR, endpoint 0 created
2023-02-11 00:58:50.113 [DEBUG] [al.protocol.ZWaveInclusionController] - NODE 150: Inclusion is adding command class COMMAND_CLASS_INDICATOR.
2023-02-11 00:58:50.113 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 150: Adding command class COMMAND_CLASS_INDICATOR to the list of supported command classes.
2023-02-11 00:58:50.114 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 150: Creating new instance of command class COMMAND_CLASS_SENSOR_BINARY
2023-02-11 00:58:50.114 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 150: Command class COMMAND_CLASS_SENSOR_BINARY, endpoint 0 created
2023-02-11 00:58:50.114 [DEBUG] [al.protocol.ZWaveInclusionController] - NODE 150: Inclusion is adding command class COMMAND_CLASS_SENSOR_BINARY.
2023-02-11 00:58:50.114 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 150: Adding command class COMMAND_CLASS_SENSOR_BINARY to the list of supported command classes.
2023-02-11 00:58:50.114 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 150: Creating new instance of command class COMMAND_CLASS_CONFIGURATION
2023-02-11 00:58:50.114 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 150: Command class COMMAND_CLASS_CONFIGURATION, endpoint 0 created
2023-02-11 00:58:50.114 [DEBUG] [al.protocol.ZWaveInclusionController] - NODE 150: Inclusion is adding command class COMMAND_CLASS_CONFIGURATION.
2023-02-11 00:58:50.114 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 150: Adding command class COMMAND_CLASS_CONFIGURATION to the list of supported command classes.
2023-02-11 00:58:50.114 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 150: Creating new instance of command class COMMAND_CLASS_WAKE_UP
2023-02-11 00:58:50.114 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 150: Command class COMMAND_CLASS_WAKE_UP, endpoint 0 created
2023-02-11 00:58:50.115 [DEBUG] [al.protocol.ZWaveInclusionController] - NODE 150: Inclusion is adding command class COMMAND_CLASS_WAKE_UP.
2023-02-11 00:58:50.115 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 150: Adding command class COMMAND_CLASS_WAKE_UP to the list of supported command classes.
2023-02-11 00:58:50.115 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 150: Unsupported command class COMMAND_CLASS_SUPERVISION
2023-02-11 00:58:50.115 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 150: Creating new instance of command class COMMAND_CLASS_FIRMWARE_UPDATE_MD
2023-02-11 00:58:50.115 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 150: Command class COMMAND_CLASS_FIRMWARE_UPDATE_MD, endpoint 0 created
2023-02-11 00:58:50.115 [DEBUG] [al.protocol.ZWaveInclusionController] - NODE 150: Inclusion is adding command class COMMAND_CLASS_FIRMWARE_UPDATE_MD.
2023-02-11 00:58:50.115 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 150: Adding command class COMMAND_CLASS_FIRMWARE_UPDATE_MD to the list of supported command classes.
2023-02-11 00:58:50.115 [DEBUG] [ve.internal.protocol.ZWaveController] - NODE 150: ZWaveController include node
2023-02-11 00:58:50.115 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 150: Starting initialisation from INCLUSION_START
2023-02-11 00:58:50.116 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2023-02-11 00:58:50.116 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 339: [WAIT_REQUEST] priority=Controller, requiresResponse=true, callback: 201
2023-02-11 00:58:50.116 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 150: Node advancer: Node just included (808308)
2023-02-11 00:58:50.116 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg: ACK
2023-02-11 00:58:50.116 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 150: Node advancer - advancing to IDENTIFY_NODE
2023-02-11 00:58:50.116 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2023-02-11 00:58:50.116 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2023-02-11 00:58:50.116 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 150: Node advancer: Initialisation starting from inclusion
2023-02-11 00:58:50.116 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 255: sendTransaction org.openhab.binding.zwave.internal.protocol.ZWaveSerialPayload@1fc6ae9f
2023-02-11 00:58:50.117 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 255: Added 340 to queue - size 1
2023-02-11 00:58:50.117 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2023-02-11 00:58:50.162 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 07 00 4A C9 06 96 00 EB
2023-02-11 00:58:50.163 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=AddNodeToNetwork[74], type=Request[0], dest=6, callback=201, payload=C9 06 96 00
2023-02-11 00:58:50.164 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=AddNodeToNetwork[74], type=Request[0], dest=6, callback=201, payload=C9 06 96 00
2023-02-11 00:58:50.164 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 339: [WAIT_REQUEST] priority=Controller, requiresResponse=true, callback: 201
2023-02-11 00:58:50.164 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 1
2023-02-11 00:58:50.164 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: TID 339: [WAIT_REQUEST] priority=Controller, requiresResponse=true, callback: 201
2023-02-11 00:58:50.164 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking TID 339: (Callback 201)
2023-02-11 00:58:50.164 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Callback match!
