thx. I disabled autoupdate, activated the debugging and disabled all of my rules. problem did not disappear, although after several attempts I do not seem to get the double change returned anymore. I need help to decrypt such a log, I notice: NODE 11: TID 217580: Transaction not completed
2023-07-26 17:29:45.543 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'KitchenWallLightsDimmer_Device' received command 0
2023-07-26 17:29:45.633 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'KitchenWallLightsDimmer_Device' changed from 58 to 78
2023-07-26 17:29:45.560 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Command received zwave:device:7b22ab1c42:node5:switch_dimmer --> 0 [PercentType]
2023-07-26 17:29:45.561 [DEBUG] [ss.ZWaveMultiLevelSwitchCommandClass] - NODE 5: Creating new message for command SWITCH_MULTILEVEL_SET
2023-07-26 17:29:45.561 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 5: SECURITY NOT required on COMMAND_CLASS_SWITCH_MULTILEVEL
2023-07-26 17:29:45.562 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 5: Command Class COMMAND_CLASS_SWITCH_MULTILEVEL is NOT required to be secured
2023-07-26 17:29:45.562 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 5: Adding to device queue
2023-07-26 17:29:45.563 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 5: Added 217578 to queue - size 1
2023-07-26 17:29:45.563 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2023-07-26 17:29:45.563 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 0A 00 13 05 03 26 01 00 25 46 A4
2023-07-26 17:29:45.564 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 5: Sending REQUEST Message = 01 0A 00 13 05 03 26 01 00 25 46 A4
2023-07-26 17:29:45.565 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - Message SENT
2023-07-26 17:29:45.565 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage started: TID 217578: [WAIT_RESPONSE] priority=Set, requiresResponse=true, callback: 70
2023-07-26 17:29:45.566 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 06
2023-07-26 17:29:45.566 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Polling initialised at 86400 seconds - start in 5000 milliseconds.
2023-07-26 17:29:45.566 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2023-07-26 17:29:45.567 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2023-07-26 17:29:45.567 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 217578: [WAIT_RESPONSE] priority=Set, requiresResponse=true, callback: 70
2023-07-26 17:29:45.567 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg: ACK
2023-07-26 17:29:45.568 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2023-07-26 17:29:45.568 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2023-07-26 17:29:45.572 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 04 01 13 01 E8
2023-07-26 17:29:45.573 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2023-07-26 17:29:45.573 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2023-07-26 17:29:45.574 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 217578: [WAIT_RESPONSE] priority=Set, requiresResponse=true, callback: 70
2023-07-26 17:29:45.574 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 1
2023-07-26 17:29:45.575 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: TID 217578: [WAIT_RESPONSE] priority=Set, requiresResponse=true, callback: 70
2023-07-26 17:29:45.575 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2023-07-26 17:29:45.575 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 5: sentData successfully placed on stack.
2023-07-26 17:29:45.576 [DEBUG] [nal.protocol.ZWaveTransactionManager] - TID 217578: Advanced to WAIT_REQUEST
2023-07-26 17:29:45.576 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 5: TID 217578: Transaction not completed
2023-07-26 17:29:45.576 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2023-07-26 17:29:45.577 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2023-07-26 17:29:45.588 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 07 00 13 46 00 00 03 AE
2023-07-26 17:29:45.589 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=SendData[19], type=Request[0], dest=0, callback=70, payload=46 00 00 03
2023-07-26 17:29:45.590 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=SendData[19], type=Request[0], dest=0, callback=70, payload=46 00 00 03
2023-07-26 17:29:45.590 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 217578: [WAIT_REQUEST] priority=Set, requiresResponse=true, callback: 70
2023-07-26 17:29:45.591 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 1
2023-07-26 17:29:45.591 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: TID 217578: [WAIT_REQUEST] priority=Set, requiresResponse=true, callback: 70
2023-07-26 17:29:45.592 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking TID 217578: (Callback 70)
2023-07-26 17:29:45.592 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Callback match!
2023-07-26 17:29:45.593 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Correlated to TID 217578: callback 70
2023-07-26 17:29:45.594 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=SendData[19], type=Request[0], dest=0, callback=70, payload=46 00 00 03
2023-07-26 17:29:45.594 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 5: SendData Request. CallBack ID = 70, Status = Transmission complete and ACK received(0)
2023-07-26 17:29:45.595 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 5: resetResendCount initComplete=true isDead=false
2023-07-26 17:29:45.596 [DEBUG] [e.internal.protocol.ZWaveTransaction] - TID 217578: Transaction COMPLETED
2023-07-26 17:29:45.596 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 5: Response processed after 31ms
2023-07-26 17:29:45.597 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 5: TID 217578: Transaction completed
2023-07-26 17:29:45.597 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 5: notifyTransactionResponse TID:217578 DONE
2023-07-26 17:29:45.598 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2023-07-26 17:29:45.599 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2023-07-26 17:29:45.600 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2023-07-26 17:29:45.622 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 09 00 04 00 05 03 26 03 4E 9F
2023-07-26 17:29:45.624 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=5, callback=0, payload=00 05 03 26 03 4E
2023-07-26 17:29:45.624 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=5, callback=0, payload=00 05 03 26 03 4E
2023-07-26 17:29:45.625 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2023-07-26 17:29:45.626 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 5: Application Command Request (ALIVE:DONE)
2023-07-26 17:29:45.626 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 5: resetResendCount initComplete=true isDead=false
2023-07-26 17:29:45.627 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 5: Incoming command class COMMAND_CLASS_SWITCH_MULTILEVEL, endpoint 0
2023-07-26 17:29:45.627 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 5: SECURITY NOT required on COMMAND_CLASS_SWITCH_MULTILEVEL
2023-07-26 17:29:45.628 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 5: Received COMMAND_CLASS_SWITCH_MULTILEVEL V2 SWITCH_MULTILEVEL_REPORT
2023-07-26 17:29:45.629 [DEBUG] [ss.ZWaveMultiLevelSwitchCommandClass] - NODE 5: Switch Multi Level report, value = 78
2023-07-26 17:29:45.629 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
2023-07-26 17:29:45.630 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_SWITCH_MULTILEVEL, value=78
2023-07-26 17:29:45.631 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Updating channel state zwave:device:7b22ab1c42:node5:switch_dimmer to 78 [PercentType]
2023-07-26 17:29:45.632 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 5: Commands processed 1.
2023-07-26 17:29:45.633 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 5: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@49ef5d.
2023-07-26 17:29:45.633 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2023-07-26 17:29:45.634 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2023-07-26 17:29:45.635 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2023-07-26 17:29:45.636 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
