I have a similar controller (the Wall Controller WCD2). I haven’t used it for anything sensible yet, and it’s been a while since I played around with it, so I am a bit hazy on the details…
My item setup was as follows:
Contact S01D011_cButton1 { zwave="13:command=scene_activation, scene=11, state=1" }
Contact S01D011_cButton2 { zwave="13:command=scene_activation, scene=12, state=0" }
Contact S01D011_cButton3 { zwave="13:command=scene_activation, scene=21, state=1" }
Contact S01D011_cButton4 { zwave="13:command=scene_activation, scene=22, state=0" }
I don’t remember exactly what my logs showed when I did play around with it, but I suspect that the device is only sending state updates. This would then be the reason your “received command ON” rule does not trigger.
About the “changed from OFF to ON” rule not triggering this could very well be because at startup the TV_Wallswitch_Scene1 item is in the Uninitialized state, and consequently it will never change from OFF to anything.
If you change the rule to read “changed to ON” I am pretty sure it should fire. Based on my experience with the device, however, it will probably only fire once after startup. This is because it seems that instead of switching between two states, the device is posting updates of the same state every time you hit a button.
So, in my setup using Contact items, the following rule is working fine for all buttons:
rule "Button 1"
Item S01D011_cButton1 received update OPEN
logInfo("test", "Button 1=" + S01D011_cButton1.state.toString())
if(S01D011_cButton1.state == OPEN) {
logInfo("test", "State=OPEN")
else {
logInfo("test", "State=CLOSED")
The above rule will write “State=OPEN” to the openhab.log file every time you hit Button 1 on the wall controller.
