Hello @sihui and @chris ,
here is the debug log. It is about node 36 (FGS 223). Voltage was applied manually to input 2 at 17:31:39, and voltage was removed from input 2 at 17:31:45 (corresponding to turn on / turn off).
2017-08-25 17:31:39.883 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 0B 00 04 00 24 05 5B 03 20 00 02 AB
2017-08-25 17:31:39.892 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Response SENT 6
2017-08-25 17:31:39.896 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], dest=36, callback=0, payload=00 24 05 5B 03 20 00 02
2017-08-25 17:31:39.899 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage past lock Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], dest=36, callback=0, payload=00 24 05 5B 03 20 00 02
2017-08-25 17:31:39.901 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], dest=36, callback=0, payload=00 24 05 5B 03 20 00 02
2017-08-25 17:31:39.908 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2017-08-25 17:31:39.910 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 36: Application Command Request (ALIVE:DONE)
2017-08-25 17:31:39.911 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 36: resetResendCount initComplete=true isDead=false
2017-08-25 17:31:39.912 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 36: Incoming command class COMMAND_CLASS_CENTRAL_SCENE, endpoint 0
2017-08-25 17:31:39.913 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 36: SECURITY NOT required on COMMAND_CLASS_CENTRAL_SCENE
2017-08-25 17:31:39.915 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 36: Received COMMAND_CLASS_CENTRAL_SCENE V2 CENTRAL_SCENE_NOTIFICATION
2017-08-25 17:31:39.917 [DEBUG] [dclass.ZWaveCentralSceneCommandClass] - NODE 36: Received scene 2 at key 0 [Single Press]
2017-08-25 17:31:39.918 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveCommandClassValueEvent
2017-08-25 17:31:39.920 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 36: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
2017-08-25 17:31:39.922 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 36: Got a value event from Z-Wave network, endpoint = 0, command class = COMMAND_CLASS_CENTRAL_SCENE, value = 2.0
2017-08-25 17:31:39.924 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 36: Updating channel state zwave:device:15db442c729:node36:scene_number to 2.0 [DecimalType]
2017-08-25 17:31:39.926 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 36: Commands processed 1.
2017-08-25 17:31:39.927 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 36: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@116db75.
2017-08-25 17:31:39.928 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2017-08-25 17:31:39.929 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2017-08-25 17:31:39.931 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2017-08-25 17:31:39.932 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start
2017-08-25 17:31:39.933 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction from controllerQueue
2017-08-25 17:31:39.933 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage nothing
2017-08-25 17:31:43.902 [DEBUG] [rialmessage.IsFailedNodeMessageClass] - NODE 30: Requesting IsFailedNode status from controller.
2017-08-25 17:31:43.904 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 255: sendTransaction org.openhab.binding.zwave.internal.protocol.ZWaveSerialPayload@169d986
2017-08-25 17:31:43.905 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 255: Adding to controller queue
2017-08-25 17:31:43.906 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 255: Added to queue - size 1
2017-08-25 17:31:43.907 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start
2017-08-25 17:31:43.908 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction from controllerQueue
2017-08-25 17:31:43.909 [DEBUG] [nal.protocol.ZWaveTransactionManager] - getTransactionToSend 6
2017-08-25 17:31:43.912 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 04 00 62 1E 87
2017-08-25 17:31:43.914 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 255: Sending REQUEST Message = 01 04 00 62 1E 87
2017-08-25 17:31:43.915 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - Message SENT
2017-08-25 17:31:43.916 [DEBUG] [e.internal.protocol.ZWaveTransaction] - TID 2307: Transaction Start type IsFailedNodeID
2017-08-25 17:31:43.918 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 06
2017-08-25 17:31:43.918 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage started: TID 2307: [WAIT_RESPONSE] requiresResponse=true callback: 0
2017-08-25 17:31:43.919 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage started: expected cmd class: null
2017-08-25 17:31:43.920 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=null[0x00], type=ACK[0x02], dest=255, callback=0, payload=
2017-08-25 17:31:43.920 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage started: expected cmd: null
2017-08-25 17:31:43.921 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage Transactions outstanding: 1
2017-08-25 17:31:43.921 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage past lock Message: class=null[0x00], type=ACK[0x02], dest=255, callback=0, payload=
2017-08-25 17:31:43.924 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=null[0x00], type=ACK[0x02], dest=255, callback=0, payload=
2017-08-25 17:31:43.925 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2017-08-25 17:31:43.926 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 04 01 62 01 99
2017-08-25 17:31:43.926 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg: ACK
2017-08-25 17:31:43.927 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2017-08-25 17:31:43.930 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Start transaction timer to Fri Aug 25 17:31:45 CEST 2017 - 1999ms
2017-08-25 17:31:43.931 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start
2017-08-25 17:31:43.929 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Response SENT 6
2017-08-25 17:31:43.928 [DEBUG] [rialmessage.IsFailedNodeMessageClass] - NODE 2: Requesting IsFailedNode status from controller.
