It is quite some fun and has some nice ringtones, but I was wondering can we change configuration on the fly using openhab & zwave module and some rules.
I would really like to change the parameter “This parameter can be selected between ALARM MUSIC and DOOR BELL music.”
That way I could use it both as an alarm and as a doorbell, any chances there?
It doesn’t look like anyone has updated the database, but it’s perfectly doable by adding a channel linked to the respective parameter. The channel type is config_decimal, and it needs a configuration option of “parameter=” and the parameter ID…
However, changing Siren_Config does not seem to have any effect. Do i need to import somehow config file into openhab2 to make it working?
I can not see any reference to this channel in:
Unfortunately it is not possible (yet) to change config parameters if zwave things are defined via text file.
You need to define your zwave device thing via HABmin (or PaperUI).