2023-02-11 00:58:50.164 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Correlated to TID 339: callback 201
2023-02-11 00:58:50.164 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=AddNodeToNetwork[74], type=Request[0], dest=6, callback=201, payload=C9 06 96 00
2023-02-11 00:58:50.164 [DEBUG] [ol.serialmessage.AddNodeMessageClass] - Add Node: Done.
2023-02-11 00:58:50.165 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 150: Device discovered
2023-02-11 00:58:50.167 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing 'zwave:device:5eab90482f:node150' to inbox.
2023-02-11 00:58:50.168 [DEBUG] [al.protocol.ZWaveInclusionController] - Inclusion event: Current state IncludeProtocolDone, new event IncludeDone
2023-02-11 00:58:50.168 [DEBUG] [ol.serialmessage.AddNodeMessageClass] - Ending INCLUSION mode.
2023-02-11 00:58:50.168 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 255: Added 341 to queue - size 2
2023-02-11 00:58:50.168 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2023-02-11 00:58:50.168 [DEBUG] [al.protocol.ZWaveInclusionController] - ZWave controller end exclusion
2023-02-11 00:58:50.168 [DEBUG] [ve.internal.protocol.ZWaveController] - ZWaveController include done
2023-02-11 00:58:50.168 [DEBUG] [nal.protocol.ZWaveTransactionManager] - TID 339: Advanced to DONE
2023-02-11 00:58:50.168 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 255: Response processed after 60ms
2023-02-11 00:58:50.168 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 255: TID 339: Transaction completed
2023-02-11 00:58:50.169 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 255: notifyTransactionResponse TID:339 DONE
2023-02-11 00:58:50.169 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2023-02-11 00:58:50.169 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2023-02-11 00:58:50.169 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 04 00 41 96 2C
2023-02-11 00:58:50.169 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 255: Sending REQUEST Message = 01 04 00 41 96 2C
2023-02-11 00:58:50.169 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - Message SENT
2023-02-11 00:58:50.169 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage started: TID 340: [WAIT_RESPONSE] priority=Controller, requiresResponse=true, callback: 0
2023-02-11 00:58:50.170 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 06
2023-02-11 00:58:50.170 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2023-02-11 00:58:50.170 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2023-02-11 00:58:50.170 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 340: [WAIT_RESPONSE] priority=Controller, requiresResponse=true, callback: 0
2023-02-11 00:58:50.170 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg: ACK
2023-02-11 00:58:50.170 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2023-02-11 00:58:50.171 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2023-02-11 00:58:50.171 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 09 01 41 53 9C 01 04 07 01 7A
2023-02-11 00:58:50.171 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=IdentifyNode[65], type=Response[1], dest=255, callback=0, payload=53 9C 01 04 07 01
2023-02-11 00:58:50.171 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=IdentifyNode[65], type=Response[1], dest=255, callback=0, payload=53 9C 01 04 07 01
2023-02-11 00:58:50.171 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 340: [WAIT_RESPONSE] priority=Controller, requiresResponse=true, callback: 0
2023-02-11 00:58:50.171 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 1
2023-02-11 00:58:50.171 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: TID 340: [WAIT_RESPONSE] priority=Controller, requiresResponse=true, callback: 0
2023-02-11 00:58:50.171 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=IdentifyNode[65], type=Response[1], dest=255, callback=0, payload=53 9C 01 04 07 01
2023-02-11 00:58:50.172 [DEBUG] [rialmessage.IdentifyNodeMessageClass] - NODE 150: ProtocolInfo
2023-02-11 00:58:50.172 [DEBUG] [rialmessage.IdentifyNodeMessageClass] - NODE 150: Listening = false
2023-02-11 00:58:50.172 [DEBUG] [rialmessage.IdentifyNodeMessageClass] - NODE 150: Routing = true
