After I have move my whole main system from an Rpi3B+ (running openhabian 2.5.6) to an Odroid C2 running openhabian 2.5.8, I have noticed my Aeotec Multisensor 6 behave kinda strange.
Exactly every ½ hour, I see this in the log:
2020-09-03 18:46:46.849 [ERROR] [e.smarthome.model.script.ThingStatus] - ZwaveNode5 is offline or doesn't exist.
2020-09-03 18:46:47.615 [INFO ] [e.smarthome.model.script.ThingStatus] - ZwaveNode5 is online.
I cant recall seeing this before. But have anyone else noticed the same?
The sensor is powered with USB. So it´s not running on battery.
The polling is set to the default 240 sec when the device runs on USB power. I have never changed this in the almost 3 years I have had this device.
I may try some debug logging, but atm I have a few others issues I´m debug logging. I hoped someone might respond with the same behaviour. Otherweise I´ll try to debug it… At least its constant every ½ hour, so it should be easy enough to tell from the log, I hope
Hmm… a small update (before I start the debug logging).
It seems like this only happen during a periode without any motion going on. The sensor is placed in my home office (where I´m sitting right now). And there have been no issue since I entered the office after the latest issue at 18:46:47.
But if you don’t know what the problem is, then someone might have “the same behaviour” but caused by a totally different reason. It’s always best to understand the cause of a problem before looking for a solution.
Totally agree. Noone can fix a problem without knowing the cause, except from pure luck!
I guess my question was more like, how much effort I should put into this. If it´s a common issue, maybe a bad device or anything like that, I could live with the offline for less than a second
On the other hand, it would be great if its just some minor issue which could be solved easily. Therefore I will start the debug logging, and hopefully within a a coupple of hours have something for you to look at.
So the issue is caused by the device not sending wakeups within the wakeup period - actually after more than twice the wakeup period. I think you said it was on mains power, so I wouldn’t have expected it to support wakeup.
Try changing the wakeup period to a longer number - at least 15 minutes if your poll period is 30 minutes, but you might as well make it longer.
Its USB powered (which I believe is the same as mains power).
Poll period is 1 day (dont ask why. I have never touched it as far as I recall).
I´ll change the wakeup to ½ hour (1800 secs).
The poll period seems to be 30 minutes for whatever reason. Anyway, as I said I think if you change the wakeup to 30 minutes it will solve this hopefully.
Seems like the change of wakeup to 1800 sec did do some changes… I have not seen the node going offline yet… (However I had to restart openhab due to sudden issues with mqtt broker binding).
I´ll continue to monitoring it, and if it doesnt go offline during the night, I assume it just needed some more time to wakeup, (Man! I can relate to that feeling ).
Although I don’t have the specific device myself, I remember some posts suggesting Aeotec devices which can be battery or mains (USB) powered set their Z-Wave status based on the power state when added to the network. This means if you added the device when on battery, then added a mains PSU, it will continue to sleep as if it were battery powered.
At the risk of adding a ‘me too’ to this issue, I have seen two Aeotec ZW089 Recessed Door Sensor Gen5 battery door sensors dropping offline and back every 15 minutes or so:
2020-09-03 13:12:35.070 [hingStatusInfoChangedEvent] - 'zwave:device:a1aa85fb:node61' changed from ONLINE to OFFLINE (COMMUNICATION_ERROR): Node is not communicating with controller
2020-09-03 13:13:44.004 [hingStatusInfoChangedEvent] - 'zwave:device:a1aa85fb:node61' changed from OFFLINE (COMMUNICATION_ERROR): Node is not communicating with controller to ONLINE
2020-09-03 13:13:44.072 [me.event.ThingUpdatedEvent] - Thing 'zwave:device:a1aa85fb:node61' has been updated.
After changing Wakeup Interval = 1800, these errors have gone so the advice was useful and appreciated!
Thinking more widely, after seeing several minor Z-Wave device config issues over the years (Wakeup Node/ Association Groups not set to the controller, Polling Period / Wakeup Interval timer intervals), I wonder if there’s an opportunity for a ‘Z-Wave config checker’ either as part of Scan or Thing Edit?
Sort of a ‘lint’ tool for device config.
Is it possible to spot that some parameters are generally ‘wrong’ or ‘ill advised’ (e.g. IF zwave_listening == false AND Poll Interval <60S THEN Poor battery life likely)?
I suppose the risk is the complexity rises exponentially if manufacturerId, modelId, or even zwave_version are needed to accomodate the ‘foibles’ of specific devices and firmware updates.
I know thanks… My device has only been included using batteri for the very start (as a test). After that I it was excluded and re-included using USB power.
But you´re right, its important to notice this differences in the way its beeing included.
And it is infact a bit strange devices. Everytime I move the Zwave dongle to another system (new setup) and add the zwave devices stored on the dongle, there is no association group setup for this device, which means I have to update this every time. Otherweise it will not send notfication of movement.
My other zwave devices remember the association group just fine.
I´m not quite sure where info about association group is stored… Perhaps @chris can answer this?
