Do you have more than one of these devices, and do they behave the same? You’ll probably need the expert for this one (@chris), but OTMH I do not see a way to resolve it.
You could hack the definitions in your binding to make this work, but probably best as a last resort.
I think we’ve seen this before with this, or other TKB devices . They use the same set of codes for multiple devices which is a real ballache.
Anyway, how to extract ourselves from this…
This device was added quite recently, so I can probably track down who added it, and we can try and have a discussion about this. We might be able to differentiate the devices using firmware versions, if not, and they really are exactly the same, then we’ll have to rethink.
Sure I can join trying to find out what we want to achieve… I have one piece of TZ35S in my installation. Do we need documentation or ?
It works correctly, however sometimes it reports back with delays good it responds to remote changes quickly.
I have dual paddle TZ37 switch also and it responds much better.
