I’m still a little new to this, so maybe there’s something obvious I’m missing. Any help would be appreciated.
Here’s the debug log, which is complaining about a command for an unknown channel.
2016-06-12 10:51:16.884 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 14: Command received zwave:device:154acc671d8:node14:switch_dimmer --> INCREASE 2016-06-12 10:51:16.887 [WARN ] [ding.zwave.handler.ZWaveThingHandler] - NODE 14: Command for unknown channel zwave:device:154acc671d8:node14:switch_dimmer with IncreaseDecreaseType 2016-06-12 10:51:16.890 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'KitchenCeiling_VRI06_Dimmer' received command INCREASE
Here’s the item definition.
Dimmer KitchenCeiling_VRI06_Dimmer "Kitchen Ceiling Light [%d %%]" <dimmablelight> {channel="zwave:device:154acc671d8:node14:switch_dimmer"}
Here’s the sitemap definition.
Slider item=KitchenCeiling_VRI06_Dimmer label="Kitchen Ceiling Light"
Here’s the zwave node definition.
{ statusInfo: { status: "ONLINE", statusDetail: "NONE", description: "VERSION" }, label: "Z-Wave Node 14: Dimmer (Kitchen Ceiling))", bridgeUID: "zwave:serial_zstick:154acc671d8", configuration: { action_heal: "-232323", switchall_mode: "0", nodename_name: "", nodename_location: "", powerlevel_timeout: "0", action_failed: "-232323", powerlevel_level: "0", group_1: [ ], action_remove: "-232323", binding_pollperiod: "1800" }, properties: { zwave_class_basic: "ROUTING_SLAVE", zwave_class_generic: "MULTILEVEL_SWITCH", zwave_deviceid: "521", zwave_frequent: "false", zwave_nodeid: "14", zwave_version: "0.4", zwave_listening: "true", zwave_routing: "true", zwave_beaming: "false", zwave_class_specific: "SCENE_SWITCH_MULTILEVEL", zwave_manufacturer: "29", zwave_devicetype: "1025", zwave_neighbours: "" }, UID: "zwave:device:154acc671d8:node14", thingTypeUID: "zwave:leviton_vri06_00_000", channels: [ { linkedItems: [ "KitchenCeiling_VRI06_Dimmer", "zwave_device_154acc671d8_node14_switch_dimmer" ], uid: "zwave:device:154acc671d8:node14:switch_dimmer", id: "switch_dimmer", channelTypeUID: "zwave:switch_dimmer", itemType: "Dimmer", label: "Dimmer", defaultTags: [ ], properties: { binding:Command:OnOffType: "SWITCH_MULTILEVEL", binding:*:PercentType: "SWITCH_MULTILEVEL,BASIC" }, configuration: { } } ] },
