I just upgraded to the latest snapshop 2.5.0. I removed and re-added all my zwave devices.
I am getting the following error:
2019-06-16 19:24:12.880 [ERROR] [lmessage.RequestNodeInfoMessageClass] - Request node info not placed on stack due to error.
Controlling devices from PAPER UI does nothing. Although the logs make it appear that everything is working.
Logs do not see any updates from devices either.
What do I do to make Zwave devices work?
I am going crazy!
Hardware:Raspberry PI
openHAB version: 2.5.0
A few weeks ago I tried the snapshot and although OH discovered my devices, I could not control them. Subsequently I saw mention zwave was broken in earlier builds, related to the OH restructuring, I believe. I assumed it was still broken.
Do I need to build my existing zwave network from scratch for OH? I have a HUSBZB-1 controller. I am currently running Home Assistant and my current plan was to set up OH items & rules (with no zwave binding) in preparation to moving my zwave to OH.I now have OH 2.4 (OpenHABian) installed for that purpose. I am running Raspbian Lite on a Pi 3B+.
In my case, it is stop & start services. (same server).
EDIT: Look at the quotes in this post to see why I thought zwave was broken in snapshots. (bold added by me)
It’s only an issue when using bindings that use the new serial transport ( org.eclipse.smarthome.io.transport.serial ) instead of gnu.io directly. In 2.5.0-SNAPSHOT these are: DSMR, EnOcean, PowerMax, RFXCom, Serial Button, Smartmeter, Plugwise, ZWave.
Z-Wave works on my setup with OH2.5 Snapshot S1601, but there are others reporting performance problems as of ± snapshot 1600-1602.
My Z-Wave network is very small (only 1 controller, 3 roller shutters and 3 portable remotes configured as secondary controller) so I haven’t seen the HEAL performance problems reported by others.
