Dear all,
sorry to bother you with hopefully basic stuff - but actually i am lost since this is my first openhab(2) setup and my first steps in automation.
Setup:
- raspberry2 with installed oh2 beta (full download), updated yesterday
- zme_uzb1 stick
- one fibaro fgk 10x zw5 3.2 (101) sensor (gets detected as fibaro fgk101
- all are included and show up with a check-mark
- I also included all informations and added them as pre-defined new items
What i want:
- basically just on my dashboard updated information if the door is opened or closed.
What I get:
- Information on battery status (100%) – should be correct
- Information that the door is open (always, doesn’t react on sensor, does never change status)
- a mystyrious error in the logfile: ( NODE 2: Endpoint 0 not found. Cannot set command classes)
- and i can’t change the properties of the sensor in the paperui -config: “3: Visual LED indications” is always set to 6 while i would like to set it to 0 – but that’s low prio…
any idea? any logs required to analyze?
thanks for your support, much appreciated!
don
