I’m using 2 USB Gen5 Sticks. And my OH server (Ubuntu 18.04) is running virtual (by HV Proxmox 5.1.2).
A lot of bindings (knx, zoneminder, bosch, zwave…) are in place.
I’m using a recent OH version, namely 2.5.0.M1
Zwave has about 55 nodes over the 2 sticks (2 different buildings).
And everything is running smooth. For a while…
Suddenly, a zwave stick (or network?) suddenly stops working.
Nothing in the logs that could explain it. It just stops sending traffic it seems. In PaperUI, everything stays online. And that’s a bit annoying, since I can’t trigger a rule on this to restart it automaticly.
Sometimes it runs for 1 days, sometimes for 3, sometimes for… Sometimes it’s stick 1, sometimes it’s stick 2. Not really an logic in it…
I’m aware of 3 other simular setups (with proxmox), and only 2 of the 4 have a simular case. That the zwave suddenly dies… On the other installation that dies, I’ve installed a new ZWave Gen5 stick, but the result was the same. So I don’t think it’s a hardware (=stick) issue.
For info, this is a small script I’ve made that checks if a zwave node (powered outlet) is sending data. If so, he does nothing. If no data is seen for 25 minutes, he’ll trigger a restart of the binding…
var Timer occupancyTimer = null
val int timeoutMinutes = 25
rule "ZWAVE Check"
Item Sch_OnOff1_Verbruik changed
if(occupancyTimer === null) {
occupancyTimer = createTimer(now.plusMinutes(timeoutMinutes ), [|
logInfo("Alarm651", "Er is geen ZWAVE update ontvangen gedurende 25 minuten")
sendCommand(ZwaveCheck, OFF)
if(ZwaveCheck.state !=ON) sendCommand(ZwaveCheck, ON)
logInfo("Info652", "Er zijn ZWAVE updates gezien")
else {
occupancyTimer.reschedule(now.plusMinutes(timeoutMinutes ))
logInfo("Info653", "Er zijn ZWAVE updates gezien")
rule "Zwave Offline"
Item ZwaveCheck changed to OFF
logInfo("Alarm", "Zwave is offline gegaan?")
createTimer(now.plusSeconds(300), [ |
if ( ZwaveCheck.state == OFF ) {
logInfo("Alarm659", "Zwave nog steeds offline, OH2 wordt herstart")
sendPushoverMessage(pushoverBuilder("ZWave is offline?").withDevice("VETEN"))
executeCommandLine("/etc/openhab2/scripts/restartZwave.py")
After hours and hours, days and days of ‘frustrations’, testing, updates, thinking, downgrades, upgrades, scripts… I think I’ve found it.
With updating my virtualisation OS (proxmox) to the latest version, I had some output in dmesg that pointed me out of a power issue. After adding an external powered USB switch, no disconnections anymore. The zwave connectivity is up for about 2 weeks now! No more sudden deaths…
Seems that linuxservers don’t like very much (un)stable USB ports. I’m using a Dell PowerEdge server, and maybe (these) servers don’t have very stable usb power output?
