I upgraded my Testsystem to OH4.0.0 M3.
After that all my ZWave Door/Windows sensor doesn’T work anymore.
Here’s the errormessage in openhab.log:
2023-06-28 06:18:54.942 [WARN ] [core.thing.internal.ThingManagerImpl] - A thing handler factory claims to support 'zwave:shenzhen_doorwindowsensor_00_000' for thing 'zwave:device:020e4758:node30' for more than 120s, but the thing type can't be found in the registry. This should be fixed in the binding.
2023-06-28 06:18:54.944 [WARN ] [core.thing.internal.ThingManagerImpl] - Could not normalize configuration for 'zwave:device:020e4758:node30' because the thing type was not found in registry.
2023-06-28 06:18:54.954 [WARN ] [core.thing.internal.ThingManagerImpl] - A thing handler factory claims to support 'zwave:shenzhen_doorwindowsensor_00_000' for thing 'zwave:device:020e4758:node32' for more than 120s, but the thing type can't be found in the registry. This should be fixed in the binding.
2023-06-28 06:18:54.956 [WARN ] [core.thing.internal.ThingManagerImpl] - Could not normalize configuration for 'zwave:device:020e4758:node32' because the thing type was not found in registry.
2023-06-28 06:18:54.965 [WARN ] [core.thing.internal.ThingManagerImpl] - A thing handler factory claims to support 'zwave:shenzhen_doorwindowsensor_00_000' for thing 'zwave:device:020e4758:node31' for more than 120s, but the thing type can't be found in the registry. This should be fixed in the binding.
2023-06-28 06:18:54.967 [WARN ] [core.thing.internal.ThingManagerImpl] - Could not normalize configuration for 'zwave:device:020e4758:node31' because the thing type was not found in registry.
I guess the device is missing in Zwave Device registry?
Has someone an idea to get them back to operation?
They were working well in OH 3.4.4 production system
My sensor looks like this one:
It look’s like the device is recognized with a other type in OH4.0.0 M3 as in OH 3.4.4.
Where can I change that the sensor are recognized as shenzhen_nasds01z_00_000 and not as “zwave:shenzhen_doorwindowsensor_00_000” ?
