Hi all,
I need your help please. I have a z-wave network with 14 nodes which worked pretty fine until recently. All of a sudden the devices don’t react anymore. From the log it seems like they don’t initialize anymore. In HABmin they show as “Node initializing: PING” or "Node initializing: “Request_NIF”. However I can’t make any sense out of it what to do next…
Help would be greatly appreciated!
Here is the log of about 1-2 min after reboot:
2019-07-19 23:31:49.707 [DEBUG] [org.openhab.binding.zwave ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.core.events.EventFactory}={service.id=319, service.bundleid=273, service.scope=bundle, component.name=org.openhab.binding.zwave.event.BindingEventFactory, component.id=205} - org.openhab.binding.zwave
2019-07-19 23:31:49.766 [DEBUG] [org.openhab.binding.zwave ] - BundleEvent STARTED - org.openhab.binding.zwave
2019-07-19 23:31:49.926 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'rrd4j.persist'
2019-07-19 23:31:49.954 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'mapdb.persist'
2019-07-19 23:31:49.989 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'influxdb.persist'
2019-07-19 23:31:50.374 [INFO ] [b.core.service.AbstractActiveService] - FritzBox refresh Service has been started
2019-07-19 23:31:51.191 [INFO ] [.dashboard.internal.DashboardService] - Started Dashboard at http://192.168.178.50:8080
2019-07-19 23:31:51.193 [INFO ] [.dashboard.internal.DashboardService] - Started Dashboard at https://192.168.178.50:8443
2019-07-19 23:31:51.292 [INFO ] [ui.habmin.internal.servlet.HABminApp] - Started HABmin servlet at /habmin
2019-07-19 23:31:52.202 [INFO ] [penhab.io.transport.mqtt.MqttService] - MQTT Service initialization completed.
2019-07-19 23:31:52.203 [INFO ] [t.mqtt.internal.MqttBrokerConnection] - Starting MQTT broker connection 'mqtt'
2019-07-19 23:31:53.341 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing 'ntp:ntp:local' to inbox.
2019-07-19 23:31:56.054 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - Initializing ZWave serial controller.
2019-07-19 23:31:56.056 [DEBUG] [zwave.handler.ZWaveControllerHandler] - Initializing ZWave Controller zwave:serial_zstick:4bd824b3.
2019-07-19 23:31:56.058 [DEBUG] [zwave.handler.ZWaveControllerHandler] - Scheduling network mesh heal for 3 hours time.
2019-07-19 23:31:56.100 [INFO ] [ing.zwave.handler.ZWaveSerialHandler] - Connecting to serial port '/dev/ttyACM0'
2019-07-19 23:31:56.130 [DEBUG] [org.openhab.binding.zwave ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.config.core.status.ConfigStatusProvider}={service.id=398, service.bundleid=273, service.scope=singleton} - org.openhab.binding.zwave
2019-07-19 23:31:56.133 [DEBUG] [org.openhab.binding.zwave ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.config.core.status.ConfigStatusProvider}={service.id=399, service.bundleid=273, service.scope=singleton} - org.openhab.binding.zwave
2019-07-19 23:31:56.133 [DEBUG] [org.openhab.binding.zwave ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.config.core.status.ConfigStatusProvider}={service.id=401, service.bundleid=273, service.scope=singleton} - org.openhab.binding.zwave
2019-07-19 23:31:56.133 [DEBUG] [org.openhab.binding.zwave ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.config.core.status.ConfigStatusProvider}={service.id=400, service.bundleid=273, service.scope=singleton} - org.openhab.binding.zwave
2019-07-19 23:31:56.146 [DEBUG] [org.openhab.binding.zwave ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.config.core.status.ConfigStatusProvider}={service.id=402, service.bundleid=273, service.scope=singleton} - org.openhab.binding.zwave
2019-07-19 23:31:56.233 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Initializing ZWave thing handler zwave:device:4bd824b3:node9.
2019-07-19 23:31:56.274 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Initializing ZWave thing handler zwave:device:4bd824b3:node6.
2019-07-19 23:31:56.277 [DEBUG] [org.openhab.binding.zwave ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.config.core.status.ConfigStatusProvider}={service.id=404, service.bundleid=273, service.scope=singleton} - org.openhab.binding.zwave
2019-07-19 23:31:56.284 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Channel zwave:device:4bd824b3:node9:switch_dimmer linked - polling started.
