@sihui & @chris
Here is the complete log with inclusion of the new node (now node 38). Binary2 remains silentā¦ The log is uploaded. The log is available at https://ufile.io/86zd6
Interesting thing: When I set association groups for S2 switch to openHAB, then on binary I can correctly read the S2 input. Log is here:
2017-08-28 22:06:45.043 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 09 00 04 08 26 03 20 01 FF 01
2017-08-28 22:06:45.049 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Response SENT 6
2017-08-28 22:06:45.052 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], dest=38, callback=8, payload=08 26 03 20 01 FF
2017-08-28 22:06:45.054 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage past lock Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], dest=38, callback=8, payload=08 26 03 20 01 FF
2017-08-28 22:06:45.057 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], dest=38, callback=8, payload=08 26 03 20 01 FF
2017-08-28 22:06:45.064 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 09 00 04 00 26 03 20 01 FF 09
2017-08-28 22:06:45.069 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2017-08-28 22:06:45.072 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 38: Application Command Request (ALIVE:DONE)
2017-08-28 22:06:45.074 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 38: resetResendCount initComplete=true isDead=false
2017-08-28 22:06:45.075 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 38: Incoming command class COMMAND_CLASS_BASIC, endpoint 0
2017-08-28 22:06:45.075 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Response SENT 6
2017-08-28 22:06:45.077 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 38: SECURITY NOT required on COMMAND_CLASS_BASIC
2017-08-28 22:06:45.078 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 38: Received COMMAND_CLASS_BASIC V1 BASIC_SET
2017-08-28 22:06:45.080 [DEBUG] [.commandclass.ZWaveBasicCommandClass] - NODE 38: Basic report, value = 255
2017-08-28 22:06:45.081 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveCommandClassValueEvent
2017-08-28 22:06:45.082 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], dest=38, callback=0, payload=00 26 03 20 01 FF
2017-08-28 22:06:45.083 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 38: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
2017-08-28 22:06:45.084 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 38: Got a value event from Z-Wave network, endpoint = 0, command class = COMMAND_CLASS_BASIC, value = 255
2017-08-28 22:06:45.086 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage past lock Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], dest=38, callback=0, payload=00 26 03 20 01 FF
2017-08-28 22:06:45.087 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 38: Updating channel state zwave:device:15db442c729:node38:switch_binary to ON [OnOffType]
2017-08-28 22:06:45.090 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 38: Commands processed 1.
2017-08-28 22:06:45.092 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 38: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@f2a824.
2017-08-28 22:06:45.093 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2017-08-28 22:06:45.094 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2017-08-28 22:06:45.104 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], dest=38, callback=0, payload=00 26 03 20 01 FF
2017-08-28 22:06:45.106 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2017-08-28 22:06:45.107 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 38: Application Command Request (ALIVE:DONE)
2017-08-28 22:06:45.108 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 38: resetResendCount initComplete=true isDead=false
2017-08-28 22:06:45.110 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 38: Incoming command class COMMAND_CLASS_BASIC, endpoint 0
2017-08-28 22:06:45.111 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 38: SECURITY NOT required on COMMAND_CLASS_BASIC
2017-08-28 22:06:45.112 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 38: Received COMMAND_CLASS_BASIC V1 BASIC_SET
2017-08-28 22:06:45.114 [DEBUG] [.commandclass.ZWaveBasicCommandClass] - NODE 38: Basic report, value = 255
2017-08-28 22:06:45.115 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveCommandClassValueEvent
2017-08-28 22:06:45.117 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 38: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
2017-08-28 22:06:45.118 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 38: Got a value event from Z-Wave network, endpoint = 0, command class = COMMAND_CLASS_BASIC, value = 255
2017-08-28 22:06:45.120 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 38: Updating channel state zwave:device:15db442c729:node38:switch_binary to ON [OnOffType]
2017-08-28 22:06:45.123 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 38: Commands processed 1.
2017-08-28 22:06:45.125 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 38: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@15e8131.
2017-08-28 22:06:45.126 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2017-08-28 22:06:45.129 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2017-08-28 22:06:45.131 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2017-08-28 22:06:45.132 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start
2017-08-28 22:06:45.133 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 28: listening == false, frequentlyListening == false, awake == false
2017-08-28 22:06:45.134 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 28: Node not awake!
2017-08-28 22:06:45.135 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 28: listening == false, frequentlyListening == false, awake == false
2017-08-28 22:06:45.136 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 28: Node not awake!
