Zwave metering plug not sending notifications
  • Platform information:
    BOARD=orangepione
    BOARD_NAME=“Orange Pi One”
    BOARDFAMILY=sun8i
    VERSION=5.73
    LINUXFAMILY=sunxi
    USB Z-wave stick on /dev/ttyACM0
    • Java Runtime Environment:
openjdk version “1.8.0_152”
OpenJDK Runtime Environment (Zulu Embedded 8.25.0.76-linux-aarch32hf) (build 1.8.0_152-b76)
OpenJDK Client VM (Zulu Embedded 8.25.0.76-linux-aarch32hf) (build 25.152-b76, mixed mode, Evaluation)
The plug works fine, I can control the relay from paperui/rules.
Polling is configured (600 seconds) and power data (voltage, current etc) are updated and seem to be consistent.
The device itself is configured (via paperui/thing configuration) to send reports every 60 seconds but those reports are not getting through. I’d really like to avoid polling when possible so the question is why I don’t get scheduled reports.
The device has 3 association groups: 1 (Lifeline), 2 and 3. I guess the device is supposed to send usage data on Lifeline.
The following log shows the network startup and first poll of the device (I’ve filtered out communications with thermostat valves). Note that there were no communications between the device initialization and the first poll. I’ve expected to receive unsolicited data from the plug,
Time	Node	Entry
16:51:38.208
Binding started. Version 2.4.0
16:52:00.682
DISCOVERY Active
16:52:03.733
TX REQ GetVersion
16:52:03.740
RX ACK 0 /128
16:52:03.760
RX RES GetVersion  0 /128
16:52:03.919
TX REQ MemoryGetId
16:52:03.926
RX ACK 0 /128
16:52:03.940
RX RES MemoryGetId MemoryGetId: HomeID E671DFE1 ControllerID NODE 1 0 /128
16:52:04.014
TX REQ SerialApiGetCapabilities
16:52:04.019
RX ACK 0 /128
16:52:04.031
RX RES SerialApiGetCapabilities Controller Info 0115:0400:0001 0 /128
16:52:04.091
TX REQ SerialApiSetTimeouts FRAME=1500s BYTE=150ms
16:52:04.100
RX ACK 0 /128
16:52:04.116
RX RES SerialApiSetTimeouts FRAME=1500s BYTE=150ms 0 /128
16:52:04.151
TX REQ GetSucNodeId
16:52:04.155
RX ACK 0 /128
16:52:04.162
RX RES GetSucNodeId SUC ID: NODE 1 0 /128
16:52:04.219
TX REQ SerialApiGetInitData
16:52:04.223
RX ACK 0 /128
16:52:04.321
RX RES SerialApiGetInitData Found 5 nodes  0 /128
16:52:04.431
TX REQ GetControllerCapabilities
16:52:04.436
RX ACK 0 /128
16:52:04.466
RX RES GetControllerCapabilities  0 /128
16:52:05.391	1
Stage advanced to IDENTIFY_NODE
16:52:05.445	1
TX REQ IdentifyNode
16:52:05.450
RX ACK 0 /128
16:52:05.465	1
RX RES IdentifyNode STATIC_CONTROLLER PC_CONTROLLER LISTENING FLIRS250 FLIRS1000 ROUTING BEAMING 0 /128
16:52:05.575	1
Stage advanced to DONE
16:52:13.346	6
THING TYPE zwave:shenzhen_powerplug_00_000
16:52:13.379	6
16:52:13.397
RX ACK 0 /128
16:52:13.606
RX ACK 0 /128
16:52:13.774
RX ACK 0 /128