2019-07-19 23:31:56.286 [DEBUG] [org.openhab.binding.zwave ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.config.core.status.ConfigStatusProvider}={service.id=403, service.bundleid=273, service.scope=singleton} - org.openhab.binding.zwave
2019-07-19 23:31:56.289 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 6: Channel zwave:device:4bd824b3:node6:scene_number linked - polling started.
2019-07-19 23:31:56.289 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 6: Channel zwave:device:4bd824b3:node6:alarm_power linked - polling started.
2019-07-19 23:31:56.290 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 6: Channel zwave:device:4bd824b3:node6:battery-level linked - polling started.
2019-07-19 23:31:56.290 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 6: Channel zwave:device:4bd824b3:node6:scene_number3 linked - polling started.
2019-07-19 23:31:56.292 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 6: Channel zwave:device:4bd824b3:node6:scene_number1 linked - polling started.
2019-07-19 23:31:56.291 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 6: Channel zwave:device:4bd824b3:node6:scene_number4 linked - polling started.
2019-07-19 23:31:56.290 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 6: Channel zwave:device:4bd824b3:node6:scene_number2 linked - polling started.
2019-07-19 23:31:56.324 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Initializing ZWave thing handler zwave:device:4bd824b3:node7.
2019-07-19 23:31:56.328 [DEBUG] [org.openhab.binding.zwave ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.config.core.status.ConfigStatusProvider}={service.id=405, service.bundleid=273, service.scope=singleton} - org.openhab.binding.zwave
2019-07-19 23:31:56.329 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Initializing ZWave thing handler zwave:device:4bd824b3:node8.
2019-07-19 23:31:56.331 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 7: Channel zwave:device:4bd824b3:node7:switch_binary linked - polling started.
2019-07-19 23:31:56.332 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 7: Channel zwave:device:4bd824b3:node7:sensor_power linked - polling started.
2019-07-19 23:31:56.332 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 7: Channel zwave:device:4bd824b3:node7:meter_watts linked - polling started.
2019-07-19 23:31:56.333 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 7: Channel zwave:device:4bd824b3:node7:meter_kwh linked - polling started.
2019-07-19 23:31:56.334 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 7: Channel zwave:device:4bd824b3:node7:config_decimal_param41 linked - polling started.
2019-07-19 23:31:56.334 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 7: Channel zwave:device:4bd824b3:node7:config_decimal_param42 linked - polling started.
2019-07-19 23:31:56.335 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 7: Channel zwave:device:4bd824b3:node7:alarm_power linked - polling started.
2019-07-19 23:31:56.335 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 8: Channel zwave:device:4bd824b3:node8:sensor_relhumidity linked - polling started.
2019-07-19 23:31:56.335 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 8: Channel zwave:device:4bd824b3:node8:sensor_temperature linked - polling started.
2019-07-19 23:31:56.336 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 8: Channel zwave:device:4bd824b3:node8:sensor_luminance linked - polling started.
2019-07-19 23:31:56.336 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 8: Channel zwave:device:4bd824b3:node8:sensor_ultraviolet linked - polling started.
2019-07-19 23:31:56.336 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 8: Channel zwave:device:4bd824b3:node8:alarm_tamper linked - polling started.
2019-07-19 23:31:56.336 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 8: Channel zwave:device:4bd824b3:node8:alarm_motion linked - polling started.
2019-07-19 23:31:56.337 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 8: Channel zwave:device:4bd824b3:node8:battery-level linked - polling started.
2019-07-19 23:31:56.338 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 7: Channel zwave:device:4bd824b3:node7:meter_reset linked - polling started.
2019-07-19 23:31:56.344 [DEBUG] [org.openhab.binding.zwave ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.config.core.status.ConfigStatusProvider}={service.id=406, service.bundleid=273, service.scope=singleton} - org.openhab.binding.zwave
2019-07-19 23:31:56.364 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - Starting receive thread
2019-07-19 23:31:56.371 [INFO ] [ing.zwave.handler.ZWaveSerialHandler] - Serial port is initialized
2019-07-19 23:31:56.372 [DEBUG] [zwave.handler.ZWaveControllerHandler] - Initialising ZWave controller
2019-07-19 23:31:56.395 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Starting ZWave thread: Receive
2019-07-19 23:31:56.434 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Initializing ZWave thing handler zwave:device:4bd824b3:node5.
