Hello
I want to configure my zwave items the “manual” way ![]()
I followed this guide: ZWave Manual Thing Configuration
In fact this is my things file:
Bridge zwave:serial_zstick:Razberry "ZWave Razberry2 Controller" @ "Wohnzimmer" [
port="/dev/ttyAMA0",
controller_softreset="false",
controller_master="true",
heal_enable="true",
security_networkkey="xxxxxxxxxxxxxxxxxxxxx",
inclusion_mode="1"
Thing zwave:fibaro_fgwp102_03_002:Razberry:node2 "ZWave Node2: Fibario Steckdose" (zwave:serial_zstick:Razberry) [node_id=2]
But this does not seem to work: in paperUi I can see this thing:
and the logs looks fine except this:
2017-11-28 22:39:18.189 [ERROR] [ding.zwave.handler.ZWaveThingHandler] - NodeID is not set in zwave:fibaro_fgwp102_03_002:Razberry:node2
I also tried the latest SNAPSHOT, same result.
Any idea how to fix that?
Complete log when saving the thing file:
2017-11-28 22:48:58.207 [INFO ] [ing.zwave.handler.ZWaveSerialHandler] - Stopped ZWave serial handler
2017-11-28 22:48:58.299 [INFO ] [el.core.internal.ModelRepositoryImpl] - Validation issues found in configuration model 'zwave.things', using it anyway:
Provide a thing type ID and a thing ID in this format:
<thingTypeId> <thingId>
2017-11-28 22:48:58.305 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'zwave.things'
2017-11-28 22:48:58.481 [INFO ] [ing.zwave.handler.ZWaveSerialHandler] - Connecting to serial port '/dev/ttyAMA0'
2017-11-28 22:48:58.490 [INFO ] [ing.zwave.handler.ZWaveSerialHandler] - Serial port is initialized
2017-11-28 22:48:58.491 [INFO ] [mmandclass.ZWaveSecurityCommandClass] - Update networkKey
2017-11-28 22:48:58.493 [INFO ] [ve.internal.protocol.ZWaveController] - Starting ZWave controller
2017-11-28 22:48:58.495 [INFO ] [ve.internal.protocol.ZWaveController] - ZWave timeout is set to 5000ms. Soft reset is false.
2017-11-28 22:48:58.609 [ERROR] [ding.zwave.handler.ZWaveThingHandler] - NodeID is not set in zwave:fibaro_fgwp102_03_002:Razberry:node2
2017-11-28 22:48:58.632 [INFO ] [el.core.internal.ModelRepositoryImpl] - Validation issues found in configuration model 'zwave.things', using it anyway:
2017-11-28 22:48:58.643 [INFO ] [el.core.internal.ModelRepositoryImpl] - Refreshing model 'zwave.things'
2017-11-28 22:49:01.769 [INFO ] [ing.zwave.handler.ZWaveSerialHandler] - Stopped ZWave serial handler
2017-11-28 22:49:01.786 [INFO ] [ing.zwave.handler.ZWaveSerialHandler] - Connecting to serial port '/dev/ttyAMA0'
2017-11-28 22:49:01.796 [INFO ] [ing.zwave.handler.ZWaveSerialHandler] - Serial port is initialized
2017-11-28 22:49:01.800 [INFO ] [mmandclass.ZWaveSecurityCommandClass] - Update networkKey
2017-11-28 22:49:01.804 [INFO ] [ve.internal.protocol.ZWaveController] - Starting ZWave controller
2017-11-28 22:49:01.807 [INFO ] [ve.internal.protocol.ZWaveController] - ZWave timeout is set to 5000ms. Soft reset is false.
