Hey All,
I have some ZWave dimmer modules which are working great.
If I assign a switch instead of dimmer I can switch on/off to 0-100%, Can an on/off switch be used to switch 0-25% without any additional rules?
Hey All,
No. A Switch will only be able to give you 0%-100%. You will need rules to do 0%-25%.
Any examples available of a rule that would set a dimmer to a specific percentage?
This is what one of my item looks like.
Dimmer ZwaveHallDimmerDim “Dimmer Hall [%d %%]” (ZwaveHallDimmer,HouseLight,Dimmable) [“Lighting”] { channel=“zwave:device:69f10e1b:node27:switch_dimmer” }
To set it to 25% in a rule:
ZwaveHallDimmerDim.sendCommand(25)
Regards, S
That is perfect thanks.
Thought I would post the full solution here for anyone else thinking of something similar.
Here are the items, the module is a Qubino ZWave dimmer :-
Switch ZMNHDD1_S1 "Light Switch" <light> (ZT_ZMNHDD1)
Dimmer ZMNHDD1_D1 "Light Dimmer" <slider> (ZT_ZMNHDD1) {zwave="0:command=switch_multilevel"}
Here is the rule to set dimmer using the switch listed above :-
rule "dimmer to 25pc"
Item ZMNHDD1_S1 changed from OFF to ON
sendCommand(ZMNHDD1_D1, 25)
rule "dimmer off"
Item ZMNHDD1_S1 changed from ON to OFF
sendCommand(ZMNHDD1_D1, OFF)
