Please help with some guidance on what I should do. I assumed it was an end number issue.But Changing it didn’t solve the problem. Your help is greatly appreciated.
I have a few nodes that will not update since I’ve upgraded my Zstick to gen 5. I’ve associated all the nodes with the new stick
There are quite a few errors that I’ll include at the bottom of this post. Here are the items:
Number multi_living_temp “Living Rm Temperature[%.0f °F]” (all,living,zwave,temp,chart_living_temp,chart_all_temp) { zwave=“13:0:command=sensor_multilevel,sensor_type=1” }
Number multi_living_hum “Living Rm Humidity[%.0f %%]” <hum_icon> (all,living,zwave,hum,chart_living_hum,chart_all_hum) { zwave=“13:0:command=sensor_multilevel,sensor_type=5” }
Number multi_living_lum “Living Rm Luminance [%.0f Lux]” <slider_70> (all,living,zwave,lum,chart_living_lum,chart_all_lum) { zwave=“13:command=sensor_multilevel,sensor_type=3” }
Contact multi_living_contact “Living Rm Motion [MAP(multi.map):%s]” (all,living,zwave,contacts) { zwave=“13:command=sensor_binary,respond_to_basic=true” }
DateTime multi_living_contact_time “Living Rm Time [%1$tm/%1$td, %1$tI:%1$tM %1$tp]” (all,living,zwave,updates)
Number multi_attic_temp “Attic Temperature[%.0f °F]” (all,attic,zwave,temp,chart_attic_temp,chart_all_temp) { zwave=“12:command=sensor_multilevel,sensor_type=1” }
Number multi_attic_hum “Attic Humidity[%.0f %%]” <hum_icon> (all,attic,zwave,hum,chart_attic_hum,chart_all_hum) { zwave=“12:command=sensor_multilevel,sensor_type=5” }
Number multi_attic_lum “Attic Luminance [%.0f Lux]” <slider_70> (all,attic,zwave,lum,chart_attic_lum,chart_all_lum) { zwave=“12:command=sensor_multilevel,sensor_type=3” }
Contact multi_attic_contact “Attic Motion [MAP(multi.map):%s]” (all,attic,zwave,contacts) { zwave=“12:command=sensor_binary,respond_to_basic=true” }
Number hvac_main “HVAC Temperature Setpoint [%.0f °F]” (all,zwave,thermostat) { zwave=“14:command=thermostat_setpoint,setpoint_type=1,setpoint_scale=1” }
Number hvac_battery “HVAC Thermostat battery [%d %%]” (all,zwave,thermostat,battery,chart_all_batt) { zwave=“14:command=battery” }
Number hvac_heatsetpoint “HVAC Heat Set [%.0f F]” (all,zwave,thermostat) { zwave=“14:command=thermostat_setpoint,setpoint_type=1,setpoint_scale=1” }
Number hvac_coolsetpoint “HVAC Cool Set [%.0f F]” (all,zwave,thermostat) { zwave=“14:command=thermostat_setpoint,setpoint_type=2,setpoint_scale=1” }
Number hvac_temperature “HVAC Temperature [%.0f °F]” (all,temp,zwave,thermostat,chart_hvac_temp,chart_all_temp) { zwave=“14:1:command=sensor_multilevel,sensor_type=1” }
Number hvac_temperature_max “HVAC Temperature Maximum [%.0f °F]” (all,zwave,thermostat,chart_hvac_temp)
Number hvac_temperature_min “HVAC Temperature Minimum [%.0f °F]” (all,zwave,thermostat,chart_hvac_temp)
Number hvac_temperature_ave “HVAC Temperature Average [%.0f °F]” (all,zwave,thermostat,chart_hvac_temp)
Number hvac_mode “Mode [MAP(tstatmode.map):%d]” (all,zwave,thermostat) { zwave=“14:command=thermostat_mode” }
Number hvac_fan_mode “Mode [MAP(tstatfan.map):%d]” (all,zwave,thermostat) { zwave=“14:command=thermostat_fan_mode” }
Number hvac_operating_state “HVAC Opp State [MAP(tstatopstate.map):%d]” (all,zwave,thermostat) { zwave=“14:command=thermostat_operating_state” }
Number hvac_fan_state “HVAC Fan State [MAP(tstatfan.map):%d]” (all,zwave,thermostat) { zwave=“14:command=thermostat_fan_state” }
Number contact_door_sl2_batt “Sliding Door 2 battery [%d %%]” (all,zwave,battery,chart_all_batt) { zwave=“7:command=battery” }
Errors
2015-11-25 08:03:49.265 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 2: No item bound for event, endpoint = 0, command class = SWITCH_MULTILEVEL, value = 0, ignoring.