2017-11-28 22:49:01.828 [ERROR] [ding.zwave.handler.ZWaveThingHandler] - NodeID is not set in zwave:fibaro_fgwp102_03_002:Razberry:node2
2017-11-28 22:49:01.879 [INFO ] [el.core.internal.ModelRepositoryImpl] - Validation issues found in configuration model 'zwave.things', using it anyway:
2017-11-28 22:49:01.882 [INFO ] [el.core.internal.ModelRepositoryImpl] - Refreshing model 'zwave.things'
2017-11-28 22:49:05.081 [INFO ] [ing.zwave.handler.ZWaveSerialHandler] - Stopped ZWave serial handler
2017-11-28 22:49:05.143 [INFO ] [ing.zwave.handler.ZWaveSerialHandler] - Connecting to serial port '/dev/ttyAMA0'
2017-11-28 22:49:05.164 [INFO ] [ing.zwave.handler.ZWaveSerialHandler] - Serial port is initialized
2017-11-28 22:49:05.167 [INFO ] [mmandclass.ZWaveSecurityCommandClass] - Update networkKey
2017-11-28 22:49:05.170 [INFO ] [ve.internal.protocol.ZWaveController] - Starting ZWave controller
2017-11-28 22:49:05.173 [INFO ] [ve.internal.protocol.ZWaveController] - ZWave timeout is set to 5000ms. Soft reset is false.
2017-11-28 22:49:05.194 [ERROR] [ding.zwave.handler.ZWaveThingHandler] - NodeID is not set in zwave:fibaro_fgwp102_03_002:Razberry:node2
2017-11-28 22:49:08.581 [INFO ] [age.SerialApiGetInitDataMessageClass] - NODE 1: Node found
2017-11-28 22:49:08.582 [INFO ] [age.SerialApiGetInitDataMessageClass] - NODE 2: Node found
2017-11-28 22:49:08.585 [INFO ] [age.SerialApiGetInitDataMessageClass] - ZWave Controller using Controller API
2017-11-28 22:49:08.587 [INFO ] [age.SerialApiGetInitDataMessageClass] - ZWave Controller is Primary Controller
2017-11-28 22:49:08.589 [INFO ] [age.SerialApiGetInitDataMessageClass] - ------------Number of Nodes Found Registered to ZWave Controller------------
2017-11-28 22:49:08.592 [INFO ] [age.SerialApiGetInitDataMessageClass] - # Nodes = 2
2017-11-28 22:49:08.594 [INFO ] [age.SerialApiGetInitDataMessageClass] - ----------------------------------------------------------------------------
2017-11-28 22:49:08.796 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing 'zwave:device:Razberry:node2' to inbox.
2017-11-28 22:49:41.880 [INFO ] [age.SerialApiGetInitDataMessageClass] - NODE 1: Node found
2017-11-28 22:49:41.883 [INFO ] [age.SerialApiGetInitDataMessageClass] - NODE 2: Node found
2017-11-28 22:49:41.887 [INFO ] [age.SerialApiGetInitDataMessageClass] - ZWave Controller using Controller API
2017-11-28 22:49:41.890 [INFO ] [age.SerialApiGetInitDataMessageClass] - ZWave Controller is Primary Controller
2017-11-28 22:49:41.893 [INFO ] [age.SerialApiGetInitDataMessageClass] - ------------Number of Nodes Found Registered to ZWave Controller------------
2017-11-28 22:49:41.897 [INFO ] [age.SerialApiGetInitDataMessageClass] - # Nodes = 2
2017-11-28 22:49:41.900 [INFO ] [age.SerialApiGetInitDataMessageClass] - ----------------------------------------------------------------------------
2017-11-28 22:49:41.906 [WARN ] [ve.internal.protocol.ZWaveController] - NODE 1: Attempting to add node that already exists
2017-11-28 22:49:41.909 [WARN ] [ve.internal.protocol.ZWaveController] - NODE 2: Attempting to add node that already exists
2017-11-28 22:49:45.240 [INFO ] [age.SerialApiGetInitDataMessageClass] - NODE 1: Node found
2017-11-28 22:49:45.243 [INFO ] [age.SerialApiGetInitDataMessageClass] - NODE 2: Node found
2017-11-28 22:49:45.247 [INFO ] [age.SerialApiGetInitDataMessageClass] - ZWave Controller using Controller API
