Hi
Why does not habmin show my ZWave as mesh how do i configure that?
/Mike
Reliable mesh view is available in the dev/secure binding:
Can i use this with 2.2 Stable?
Have i to redo all items?
/Mike
Yes.
Yes.
Is it just to uninstall current zwave binding and copy this to addons?
/Mike
Broadly speaking, yes, but please read the first few emails in the thread as it provides more information about swapping to the other version.
Did not work.
Could not get ZW095 to work.
2018-01-10 20:58:48.958 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 18 00 04 00 09 12 56 01 32 02 21 74 00 4C 46 34 00 00 00 00 00 00 CE AF 95
2018-01-10 20:58:48.963 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Response SENT 6
2018-01-10 20:58:48.967 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], dest=9, callback=0, payload=00 09 12 56 01 32 02 21 74 00 4C 46 34 00 00 00 00 00 00 CE AF
2018-01-10 20:58:48.971 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage past lock Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], dest=9, callback=0, payload=00 09 12 56 01 32 02 21 74 00 4C 46 34 00 00 00 00 00 00 CE AF
2018-01-10 20:58:48.974 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], dest=9, callback=0, payload=00 09 12 56 01 32 02 21 74 00 4C 46 34 00 00 00 00 00 00 CE AF
2018-01-10 20:58:48.976 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2018-01-10 20:58:48.977 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 9: Application Command Request (ALIVE:STATIC_VALUES)
2018-01-10 20:58:48.979 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 9: Decapsulating COMMAND_CLASS_CRC_16_ENCAP
2018-01-10 20:58:48.981 [INFO ] [.ZWaveCRC16EncapsulationCommandClass] - NODE 9: CRC check failed message contains CE AF but should be 20 6B
2018-01-10 20:58:48.982 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2018-01-10 20:58:48.984 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start
Does not show online.
As the error states - the CRC check failed on the message.
I factory reset ZW095 and now i do not get any error but i also dont get any values.
The network does not look healthy can i manually start a mesh heal?
Now the CRC error is back, can not understand why i get this in new binding when i did not get it in the old one.
/Mike