2019-07-19 23:31:56.436 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Initializing ZWave thing handler zwave:device:4bd824b3:node14.
2019-07-19 23:31:56.437 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Initializing ZWave thing handler zwave:device:4bd824b3:node3.
2019-07-19 23:31:56.443 [DEBUG] [org.openhab.binding.zwave ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.config.core.status.ConfigStatusProvider}={service.id=407, service.bundleid=273, service.scope=singleton} - org.openhab.binding.zwave
2019-07-19 23:31:56.444 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Initializing ZWave thing handler zwave:device:4bd824b3:node2.
2019-07-19 23:31:56.447 [DEBUG] [org.openhab.binding.zwave ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.config.core.status.ConfigStatusProvider}={service.id=408, service.bundleid=273, service.scope=singleton} - org.openhab.binding.zwave
2019-07-19 23:31:56.449 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 10 00 04 00 03 0A 32 02 21 34 00 00 00 21 00 00 E6
2019-07-19 23:31:56.449 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Initializing ZWave thing handler zwave:device:4bd824b3:node4.
2019-07-19 23:31:56.455 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Channel zwave:device:4bd824b3:node5:switch_binary linked - polling started.
2019-07-19 23:31:56.456 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Channel zwave:device:4bd824b3:node5:blinds_control linked - polling started.
2019-07-19 23:31:56.456 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Channel zwave:device:4bd824b3:node5:scene_number linked - polling started.
2019-07-19 23:31:56.457 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Channel zwave:device:4bd824b3:node5:meter_watts linked - polling started.
2019-07-19 23:31:56.456 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Channel zwave:device:4bd824b3:node5:sensor_power linked - polling started.
2019-07-19 23:31:56.459 [DEBUG] [org.openhab.binding.zwave ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.config.core.status.ConfigStatusProvider}={service.id=409, service.bundleid=273, service.scope=singleton} - org.openhab.binding.zwave
2019-07-19 23:31:56.459 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Channel zwave:device:4bd824b3:node5:meter_kwh linked - polling started.
2019-07-19 23:31:56.460 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Channel zwave:device:4bd824b3:node5:blinds_shutter linked - polling started.
2019-07-19 23:31:56.460 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Channel zwave:device:4bd824b3:node5:blinds_lamella linked - polling started.
2019-07-19 23:31:56.471 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 10 00 04 00 03 0A 32 02 21 34 00 00 00 20 00 00 E7
2019-07-19 23:31:56.474 [DEBUG] [org.openhab.binding.zwave ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.config.core.status.ConfigStatusProvider}={service.id=410, service.bundleid=273, service.scope=singleton} - org.openhab.binding.zwave
2019-07-19 23:31:56.478 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 14: Channel zwave:device:4bd824b3:node14:switch_binary2 linked - polling started.
2019-07-19 23:31:56.477 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 14: Channel zwave:device:4bd824b3:node14:switch_binary linked - polling started.
2019-07-19 23:31:56.483 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Initializing ZWave thing handler zwave:device:4bd824b3:node12.
2019-07-19 23:31:56.477 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 14: Channel zwave:device:4bd824b3:node14:switch_binary1 linked - polling started.
2019-07-19 23:31:56.493 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Channel zwave:device:4bd824b3:node2:alarm_tamper linked - polling started.
2019-07-19 23:31:56.493 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Channel zwave:device:4bd824b3:node2:sensor_door linked - polling started.
2019-07-19 23:31:56.493 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Channel zwave:device:4bd824b3:node2:battery-level linked - polling started.
2019-07-19 23:31:56.500 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 4: Channel zwave:device:4bd824b3:node4:meter_kwh linked - polling started.
2019-07-19 23:31:56.501 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 4: Channel zwave:device:4bd824b3:node4:scene_number linked - polling started.
2019-07-19 23:31:56.504 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 10 00 04 10 03 0A 32 02 21 34 00 00 00 20 00 00 F7
2019-07-19 23:31:56.501 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 4: Channel zwave:device:4bd824b3:node4:meter_reset linked - polling started.
2019-07-19 23:31:56.504 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 4: Channel zwave:device:4bd824b3:node4:meter_kwh1 linked - polling started.
2019-07-19 23:31:56.504 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 4: Channel zwave:device:4bd824b3:node4:switch_binary1 linked - polling started.
