hello,
After upgrading to openhab 2.2  I do not get status updates (when pressing physical Button nothing happens in OH2) from Channel 2.
I had this problem with oh2.1 and fixed it by using zwave snapshot binding + update the lifeline in the device associations…
Now I tried to work with the 2.2 binding and updated the lifeline + on/off of S2 to openhab controller and still no update from channel 2.
When I press the physical button I see those logs:
18-Dec-2017 23:36:10.218 [DEBUG] [wave.handler.ZWaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 09 00 04 08 07 03 20 01 FF 20
18-Dec-2017 23:36:10.221 [DEBUG] [ab.binding.zwave.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
18-Dec-2017 23:36:10.223 [DEBUG] [nhab.binding.zwave.internal.protocol.SerialMessage] - Assembled message buffer = 01 09 00 04 08 07 03 20 01 FF 20
18-Dec-2017 23:36:10.225 [DEBUG] [ab.binding.zwave.internal.protocol.ZWaveController] - Process Message = 01 09 00 04 08 07 03 20 01 FF 20
18-Dec-2017 23:36:10.228 [DEBUG] [ab.binding.zwave.internal.protocol.ZWaveController] - Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], priority=High, dest=255, callback=0, payload=08 07 03 20 01 FF
18-Dec-2017 23:36:10.229 [DEBUG] [tocol.serialmessage.ApplicationCommandMessageClass] - NODE 7: Application Command Request (ALIVE:DONE)
18-Dec-2017 23:36:10.231 [DEBUG] [protocol.initialization.ZWaveNodeInitStageAdvancer] - NODE 7: Starting initialisation from DONE
18-Dec-2017 23:36:10.233 [DEBUG] [ab.binding.zwave.internal.protocol.ZWaveController] - Event Listener org.openhab.binding.zwave.internal.protocol.initialization.ZWaveNodeInitStageAdvancer@1c0b5e4 already registered
18-Dec-2017 23:36:10.233 [DEBUG] [wave.handler.ZWaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 09 00 04 00 07 03 20 01 FF 28
18-Dec-2017 23:36:10.235 [DEBUG] [tocol.serialmessage.ApplicationCommandMessageClass] - NODE 7: Incoming command class BASIC
18-Dec-2017 23:36:10.236 [DEBUG] [ernal.protocol.commandclass.ZWaveBasicCommandClass] - NODE 7: Received Basic Request
18-Dec-2017 23:36:10.238 [DEBUG] [ernal.protocol.commandclass.ZWaveBasicCommandClass] - NODE 7: Basic Set sent to the controller will be processed as Basic Report
18-Dec-2017 23:36:10.240 [DEBUG] [ernal.protocol.commandclass.ZWaveBasicCommandClass] - NODE 7: Basic report, value = 0xFF
18-Dec-2017 23:36:10.241 [DEBUG] [ab.binding.zwave.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveCommandClassValueEvent
18-Dec-2017 23:36:10.243 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 7: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
18-Dec-2017 23:36:10.245 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 7: Got a value event from Z-Wave network, endpoint = 0, command class = BASIC, value = 255
18-Dec-2017 23:36:10.247 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 7: Updating channel state zwave:device:Zwave:node7:switch_binary to ON [OnOffType]
18-Dec-2017 23:36:10.250 [DEBUG] [ernal.protocol.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Sent Message: class=SendData[0x13], type=Request[0x00], priority=Set, dest=7, callback=181, payload=07 07 60 0D 01 02 25 01 00
18-Dec-2017 23:36:10.253 [DEBUG] [ernal.protocol.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Recv Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], priority=High, dest=255, callback=0, payload=08 07 03 20 01 FF
18-Dec-2017 23:36:10.254 [DEBUG] [ernal.protocol.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: class=ApplicationCommandHandler, callback id=181, expected=SendData, cancelled=false MISMATCH
18-Dec-2017 23:36:10.256 [DEBUG] [ab.binding.zwave.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
18-Dec-2017 23:36:10.258 [DEBUG] [nhab.binding.zwave.internal.protocol.SerialMessage] - Assembled message buffer = 01 09 00 04 00 07 03 20 01 FF 28
18-Dec-2017 23:36:10.260 [DEBUG] [ab.binding.zwave.internal.protocol.ZWaveController] - Process Message = 01 09 00 04 00 07 03 20 01 FF 28
18-Dec-2017 23:36:10.263 [DEBUG] [ab.binding.zwave.internal.protocol.ZWaveController] - Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], priority=High, dest=255, callback=0, payload=00 07 03 20 01 FF
18-Dec-2017 23:36:10.265 [DEBUG] [tocol.serialmessage.ApplicationCommandMessageClass] - NODE 7: Application Command Request (ALIVE:DONE)
18-Dec-2017 23:36:10.266 [DEBUG] [protocol.initialization.ZWaveNodeInitStageAdvancer] - NODE 7: Starting initialisation from DONE
18-Dec-2017 23:36:10.268 [DEBUG] [ab.binding.zwave.internal.protocol.ZWaveController] - Event Listener org.openhab.binding.zwave.internal.protocol.initialization.ZWaveNodeInitStageAdvancer@1c0b5e4 already registered
18-Dec-2017 23:36:10.270 [DEBUG] [tocol.serialmessage.ApplicationCommandMessageClass] - NODE 7: Incoming command class BASIC
18-Dec-2017 23:36:10.271 [DEBUG] [ernal.protocol.commandclass.ZWaveBasicCommandClass] - NODE 7: Received Basic Request
18-Dec-2017 23:36:10.273 [DEBUG] [ernal.protocol.commandclass.ZWaveBasicCommandClass] - NODE 7: Basic Set sent to the controller will be processed as Basic Report
18-Dec-2017 23:36:10.274 [DEBUG] [ernal.protocol.commandclass.ZWaveBasicCommandClass] - NODE 7: Basic report, value = 0xFF
18-Dec-2017 23:36:10.276 [DEBUG] [ab.binding.zwave.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveCommandClassValueEvent
18-Dec-2017 23:36:10.278 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 7: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
18-Dec-2017 23:36:10.279 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 7: Got a value event from Z-Wave network, endpoint = 0, command class = BASIC, value = 255
18-Dec-2017 23:36:10.282 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 7: Updating channel state zwave:device:Zwave:node7:switch_binary to ON [OnOffType]
18-Dec-2017 23:36:10.285 [DEBUG] [ernal.protocol.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Sent Message: class=SendData[0x13], type=Request[0x00], priority=Set, dest=7, callback=181, payload=07 07 60 0D 01 02 25 01 00
18-Dec-2017 23:36:10.287 [DEBUG] [ernal.protocol.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Recv Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], priority=High, dest=255, callback=0, payload=00 07 03 20 01 FF
18-Dec-2017 23:36:10.289 [DEBUG] [ernal.protocol.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: class=ApplicationCommandHandler, callback id=181, expected=SendData, cancelled=false MISMATCH
But still the openhab item not getting an update…
After restoring the zwave binding of snapshot 2.2 it came back to work…
Am I missing something? as far as I know the release should contain the snapshot…
