Has anyone had luck adding a GE ZW3010 dimmer to openhab.
I’m running 2.5 on a RasPi, with a Aeotec’s Z-Stick .
And all I get is, unknown device? I’ve tried twice with the same result.
See screen shot from Habmin attributes:
Thanks for any help?
It is defined in our database but it looks to me many of the configuration parameters are missing. The entry is here.
https://www.cd-jackson.com/index.php/zwave/zwave-device-database/zwave-device-list/devicesummary/1080
I will try to add the missing parameters. We then need to wait for the weekly database export and then a snapshot build of the Z-Wave binding.
EDIT: I was able to add more configuration parameters and some options to existing ones.
I just added one of these (ZW3010) and openHab shows it as an “Unknown Device”. Is there something i need to do to get the updated database?
You are running Unknown OH version. The answer is therefore unknown.
Sorry, Bruce.
Platform information:
You need to update to openHAB 2.5.2. Be sure to read the Release Notes first.
If you have restdocs
installed, uninstall first & reinstall. Its location moved.
Thanks!
Also be careful. 2.5.2
added a whitelist for the exec binding due to security concerns. Check the announcement here.
Thanks for the heads up on the Exec binding: I followed the instructions in the binding documentation, but I’m still getting an error.
2020-03-07 14:33:34.234 [WARN ] [ng.exec.internal.handler.ExecHandler] - Tried to execute 'c:\apcupsd\bin\apcaccess -u', but it is not contained in whitelist.
My file exec.whitelist
looks like this:
Perhaps I misunderstood what was meant by this:
Allowed commands need to be added to the
misc/exec.whitelist
file in the configuration directory
I placed the file at C:\openHAB2\conf\misc\exec.whitelist
Thanks again for the your quick replies!
I do not use the exec binding but I know there is plenty of advice here. Perhaps search for whitelist.