2017-08-25 17:31:43.934 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 255: sendTransaction org.openhab.binding.zwave.internal.protocol.ZWaveSerialPayload@1c51cfb
2017-08-25 17:31:43.931 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage lastTransaction: TID 2307: [WAIT_RESPONSE] requiresResponse=true callback: 0
2017-08-25 17:31:43.935 [DEBUG] [nal.protocol.ZWaveTransactionManager] - STOP transaction timer
2017-08-25 17:31:43.937 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Start transaction timer to Fri Aug 25 17:31:45 CEST 2017 - 1986ms
2017-08-25 17:31:43.934 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=IsFailedNodeID[0x62], type=Response[0x01], dest=255, callback=0, payload=01
2017-08-25 17:31:43.938 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 255: Adding to controller queue
2017-08-25 17:31:43.940 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 255: Added to queue - size 1
2017-08-25 17:31:43.940 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage past lock Message: class=IsFailedNodeID[0x62], type=Response[0x01], dest=255, callback=0, payload=01
2017-08-25 17:31:43.941 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction lastTransaction outstanding...
2017-08-25 17:31:43.941 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start
2017-08-25 17:31:43.942 [DEBUG] [nal.protocol.ZWaveTransactionManager] - STOP transaction timer
2017-08-25 17:31:43.944 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Start transaction timer to Fri Aug 25 17:31:45 CEST 2017 - 1978ms
2017-08-25 17:31:43.945 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction lastTransaction outstanding...
2017-08-25 17:31:43.946 [DEBUG] [rialmessage.IsFailedNodeMessageClass] - NODE 28: Requesting IsFailedNode status from controller.
2017-08-25 17:31:43.946 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=IsFailedNodeID[0x62], type=Response[0x01], dest=255, callback=0, payload=01
2017-08-25 17:31:43.948 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 2307: [WAIT_RESPONSE] requiresResponse=true callback: 0
2017-08-25 17:31:43.948 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 255: sendTransaction org.openhab.binding.zwave.internal.protocol.ZWaveSerialPayload@1a0717f
2017-08-25 17:31:43.951 [DEBUG] [nal.protocol.ZWaveTransactionManager] - STOP transaction timer
2017-08-25 17:31:43.953 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Start transaction timer to Fri Aug 25 17:31:45 CEST 2017 - 1969ms
2017-08-25 17:31:43.955 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 255: Adding to controller queue
2017-08-25 17:31:43.956 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 255: Added to queue - size 2
2017-08-25 17:31:43.958 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 1
2017-08-25 17:31:43.958 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start
2017-08-25 17:31:43.959 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: TID 2307: [WAIT_RESPONSE] requiresResponse=true callback: 0
2017-08-25 17:31:43.961 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction lastTransaction outstanding...
2017-08-25 17:31:43.962 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=IsFailedNodeID[0x62], type=Response[0x01], dest=255, callback=0, payload=01
2017-08-25 17:31:43.962 [DEBUG] [nal.protocol.ZWaveTransactionManager] - STOP transaction timer
2017-08-25 17:31:43.963 [WARN ] [rialmessage.IsFailedNodeMessageClass] - NODE 30: Is currently marked as failed by the controller!
