All,
this time I have an interesting case for the community
I wanted to make my heating system smart, so I started buying the Zwave Spirit Thermostatic Valve.
I first bought one - just to try. Thing has been configured with autodiscovery and items (those I needed) manually:
// Studio
Number Studio_ZWaveThermoValve_BatteryLevel "Guest Room Thermovalve Battery Level [%.1f %%]" <batterylevel> (GuestRoom, gBatteryLevel) ["Battery Level"] {channel="zwave:device:f3ae20de:node2:battery-level"}
Number Studio_ZWaveThermoValve_SetpointHeat "Guest Room Thermovalve Setpoint [%.1f °C]" <temperature> (GuestRoom, gThermoValveSP) ["Thermovalve SP"] {channel="zwave:device:f3ae20de:node2:thermostat_setpoint_heating"}
Number Studio_ZWaveThermoValve_SetpointEnergyHeat "Guest Room Thermovalve Setpoint Energy Heat [%.1f °C]" <temperature> (GuestRoom, gThermoValveSPE) ["Thermovalve SPE"] {channel="zwave:device:f3ae20de:node2:thermostat_setpoint_heating_econ"}
Number Studio_ZWaveThermoValve_Dimmer "Guest Room Thermovalve position [%.2f]" <dimmer> (GuestRoom, gThermoValvePos) ["Thermovalve Pos"] {channel="zwave:device:f3ae20de:node2:switch_dimmer"}
Number Studio_ZWaveThermoValve_ThermostatMode "Guest Room Thermovalve Mode [%.1f]" <temperature> (GuestRoom, gThermoValveMode) ["Thermovalve Mode"] {channel="zwave:device:f3ae20de:node2:thermostat_mode"}
Number Studio_ZWaveThermoValve_CurrentTemperature "Guest Room Thermovalve Temperature [%.1f °C]" <temperature> (GuestRoom, gTemperature) ["Temperature"] {channel="zwave:device:f3ae20de:node2:sensor_temperature"}
I setup a rule (see also my post here) to switch it off when the corresponding window is open and viceversa
import org.eclipse.smarthome.model.script.ScriptServiceUtil
rule "A door sensor has been triggered"
Member of gOpenItems changed
val String ruleIdentifier = "Setting Thermovalve"
val window = triggeringItem
logInfo(ruleIdentifier, "{} has triggered the event!", window.name)
val roomName = window.name.split("_").get(0)
val thermoValveName = roomName+"_ZWaveThermoValve_ThermostatMode"
var thermoValveItem
if (ScriptServiceUtil.getItemRegistry.getItem(thermoValveName) == newArrayList) {
logInfo(ruleIdentifier, "{} does not have an associated thermovalve with name {}", roomName, thermoValveName)
return;
else
thermoValveItem = ScriptServiceUtil.getItemRegistry.getItem(thermoValveName)
val windowState = if(window.state == ON) "open" else "close"
val setValue = if(window.state == ON) 0 else 1
logInfo(ruleIdentifier, "{} got to status {}! Setting {} to {}", roomName, windowState, thermoValveName, setValue)
thermoValveItem.sendCommand(setValue)
Everthing worked perfectly, and I can fully understand the embedded control rule, i.e. the higher is the different between Studio_ZWaveThermoValve_SetpointHeat
and Studio_ZWaveThermoValve_CurrentTemperature
, the higher is Studio_ZWaveThermoValve_Dimmer
So far, so good.
Last week I got the remaining six thermovalves, to get the whole heating system under control.
