I’m not sure what these classes are, but for sure they aren’t implemented and they possibly might not actually exist. In general, Sigma have what they call Z/IP which implements ZWave over IP (to a gateway), but these classes are simply encapsulation classes.
I have many battery operated devices around the house with no mains power devices, so several devices are now dead as they are so far from the controller.
One option will be another openhab instance with mqtt updates, but i was looking for these zwave / IP devices for simplicity…
It sounds like you should improve the mesh of your network. If you are suggesting to add multiple controllers, then you will likely find other problems with your system, so it’s probably better to solve the network problems that you have by improving the mesh by adding mains powered devices or repeaters. This is likely to improve things globally rather than having to add a number of controllers.