2017-08-25 17:31:43.964 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Start transaction timer to Fri Aug 25 17:31:45 CEST 2017 - 1959ms
2017-08-25 17:31:43.965 [DEBUG] [e.internal.protocol.ZWaveTransaction] - TID 2307: Transaction COMPLETED
2017-08-25 17:31:43.966 [DEBUG] [e.internal.protocol.ZWaveTransaction] - TID 2307: TransactionAdvance ST: DONE
2017-08-25 17:31:43.967 [DEBUG] [e.internal.protocol.ZWaveTransaction] - TID 2307: TransactionAdvance WT: null {}
2017-08-25 17:31:43.969 [DEBUG] [e.internal.protocol.ZWaveTransaction] - TID 2307: TransactionAdvance RX: Message: class=IsFailedNodeID[0x62], type=Response[0x01], dest=255, callback=0, payload=01
2017-08-25 17:31:43.971 [DEBUG] [e.internal.protocol.ZWaveTransaction] - TID 2307: TransactionAdvance TO: DONE
2017-08-25 17:31:43.972 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 255: Response processed after 56ms
2017-08-25 17:31:43.973 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 255: TID 2307: Transaction completed
2017-08-25 17:31:43.974 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 255: notifyTransactionResponse TID:2307 DONE
2017-08-25 17:31:43.976 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveTransactionCompletedEvent
2017-08-25 17:31:43.976 [DEBUG] [nal.protocol.ZWaveTransactionManager] - TID 2307: Transaction event listener: DONE: DONE ->
2017-08-25 17:31:43.977 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2017-08-25 17:31:43.978 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 255: -- To notify -- COMPLETE
2017-08-25 17:31:43.978 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start
2017-08-25 17:31:43.979 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction from controllerQueue
2017-08-25 17:31:43.980 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ********* Transaction Response Complete 2307 --
2017-08-25 17:31:43.981 [DEBUG] [nal.protocol.ZWaveTransactionManager] - getTransactionToSend 6
2017-08-25 17:31:43.981 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 30: Node Init response (0) COMPLETE
2017-08-25 17:31:43.987 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 30: Node Init transaction completed with response COMPLETE
2017-08-25 17:31:43.988 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 04 00 62 02 9B
2017-08-25 17:31:43.990 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 255: Sending REQUEST Message = 01 04 00 62 02 9B
2017-08-25 17:31:43.992 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - Message SENT
2017-08-25 17:31:43.994 [DEBUG] [e.internal.protocol.ZWaveTransaction] - TID 2308: Transaction Start type IsFailedNodeID
2017-08-25 17:31:43.995 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage started: TID 2308: [WAIT_RESPONSE] requiresResponse=true callback: 0
2017-08-25 17:31:43.995 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 06
2017-08-25 17:31:43.997 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage started: expected cmd class: null
2017-08-25 17:31:43.998 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage started: expected cmd: null
2017-08-25 17:31:43.998 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=null[0x00], type=ACK[0x02], dest=255, callback=0, payload=
2017-08-25 17:31:43.999 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage Transactions outstanding: 1
2017-08-25 17:31:44.000 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage past lock Message: class=null[0x00], type=ACK[0x02], dest=255, callback=0, payload=
2017-08-25 17:31:44.000 [DEBUG] [nal.protocol.ZWaveTransactionManager] - STOP transaction timer
2017-08-25 17:31:44.001 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Start transaction timer to Fri Aug 25 17:31:46 CEST 2017 - 1999ms
2017-08-25 17:31:44.002 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage lastTransaction: TID 2308: [WAIT_RESPONSE] requiresResponse=true callback: 0
2017-08-25 17:31:44.003 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 04 01 62 01 99
2017-08-25 17:31:44.003 [DEBUG] [nal.protocol.ZWaveTransactionManager] - STOP transaction timer
2017-08-25 17:31:44.004 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Start transaction timer to Fri Aug 25 17:31:46 CEST 2017 - 1996ms
2017-08-25 17:31:44.004 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Response SENT 6
2017-08-25 17:31:44.005 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=null[0x00], type=ACK[0x02], dest=255, callback=0, payload=
2017-08-25 17:31:44.006 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=IsFailedNodeID[0x62], type=Response[0x01], dest=255, callback=0, payload=01
2017-08-25 17:31:44.006 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 2308: [WAIT_RESPONSE] requiresResponse=true callback: 0
2017-08-25 17:31:44.007 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage past lock Message: class=IsFailedNodeID[0x62], type=Response[0x01], dest=255, callback=0, payload=01
2017-08-25 17:31:44.007 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg: ACK
2017-08-25 17:31:44.008 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=IsFailedNodeID[0x62], type=Response[0x01], dest=255, callback=0, payload=01
2017-08-25 17:31:44.009 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 2308: [WAIT_RESPONSE] requiresResponse=true callback: 0
2017-08-25 17:31:44.010 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 1
2017-08-25 17:31:44.011 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: TID 2308: [WAIT_RESPONSE] requiresResponse=true callback: 0
2017-08-25 17:31:44.013 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=IsFailedNodeID[0x62], type=Response[0x01], dest=255, callback=0, payload=01
2017-08-25 17:31:44.014 [WARN ] [rialmessage.IsFailedNodeMessageClass] - NODE 2: Is currently marked as failed by the controller!