My item lists was quite easy to adapt, adding one thermovalve after the other and changing zwave ID and labels
// BedRoom
Number Bedroom_ZWaveThermoValve_BatteryLevel "Bedroom Thermovalve Battery Level [%.1f %%]" <batterylevel> (Bedroom, gBatteryLevel) ["Battery Level"] {channel="zwave:device:f3ae20de:node4:battery-level"}
Number Bedroom_ZWaveThermoValve_SetpointHeat "Bedroom Thermovalve Setpoint [%.1f °C]" <temperature> (Bedroom, gThermoValveSP) ["Thermovalve SP"] {channel="zwave:device:f3ae20de:node4:thermostat_setpoint_heating"}
Number Bedroom_ZWaveThermoValve_SetpointEnergyHeat "Bedroom Thermovalve Setpoint Energy Heat [%.1f °C]" <temperature> (Bedroom, gThermoValveSPE) ["Thermovalve SPE"] {channel="zwave:device:f3ae20de:node4:thermostat_setpoint_heating_econ"}
Number Bedroom_ZWaveThermoValve_Dimmer "Bedroom Thermovalve position [%.2f]" <dimmer> (Bedroom, gThermoValvePos) ["Thermovalve Pos"] {channel="zwave:device:f3ae20de:node4:switch_dimmer"}
Number Bedroom_ZWaveThermoValve_ThermostatMode "Bedroom Thermovalve Mode [%.1f]" <temperature> (Bedroom, gThermoValveMode) ["Thermovalve Mode"] {channel="zwave:device:f3ae20de:node4:thermostat_mode"}
Number Bedroom_ZWaveThermoValve_CurrentTemperature "Bedroom Thermovalve Temperature [%.1f °C]" <temperature> (Bedroom, gTemperature) ["Temperature"] {channel="zwave:device:f3ae20de:node4:sensor_temperature"}
// Living Room - left
Number LivingRoomWindowLeft_ZWaveThermoValve_BatteryLevel "Living Room (L) Thermovalve Battery Level [%.1f %%]" <batterylevel> (LivingDining, gBatteryLevel) ["Battery Level"] {channel="zwave:device:f3ae20de:node7:battery-level"}
Number LivingRoomWindowLeft_ZWaveThermoValve_SetpointHeat "Living Room (L) Thermovalve Setpoint [%.1f °C]" <temperature> (LivingDining, gThermoValveSP) ["Thermovalve SP"] {channel="zwave:device:f3ae20de:node7:thermostat_setpoint_heating"}
Number LivingRoomWindowLeft_ZWaveThermoValve_SetpointEnergyHeat "Living Room (L) Thermovalve Setpoint Energy Heat [%.1f °C]" <temperature> (LivingDining, gThermoValveSPE) ["Thermovalve SPE"] {channel="zwave:device:f3ae20de:node7:thermostat_setpoint_heating_econ"}
Number LivingRoomWindowLeft_ZWaveThermoValve_Dimmer "Living Room (L) Thermovalve position [%.2f]" <dimmer> (LivingDining, gThermoValvePos) ["Thermovalve Pos"] {channel="zwave:device:f3ae20de:node7:switch_dimmer"}
Number LivingRoomWindowLeft_ZWaveThermoValve_ThermostatMode "Living Room (L) Thermovalve Mode [%.1f]" <temperature> (LivingDining, gThermoValveMode) ["Thermovalve Mode"] {channel="zwave:device:f3ae20de:node7:thermostat_mode"}
Number LivingRoomWindowLeft_ZWaveThermoValve_CurrentTemperature "Living Room (L) Thermovalve Temperature [%.1f °C]" <temperature> (LivingDining, gTemperature) ["Temperature"] {channel="zwave:device:f3ae20de:node7:sensor_temperature"}
// Living Room - right
Number LivingRoomWindowRight_ZWaveThermoValve_BatteryLevel "Living Room (R) Thermovalve Battery Level [%.1f %%]" <batterylevel> (LivingDining, gBatteryLevel) ["Battery Level"] {channel="zwave:device:f3ae20de:node8:battery-level"}