2019-07-19 23:31:56.505 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 4: Channel zwave:device:4bd824b3:node4:switch_binary2 linked - polling started.
2019-07-19 23:31:56.505 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 4: Channel zwave:device:4bd824b3:node4:meter_watts1 linked - polling started.
2019-07-19 23:31:56.506 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 4: Channel zwave:device:4bd824b3:node4:meter_kwh2 linked - polling started.
2019-07-19 23:31:56.506 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 4: Channel zwave:device:4bd824b3:node4:meter_watts2 linked - polling started.
2019-07-19 23:31:56.507 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 3: Channel zwave:device:4bd824b3:node3:switch_binary linked - polling started.
2019-07-19 23:31:56.508 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 3: Channel zwave:device:4bd824b3:node3:scene_number linked - polling started.
2019-07-19 23:31:56.508 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 3: Channel zwave:device:4bd824b3:node3:meter_current linked - polling started.
2019-07-19 23:31:56.508 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 3: Channel zwave:device:4bd824b3:node3:meter_kwh linked - polling started.
2019-07-19 23:31:56.501 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 4: Channel zwave:device:4bd824b3:node4:meter_watts linked - polling started.
2019-07-19 23:31:56.509 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 4: Channel zwave:device:4bd824b3:node4:alarm_general linked - polling started.
2019-07-19 23:31:56.509 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 3: Channel zwave:device:4bd824b3:node3:meter_reset linked - polling started.
2019-07-19 23:31:56.512 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 12: Channel zwave:device:4bd824b3:node12:sensor_door linked - polling started.
2019-07-19 23:31:56.514 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 12: Channel zwave:device:4bd824b3:node12:alarm_burglar linked - polling started.
2019-07-19 23:31:56.515 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 12: Channel zwave:device:4bd824b3:node12:battery-level linked - polling started.
2019-07-19 23:31:56.532 [INFO ] [ve.internal.protocol.ZWaveController] - Starting ZWave controller
2019-07-19 23:31:56.533 [INFO ] [ve.internal.protocol.ZWaveController] - ZWave timeout is set to 5000ms. Soft reset is false.
2019-07-19 23:31:56.537 [DEBUG] [ve.internal.protocol.ZWaveController] - Event listener added.
2019-07-19 23:31:56.538 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2019-07-19 23:31:56.544 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - Creating ZWave discovery service for zwave:serial_zstick:4bd824b3 with scan time of 30
2019-07-19 23:31:56.545 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - ZWave discovery: Active zwave:serial_zstick:4bd824b3
2019-07-19 23:31:56.555 [DEBUG] [org.openhab.binding.zwave ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.config.discovery.DiscoveryService}={service.id=411, service.bundleid=273, service.scope=singleton} - org.openhab.binding.zwave
2019-07-19 23:31:56.557 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2019-07-19 23:31:56.592 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Initializing ZWave thing handler zwave:device:4bd824b3:node13.
2019-07-19 23:31:56.599 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 13: Channel zwave:device:4bd824b3:node13:sensor_binary linked - polling started.
2019-07-19 23:31:56.599 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 13: Channel zwave:device:4bd824b3:node13:sensor_co linked - polling started.
2019-07-19 23:31:56.602 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 13: Channel zwave:device:4bd824b3:node13:alarm_burglar linked - polling started.
2019-07-19 23:31:56.602 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 13: Channel zwave:device:4bd824b3:node13:alarm_system linked - polling started.
2019-07-19 23:31:56.603 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 13: Channel zwave:device:4bd824b3:node13:battery-level linked - polling started.
2019-07-19 23:31:56.603 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 13: Channel zwave:device:4bd824b3:node13:alarm_power linked - polling started.
2019-07-19 23:31:56.604 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 13: Channel zwave:device:4bd824b3:node13:alarm_general linked - polling started.
2019-07-19 23:31:56.602 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 13: Channel zwave:device:4bd824b3:node13:alarm_heat linked - polling started.
2019-07-19 23:31:56.601 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 13: Channel zwave:device:4bd824b3:node13:alarm_co linked - polling started.
2019-07-19 23:31:56.600 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 13: Channel zwave:device:4bd824b3:node13:sensor_temperature linked - polling started.
2019-07-19 23:31:56.610 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Initializing ZWave thing handler zwave:device:4bd824b3:node11.
