On Build 689 (using offline) I have not had any success with zwave and also with the Razberry card zwave controller.
The binding reports that the controller is not found :
Serial Error: Port /dev/ttyAMA0 does not exist
and on a re-start of OH2 the zwave binding is uninstalled.
I have tried setting the setenv parameter to
-Dgnu.io.rxtx.SerialPorts=/dev/ttyAMA0"
both before and after installing the binding but the device is not recognised and the binding gets uninstalled on a restart.
My installation was all going smoothly back at Build #595. Started having troubles with Build #675.
Debug logfile attached.openhab.log.ZWaveDebug.xml (202.9 KB)
Thanks in anticipation for any help with this.
