- Platform information:
- PI3
- Openhabian
- Latest Updates
Item: https://www.openhab.org/addons/bindings/zwave/thing.html?manufacturer=ge&file=smartdoorsensor_0_0.html
Hardly ever do i go out and buy multiple sensors before testing atleast one. I order 5 of these sensors, they were 25 on amazon. 2 have arrived. First one is getting all kinds of errors and no data sent back. Second one manufacturer can’t be recognized.
I have no clue where to start with this. I’ve tried, excluding it, re-adding, multiple updates and reboots. Any suggestions?
Hinge Debug Log.txt (9.2 KB)
That looks to be a filtered trace log with little useful information. Debug level unfiltered logs are needed for debugging.
Yeah I have it filtered for that node, I’ll remove the filter and see if I can capture it.
The developer has said trace level is not useful. Please use debug.
I have debug turned on for zwave, is there anything else i should change?
I woke up this morning to half my zwave items being offline, and front door (this sensor) was also offline but in habmin it was waiting to initialize. Rebooted openhab and it looks like the item fully installed but still not getting a reading. Actually seen node dead for node 25 at one point. Attached is a new log unfiltered.Hinge Debug Log.txt (124.7 KB)
Now it says in habmin “Node Initializing MANUFACTURER”
Status: ONLINE Node initialising: APP_VERSION
dbReference 504
defaultAssociations 1
manufacturerId 0063
manufacturerRef 4953:3032
modelId 32563
vendor Jasco Products
zwave_beaming true
zwave_class_basic BASIC_TYPE_ROUTING_SLAVE
zwave_class_generic GENERIC_TYPE_SENSOR_NOTIFICATION
zwave_class_specific SPECIFIC_TYPE_NOTIFICATION_SENSOR
zwave_deviceid 12338
zwave_devicetype 18771
zwave_frequent false
zwave_lastwakeup 2020-05-19T15:16:22Z
zwave_listening false
zwave_manufacturer 99
zwave_neighbours
zwave_nodeid 25
zwave_routing true
zwave_secure false
zwave_version 0.0
Hey look at that, started working.
working.txt (76.6 KB)
I can see the switch go from 0 to 255 and I can see item go on and off, but I can’t see it in paper under the thing or on sitemap other then a lightbulb icon goes on/off
The zwave log viewer might make it easier to see what is happening.
https://www.cd-jackson.com/index.php/openhab/zwave-log-viewer
Yes I’ve been using the log viewer, nothing stands out. I got it fully working however its item status is blank in paper. I added the second one and this time its was able to identify it however same issues as the first. This is going to be painful as I have three more to add as well.