Number LivingRoomWindowRight_ZWaveThermoValve_SetpointHeat "Living Room (R) Thermovalve Setpoint [%.1f °C]" <temperature> (LivingDining, gThermoValveSP) ["Thermovalve SP"] {channel="zwave:device:f3ae20de:node8:thermostat_setpoint_heating"}
Number LivingRoomWindowRight_ZWaveThermoValve_SetpointEnergyHeat "Living Room (R) Thermovalve Setpoint Energy Heat [%.1f °C]" <temperature> (LivingDining, gThermoValveSPE) ["Thermovalve SPE"] {channel="zwave:device:f3ae20de:node8:thermostat_setpoint_heating_econ"}
Number LivingRoomWindowRight_ZWaveThermoValve_Dimmer "Living Room (R) Thermovalve position [%.2f]" <dimmer> (LivingDining, gThermoValvePos) ["Thermovalve Pos"] {channel="zwave:device:f3ae20de:node8:switch_dimmer"}
Number LivingRoomWindowRight_ZWaveThermoValve_ThermostatMode "Living Room (R) Thermovalve Mode [%.1f]" <temperature> (LivingDining, gThermoValveMode) ["Thermovalve Mode"] {channel="zwave:device:f3ae20de:node8:thermostat_mode"}
Number LivingRoomWindowRight_ZWaveThermoValve_CurrentTemperature "Living Room (R) Thermovalve Temperature [%.1f °C]" <temperature> (LivingDining, gTemperature) ["Temperature"] {channel="zwave:device:f3ae20de:node8:sensor_temperature"}
// Kids
Number Kidsroom_ZWaveThermoValve_BatteryLevel "Kids Room Thermovalve Battery Level [%.1f %%]" <batterylevel> (KidsRoom, gBatteryLevel) ["Battery Level"] {channel="zwave:device:f3ae20de:node3:battery-level"}
Number Kidsroom_ZWaveThermoValve_SetpointHeat "Kids Room Thermovalve Setpoint [%.1f °C]" <temperature> (KidsRoom, gThermoValveSP) ["Thermovalve SP"] {channel="zwave:device:f3ae20de:node3:thermostat_setpoint_heating"}
Number Kidsroom_ZWaveThermoValve_SetpointEnergyHeat "Kids Room Thermovalve Setpoint Energy Heat [%.1f °C]" <temperature> (KidsRoom, gThermoValveSPE) ["Thermovalve SPE"] {channel="zwave:device:f3ae20de:node3:thermostat_setpoint_heating_econ"}
Number Kidsroom_ZWaveThermoValve_Dimmer "Kids Room Thermovalve position [%.2f]" <dimmer> (KidsRoom, gThermoValvePos) ["Thermovalve Pos"] {channel="zwave:device:f3ae20de:node3:switch_dimmer"}
Number Kidsroom_ZWaveThermoValve_ThermostatMode "Kids Room Thermovalve Mode [%.1f]" <temperature> (KidsRoom, gThermoValveMode) ["Thermovalve Mode"] {channel="zwave:device:f3ae20de:node3:thermostat_mode"}
Number Kidsroom_ZWaveThermoValve_CurrentTemperature "Kids Room Thermovalve Temperature [%.1f °C]" <temperature> (KidsRoom, gTemperature) ["Temperature"] {channel="zwave:device:f3ae20de:node3:sensor_temperature"}
// Large bathroom
Number LargeBath_ZWaveThermoValve_BatteryLevel "Large Bath Thermovalve Battery Level [%.1f %%]" <batterylevel> (LargeBath, gBatteryLevel) ["Battery Level"] {channel="zwave:device:f3ae20de:node6:battery-level"}
Number LargeBath_ZWaveThermoValve_SetpointHeat "Large Bath Thermovalve Setpoint [%.1f °C]" <temperature> (LargeBath, gThermoValveSP) ["Thermovalve SP"] {channel="zwave:device:f3ae20de:node6:thermostat_setpoint_heating"}
Number LargeBath_ZWaveThermoValve_SetpointEnergyHeat "Large Bath Thermovalve Setpoint Energy Heat [%.1f °C]" <temperature> (LargeBath, gThermoValveSPE) ["Thermovalve SPE"] {channel="zwave:device:f3ae20de:node6:thermostat_setpoint_heating_econ"}
