Hello! I just bought some (used) switches and when I added them to my network with some existing devices, I see them as unknown, and that I should raise an issue. Thanks in advance for any help.
I thought the leviton switch I bought was in the database but I guess it’s not working or identifying itself as a different model. RZI06-1L
If used devices are not properly excluded from the old network or properly factory reset you won’t be able to include them into your network.
So please exclude them again from your network and in addition to that you should do a factory reset (just to be sure), then include them again.
Based on the information above, the device is included ok. My guess is that @joemoriss is using an old binding that doesn’t include the device (eg 2.3) as it was only added “recently” (ie July) so will only be in the 2.4 versions.
