ZW089 Recessed Door Sensor Gen5 issues
I’m having some issues with my Aeontec door sensors. If i try to adjust parameters or the association group of one of my door sensors i get the following log, iam currently running latest snapshot for the Zwave binding. But it wasn’t also working on the previous version i used from de openhabian build of december.:
    2018-04-11 22:20:24.677 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 14: Configuration update received
    2018-04-11 22:20:24.686 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 14: Configuration update group_1 to [node_1_0]
    2018-04-11 22:20:24.690 [ERROR] [st.core.internal.thing.ThingResource] - Exception during HTTP PUT request for update config at 'things/zwave:device:16297352af7:node14/config'
    	at org.openhab.binding.zwave.handler.ZWaveThingHandler.handleConfigurationUpdate(ZWaveThingHandler.java:623) [211:org.openhab.binding.zwave:2.3.0.201804092039]
    	at org.eclipse.smarthome.core.thing.internal.ThingRegistryImpl.updateConfiguration(ThingRegistryImpl.java:94) [116:org.eclipse.smarthome.core.thing:0.10.0.b1]
    	at org.eclipse.smarthome.io.rest.core.internal.thing.ThingResource.updateConfiguration(ThingResource.java:413) [126:org.eclipse.smarthome.io.rest.core:0.10.0.b1]
    	at sun.reflect.GeneratedMethodAccessor140.invoke(Unknown Source) ~[?:?]
    	at org.glassfish.jersey.server.model.internal.ResourceMethodInvocationHandlerFactory$1.invoke(ResourceMethodInvocationHandlerFactory.java:81) [178:org.glassfish.jersey.core.jersey-server:2.22.2]
    	at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher$1.run(AbstractJavaResourceMethodDispatcher.java:144) [178:org.glassfish.jersey.core.jersey-server:2.22.2]
    	at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher.invoke(AbstractJavaResourceMethodDispatcher.java:161) [178:org.glassfish.jersey.core.jersey-server:2.22.2]
    	at org.glassfish.jersey.server.model.internal.JavaResourceMethodDispatcherProvider$ResponseOutInvoker.doDispatch(JavaResourceMethodDispatcherProvider.java:160) [178:org.glassfish.jersey.core.jersey-server:2.22.2]
    	at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher.dispatch(AbstractJavaResourceMethodDispatcher.java:99) [178:org.glassfish.jersey.core.jersey-server:2.22.2]
    	at org.glassfish.jersey.server.model.ResourceMethodInvoker.invoke(ResourceMethodInvoker.java:389) [178:org.glassfish.jersey.core.jersey-server:2.22.2]
    	at org.glassfish.jersey.server.model.ResourceMethodInvoker.apply(ResourceMethodInvoker.java:347) [178:org.glassfish.jersey.core.jersey-server:2.22.2]
    	at org.glassfish.jersey.server.model.ResourceMethodInvoker.apply(ResourceMethodInvoker.java:102) [178:org.glassfish.jersey.core.jersey-server:2.22.2]
    	at org.glassfish.jersey.server.ServerRuntime$2.run(ServerRuntime.java:326) [178:org.glassfish.jersey.core.jersey-server:2.22.2]
    	at org.glassfish.jersey.internal.Errors$1.call(Errors.java:271) [177:org.glassfish.jersey.core.jersey-common:2.22.2]
    	at org.glassfish.jersey.internal.Errors$1.call(Errors.java:267) [177:org.glassfish.jersey.core.jersey-common:2.22.2]
    	at org.glassfish.jersey.internal.Errors.process(Errors.java:315) [177:org.glassfish.jersey.core.jersey-common:2.22.2]
    	at org.glassfish.jersey.internal.Errors.process(Errors.java:297) [177:org.glassfish.jersey.core.jersey-common:2.22.2]
    	at org.glassfish.jersey.internal.Errors.process(Errors.java:267) [177:org.glassfish.jersey.core.jersey-common:2.22.2]
    	at org.glassfish.jersey.process.internal.RequestScope.runInScope(RequestScope.java:317) [177:org.glassfish.jersey.core.jersey-common:2.22.2]
    	at org.glassfish.jersey.server.ServerRuntime.process(ServerRuntime.java:305) [178:org.glassfish.jersey.core.jersey-server:2.22.2]
    	at org.glassfish.jersey.server.ApplicationHandler.handle(ApplicationHandler.java:1154) [178:org.glassfish.jersey.core.jersey-server:2.22.2]
    	at org.glassfish.jersey.servlet.WebComponent.serviceImpl(WebComponent.java:473) [175:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
    	at org.glassfish.jersey.servlet.WebComponent.service(WebComponent.java:427) [175:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