Number LargeBath_ZWaveThermoValve_Dimmer "Large Bath Thermovalve position [%.2f]" <dimmer> (LargeBath, gThermoValvePos) ["Thermovalve Pos"] {channel="zwave:device:f3ae20de:node6:switch_dimmer"}
Number LargeBath_ZWaveThermoValve_ThermostatMode "Large Bath Thermovalve Mode [%.1f]" <temperature> (LargeBath, gThermoValveMode) ["Thermovalve Mode"] {channel="zwave:device:f3ae20de:node6:thermostat_mode"}
Number LargeBath_ZWaveThermoValve_CurrentTemperature "Large Bath Thermovalve Temperature [%.1f °C]" <temperature> (LargeBath, gTemperature) ["Temperature"] {channel="zwave:device:f3ae20de:node6:sensor_temperature"}
// Small bathroom
Number SmallBath_ZWaveThermoValve_BatteryLevel "Small Bath Thermovalve Battery Level [%.1f %%]" <batterylevel> (SmallBath, gBatteryLevel) ["Battery Level"] {channel="zwave:device:f3ae20de:node5:battery-level"}
Number SmallBath_ZWaveThermoValve_SetpointHeat "Small Bath Thermovalve Setpoint [%.1f °C]" <temperature> (SmallBath, gThermoValveSP) ["Thermovalve SP"] {channel="zwave:device:f3ae20de:node5:thermostat_setpoint_heating"}
Number SmallBath_ZWaveThermoValve_SetpointEnergyHeat "Small Bath Thermovalve Setpoint Energy Heat [%.1f °C]" <temperature> (SmallBath, gThermoValveSPE) ["Thermovalve SPE"] {channel="zwave:device:f3ae20de:node5:thermostat_setpoint_heating_econ"}
Number SmallBath_ZWaveThermoValve_Dimmer "Small Bath Thermovalve position [%.2f]" <dimmer> (SmallBath, gThermoValvePos) ["Thermovalve Pos"] {channel="zwave:device:f3ae20de:node5:switch_dimmer"}
Number SmallBath_ZWaveThermoValve_ThermostatMode "Small Bath Thermovalve Mode [%.1f]" <temperature> (SmallBath, gThermoValveMode) ["Thermovalve Mode"] {channel="zwave:device:f3ae20de:node5:thermostat_mode"}
Number SmallBath_ZWaveThermoValve_CurrentTemperature "Small Bath Thermovalve Temperature [%.1f °C]" <temperature> (SmallBath, gTemperature) ["Temperature"] {channel="zwave:device:f3ae20de:node5:sensor_temperature"}
The rule was kept and it works: whenever I open a window, I get the corresponding thermovalve closed. As soon as I close it, the valve is back to open. The rule is not completed yet, I would like to revert to the previous state, not to default “heat” mode. But this is not the topic of this post .
I started noticing that the nice ?_ZWaveThermoValve_SetpointHeat
vs ?_ZWaveThermoValve_CurrentTemperature
vs ?_ZWaveThermoValve_Dimmer
does not work anymore!
For example, right now in children’s room I have
: 19.0 °C -
: 18.6 °C -
: 1 (Heat) -
: 0%
while the first thermovalve still works OK
: 19.0 °C -
: 18.7 °C -
: 1 (Heat) -
: 7%
Why does the thermovalve I added lately ignore the set temperature?!!?
Any why to debug this? It seems the device has some (low lever?) commands that can be sent to it (see below, German only, sorry), is it any useful?
I also see it is possible to upload the firmware, is this possible from a OH station?
Below also the relevant log lines from today. Nothing special, a couple of time the window has been open and I set the temperature to 19°C while my children were still sleeping
Thanks for your help and apologize for the long post!
