This is a repost of an earlier post that was lost in the rollback of the forums - apologies if you replied and I didn’t see your reply.
I’ve recently purchased a Z Wave lightbulb from Aeotec and added it to my OpenHab3 ZWave network - the bulb is correctly identified by the binding as a “ZWA001 Bulb 6 Multi-White”.
It is successfully detected by the ZWave binding and presents four channels:
As you can see I’ve added items for the:
- Dimmer
- Colour Temperature - this should let me change the “warmth” of the light.
I’ve also defined these items:
Dimmer Study_Bulb_6_Toggle “Study Light” [Lighting] { channel=“zwave:device:d9cc00035a:node8:switch_dimmer” }Dimmer Study_Bulb_6_Temp { channel=“zwave:device:d9cc00035a:node8:color_temperature” }
The dimmer functionality works fine, but I’m having trouble with the colour temperature item - for reasons I’m not too sure on here when I change the item:
- The light will change brightness, not temperate
- The value of the slider in the UI will jump to 0 after the bulb changes brightness (I could live with this if it actually changed the temperature).
So for some reason it appears the channel is controlling the brightness, not the temperature. I’m fairly new to Z-Wave so I’m unable to suggest what is wrong here. However, I can post the logs of what is going on when I change the temperature:
The node config XML is:
<node>
<homeId>0xe67cbab9</homeId>
<nodeId>8</nodeId>
<version>4</version>
<manufacturer>0x371</manufacturer>
<deviceId>0x1</deviceId>
<deviceType>0x3</deviceType>
<listening>true</listening>
<frequentlyListening>false</frequentlyListening>
<routing>true</routing>
<security>false</security>
<beaming>true</beaming>
<maxBaudRate>40000</maxBaudRate>
<sleepDelay>1000</sleepDelay>
<nodeInformationFrame>
<commandClass>COMMAND_CLASS_ZWAVEPLUS_INFO</commandClass>
<commandClass>COMMAND_CLASS_SWITCH_MULTILEVEL</commandClass>
<commandClass>COMMAND_CLASS_SWITCH_COLOR</commandClass>
<commandClass>COMMAND_CLASS_SCENE_ACTIVATION</commandClass>
<commandClass>COMMAND_CLASS_SCENE_ACTUATOR_CONF</commandClass>
<commandClass>COMMAND_CLASS_CONFIGURATION</commandClass>
<commandClass>COMMAND_CLASS_ASSOCIATION</commandClass>
<commandClass>COMMAND_CLASS_ASSOCIATION_GRP_INFO</commandClass>
<commandClass>COMMAND_CLASS_TRANSPORT_SERVICE</commandClass>
<commandClass>COMMAND_CLASS_VERSION</commandClass>
<commandClass>COMMAND_CLASS_MANUFACTURER_SPECIFIC</commandClass>
<commandClass>COMMAND_CLASS_DEVICE_RESET_LOCALLY</commandClass>
<commandClass>COMMAND_CLASS_POWERLEVEL</commandClass>
<commandClass>COMMAND_CLASS_SECURITY_2</commandClass>
<commandClass>COMMAND_CLASS_SECURITY</commandClass>
<commandClass>COMMAND_CLASS_SUPERVISION</commandClass>
<commandClass>COMMAND_CLASS_FIRMWARE_UPDATE_MD</commandClass>
</nodeInformationFrame>
<associationGroups class="concurrent-hash-map">
<entry>
<int>1</int>
<associationGroup>
<index>1</index>
<maxNodes>0</maxNodes>
<associations>
<associationMember>
<node>1</node>
</associationMember>
</associations>
</associationGroup>
</entry>
</associationGroups>
<endpoints class="concurrent-hash-map">
<entry>
<int>0</int>
<endPoint>
<deviceClass>
<basicDeviceClass>BASIC_TYPE_ROUTING_SLAVE</basicDeviceClass>
<genericDeviceClass>GENERIC_TYPE_SWITCH_MULTILEVEL</genericDeviceClass>