2019-07-19 23:31:56.615 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Initializing ZWave thing handler zwave:device:4bd824b3:node10.
2019-07-19 23:31:56.626 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Channel zwave:device:4bd824b3:node11:sensor_power linked - polling started.
2019-07-19 23:31:56.626 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Channel zwave:device:4bd824b3:node11:switch_dimmer linked - polling started.
2019-07-19 23:31:56.626 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Channel zwave:device:4bd824b3:node11:meter_watts linked - polling started.
2019-07-19 23:31:56.627 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Channel zwave:device:4bd824b3:node11:meter_kwh linked - polling started.
2019-07-19 23:31:56.627 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Channel zwave:device:4bd824b3:node11:color_color linked - polling started.
2019-07-19 23:31:56.627 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Channel zwave:device:4bd824b3:node11:scene_number_param72 linked - polling started.
2019-07-19 23:31:56.628 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Channel zwave:device:4bd824b3:node11:switch_dimmer2 linked - polling started.
2019-07-19 23:31:56.628 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Channel zwave:device:4bd824b3:node11:switch_dimmer4 linked - polling started.
2019-07-19 23:31:56.628 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Channel zwave:device:4bd824b3:node11:switch_dimmer3 linked - polling started.
2019-07-19 23:31:56.629 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Channel zwave:device:4bd824b3:node11:switch_dimmer5 linked - polling started.
2019-07-19 23:31:56.629 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Channel zwave:device:4bd824b3:node10:sensor_power linked - polling started.
2019-07-19 23:31:56.629 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Channel zwave:device:4bd824b3:node10:scene_number linked - polling started.
2019-07-19 23:31:56.630 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Channel zwave:device:4bd824b3:node10:meter_kwh linked - polling started.
2019-07-19 23:31:56.631 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Channel zwave:device:4bd824b3:node10:meter_watts linked - polling started.
2019-07-19 23:31:56.631 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Channel zwave:device:4bd824b3:node10:meter_reset linked - polling started.
2019-07-19 23:31:56.632 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Channel zwave:device:4bd824b3:node10:config_decimal_param19 linked - polling started.
2019-07-19 23:31:56.632 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Channel zwave:device:4bd824b3:node10:alarm_heat linked - polling started.
2019-07-19 23:31:56.632 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Channel zwave:device:4bd824b3:node10:alarm_power linked - polling started.
2019-07-19 23:31:56.633 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Channel zwave:device:4bd824b3:node10:alarm_system linked - polling started.
2019-07-19 23:31:56.633 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Channel zwave:device:4bd824b3:node10:switch_dimmer1 linked - polling started.
2019-07-19 23:31:56.633 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Channel zwave:device:4bd824b3:node10:sensor_power1 linked - polling started.
2019-07-19 23:31:56.634 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Channel zwave:device:4bd824b3:node10:meter_watts1 linked - polling started.
2019-07-19 23:31:56.634 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Channel zwave:device:4bd824b3:node10:alarm_heat1 linked - polling started.
2019-07-19 23:31:56.635 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Channel zwave:device:4bd824b3:node10:alarm_power1 linked - polling started.
2019-07-19 23:31:56.635 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Channel zwave:device:4bd824b3:node10:alarm_system1 linked - polling started.
2019-07-19 23:31:56.635 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Channel zwave:device:4bd824b3:node10:switch_dimmer2 linked - polling started.
2019-07-19 23:31:56.634 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Channel zwave:device:4bd824b3:node10:meter_kwh1 linked - polling started.
2019-07-19 23:31:59.061 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'daytime.rules'
2019-07-19 23:31:59.273 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'haus.sitemap'
2019-07-19 23:31:59.406 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 4: Channel zwave:device:4bd824b3:node4:switch_binary1 linked - polling started.
2019-07-19 23:31:59.416 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 4: Channel zwave:device:4bd824b3:node4:switch_binary2 linked - polling started.
2019-07-19 23:31:59.419 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 3: Channel zwave:device:4bd824b3:node3:switch_binary linked - polling started.
2019-07-19 23:31:59.420 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Channel zwave:device:4bd824b3:node5:blinds_control linked - polling started.
2019-07-19 23:31:59.421 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 7: Channel zwave:device:4bd824b3:node7:switch_binary linked - polling started.
2019-07-19 23:31:59.421 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Channel zwave:device:4bd824b3:node10:switch_dimmer1 linked - polling started.