2023-02-11 00:58:50.172 [DEBUG] [rialmessage.IdentifyNodeMessageClass] - NODE 150: Beaming = true
2023-02-11 00:58:50.172 [DEBUG] [rialmessage.IdentifyNodeMessageClass] - NODE 150: Version = 4
2023-02-11 00:58:50.172 [DEBUG] [rialmessage.IdentifyNodeMessageClass] - NODE 150: FLIRS = false
2023-02-11 00:58:50.172 [DEBUG] [rialmessage.IdentifyNodeMessageClass] - NODE 150: Security = false
2023-02-11 00:58:50.172 [DEBUG] [rialmessage.IdentifyNodeMessageClass] - NODE 150: Max Baud = 40000
2023-02-11 00:58:50.172 [DEBUG] [rialmessage.IdentifyNodeMessageClass] - NODE 150: Basic = BASIC_TYPE_ROUTING_SLAVE
2023-02-11 00:58:50.172 [DEBUG] [rialmessage.IdentifyNodeMessageClass] - NODE 150: Generic = GENERIC_TYPE_SENSOR_NOTIFICATION
2023-02-11 00:58:50.172 [DEBUG] [rialmessage.IdentifyNodeMessageClass] - NODE 150: Specific = SPECIFIC_TYPE_NOTIFICATION_SENSOR
2023-02-11 00:58:50.172 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 150: Creating new instance of command class COMMAND_CLASS_NO_OPERATION
2023-02-11 00:58:50.173 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 150: Command class COMMAND_CLASS_NO_OPERATION, endpoint 0 created
2023-02-11 00:58:50.173 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 150: Version = 1, version set. Enabling extra functionality.
2023-02-11 00:58:50.173 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 150: Adding command class COMMAND_CLASS_NO_OPERATION to the list of supported command classes.
2023-02-11 00:58:50.173 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 150: Creating new instance of command class COMMAND_CLASS_BASIC
2023-02-11 00:58:50.173 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 150: Command class COMMAND_CLASS_BASIC, endpoint 0 created
2023-02-11 00:58:50.173 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 150: Adding command class COMMAND_CLASS_BASIC to the list of supported command classes.
2023-02-11 00:58:50.173 [DEBUG] [e.internal.protocol.ZWaveTransaction] - TID 340: Transaction COMPLETED
2023-02-11 00:58:50.173 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 255: Response processed after 4ms
2023-02-11 00:58:50.173 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 255: TID 340: Transaction completed
2023-02-11 00:58:50.173 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 255: notifyTransactionResponse TID:340 DONE
2023-02-11 00:58:50.174 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2023-02-11 00:58:50.174 [DEBUG] [nal.protocol.ZWaveTransactionManager] - TID 340: Transaction event listener: DONE: DONE -> UNINTIALIZED
2023-02-11 00:58:50.174 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2023-02-11 00:58:50.174 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 150: Node Init response (0) org.openhab.binding.zwave.internal.protocol.ZWaveTransactionResponse@153ec5ef
2023-02-11 00:58:50.174 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 05 00 4A 05 00 B5
2023-02-11 00:58:50.174 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 150: Node Init transaction completed with response COMPLETE
2023-02-11 00:58:50.174 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 255: Sending REQUEST Message = 01 05 00 4A 05 00 B5
2023-02-11 00:58:50.174 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - Message SENT
2023-02-11 00:58:50.174 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage started: TID 341: [WAIT_REQUEST] priority=Controller, requiresResponse=true, callback: 0
2023-02-11 00:58:50.175 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 06
2023-02-11 00:58:50.175 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2023-02-11 00:58:50.175 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2023-02-11 00:58:50.175 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 341: [WAIT_REQUEST] priority=Controller, requiresResponse=true, callback: 0
2023-02-11 00:58:50.175 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg: ACK
2023-02-11 00:58:50.175 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2023-02-11 00:58:50.175 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2023-02-11 00:58:51.175 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2023-02-11 00:58:51.176 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 150: Is awake with 0 messages in the queue, state IDENTIFY_NODE