2017-11-28 22:49:45.249 [INFO ] [age.SerialApiGetInitDataMessageClass] - ZWave Controller is Primary Controller
2017-11-28 22:49:45.252 [INFO ] [age.SerialApiGetInitDataMessageClass] - ------------Number of Nodes Found Registered to ZWave Controller------------
2017-11-28 22:49:45.264 [INFO ] [age.SerialApiGetInitDataMessageClass] - # Nodes = 2
2017-11-28 22:49:45.267 [INFO ] [age.SerialApiGetInitDataMessageClass] - ----------------------------------------------------------------------------
2017-11-28 22:49:45.272 [WARN ] [ve.internal.protocol.ZWaveController] - NODE 1: Attempting to add node that already exists
2017-11-28 22:49:45.272 [WARN ] [ve.internal.protocol.ZWaveController] - NODE 2: Attempting to add node that already exists
2017-11-28 22:49:46.910 [INFO ] [age.SerialApiGetInitDataMessageClass] - NODE 1: Node found
2017-11-28 22:49:46.934 [INFO ] [age.SerialApiGetInitDataMessageClass] - NODE 2: Node found
2017-11-28 22:49:46.937 [INFO ] [age.SerialApiGetInitDataMessageClass] - ZWave Controller using Controller API
2017-11-28 22:49:46.939 [INFO ] [age.SerialApiGetInitDataMessageClass] - ZWave Controller is Primary Controller
2017-11-28 22:49:46.940 [INFO ] [age.SerialApiGetInitDataMessageClass] - ------------Number of Nodes Found Registered to ZWave Controller------------
2017-11-28 22:49:46.943 [INFO ] [age.SerialApiGetInitDataMessageClass] - # Nodes = 2
2017-11-28 22:49:46.944 [INFO ] [age.SerialApiGetInitDataMessageClass] - ----------------------------------------------------------------------------
2017-11-28 22:49:46.949 [WARN ] [ve.internal.protocol.ZWaveController] - NODE 1: Attempting to add node that already exists
2017-11-28 22:49:46.955 [WARN ] [ve.internal.protocol.ZWaveController] - NODE 2: Attempting to add node that already exists
2017-11-28 22:49:50.270 [INFO ] [age.SerialApiGetInitDataMessageClass] - NODE 1: Node found
2017-11-28 22:49:50.272 [INFO ] [age.SerialApiGetInitDataMessageClass] - NODE 2: Node found
2017-11-28 22:49:50.274 [INFO ] [age.SerialApiGetInitDataMessageClass] - ZWave Controller using Controller API
2017-11-28 22:49:50.276 [INFO ] [age.SerialApiGetInitDataMessageClass] - ZWave Controller is Primary Controller
2017-11-28 22:49:50.278 [INFO ] [age.SerialApiGetInitDataMessageClass] - ------------Number of Nodes Found Registered to ZWave Controller------------
2017-11-28 22:49:50.279 [INFO ] [age.SerialApiGetInitDataMessageClass] - # Nodes = 2
2017-11-28 22:49:50.281 [INFO ] [age.SerialApiGetInitDataMessageClass] - ----------------------------------------------------------------------------
2017-11-28 22:49:50.285 [WARN ] [ve.internal.protocol.ZWaveController] - NODE 1: Attempting to add node that already exists
2017-11-28 22:49:50.287 [WARN ] [ve.internal.protocol.ZWaveController] - NODE 2: Attempting to add node that already exists
2017-11-28 22:49:51.939 [INFO ] [age.SerialApiGetInitDataMessageClass] - NODE 1: Node found
2017-11-28 22:49:51.941 [INFO ] [age.SerialApiGetInitDataMessageClass] - NODE 2: Node found
2017-11-28 22:49:51.945 [INFO ] [age.SerialApiGetInitDataMessageClass] - ZWave Controller using Controller API
2017-11-28 22:49:51.948 [INFO ] [age.SerialApiGetInitDataMessageClass] - ZWave Controller is Primary Controller
2017-11-28 22:49:51.949 [INFO ] [age.SerialApiGetInitDataMessageClass] - ------------Number of Nodes Found Registered to ZWave Controller------------
2017-11-28 22:49:51.951 [INFO ] [age.SerialApiGetInitDataMessageClass] - # Nodes = 2
