brownjl
(James)
August 29, 2019, 11:31pm
1
Struggling with a ZW111 ive added it and it shows as unknown. I have checked the database and it seems to be there. I’m also running the latest snapshot of the zwave -
263 │ Active │ 80 │ 2.5.0.201908282134 │ openHAB Add-ons :: Bundles :: ZWave Binding
I’ve attached the node xml - Node.xml .
Can any one spot what i’m doing wrong? I did read the firmware on the device I have 2.3 is quite new.
James
UHere is the device listing.
https://www.cd-jackson.com/index.php/zwave/zwave-device-database/zwave-device-list/devicesummary/1096
For some reason, your particular device was not defined for the newer firmware.
I updated the database.
The entry gets reviewed
The binding gets posted to GitHub check date here
The binding jar gets built and placed in a snapshot build. It will also be available here .