2023-02-11 00:58:51.177 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - awakeMax for this Timer Task 20 in 0.5 second intervals
2023-02-11 00:58:51.177 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 150: Start sleep timer with 500ms interval
2023-02-11 00:58:51.177 [DEBUG] [ve.internal.protocol.ZWaveController] - NODE 150: Node Status event - Node is AWAKE
2023-02-11 00:58:51.177 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 150: Node advancer - advancing to SECURITY_REPORT
2023-02-11 00:58:51.178 [DEBUG] [mmandclass.ZWaveSecurityCommandClass] - NODE 150: Updated networkKey
2023-02-11 00:58:51.178 [DEBUG] [mmandclass.ZWaveSecurityCommandClass] - NODE 150: setupNetworkKey useSchemeZero=false
2023-02-11 00:58:51.178 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 150: Skipping secure inclusion
2023-02-11 00:58:51.178 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 150: Node advancer - advancing to MANUFACTURER
2023-02-11 00:58:51.178 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 150: Node advancer: MANUFACTURER - send ManufacturerSpecific
2023-02-11 00:58:51.179 [DEBUG] [WaveManufacturerSpecificCommandClass] - NODE 150: Creating new message for command MANUFACTURER_SPECIFIC_GET
2023-02-11 00:58:51.179 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 150: ZWaveCommandClassTransactionPayload - send to node
2023-02-11 00:58:51.179 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 150: SECURITY NOT required on COMMAND_CLASS_MANUFACTURER_SPECIFIC
2023-02-11 00:58:51.179 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 150: Command Class COMMAND_CLASS_MANUFACTURER_SPECIFIC is NOT required to be secured
2023-02-11 00:58:51.179 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 150: sendTransaction org.openhab.binding.zwave.internal.protocol.transaction.ZWaveCommandClassTransactionPayload@2d4ea3c
2023-02-11 00:58:51.179 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 150: Bump transaction 342 priority from Config to Immediate
2023-02-11 00:58:51.179 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 150: Adding to device queue
2023-02-11 00:58:51.179 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 150: Added 342 to queue - size 14
2023-02-11 00:58:51.180 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2023-02-11 00:58:51.677 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 150: WakeupTimerTask 1 Messages waiting, state MANUFACTURER count 1
2023-02-11 00:58:52.177 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 150: WakeupTimerTask 1 Messages waiting, state MANUFACTURER count 2
2023-02-11 00:58:52.677 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 150: WakeupTimerTask 1 Messages waiting, state MANUFACTURER count 3
2023-02-11 00:58:53.178 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 150: WakeupTimerTask 1 Messages waiting, state MANUFACTURER count 4
2023-02-11 00:58:53.178 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2023-02-11 00:58:53.231 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 12 00 04 00 93 0A 32 02 21 74 00 00 00 00 00 00 BC 00 A9
2023-02-11 00:58:53.231 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=147, callback=0, payload=00 93 0A 32 02 21 74 00 00 00 00 00 00 BC 00
Part of log where It indicates sensor type unknown
{2023-02-11 00:58:57.664 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 150: Application Command Request (ALIVE:DYNAMIC_VALUES)
2023-02-11 00:58:57.664 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 150: Incoming command class COMMAND_CLASS_SENSOR_BINARY, endpoint 0
2023-02-11 00:58:57.664 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 150: SECURITY not supported
2023-02-11 00:58:57.664 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 150: Received COMMAND_CLASS_SENSOR_BINARY V2 SENSOR_BINARY_REPORT
2023-02-11 00:58:57.664 [DEBUG] [dclass.ZWaveBinarySensorCommandClass] - Processing Sensor Type 0
2023-02-11 00:58:57.664 [DEBUG] [dclass.ZWaveBinarySensorCommandClass] - Sensor Type is UNKNOWN
2023-02-11 00:58:57.665 [DEBUG] [dclass.ZWaveBinarySensorCommandClass] - NODE 150: Sensor Binary report, type=Unknown, value=0
2023-02-11 00:58:57.665 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 150: Commands processed 1.
