Hi, many thanks @sihui.
So I opened my first issue on github. Hope its the right place.
Thereâs no such thing as âhot fixedâ - all database entries are exported in the same way. In this case, someone has added the semicolon to the configuration as we see in the image in your post.
I will look at this tonight.
Iâve updated the database to fix this now - any further issues, just yellâŠ
Thank you
Iâm Having the exact same issue with the Hank HKZW-RGB01-V1.0 RGB bulb. Presumably this is the same root cause?
14:52:52.701 [WARN ] [nding.zwave.handler.ZWaveThingHandler] - NODE 106: No command converter set for command zwave:device:d106546d:node106:color_temperature type PercentType
A different device means a different issue. Please open a new thread.
It could be the same issue, depends on the OH Version, you discovered the device.
The database was corrupted with OH 2.5.0, so if you discovered the device with this version, it is the same error. In newer OH Versions, OH 2.5.1 und 2.5.2 the database is corrected, so please delete (not exclude) and rediscover your device.
Edit: the database entry for your specific device was repaired an March, 1.
So it should be included in 2.5.2. I donât know the release dates, but 2.5.2 is young enough.