2017-11-28 22:49:51.953 [INFO ] [age.SerialApiGetInitDataMessageClass] - ----------------------------------------------------------------------------
2017-11-28 22:49:51.966 [WARN ] [ve.internal.protocol.ZWaveController] - NODE 1: Attempting to add node that already exists
2017-11-28 22:49:51.966 [WARN ] [ve.internal.protocol.ZWaveController] - NODE 2: Attempting to add node that already exists
2017-11-28 22:49:55.301 [INFO ] [age.SerialApiGetInitDataMessageClass] - NODE 1: Node found
2017-11-28 22:49:55.303 [INFO ] [age.SerialApiGetInitDataMessageClass] - NODE 2: Node found
2017-11-28 22:49:55.305 [INFO ] [age.SerialApiGetInitDataMessageClass] - ZWave Controller using Controller API
2017-11-28 22:49:55.307 [INFO ] [age.SerialApiGetInitDataMessageClass] - ZWave Controller is Primary Controller
2017-11-28 22:49:55.310 [INFO ] [age.SerialApiGetInitDataMessageClass] - ------------Number of Nodes Found Registered to ZWave Controller------------
2017-11-28 22:49:55.312 [INFO ] [age.SerialApiGetInitDataMessageClass] - # Nodes = 2
2017-11-28 22:49:55.315 [INFO ] [age.SerialApiGetInitDataMessageClass] - ----------------------------------------------------------------------------
2017-11-28 22:49:55.320 [WARN ] [ve.internal.protocol.ZWaveController] - NODE 1: Attempting to add node that already exists
2017-11-28 22:49:55.322 [WARN ] [ve.internal.protocol.ZWaveController] - NODE 2: Attempting to add node that already exists
2017-11-28 22:49:56.970 [INFO ] [age.SerialApiGetInitDataMessageClass] - NODE 1: Node found
2017-11-28 22:49:56.979 [INFO ] [age.SerialApiGetInitDataMessageClass] - NODE 2: Node found
2017-11-28 22:49:56.983 [INFO ] [age.SerialApiGetInitDataMessageClass] - ZWave Controller using Controller API
2017-11-28 22:49:56.985 [INFO ] [age.SerialApiGetInitDataMessageClass] - ZWave Controller is Primary Controller
2017-11-28 22:49:56.988 [INFO ] [age.SerialApiGetInitDataMessageClass] - ------------Number of Nodes Found Registered to ZWave Controller------------
2017-11-28 22:49:56.990 [INFO ] [age.SerialApiGetInitDataMessageClass] - # Nodes = 2
2017-11-28 22:49:56.993 [INFO ] [age.SerialApiGetInitDataMessageClass] - ----------------------------------------------------------------------------
2017-11-28 22:49:56.998 [WARN ] [ve.internal.protocol.ZWaveController] - NODE 1: Attempting to add node that already exists
2017-11-28 22:49:56.998 [WARN ] [ve.internal.protocol.ZWaveController] - NODE 2: Attempting to add node that already exists
2017-11-28 22:50:00.335 [INFO ] [age.SerialApiGetInitDataMessageClass] - NODE 1: Node found
2017-11-28 22:50:00.338 [INFO ] [age.SerialApiGetInitDataMessageClass] - NODE 2: Node found
2017-11-28 22:50:00.341 [INFO ] [age.SerialApiGetInitDataMessageClass] - ZWave Controller using Controller API
2017-11-28 22:50:00.344 [INFO ] [age.SerialApiGetInitDataMessageClass] - ZWave Controller is Primary Controller
2017-11-28 22:50:00.348 [INFO ] [age.SerialApiGetInitDataMessageClass] - ------------Number of Nodes Found Registered to ZWave Controller------------
2017-11-28 22:50:00.351 [INFO ] [age.SerialApiGetInitDataMessageClass] - # Nodes = 2
2017-11-28 22:50:00.354 [INFO ] [age.SerialApiGetInitDataMessageClass] - ----------------------------------------------------------------------------
2017-11-28 22:50:00.361 [WARN ] [ve.internal.protocol.ZWaveController] - NODE 1: Attempting to add node that already exists
2017-11-28 22:50:00.364 [WARN ] [ve.internal.protocol.ZWaveController] - NODE 2: Attempting to add node that already exists