2017-08-28 22:06:45.138 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction from controllerQueue
2017-08-28 22:06:45.139 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage nothing
2017-08-28 22:06:50.424 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 09 00 04 08 26 03 20 01 00 FE
2017-08-28 22:06:50.429 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Response SENT 6
2017-08-28 22:06:50.432 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], dest=38, callback=8, payload=08 26 03 20 01 00
2017-08-28 22:06:50.435 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage past lock Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], dest=38, callback=8, payload=08 26 03 20 01 00
2017-08-28 22:06:50.437 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], dest=38, callback=8, payload=08 26 03 20 01 00
2017-08-28 22:06:50.439 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2017-08-28 22:06:50.440 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 09 00 04 00 26 03 20 01 00 F6
2017-08-28 22:06:50.440 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 38: Application Command Request (ALIVE:DONE)
2017-08-28 22:06:50.442 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 38: resetResendCount initComplete=true isDead=false
2017-08-28 22:06:50.444 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 38: Incoming command class COMMAND_CLASS_BASIC, endpoint 0
2017-08-28 22:06:50.445 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 38: SECURITY NOT required on COMMAND_CLASS_BASIC
2017-08-28 22:06:50.446 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 38: Received COMMAND_CLASS_BASIC V1 BASIC_SET
2017-08-28 22:06:50.448 [DEBUG] [.commandclass.ZWaveBasicCommandClass] - NODE 38: Basic report, value = 0
2017-08-28 22:06:50.448 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Response SENT 6
2017-08-28 22:06:50.449 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveCommandClassValueEvent
2017-08-28 22:06:50.450 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 38: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
2017-08-28 22:06:50.451 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 38: Got a value event from Z-Wave network, endpoint = 0, command class = COMMAND_CLASS_BASIC, value = 0
2017-08-28 22:06:50.453 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 38: Updating channel state zwave:device:15db442c729:node38:switch_binary to OFF [OnOffType]
2017-08-28 22:06:50.454 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], dest=38, callback=0, payload=00 26 03 20 01 00
2017-08-28 22:06:50.456 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 38: Commands processed 1.
2017-08-28 22:06:50.457 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 38: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@36f848.
2017-08-28 22:06:50.458 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2017-08-28 22:06:50.459 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2017-08-28 22:06:50.460 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage past lock Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], dest=38, callback=0, payload=00 26 03 20 01 00
2017-08-28 22:06:50.461 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2017-08-28 22:06:50.462 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start
2017-08-28 22:06:50.463 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 28: listening == false, frequentlyListening == false, awake == false
2017-08-28 22:06:50.468 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 28: Node not awake!
2017-08-28 22:06:50.469 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 28: listening == false, frequentlyListening == false, awake == false
2017-08-28 22:06:50.470 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 28: Node not awake!
2017-08-28 22:06:50.471 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction from controllerQueue
2017-08-28 22:06:50.472 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage nothing
2017-08-28 22:06:50.474 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], dest=38, callback=0, payload=00 26 03 20 01 00
2017-08-28 22:06:50.475 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2017-08-28 22:06:50.476 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 38: Application Command Request (ALIVE:DONE)
2017-08-28 22:06:50.477 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 38: resetResendCount initComplete=true isDead=false
2017-08-28 22:06:50.479 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 38: Incoming command class COMMAND_CLASS_BASIC, endpoint 0
2017-08-28 22:06:50.480 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 38: SECURITY NOT required on COMMAND_CLASS_BASIC
2017-08-28 22:06:50.481 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 38: Received COMMAND_CLASS_BASIC V1 BASIC_SET
2017-08-28 22:06:50.482 [DEBUG] [.commandclass.ZWaveBasicCommandClass] - NODE 38: Basic report, value = 0
2017-08-28 22:06:50.483 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveCommandClassValueEvent
2017-08-28 22:06:50.485 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 38: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
2017-08-28 22:06:50.486 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 38: Got a value event from Z-Wave network, endpoint = 0, command class = COMMAND_CLASS_BASIC, value = 0
2017-08-28 22:06:50.488 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 38: Updating channel state zwave:device:15db442c729:node38:switch_binary to OFF [OnOffType]
2017-08-28 22:06:50.492 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 38: Commands processed 1.
2017-08-28 22:06:50.493 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 38: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@10b704b.
2017-08-28 22:06:50.494 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2017-08-28 22:06:50.498 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2017-08-28 22:06:50.499 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
Thx, Michael