2023-02-11 00:58:57.665 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 150: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@3d58aa55.
2023-02-11 00:58:57.665 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 150: Command verified org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@3d58aa55.
2023-02-11 00:58:57.665 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 150: notifyTransactionResponse TID:403 DONE
2023-02-11 00:58:57.665 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 1
2023-02-11 00:58:57.665 [DEBUG] [nal.protocol.ZWaveTransactionManager] - TID 403: Transaction event listener: DONE: DONE -> UNINTIALIZED
2023-02-11 00:58:57.665 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2023-02-11 00:58:57.665 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2023-02-11 00:58:57.665 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2023-02-11 00:58:57.665 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 150: Node Init response (0) org.openhab.binding.zwave.internal.protocol.ZWaveTransactionResponse@3c5b2c0d
2023-02-11 00:58:57.666 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 150: Node Init transaction completed with response COMPLETE
2023-02-11 00:58:57.666 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 150: Node advancer: DYNAMIC_VALUES - checking COMMAND_CLASS_ALARM
2023-02-11 00:58:57.666 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 150: Found 1 instances of COMMAND_CLASS_ALARM for endpoint 0
2023-02-11 00:58:57.666 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 150: Node advancer: DYNAMIC_VALUES - checking COMMAND_CLASS_WAKE_UP
2023-02-11 00:58:57.666 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 150: Node advancer: DYNAMIC_VALUES - checking COMMAND_CLASS_ZWAVEPLUS_INFO
2023-02-11 00:58:57.666 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 150: Node advancer: DYNAMIC_VALUES - checking COMMAND_CLASS_NO_OPERATION
2023-02-11 00:58:57.666 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 150: Node advancer: DYNAMIC_VALUES - checking COMMAND_CLASS_MULTI_CHANNEL_ASSOCIATION
2023-02-11 00:58:57.666 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 150: Node advancer: Initialisation complete!
2023-02-11 00:58:57.666 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 150: Node advancer - advancing to DYNAMIC_END
2023-02-11 00:58:57.666 [DEBUG] [l.initialization.ZWaveNodeSerializer] - NODE 150: Serializing to file /openhab/userdata/zwave/network_e2bc20fb__node_150.xml
2023-02-11 00:58:57.669 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 150: Node advancer - advancing to DONE
2023-02-11 00:58:57.669 [DEBUG] [l.initialization.ZWaveNodeSerializer] - NODE 150: Serializing to file /openhab/userdata/zwave/network_e2bc20fb__node_150.xml
2023-02-11 00:58:57.677 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 150: WakeupTimerTask 0 Messages waiting, state DONE count 13
2023-02-11 00:58:57.677 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 150: Go back to sleep, state DONE, count 13 messages 0
2023-02-11 00:58:57.677 [DEBUG] [commandclass.ZWaveWakeUpCommandClass] - NODE 150: Creating new message for application command WAKE_UP_NO_MORE_INFORMATION
2023-02-11 00:58:57.677 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 150: SECURITY not supported
2023-02-11 00:58:57.677 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 150: Command Class COMMAND_CLASS_WAKE_UP is NOT required to be secured
2023-02-11 00:58:57.678 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 150: sendTransaction org.openhab.binding.zwave.internal.protocol.transaction.ZWaveCommandClassTransactionPayload@7677e793
2023-02-11 00:58:57.678 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 150: Bump transaction 404 priority from Immediate to Immediate
2023-02-11 00:58:57.678 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 150: Adding to device queue
2023-02-11 00:58:57.678 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 150: Added 404 to queue - size 14
2023-02-11 00:58:57.678 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2023-02-11 00:58:57.678 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 09 00 13 96 02 84 08 25 0B D3
2023-02-11 00:58:57.678 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 150: Sending REQUEST Message = 01 09 00 13 96 02 84 08 25 0B D3
2023-02-11 00:58:57.678 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - Message SENT
2023-02-11 00:58:57.679 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage started: TID 404: [WAIT_RESPONSE] priority=Immediate, requiresResponse=true, callback: 11
2023-02-11 00:58:57.679 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 06
2023-02-11 00:58:57.679 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2023-02-11 00:58:57.679 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2023-02-11 00:58:57.680 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 404: [WAIT_RESPONSE] priority=Immediate, requiresResponse=true, callback: 11
2023-02-11 00:58:57.680 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg: ACK
2023-02-11 00:58:57.680 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2023-02-11 00:58:57.680 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2023-02-11 00:58:57.683 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 04 01 13 01 E8
2023-02-11 00:58:57.683 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2023-02-11 00:58:57.683 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2023-02-11 00:58:57.683 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 404: [WAIT_RESPONSE] priority=Immediate, requiresResponse=true, callback: 11
2023-02-11 00:58:57.684 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 1
2023-02-11 00:58:57.684 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: TID 404: [WAIT_RESPONSE] priority=Immediate, requiresResponse=true, callback: 11
2023-02-11 00:58:57.684 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2023-02-11 00:58:57.684 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 150: sentData successfully placed on stack.
