I am configuring on openHAB my ZWave network and so far I saw that all my devices have been recognized correctly but one, that is actually recognized as a thing but shows no channels to link to an item.
This is an aged HomePro dimmer, but still works very well.
According to what I found searching in the community, as the device is shown correctly as a thing, I understand the correct way to address the issue is providing the node details xml file and ask to add it to the database, so I’m doing that here below.
If there’s any other info needed please kindly let me know and apologies if I missed it, I’m actually a openHAB noob.
Best regards
pi@raz:/var/lib/openhab/zwave $ cat network_d4299cd5__node_6.xml
<node>
<homeId>0xd4299cd5</homeId>
<nodeId>6</nodeId>
<version>2</version>
<manufacturer>0x7fffffff</manufacturer>
<deviceId>0x7fffffff</deviceId>
<deviceType>0x7fffffff</deviceType>
<listening>true</listening>
<frequentlyListening>false</frequentlyListening>
<routing>true</routing>
<security>false</security>
<beaming>false</beaming>
<maxBaudRate>9600</maxBaudRate>
<sleepDelay>500</sleepDelay>
<nodeInformationFrame>
<commandClass>COMMAND_CLASS_SWITCH_MULTILEVEL</commandClass>
<commandClass>COMMAND_CLASS_SWITCH_ALL</commandClass>
<commandClass>COMMAND_CLASS_PROTECTION</commandClass>
</nodeInformationFrame>
<associationGroups class="concurrent-hash-map"/>
<endpoints class="concurrent-hash-map">
<entry>
<int>0</int>
<endPoint>
<deviceClass>
<basicDeviceClass>BASIC_TYPE_SLAVE</basicDeviceClass>
<genericDeviceClass>GENERIC_TYPE_SWITCH_MULTILEVEL</genericDeviceClass>
<specificDeviceClass>SPECIFIC_TYPE_NOT_USED</specificDeviceClass>
</deviceClass>
<endpointId>0</endpointId>
<secureCommandClasses/>
<supportedCommandClasses class="concurrent-hash-map">
<entry>
<commandClass>COMMAND_CLASS_NO_OPERATION</commandClass>
<COMMAND__CLASS__NO__OPERATION>
<version>1</version>
<instances>1</instances>
<control>false</control>
<versionSupported>1</versionSupported>
</COMMAND__CLASS__NO__OPERATION>
</entry>
<entry>
<commandClass>COMMAND_CLASS_BASIC</commandClass>
<COMMAND__CLASS__BASIC>
<version>0</version>
<versionSupported>0</versionSupported>
<isGetSupported>true</isGetSupported>
</COMMAND__CLASS__BASIC>
</entry>
<entry>
<multiLevelSwitchCommandClass>
</multiLevelSwitchCommandClass>
</entry>
<entry>
<COMMAND__CLASS__SWITCH__ALL>
<mode>SWITCH_ALL_INCLUDE_ON_OFF</mode>
</COMMAND__CLASS__SWITCH__ALL>
</entry>
<entry>
<COMMAND__CLASS__PROTECTION>
<localModes/>
<rfModes/>
</COMMAND__CLASS__PROTECTION>
</entry>
</supportedCommandClasses>
</endPoint>
</entry>
</endpoints>
<nodeNeighbors/>
<lastReceived>2023-01-14 07:13:34.655 UTC</lastReceived>
</node>pi@raz:/var/lib/openhab/zwave $