2019-07-19 23:31:59.422 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Channel zwave:device:4bd824b3:node9:switch_dimmer linked - polling started.
2019-07-19 23:31:59.423 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Channel zwave:device:4bd824b3:node11:switch_dimmer linked - polling started.
2019-07-19 23:31:59.423 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Channel zwave:device:4bd824b3:node11:color_color linked - polling started.
2019-07-19 23:31:59.424 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Channel zwave:device:4bd824b3:node11:switch_dimmer5 linked - polling started.
2019-07-19 23:31:59.425 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Channel zwave:device:4bd824b3:node11:switch_dimmer2 linked - polling started.
2019-07-19 23:31:59.425 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Channel zwave:device:4bd824b3:node11:switch_dimmer3 linked - polling started.
2019-07-19 23:31:59.427 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 13: Channel zwave:device:4bd824b3:node13:sensor_co linked - polling started.
2019-07-19 23:31:59.434 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 13: Channel zwave:device:4bd824b3:node13:alarm_co linked - polling started.
2019-07-19 23:31:59.426 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Channel zwave:device:4bd824b3:node11:scene_number_param72 linked - polling started.
2019-07-19 23:31:59.426 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Channel zwave:device:4bd824b3:node11:switch_dimmer4 linked - polling started.
2019-07-19 23:31:59.446 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 13: Channel zwave:device:4bd824b3:node13:sensor_temperature linked - polling started.
2019-07-19 23:31:59.448 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 13: Channel zwave:device:4bd824b3:node13:alarm_heat linked - polling started.
2019-07-19 23:31:59.452 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 13: Channel zwave:device:4bd824b3:node13:battery-level linked - polling started.
2019-07-19 23:31:59.453 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Channel zwave:device:4bd824b3:node2:battery-level linked - polling started.
2019-07-19 23:31:59.452 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Channel zwave:device:4bd824b3:node2:sensor_door linked - polling started.
2019-07-19 23:31:59.458 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 6: Channel zwave:device:4bd824b3:node6:scene_number linked - polling started.
2019-07-19 23:31:59.469 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 8: Channel zwave:device:4bd824b3:node8:sensor_temperature linked - polling started.
2019-07-19 23:31:59.470 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 8: Channel zwave:device:4bd824b3:node8:sensor_relhumidity linked - polling started.
2019-07-19 23:31:59.484 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 12: Channel zwave:device:4bd824b3:node12:sensor_door linked - polling started.
2019-07-19 23:31:59.485 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 14: Channel zwave:device:4bd824b3:node14:switch_binary1 linked - polling started.
2019-07-19 23:31:59.539 [DEBUG] [.ZWaveController$InitializeDelayTask] - Initialising network
2019-07-19 23:31:59.568 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 255: Added 0 to queue - size 1
2019-07-19 23:31:59.569 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2019-07-19 23:31:59.571 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 03 00 15 E9
2019-07-19 23:31:59.572 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 255: Sending REQUEST Message = 01 03 00 15 E9
2019-07-19 23:31:59.574 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 06
2019-07-19 23:31:59.576 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2019-07-19 23:31:59.577 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2019-07-19 23:31:59.577 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 10 01 15 5A 2D 57 61 76 65 20 33 2E 39 35 00 01 99
2019-07-19 23:31:59.578 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2019-07-19 23:31:59.578 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg: ACK
2019-07-19 23:31:59.579 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2019-07-19 23:31:59.581 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - Message SENT
2019-07-19 23:31:59.582 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage started: TID 0: [WAIT_RESPONSE] priority=Controller, requiresResponse=true, callback: 0
2019-07-19 23:31:59.582 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=GetVersion[21], type=Response[1], dest=255, callback=0, payload=5A 2D 57 61 76 65 20 33 2E 39 35 00 01
2019-07-19 23:31:59.584 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2019-07-19 23:31:59.585 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=GetVersion[21], type=Response[1], dest=255, callback=0, payload=5A 2D 57 61 76 65 20 33 2E 39 35 00 01
2019-07-19 23:31:59.586 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 0: [WAIT_RESPONSE] priority=Controller, requiresResponse=true, callback: 0
2019-07-19 23:31:59.587 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 1
2019-07-19 23:31:59.587 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: TID 0: [WAIT_RESPONSE] priority=Controller, requiresResponse=true, callback: 0
