If the device is ZWave compliant, then it will work. Just make sure the devices are compatible with the US 908.42 Mhz frequency (my assumption since you’ve chosen the Gen 5).
The only standard I can find is its the same freq as the stick 868.42MHz how do you know it will work when paired with OH don’t you have too write code too make the sensors work?
Don’t treat the database like it’s the truth to everything either. There might be an upgraded firmware or other changes in the product you are buying since it was added to the DB or something just might not work the way it’s supposed to when you first try it. I currently have an PSP05 sensor which is listed, and while some people have gotten it to work, many (myself included) have not. I’m confident it’ll work some day, but it might need some debugging on your part. Safest bet is to buy the stuff that others have already confirmed as working without problems.