2017-08-25 17:31:44.015 [DEBUG] [e.internal.protocol.ZWaveTransaction] - TID 2308: Transaction COMPLETED
2017-08-25 17:31:44.016 [DEBUG] [e.internal.protocol.ZWaveTransaction] - TID 2308: TransactionAdvance ST: DONE
2017-08-25 17:31:44.017 [DEBUG] [e.internal.protocol.ZWaveTransaction] - TID 2308: TransactionAdvance WT: null {}
2017-08-25 17:31:44.018 [DEBUG] [e.internal.protocol.ZWaveTransaction] - TID 2308: TransactionAdvance RX: Message: class=IsFailedNodeID[0x62], type=Response[0x01], dest=255, callback=0, payload=01
2017-08-25 17:31:44.019 [DEBUG] [e.internal.protocol.ZWaveTransaction] - TID 2308: TransactionAdvance TO: DONE
2017-08-25 17:31:44.020 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 255: Response processed after 26ms
2017-08-25 17:31:44.022 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 255: TID 2308: Transaction completed
2017-08-25 17:31:44.023 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 255: notifyTransactionResponse TID:2308 DONE
2017-08-25 17:31:44.024 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveTransactionCompletedEvent
2017-08-25 17:31:44.024 [DEBUG] [nal.protocol.ZWaveTransactionManager] - TID 2308: Transaction event listener: DONE: DONE ->
2017-08-25 17:31:44.025 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2017-08-25 17:31:44.025 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 255: -- To notify -- COMPLETE
2017-08-25 17:31:44.026 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start
2017-08-25 17:31:44.028 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ********* Transaction Response Complete 2308 --
2017-08-25 17:31:44.028 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction from controllerQueue
2017-08-25 17:31:44.029 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 2: Node Init response (0) COMPLETE
2017-08-25 17:31:44.032 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 2: Node Init transaction completed with response COMPLETE
2017-08-25 17:31:44.033 [DEBUG] [nal.protocol.ZWaveTransactionManager] - getTransactionToSend 6
2017-08-25 17:31:44.035 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 04 00 62 1C 85
2017-08-25 17:31:44.036 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 255: Sending REQUEST Message = 01 04 00 62 1C 85
2017-08-25 17:31:44.038 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - Message SENT
2017-08-25 17:31:44.039 [DEBUG] [e.internal.protocol.ZWaveTransaction] - TID 2309: Transaction Start type IsFailedNodeID
2017-08-25 17:31:44.039 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage started: TID 2309: [WAIT_RESPONSE] requiresResponse=true callback: 0
2017-08-25 17:31:44.040 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 06
2017-08-25 17:31:44.041 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage started: expected cmd class: null
2017-08-25 17:31:44.042 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=null[0x00], type=ACK[0x02], dest=255, callback=0, payload=
2017-08-25 17:31:44.042 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage started: expected cmd: null
2017-08-25 17:31:44.043 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage Transactions outstanding: 1
2017-08-25 17:31:44.043 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage past lock Message: class=null[0x00], type=ACK[0x02], dest=255, callback=0, payload=
2017-08-25 17:31:44.044 [DEBUG] [nal.protocol.ZWaveTransactionManager] - STOP transaction timer
2017-08-25 17:31:44.045 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Start transaction timer to Fri Aug 25 17:31:46 CEST 2017 - 1999ms
2017-08-25 17:31:44.046 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 04 01 62 01 99
2017-08-25 17:31:44.046 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage lastTransaction: TID 2309: [WAIT_RESPONSE] requiresResponse=true callback: 0
2017-08-25 17:31:44.047 [DEBUG] [nal.protocol.ZWaveTransactionManager] - STOP transaction timer
2017-08-25 17:31:44.048 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Response SENT 6
2017-08-25 17:31:44.048 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Start transaction timer to Fri Aug 25 17:31:46 CEST 2017 - 1996ms
2017-08-25 17:31:44.050 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=null[0x00], type=ACK[0x02], dest=255, callback=0, payload=
2017-08-25 17:31:44.050 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 1<>127 : Message: class=IsFailedNodeID[0x62], type=Response[0x01], dest=255, callback=0, payload=01
2017-08-25 17:31:44.051 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 2309: [WAIT_RESPONSE] requiresResponse=true callback: 0
2017-08-25 17:31:44.052 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage past lock Message: class=IsFailedNodeID[0x62], type=Response[0x01], dest=255, callback=0, payload=01
2017-08-25 17:31:44.052 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg: ACK
2017-08-25 17:31:44.053 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=IsFailedNodeID[0x62], type=Response[0x01], dest=255, callback=0, payload=01
2017-08-25 17:31:44.054 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 2309: [WAIT_RESPONSE] requiresResponse=true callback: 0
2017-08-25 17:31:44.055 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 1
2017-08-25 17:31:44.056 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: TID 2309: [WAIT_RESPONSE] requiresResponse=true callback: 0
2017-08-25 17:31:44.058 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=IsFailedNodeID[0x62], type=Response[0x01], dest=255, callback=0, payload=01
2017-08-25 17:31:44.059 [WARN ] [rialmessage.IsFailedNodeMessageClass] - NODE 28: Is currently marked as failed by the controller!
