Changing the configuration is not possible due to incorrect handling of parameter 8: Timeout after wake up. Default it shows -1, but any value is rejected, no matter the value of it (it says value should be higher than 8). As parameter 8 can not be set, it blocks the change of any other parameter.
- 8: Timeout after wake up
Select a value which is not lower than 8.
Set the timeout of awake after the Wake Up CC is sent out…
Sensor info:
zwave_class_basic BASIC_TYPE_ROUTING_SLAVE
zwave_class_generic GENERIC_TYPE_SENSOR_MULTILEVEL
zwave_neighbours 4,5
modelId ZW100
zwave_version 1.15
zwave_plus_devicetype NODE_TYPE_ZWAVEPLUS_NODE
versionMin 1.10
vendor AEON Labs
defaultAssociations 1
zwave_routing true
zwave_beaming true
zwave_secure false
zwave_class_specific SPECIFIC_TYPE_ROUTING_SENSOR_MULTILEVEL
zwave_devicetype 2
zwave_frequent false
zwave_listening true
manufacturerId 0086
manufacturerRef 0002:0064,0102:0064,0202:0064,1A02:0064
dbReference 778
zwave_deviceid 100
zwave_nodeid 3
zwave_lastheal 2021-08-04T07:20:00Z
zwave_plus_roletype UNKNOWN_FF
zwave_manufacturer 134
Openhab version: 3.1.0 stable