Max
[23:37:03] openhabian@openhab:/var/log/openhab2$ grep Kidsroom_ZWaveThermoValve_ events.log
2020-03-30 05:47:20.799 [vent.ItemStateChangedEvent] - Kidsroom_ZWaveThermoValve_CurrentTemperature changed from 19.28 to 19.19
2020-03-30 05:47:20.802 [GroupItemStateChangedEvent] - gTemperature changed from 19.77 to 19.76 through Kidsroom_ZWaveThermoValve_CurrentTemperature
2020-03-30 08:29:54.071 [ome.event.ItemCommandEvent] - Item 'Kidsroom_ZWaveThermoValve_SetpointHeat' received command 19.0
2020-03-30 08:29:54.075 [nt.ItemStatePredictedEvent] - Kidsroom_ZWaveThermoValve_SetpointHeat predicted to become 19.0
2020-03-30 08:29:54.105 [vent.ItemStateChangedEvent] - Kidsroom_ZWaveThermoValve_SetpointHeat changed from 18.5 to 19.0
2020-03-30 09:41:48.363 [ome.event.ItemCommandEvent] - Item 'Kidsroom_ZWaveThermoValve_ThermostatMode' received command 0
2020-03-30 09:41:48.365 [nt.ItemStatePredictedEvent] - Kidsroom_ZWaveThermoValve_ThermostatMode predicted to become 0
2020-03-30 09:41:48.380 [vent.ItemStateChangedEvent] - Kidsroom_ZWaveThermoValve_ThermostatMode changed from 1 to 0
2020-03-30 09:41:50.981 [GroupItemStateChangedEvent] - gTemperature changed from 19.69 to 19.71 through Kidsroom_ZWaveThermoValve_CurrentTemperature
2020-03-30 09:41:50.986 [vent.ItemStateChangedEvent] - Kidsroom_ZWaveThermoValve_CurrentTemperature changed from 19.19 to 19.46
2020-03-30 09:46:48.512 [vent.ItemStateChangedEvent] - Kidsroom_ZWaveThermoValve_CurrentTemperature changed from 19.46 to 18.66
2020-03-30 09:46:48.518 [GroupItemStateChangedEvent] - gTemperature changed from 19.54 to 19.48 through Kidsroom_ZWaveThermoValve_CurrentTemperature
2020-03-30 09:49:51.461 [vent.ItemStateChangedEvent] - Kidsroom_ZWaveThermoValve_CurrentTemperature changed from 18.66 to 18.05
2020-03-30 09:49:51.468 [GroupItemStateChangedEvent] - gTemperature changed from 19.42 to 19.37 through Kidsroom_ZWaveThermoValve_CurrentTemperature
2020-03-30 09:53:55.400 [GroupItemStateChangedEvent] - gTemperature changed from 19.28 to 19.23 through Kidsroom_ZWaveThermoValve_CurrentTemperature
2020-03-30 09:53:55.404 [vent.ItemStateChangedEvent] - Kidsroom_ZWaveThermoValve_CurrentTemperature changed from 18.05 to 17.43
2020-03-30 09:57:59.329 [vent.ItemStateChangedEvent] - Kidsroom_ZWaveThermoValve_CurrentTemperature changed from 17.43 to 16.99
2020-03-30 09:57:59.333 [GroupItemStateChangedEvent] - gTemperature changed from 18.84 to 18.80 through Kidsroom_ZWaveThermoValve_CurrentTemperature
2020-03-30 10:02:03.259 [vent.ItemStateChangedEvent] - Kidsroom_ZWaveThermoValve_CurrentTemperature changed from 16.99 to 16.47
2020-03-30 10:02:03.263 [GroupItemStateChangedEvent] - gTemperature changed from 18.76 to 18.72 through Kidsroom_ZWaveThermoValve_CurrentTemperature
2020-03-30 10:02:34.909 [ome.event.ItemCommandEvent] - Item 'Kidsroom_ZWaveThermoValve_ThermostatMode' received command 1
2020-03-30 10:02:34.912 [nt.ItemStatePredictedEvent] - Kidsroom_ZWaveThermoValve_ThermostatMode predicted to become 1
2020-03-30 10:02:34.930 [vent.ItemStateChangedEvent] - Kidsroom_ZWaveThermoValve_ThermostatMode changed from 0 to 1