2023-02-11 00:58:57.684 [DEBUG] [nal.protocol.ZWaveTransactionManager] - TID 404: Advanced to WAIT_REQUEST
2023-02-11 00:58:57.684 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 150: TID 404: Transaction not completed
2023-02-11 00:58:57.684 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2023-02-11 00:58:57.684 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2023-02-11 00:58:57.700 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 18 00 13 0B 00 00 01 00 B9 7F 7F 7F 7F 01 01 03 00 00 00 00 02 01 00 00 47
2023-02-11 00:58:57.700 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=SendData[19], type=Request[0], dest=0, callback=11, payload=0B 00 00 01 00 B9 7F 7F 7F 7F 01 01 03 00 00 00 00 02 01 00 00
2023-02-11 00:58:57.701 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=SendData[19], type=Request[0], dest=0, callback=11, payload=0B 00 00 01 00 B9 7F 7F 7F 7F 01 01 03 00 00 00 00 02 01 00 00
2023-02-11 00:58:57.701 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 404: [WAIT_REQUEST] priority=Immediate, requiresResponse=true, callback: 11
2023-02-11 00:58:57.701 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 1
2023-02-11 00:58:57.701 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: TID 404: [WAIT_REQUEST] priority=Immediate, requiresResponse=true, callback: 11
2023-02-11 00:58:57.701 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking TID 404: (Callback 11)
2023-02-11 00:58:57.701 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Callback match!
2023-02-11 00:58:57.701 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Correlated to TID 404: callback 11
2023-02-11 00:58:57.701 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=SendData[19], type=Request[0], dest=0, callback=11, payload=0B 00 00 01 00 B9 7F 7F 7F 7F 01 01 03 00 00 00 00 02 01 00 00
2023-02-11 00:58:57.701 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 150: SendData Request. CallBack ID = 11, Status = Transmission complete and ACK received(0)
2023-02-11 00:58:57.701 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 150: resetResendCount initComplete=true isDead=false
2023-02-11 00:58:57.702 [DEBUG] [e.internal.protocol.ZWaveTransaction] - TID 404: Transaction COMPLETED
2023-02-11 00:58:57.702 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 150: Response processed after 23ms
2023-02-11 00:58:57.702 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 150: TID 404: Transaction completed
2023-02-11 00:58:57.702 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 150: notifyTransactionResponse TID:404 DONE
2023-02-11 00:58:57.702 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2023-02-11 00:58:57.702 [DEBUG] [nal.protocol.ZWaveTransactionManager] - TID 404: Transaction event listener: DONE: DONE -> UNINTIALIZED
2023-02-11 00:58:57.702 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2023-02-11 00:58:57.702 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 150: Went to sleep COMPLETE
2023-02-11 00:58:57.835 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 0B 00 04 00 81 03 20 01 FF BC 00 10
2023-02-11 00:58:57.835 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=129, callback=0, payload=00 81 03 20 01 FF BC 00
2023-02-11 00:58:57.835 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=129, callback=0, payload=00 81 03 20 01 FF BC 00
2023-02-11 00:58:57.836 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
Any help with this would be great.