2015-11-25 08:03:49.393 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 3: No item bound for event, endpoint = 0, command class = SWITCH_MULTILEVEL, value = 0, ignoring.
2015-11-25 08:03:49.502 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 4: No item bound for event, endpoint = 0, command class = SWITCH_MULTILEVEL, value = 0, ignoring.
2015-11-25 08:03:49.533 [ERROR] [eController$ZWaveReceiveThread] - Protocol error (CAN), resending
2015-11-25 08:03:49.536 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 4: No item bound for event, endpoint = 0, command class = SWITCH_MULTILEVEL, value = 0, ignoring.
2015-11-25 08:03:49.709 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 5: No item bound for event, endpoint = 0, command class = SWITCH_BINARY, value = 0, ignoring.
2015-11-25 08:03:49.853 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 11: No item bound for event, endpoint = 0, command class = SWITCH_BINARY, value = 0, ignoring.
2015-11-25 08:03:50.018 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 11: No item bound for event, endpoint = 0, command class = SENSOR_MULTILEVEL, value = 0E+1, ignoring.
2015-11-25 08:03:50.065 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 11: No item bound for event, endpoint = 0, command class = SENSOR_BINARY, value = 0, ignoring.
2015-11-25 08:03:51.545 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 14: No item bound for event, endpoint = 0, command class = THERMOSTAT_MODE, value = 3, ignoring.
2015-11-25 08:03:51.687 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 14: No item bound for event, endpoint = 1, command class = SENSOR_MULTILEVEL, value = 69, ignoring.
2015-11-25 08:03:51.779 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 14: No item bound for event, endpoint = 2, command class = SENSOR_MULTILEVEL, value = 55, ignoring.
2015-11-25 08:03:51.872 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 14: No item bound for event, endpoint = 0, command class = SENSOR_MULTILEVEL, value = 69, ignoring.
2015-11-25 08:03:52.032 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 14: No item bound for event, endpoint = 0, command class = THERMOSTAT_SETPOINT, value = 8E+1, ignoring.
2015-11-25 08:03:52.173 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 14: No item bound for event, endpoint = 0, command class = THERMOSTAT_SETPOINT, value = 6E+1, ignoring.
2015-11-25 08:03:52.308 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 14: No item bound for event, endpoint = 0, command class = THERMOSTAT_OPERATING_STATE, value = 0, ignoring.
2015-11-25 08:03:52.523 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 14: No item bound for event, endpoint = 0, command class = BATTERY, value = 78, ignoring.
2015-11-25 08:03:52.694 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 14: No item bound for event, endpoint = 0, command class = THERMOSTAT_FAN_STATE, value = 0, ignoring.
2015-11-25 08:03:52.882 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 14: No item bound for event, endpoint = 0, command class = THERMOSTAT_FAN_MODE, value = 0, ignoring.
2015-11-25 08:03:53.038 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 15: No item bound for event, endpoint = 0, command class = METER, value = 381.48, ignoring.
2015-11-25 08:03:53.089 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 15: No item bound for event, endpoint = 0, command class = METER, value = 56.236, ignoring.
2015-11-25 08:03:53.137 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 15: No item bound for event, endpoint = 0, command class = SENSOR_MULTILEVEL, value = 381.48, ignoring.
2015-11-25 08:03:53.181 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 15: No item bound for event, endpoint = 0, command class = BATTERY, value = 0, ignoring.
2015-11-25 08:03:53.235 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 15: No item bound for event, endpoint = 1, command class = METER, value = 265.76, ignoring.
2015-11-25 08:03:53.291 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 15: No item bound for event, endpoint = 1, command class = METER, value = 36.437, ignoring.
2015-11-25 08:03:53.344 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 15: No item bound for event, endpoint = 1, command class = SENSOR_MULTILEVEL, value = 266.64, ignoring.
2015-11-25 08:03:53.399 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 15: No item bound for event, endpoint = 2, command class = METER, value = 119.13, ignoring.
2015-11-25 08:03:53.455 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 15: No item bound for event, endpoint = 2, command class = METER, value = 19.799, ignoring.
2015-11-25 08:03:53.506 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 15: No item bound for event, endpoint = 2, command class = SENSOR_MULTILEVEL, value = 119.13, ignoring
2015-11-25 08:34:18.352 [WARN ] [.b.z.i.c.ZWaveConverterHandler] - No command class found for item = contact_door_sl2, command class name = switch_binary, using 0 refresh interval.
