I’m using an Openhabian Pi, running OpenHAB 2.5.9, and a zwave dongle (which I’ve used very successfully with a Fibaro plug-in power switch). I’m mostly using the PaperUI, but also have looked in HABmin.
I’m now trying to use a SCN04 Four-key Scene Controller - I’ve added the “thing” easily enough, and added two “items”. The button has a channel for “scene number” and another for “battery level”, so I added an item for each.
My problem is that I can’t really “see” if the button is working. That is, pressing it makes the little LED light up, but I don’t see any particular reaction from OpenHAB - nothing in the UI and I don’t see any extra being written to the log either.
I notice that if I edit the Thing, I’m given a screen with some Association Groups. All of these are empty, but I believe should be set to “controller”. If I make those changes and save, the log says:
2020-09-24 17:43:29.628 [me.event.ThingUpdatedEvent] - Thing 'zwave:device:30fd47f1:node6' has been updated.
2020-09-24 17:43:29.636 [vent.ConfigStatusInfoEvent] - ConfigStatusInfo [configStatusMessages=[ConfigStatusMessage [parameterName=wakeup_node, type=PENDING, messageKey=null, arguments=null, message=null, statusCode=null], ConfigStatusMessage [parameterName=wakeup_interval, type=PENDING, messageKey=null, arguments=null, message=null, statusCode=null]]]
2020-09-24 17:43:53.660 [me.event.ThingUpdatedEvent] - Thing 'zwave:device:30fd47f1:node6' has been updated.
However, if I go back into the edit Thing screen, all my previous config is gone (in both UIs). This problem, coupled with the lack of log output makes me wonder if the config has really taken effect or not. I wondered if the device needs to wake up to then receive the config from the controller - but pressing a button on it for 3 seconds (or a single click, double click etc) doesn’t seem to do anything either.
Is there a way to check, or indeed to see every button press (even if mishandled later on)?