<specificDeviceClass>SPECIFIC_TYPE_POWER_SWITCH_MULTILEVEL</specificDeviceClass>
</deviceClass>
<endpointId>0</endpointId>
<secureCommandClasses/>
<supportedCommandClasses class="concurrent-hash-map">
<entry>
<COMMAND__CLASS__DEVICE__RESET__LOCALLY>
<version>1</version>
<instances>1</instances>
<control>false</control>
<versionSupported>1</versionSupported>
</COMMAND__CLASS__DEVICE__RESET__LOCALLY>
</entry>
<entry>
<COMMAND__CLASS__VERSION>
<version>2</version>
<versionSupported>2</versionSupported>
<libraryType>LIB_SLAVE_ENHANCED</libraryType>
<protocolVersion>4.61</protocolVersion>
<applicationVersion>2.0</applicationVersion>
<hardwareVersion>1</hardwareVersion>
</COMMAND__CLASS__VERSION>
</entry>
<entry>
<commandClass>COMMAND_CLASS_BASIC</commandClass>
<COMMAND__CLASS__BASIC>
<isGetSupported>true</isGetSupported>
</COMMAND__CLASS__BASIC>
</entry>
<entry>
<multiLevelSwitchCommandClass>
</multiLevelSwitchCommandClass>
</entry>
<entry>
<COMMAND__CLASS__SCENE__ACTUATOR__CONF>
</COMMAND__CLASS__SCENE__ACTUATOR__CONF>
</entry>
<entry>
<COMMAND__CLASS__SCENE__ACTIVATION>
</COMMAND__CLASS__SCENE__ACTIVATION>
</entry>
<entry>
<COMMAND__CLASS__SWITCH__COLOR>
<supportedColors>
<colorType>WARM_WHITE</colorType>
<colorType>COLD_WHITE</colorType>
</supportedColors>
<refreshList/>
<colorMap>
<entry>
<null/>
</entry>
<entry>
<null/>
</entry>
</colorMap>
</COMMAND__CLASS__SWITCH__COLOR>
</entry>
<entry>
<COMMAND__CLASS__ASSOCIATION>
<maxGroups>1</maxGroups>
</COMMAND__CLASS__ASSOCIATION>
</entry>
<entry>
<COMMAND__CLASS__ASSOCIATION__GRP__INFO>
<autoSubscribeGroups/>
</COMMAND__CLASS__ASSOCIATION__GRP__INFO>
</entry>
<entry>
<COMMAND__CLASS__CONFIGURATION>
<configParameters>
<entry>
<int>80</int>
<configurationParameter>
<index>80</index>
<size>1</size>
<value>1</value>
<readOnly>false</readOnly>
<writeOnly>false</writeOnly>
</configurationParameter>
</entry>
<entry>
<int>81</int>
<index>81</index>
<size>2</size>
<value>2700</value>
</entry>
<entry>
<int>82</int>
<index>82</index>
<size>2</size>
<value>6500</value>
</entry>
</configParameters>
</COMMAND__CLASS__CONFIGURATION>
</entry>
<entry>
<commandClass>COMMAND_CLASS_NO_OPERATION</commandClass>
<COMMAND__CLASS__NO__OPERATION>
</COMMAND__CLASS__NO__OPERATION>
</entry>
<entry>
<COMMAND__CLASS__ZWAVEPLUS__INFO>
<zwPlusVersion>1</zwPlusVersion>
<zwPlusRole>ROLE_TYPE_SLAVE_ALWAYS_ON</zwPlusRole>
<zwPlusNodeType>NODE_TYPE_ZWAVEPLUS_NODE</zwPlusNodeType>
</COMMAND__CLASS__ZWAVEPLUS__INFO>
</entry>
<entry>
<COMMAND__CLASS__MANUFACTURER__SPECIFIC>
<initSerialNumber>false</initSerialNumber>
<deviceManufacturer>881</deviceManufacturer>
<deviceType>3</deviceType>
<deviceId>1</deviceId>
</COMMAND__CLASS__MANUFACTURER__SPECIFIC>
</entry>
<entry>
<COMMAND__CLASS__SECURITY>
</COMMAND__CLASS__SECURITY>
</entry>
<entry>
<COMMAND__CLASS__POWERLEVEL>
<powerLevel>0</powerLevel>
<powerTimeout>0</powerTimeout>
</COMMAND__CLASS__POWERLEVEL>
</entry>
<entry>
<COMMAND__CLASS__FIRMWARE__UPDATE__MD>
<versionSupported>4</versionSupported>
</COMMAND__CLASS__FIRMWARE__UPDATE__MD>
</entry>
</supportedCommandClasses>
</endPoint>
</entry>
</endpoints>
<nodeNeighbors>
<int>1</int>
<int>4</int>
<int>5</int>
</nodeNeighbors>
<lastReceived>2021-02-06 12:09:17.907 UTC</lastReceived>
</node>
Happy to supply any other logs that might help with diagnosis of what is going on here?