16:52:13.922	6
TX REQ IdentifyNode
16:52:13.928
RX ACK 0 /128
16:52:13.944	6
RX RES IdentifyNode ROUTING_SLAVE POWER_SWITCH_BINARY LISTENING FLIRS250 FLIRS1000 ROUTING BEAMING 0 /128
16:52:14.035	6
Stage advanced to PING
16:52:14.066	6
TX REQ SendData 1 NO_OPERATION  ACK AUTO_ROUTE EXPLORE
16:52:14.072
RX ACK 0 /128
16:52:14.083	6
RX RES SendData 1 ACCEPTED BY CONTROLLER 0 /128
16:52:14.111	6
RX REQ SendData 1 ACK RECEIVED from device in 45ms 0 /128
16:52:14.162	6
Stage advanced to REQUEST_NIF
16:52:14.182	6
TX REQ RequestNodeInfo
16:52:14.188
RX ACK 0 /128
16:52:14.195	6
RX RES RequestNodeInfo OK 0 /128
16:52:14.250	6
RX REQ ApplicationUpdate UPDATE_STATE_NODE_INFO_RECEIVED  0 /128
16:52:14.318	6
Stage advanced to STATIC_END
16:52:14.412	6
Stage advanced to DYNAMIC_VALUES
16:52:14.463	6
TX REQ SendData 2 METER_GET ELECTRIC_A  ACK AUTO_ROUTE EXPLORE
16:52:14.468
RX ACK 0 /128
16:52:14.480	6
RX RES SendData 2 ACCEPTED BY CONTROLLER 0 /128
16:52:14.498	6
RX REQ SendData 2 ACK RECEIVED from device in 35ms 0 /128
16:52:14.803	6
RX REQ ApplicationCommandHandler METER_REPORT ELECTRIC_KVAH 0 /128
16:52:14.839	6
STATE UPDATE zwave:device:52508370:node6:meter_current 0.66 [DecimalType]
16:52:14.882	6
TX REQ SendData 3 METER_GET ELECTRIC_KWH  ACK AUTO_ROUTE EXPLORE
16:52:14.887
RX ACK 0 /128
16:52:14.898	6
RX RES SendData 3 ACCEPTED BY CONTROLLER 0 /128
16:52:14.920	6
RX REQ SendData 3 ACK RECEIVED from device in 38ms 0 /128
16:52:14.934	6
RX REQ ApplicationCommandHandler METER_REPORT ELECTRIC_KWH 0 /128
16:52:14.976	6
STATE UPDATE zwave:device:52508370:node6:meter_kwh 0.53 [DecimalType]
16:52:15.016	6
TX REQ SendData 4 METER_GET ELECTRIC_V  ACK AUTO_ROUTE EXPLORE
16:52:15.021
RX ACK 0 /128
16:52:15.034	6
RX RES SendData 4 ACCEPTED BY CONTROLLER 0 /128
16:52:15.053	6
RX REQ SendData 4 ACK RECEIVED from device in 37ms 0 /128
16:52:15.067	6
16:52:15.105	6
STATE UPDATE zwave:device:52508370:node6:meter_voltage 231.49 [DecimalType]
16:52:15.159	6
TX REQ SendData 5 METER_GET ELECTRIC_W  ACK AUTO_ROUTE EXPLORE
16:52:15.165
RX ACK 0 /128
16:52:15.174	6
RX RES SendData 5 ACCEPTED BY CONTROLLER 0 /128
16:52:15.199	6
RX REQ SendData 5 ACK RECEIVED from device in 40ms 0 /128
16:52:15.215	6
RX REQ ApplicationCommandHandler METER_REPORT ELECTRIC_W 0 /128
16:52:15.244	6
STATE UPDATE zwave:device:52508370:node6:meter_watts 124.8 [DecimalType]
16:52:15.291	6
TX REQ SendData 6 SWITCH_BINARY_GET  ACK AUTO_ROUTE EXPLORE
16:52:15.297
RX ACK 0 /128
16:52:15.308	6
RX RES SendData 6 ACCEPTED BY CONTROLLER 0 /128
16:52:15.334	6
RX REQ SendData 6 ACK RECEIVED from device in 43ms 0 /128
16:52:15.347	6
RX REQ ApplicationCommandHandler SWITCH_BINARY_REPORT ON 0 /128
16:52:15.379	6
STATE UPDATE zwave:device:52508370:node6:switch_binary ON [OnOffType]