2020-03-30 10:02:36.524 [vent.ItemStateChangedEvent] - Kidsroom_ZWaveThermoValve_Dimmer changed from 0.00000000 to 0.15000000
2020-03-30 10:02:36.528 [GroupItemStateChangedEvent] - gThermoValvePos changed from 0.01142857 to 0.03285714 through Kidsroom_ZWaveThermoValve_Dimmer
2020-03-30 10:03:04.234 [GroupItemStateChangedEvent] - gThermoValvePos changed from 0.03285714 to 0.02857143 through Kidsroom_ZWaveThermoValve_Dimmer
2020-03-30 10:03:04.237 [vent.ItemStateChangedEvent] - Kidsroom_ZWaveThermoValve_Dimmer changed from 0.15000000 to 0.12000000
2020-03-30 10:05:06.214 [GroupItemStateChangedEvent] - gThermoValvePos changed from 0.02428571 to 0.02285714 through Kidsroom_ZWaveThermoValve_Dimmer
2020-03-30 10:05:06.218 [vent.ItemStateChangedEvent] - Kidsroom_ZWaveThermoValve_Dimmer changed from 0.12000000 to 0.11000000
2020-03-30 10:06:07.206 [GroupItemStateChangedEvent] - gThermoValvePos changed from 0.02142857 to 0.01857143 through Kidsroom_ZWaveThermoValve_Dimmer
2020-03-30 10:06:07.210 [vent.ItemStateChangedEvent] - Kidsroom_ZWaveThermoValve_Dimmer changed from 0.11000000 to 0.09000000
2020-03-30 10:07:08.180 [GroupItemStateChangedEvent] - gThermoValvePos changed from 0.01857143 to 0.01714286 through Kidsroom_ZWaveThermoValve_Dimmer
2020-03-30 10:07:08.185 [vent.ItemStateChangedEvent] - Kidsroom_ZWaveThermoValve_Dimmer changed from 0.09000000 to 0.08000000
2020-03-30 10:08:09.168 [GroupItemStateChangedEvent] - gThermoValvePos changed from 0.01714286 to 0.01285714 through Kidsroom_ZWaveThermoValve_Dimmer
2020-03-30 10:08:09.173 [vent.ItemStateChangedEvent] - Kidsroom_ZWaveThermoValve_Dimmer changed from 0.08000000 to 0.05000000
2020-03-30 10:09:10.150 [vent.ItemStateChangedEvent] - Kidsroom_ZWaveThermoValve_Dimmer changed from 0.05000000 to 0.03000000
2020-03-30 10:09:10.154 [GroupItemStateChangedEvent] - gThermoValvePos changed from 0.01285714 to 0.01000000 through Kidsroom_ZWaveThermoValve_Dimmer
2020-03-30 10:09:10.182 [vent.ItemStateChangedEvent] - Kidsroom_ZWaveThermoValve_CurrentTemperature changed from 16.47 to 16.91
2020-03-30 10:09:10.187 [GroupItemStateChangedEvent] - gTemperature changed from 18.72 to 18.76 through Kidsroom_ZWaveThermoValve_CurrentTemperature
2020-03-30 10:10:11.122 [GroupItemStateChangedEvent] - gThermoValvePos changed from 0.01000000 to 0.00714286 through Kidsroom_ZWaveThermoValve_Dimmer
2020-03-30 10:10:11.126 [vent.ItemStateChangedEvent] - Kidsroom_ZWaveThermoValve_Dimmer changed from 0.03000000 to 0.01000000
2020-03-30 10:11:12.114 [GroupItemStateChangedEvent] - gThermoValvePos changed from 0.00714286 to 0.00571429 through Kidsroom_ZWaveThermoValve_Dimmer
2020-03-30 10:11:12.119 [vent.ItemStateChangedEvent] - Kidsroom_ZWaveThermoValve_Dimmer changed from 0.01000000 to 0.00000000
2020-03-30 10:14:15.069 [vent.ItemStateChangedEvent] - Kidsroom_ZWaveThermoValve_CurrentTemperature changed from 16.91 to 17.52
2020-03-30 10:14:15.075 [GroupItemStateChangedEvent] - gTemperature changed from 18.94 to 18.99 through Kidsroom_ZWaveThermoValve_CurrentTemperature
2020-03-30 10:19:19.990 [GroupItemStateChangedEvent] - gTemperature changed from 19.08 to 19.12 through Kidsroom_ZWaveThermoValve_CurrentTemperature
