I bought a few ZD2102 door sensors (cheapest zwave sensor I’ve found). They can be expanded by adding an external reed switch (i.e. for two pane windows), however, a parameter needs to be changed in order to operate the external reed switch. My problem is that Habmin is not showing any configuration parameters on the UI for these sensors…
When the device wakes I am getting no state (OPEN/CLOSED) and the battery reports to be 0. However, when the device is actuated upon, I get the state and the correct battery level. Any ideas?
It shouldn’t get the state - this is normal. Battery is requested occasionally, but not every wakeup.
Strange. It’s obviously reading the file as it’s seeing the associations. There’s only 1 parameter anyway, but I’m not sure why it’s not showing up.
Maybe it’s disabled (unlikely since you can’t set the configration and apparently it’s enabled by default), or maybe you have the item configuration incorrect? I’d hazard that the item config is wrong?
That’s correct then - as above, it shouldn’t send it when it wakes. That just not what is meant to happen, and if you want this to happen you need to add polling (which I don’t recommend).
If you post the XML file and the item definition I’ll take a look at it.
I am only getting the battery level when I open the back of the device (it’s supposed to be a manual wake if I understand correctly). Not sure about this, but I think that when the device wakes the battery level shows 0… I do not get any battery level when the contact opens or closes either.
I thought my fiber door sensors did get their states when they woke, I’m confused.
I don’t think so, but I could very well be wrong. Maybe the Fibaro devices send the data, but it’s not mandated, and is therefore up to each manufacturer to implement so the Vision sensors don’t have to…
