Hi @chris,
My log file displays the following error on zwave nodes initialization:
2016-08-23 20:44:48.846 [ERROR] [ve.internal.protocol.ZWaveController] - NODE 11: Restore from config: Error deserialising XML file. com.thoughtworks.xstream.converters.reflection.AbstractReflectionConverter$UnknownFieldException: No such field org.openhab.binding.zwave.internal.protocol.commandclass.ZWaveAssociationCommandClass.configAssociations
---- Debugging information ----
field : configAssociations
class : org.openhab.binding.zwave.internal.protocol.commandclass.ZWaveAssociationCommandClass
required-type : org.openhab.binding.zwave.internal.protocol.commandclass.ZWaveAssociationCommandClass
converter-type : com.thoughtworks.xstream.converters.reflection.ReflectionConverter
path : /node/supportedCommandClasses/entry[4]/associationCommandClass/configAssociations
line number : 69
class[1] : java.util.HashMap
converter-type[1] : com.thoughtworks.xstream.converters.collections.MapConverter
class[2] : org.openhab.binding.zwave.internal.protocol.ZWaveNode
version : 1.4.7
2016-08-23 20:44:48.860 [ERROR] [ve.internal.protocol.ZWaveController] - NODE 27: Restore from config: Error deserialising XML file. com.thoughtworks.xstream.converters.reflection.AbstractReflectionConverter$UnknownFieldException: No such field org.openhab.binding.zwave.internal.protocol.commandclass.ZWaveAssociationCommandClass.configAssociations
line number : 69
version : 1.4.7
Here is the corresponding node files: node27.xml (8.0 KB)
node11.xml (8.1 KB)
OH2 version: 2.0.0-SNAPSHOT - Build #455
Zwave binding version: org.openhab.binding.zwave-2.0.0-20160823.010129-175.jar
What is the problem ?