2020-03-30 10:19:19.995 [vent.ItemStateChangedEvent] - Kidsroom_ZWaveThermoValve_CurrentTemperature changed from 17.52 to 18.05
2020-03-30 10:26:26.871 [vent.ItemStateChangedEvent] - Kidsroom_ZWaveThermoValve_CurrentTemperature changed from 18.05 to 18.58
2020-03-30 10:26:26.876 [GroupItemStateChangedEvent] - gTemperature changed from 19.26 to 19.30 through Kidsroom_ZWaveThermoValve_CurrentTemperature
2020-03-30 10:33:33.761 [GroupItemStateChangedEvent] - gTemperature changed from 19.37 to 19.41 through Kidsroom_ZWaveThermoValve_CurrentTemperature
2020-03-30 10:33:33.765 [vent.ItemStateChangedEvent] - Kidsroom_ZWaveThermoValve_CurrentTemperature changed from 18.58 to 19.02
2020-03-30 10:49:49.502 [vent.ItemStateChangedEvent] - Kidsroom_ZWaveThermoValve_CurrentTemperature changed from 19.02 to 19.54
2020-03-30 10:49:49.508 [GroupItemStateChangedEvent] - gTemperature changed from 19.56 to 19.60 through Kidsroom_ZWaveThermoValve_CurrentTemperature
2020-03-30 11:31:29.825 [vent.ItemStateChangedEvent] - Kidsroom_ZWaveThermoValve_CurrentTemperature changed from 19.54 to 20.07
2020-03-30 11:31:29.831 [GroupItemStateChangedEvent] - gTemperature changed from 20.02 to 20.07 through Kidsroom_ZWaveThermoValve_CurrentTemperature
2020-03-30 16:35:20.704 [ome.event.ItemCommandEvent] - Item 'Kidsroom_ZWaveThermoValve_ThermostatMode' received command 0
2020-03-30 16:35:20.709 [nt.ItemStatePredictedEvent] - Kidsroom_ZWaveThermoValve_ThermostatMode predicted to become 0
2020-03-30 16:35:20.740 [vent.ItemStateChangedEvent] - Kidsroom_ZWaveThermoValve_ThermostatMode changed from 1 to 0
2020-03-30 16:35:22.439 [GroupItemStateChangedEvent] - gTemperature changed from 20.21 to 20.23 through Kidsroom_ZWaveThermoValve_CurrentTemperature
2020-03-30 16:35:22.446 [vent.ItemStateChangedEvent] - Kidsroom_ZWaveThermoValve_CurrentTemperature changed from 20.07 to 20.34
2020-03-30 16:35:48.430 [ome.event.ItemCommandEvent] - Item 'Kidsroom_ZWaveThermoValve_ThermostatMode' received command 1
2020-03-30 16:35:48.432 [nt.ItemStatePredictedEvent] - Kidsroom_ZWaveThermoValve_ThermostatMode predicted to become 1
2020-03-30 16:35:48.448 [vent.ItemStateChangedEvent] - Kidsroom_ZWaveThermoValve_ThermostatMode changed from 0 to 1
2020-03-30 17:29:16.067 [GroupItemStateChangedEvent] - gTemperature changed from 20.31 to 20.25 through Kidsroom_ZWaveThermoValve_CurrentTemperature
2020-03-30 17:29:16.072 [vent.ItemStateChangedEvent] - Kidsroom_ZWaveThermoValve_CurrentTemperature changed from 20.34 to 19.54
2020-03-30 18:02:48.518 [vent.ItemStateChangedEvent] - Kidsroom_ZWaveThermoValve_CurrentTemperature changed from 19.54 to 19.02
2020-03-30 18:02:48.523 [GroupItemStateChangedEvent] - gTemperature changed from 20.36 to 20.32 through Kidsroom_ZWaveThermoValve_CurrentTemperature
2020-03-30 18:59:44.116 [vent.ItemStateChangedEvent] - Kidsroom_ZWaveThermoValve_CurrentTemperature changed from 19.02 to 18.58
2020-03-30 18:59:44.120 [GroupItemStateChangedEvent] - gTemperature changed from 20.37 to 20.34 through Kidsroom_ZWaveThermoValve_CurrentTemperature