    	at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:388) [175:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
    	at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:341) [175:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
    	at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:228) [175:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
    	at com.eclipsesource.jaxrs.publisher.internal.ServletContainerBridge.service(ServletContainerBridge.java:76) [15:com.eclipsesource.jaxrs.publisher:5.3.1.201602281253]
    	at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:848) [88:org.eclipse.jetty.servlet:9.3.22.v20171030]
    	at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:584) [88:org.eclipse.jetty.servlet:9.3.22.v20171030]
    	at org.ops4j.pax.web.service.jetty.internal.HttpServiceServletHandler.doHandle(HttpServiceServletHandler.java:71) [191:org.ops4j.pax.web.pax-web-jetty:6.0.7]
    	at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143) [87:org.eclipse.jetty.server:9.3.22.v20171030]
    	at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:548) [85:org.eclipse.jetty.security:9.3.22.v20171030]
    	at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:226) [87:org.eclipse.jetty.server:9.3.22.v20171030]
    	at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1180) [87:org.eclipse.jetty.server:9.3.22.v20171030]
    	at org.ops4j.pax.web.service.jetty.internal.HttpServiceContext.doHandle(HttpServiceContext.java:284) [191:org.ops4j.pax.web.pax-web-jetty:6.0.7]
    	at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:512) [88:org.eclipse.jetty.servlet:9.3.22.v20171030]
    	at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:185) [87:org.eclipse.jetty.server:9.3.22.v20171030]
    	at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1112) [87:org.eclipse.jetty.server:9.3.22.v20171030]
    	at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141) [87:org.eclipse.jetty.server:9.3.22.v20171030]
    	at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:80) [191:org.ops4j.pax.web.pax-web-jetty:6.0.7]
    	at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:134) [87:org.eclipse.jetty.server:9.3.22.v20171030]
    	at org.eclipse.jetty.server.Server.handle(Server.java:534) [87:org.eclipse.jetty.server:9.3.22.v20171030]
    	at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:333) [87:org.eclipse.jetty.server:9.3.22.v20171030]
    	at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:251) [87:org.eclipse.jetty.server:9.3.22.v20171030]
    	at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:283) [79:org.eclipse.jetty.io:9.3.22.v20171030]
    	at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:108) [79:org.eclipse.jetty.io:9.3.22.v20171030]
    	at org.eclipse.jetty.io.SelectChannelEndPoint$2.run(SelectChannelEndPoint.java:93) [79:org.eclipse.jetty.io:9.3.22.v20171030]
    	at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.executeProduceConsume(ExecuteProduceConsume.java:303) [90:org.eclipse.jetty.util:9.3.22.v20171030]
    	at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.produceConsume(ExecuteProduceConsume.java:148) [90:org.eclipse.jetty.util:9.3.22.v20171030]
    	at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.run(ExecuteProduceConsume.java:136) [90:org.eclipse.jetty.util:9.3.22.v20171030]
    	at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:671) [90:org.eclipse.jetty.util:9.3.22.v20171030]
    	at org.eclipse.jetty.util.thread.QueuedThreadPool$2.run(QueuedThreadPool.java:589) [90:org.eclipse.jetty.util:9.3.22.v20171030]
In my test setup last year they were working. But that was openhab2 from i believe July 2017. I Hope someone can help me with this, This is the last issue to overcome and i can dump my Smartthings.
I would suggest to try the development version as I believe this is fixed there -:
Hi Chris thanks for the response. It tried the test binding and indeed it doesn’t provide addition errors in the log file. But it also does not update the association field ( it looks like it is being updated but when i refresh the page its still empty).
Also no open/close response from the sensor. They where working on binding 2.1 when i tested them last summer. I hope someone knows the solution to fix these 2 sensors.