2017-08-25 17:31:44.060 [DEBUG] [e.internal.protocol.ZWaveTransaction] - TID 2309: Transaction COMPLETED
2017-08-25 17:31:44.061 [DEBUG] [e.internal.protocol.ZWaveTransaction] - TID 2309: TransactionAdvance ST: DONE
2017-08-25 17:31:44.061 [DEBUG] [e.internal.protocol.ZWaveTransaction] - TID 2309: TransactionAdvance WT: null {}
2017-08-25 17:31:44.063 [DEBUG] [e.internal.protocol.ZWaveTransaction] - TID 2309: TransactionAdvance RX: Message: class=IsFailedNodeID[0x62], type=Response[0x01], dest=255, callback=0, payload=01
2017-08-25 17:31:44.063 [DEBUG] [e.internal.protocol.ZWaveTransaction] - TID 2309: TransactionAdvance TO: DONE
2017-08-25 17:31:44.064 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 255: Response processed after 26ms
2017-08-25 17:31:44.065 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 255: TID 2309: Transaction completed
2017-08-25 17:31:44.066 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 255: notifyTransactionResponse TID:2309 DONE
2017-08-25 17:31:44.067 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveTransactionCompletedEvent
2017-08-25 17:31:44.067 [DEBUG] [nal.protocol.ZWaveTransactionManager] - TID 2309: Transaction event listener: DONE: DONE ->
2017-08-25 17:31:44.068 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2017-08-25 17:31:44.068 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 255: -- To notify -- COMPLETE
2017-08-25 17:31:44.069 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start
2017-08-25 17:31:44.069 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction from controllerQueue
2017-08-25 17:31:44.069 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ********* Transaction Response Complete 2309 --
2017-08-25 17:31:44.072 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage nothing
2017-08-25 17:31:44.072 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 28: Node Init response (0) COMPLETE
2017-08-25 17:31:44.073 [DEBUG] [nal.protocol.ZWaveTransactionManager] - STOP transaction timer
2017-08-25 17:31:44.073 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 28: Node Init transaction completed with response COMPLETE
2017-08-25 17:31:45.764 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 0B 00 04 00 24 05 5B 03 21 00 02 AA
2017-08-25 17:31:45.770 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Response SENT 6
2017-08-25 17:31:45.774 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], dest=36, callback=0, payload=00 24 05 5B 03 21 00 02
2017-08-25 17:31:45.777 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage past lock Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], dest=36, callback=0, payload=00 24 05 5B 03 21 00 02
2017-08-25 17:31:45.779 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], dest=36, callback=0, payload=00 24 05 5B 03 21 00 02
2017-08-25 17:31:45.781 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2017-08-25 17:31:45.782 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 36: Application Command Request (ALIVE:DONE)
2017-08-25 17:31:45.783 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 36: resetResendCount initComplete=true isDead=false
2017-08-25 17:31:45.785 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 36: Incoming command class COMMAND_CLASS_CENTRAL_SCENE, endpoint 0
2017-08-25 17:31:45.786 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 36: SECURITY NOT required on COMMAND_CLASS_CENTRAL_SCENE
2017-08-25 17:31:45.788 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 36: Received COMMAND_CLASS_CENTRAL_SCENE V2 CENTRAL_SCENE_NOTIFICATION
2017-08-25 17:31:45.789 [DEBUG] [dclass.ZWaveCentralSceneCommandClass] - NODE 36: Received scene 2 at key 0 [Single Press]
2017-08-25 17:31:45.791 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveCommandClassValueEvent
2017-08-25 17:31:45.792 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 36: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
2017-08-25 17:31:45.793 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 36: Got a value event from Z-Wave network, endpoint = 0, command class = COMMAND_CLASS_CENTRAL_SCENE, value = 2.0
2017-08-25 17:31:45.796 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 36: Updating channel state zwave:device:15db442c729:node36:scene_number to 2.0 [DecimalType]
2017-08-25 17:31:45.797 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 36: Commands processed 1.
2017-08-25 17:31:45.798 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 36: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@126bbd8.
2017-08-25 17:31:45.799 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2017-08-25 17:31:45.800 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2017-08-25 17:31:45.801 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2017-08-25 17:31:45.803 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start
2017-08-25 17:31:45.804 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction from controllerQueue
2017-08-25 17:31:45.805 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage nothing
Is that of any help?
Thank you! Michael