16:52:15.430	6
TX REQ SendData 7 POWERLEVEL_GET  ACK AUTO_ROUTE EXPLORE
16:52:15.435
RX ACK 0 /128
16:52:15.442	6
RX RES SendData 7 ACCEPTED BY CONTROLLER 0 /128
16:52:15.476	6
RX REQ SendData 7 ACK RECEIVED from device in 46ms 0 /128
16:52:15.490	6
RX REQ ApplicationCommandHandler POWERLEVEL_REPORT 0 /128
16:52:15.556	6
Stage advanced to DYNAMIC_END
16:52:15.656	6
16:56:37.331	6
TX REQ SendData 8 SWITCH_BINARY_GET  ACK AUTO_ROUTE EXPLORE
16:56:37.338
RX ACK 0 /128
16:56:37.347	6
RX RES SendData 8 ACCEPTED BY CONTROLLER 0 /128
16:56:37.399	6
RX REQ SendData 8 ACK RECEIVED from device in 68ms 0 /128
16:56:37.425	6
16:56:37.508	6
16:56:37.546	6
TX REQ SendData 9 METER_GET ELECTRIC_A  ACK AUTO_ROUTE EXPLORE
16:56:37.552
RX ACK 0 /128
16:56:37.566	6
RX RES SendData 9 ACCEPTED BY CONTROLLER 0 /128
16:56:37.587	6
RX REQ SendData 9 ACK RECEIVED from device in 41ms 0 /128
16:56:37.618	6
16:56:37.669	6
STATE UPDATE zwave:device:52508370:node6:meter_current 0.63 [DecimalType]
16:56:37.708	6
TX REQ SendData 10 METER_GET ELECTRIC_KWH  ACK AUTO_ROUTE EXPLORE
16:56:37.720
RX ACK 0 /128
16:56:37.732	6
RX RES SendData 10 ACCEPTED BY CONTROLLER 0 /128
16:56:37.762	6
RX REQ SendData 10 ACK RECEIVED from device in 54ms 0 /128
16:56:37.796	6
16:56:37.850	6
STATE UPDATE zwave:device:52508370:node6:meter_kwh 0.54 [DecimalType]
16:56:37.885	6
TX REQ SendData 11 METER_GET ELECTRIC_W  ACK AUTO_ROUTE EXPLORE
16:56:37.891
RX ACK 0 /128
16:56:37.899	6
RX RES SendData 11 ACCEPTED BY CONTROLLER 0 /128
16:56:37.923	6
RX REQ SendData 11 ACK RECEIVED from device in 38ms 0 /128
16:56:37.939	6
16:56:37.995	6
STATE UPDATE zwave:device:52508370:node6:meter_watts 116.92 [DecimalType]
16:56:38.025	6
TX REQ SendData 12 METER_GET ELECTRIC_V  ACK AUTO_ROUTE EXPLORE
16:56:38.031
RX ACK 0 /128
16:56:38.043	6
RX RES SendData 12 ACCEPTED BY CONTROLLER 0 /128
16:56:38.061	6
RX REQ SendData 12 ACK RECEIVED from device in 36ms 0 /128
16:56:38.077	6
16:56:38.127	6
STATE UPDATE zwave:device:52508370:node6:meter_voltage 231.94 [DecimalType]
16:57:49.376
RX ACK 0 /128
16:57:49.739
RX ACK 0 /128
16:57:49.995
RX ACK 0 /128
16:57:50.206
RX ACK 0 /128
16:57:50.422
RX ACK 0 /128
16:57:54.336
RX ACK 0 /128
16:58:49.460
RX ACK 0 /128
16:58:49.692
RX ACK 0 /128
16:58:49.897
RX ACK 0 /128
16:58:50.112
RX ACK 0 /128
16:58:50.368
RX ACK 0 /128
16:58:54.426
RX ACK 0 /128
I do not have much experience with z-wave so would be grateful for any advice on why the scheduled reports are not working.
I’ve the same problem!
Please use the latest snapshot of the binding. If there are still issues, reconfigure the device (this is an option in the device configuration - just set it to true and save) and also provide a debug log.
Thank you, started working after healing the network.