2019-07-19 23:31:59.588 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=GetVersion[21], type=Response[1], dest=255, callback=0, payload=5A 2D 57 61 76 65 20 33 2E 39 35 00 01
2019-07-19 23:31:59.592 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 255: Added 1 to queue - size 1
2019-07-19 23:31:59.593 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2019-07-19 23:31:59.601 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 255: Added 2 to queue - size 2
2019-07-19 23:31:59.602 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2019-07-19 23:31:59.611 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 255: Added 3 to queue - size 3
2019-07-19 23:31:59.612 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2019-07-19 23:31:59.622 [DEBUG] [rialmessage.GetSucNodeIdMessageClass] - Get SUC NodeID
2019-07-19 23:31:59.623 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 255: Added 4 to queue - size 4
2019-07-19 23:31:59.624 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2019-07-19 23:31:59.634 [DEBUG] [serialmessage.GetVersionMessageClass] - Got MessageGetVersion response. Version=Z-Wave 3.95, Library Type=1
2019-07-19 23:31:59.635 [DEBUG] [e.internal.protocol.ZWaveTransaction] - TID 0: Transaction COMPLETED
2019-07-19 23:31:59.637 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 255: Response processed after 54ms
2019-07-19 23:31:59.638 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 255: TID 0: Transaction completed
2019-07-19 23:31:59.639 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 255: notifyTransactionResponse TID:0 DONE
2019-07-19 23:31:59.652 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2019-07-19 23:31:59.653 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2019-07-19 23:31:59.655 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 03 00 20 DC
2019-07-19 23:31:59.656 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 255: Sending REQUEST Message = 01 03 00 20 DC
2019-07-19 23:31:59.657 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 06
2019-07-19 23:31:59.657 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - Message SENT
2019-07-19 23:31:59.660 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage started: TID 1: [WAIT_RESPONSE] priority=Controller, requiresResponse=true, callback: 0
2019-07-19 23:31:59.661 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2019-07-19 23:31:59.663 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 08 01 20 D0 98 9A 87 01 82
2019-07-19 23:31:59.664 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2019-07-19 23:31:59.665 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 1: [WAIT_RESPONSE] priority=Controller, requiresResponse=true, callback: 0
2019-07-19 23:31:59.666 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg: ACK
2019-07-19 23:31:59.668 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2019-07-19 23:31:59.669 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=MemoryGetId[32], type=Response[1], dest=255, callback=0, payload=D0 98 9A 87 01
2019-07-19 23:31:59.671 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2019-07-19 23:31:59.672 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=MemoryGetId[32], type=Response[1], dest=255, callback=0, payload=D0 98 9A 87 01
2019-07-19 23:31:59.674 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 1: [WAIT_RESPONSE] priority=Controller, requiresResponse=true, callback: 0
2019-07-19 23:31:59.675 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 1
2019-07-19 23:31:59.678 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: TID 1: [WAIT_RESPONSE] priority=Controller, requiresResponse=true, callback: 0
2019-07-19 23:31:59.683 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=MemoryGetId[32], type=Response[1], dest=255, callback=0, payload=D0 98 9A 87 01
2019-07-19 23:31:59.685 [DEBUG] [erialmessage.MemoryGetIdMessageClass] - Got MessageMemoryGetId response. Home id = 0xd0989a87, Controller Node id = 1
2019-07-19 23:31:59.686 [DEBUG] [e.internal.protocol.ZWaveTransaction] - TID 1: Transaction COMPLETED
2019-07-19 23:31:59.689 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 255: Response processed after 29ms
2019-07-19 23:31:59.690 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 255: TID 1: Transaction completed
2019-07-19 23:31:59.694 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 255: notifyTransactionResponse TID:1 DONE
2019-07-19 23:31:59.696 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2019-07-19 23:31:59.699 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2019-07-19 23:31:59.700 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 03 00 07 FB
2019-07-19 23:31:59.707 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 255: Sending REQUEST Message = 01 03 00 07 FB
2019-07-19 23:31:59.708 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 06
2019-07-19 23:31:59.709 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2019-07-19 23:31:59.708 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - Message SENT
2019-07-19 23:31:59.715 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage started: TID 2: [WAIT_RESPONSE] priority=Controller, requiresResponse=true, callback: 0
2019-07-19 23:31:59.715 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 2B 01 07 01 00 00 86 00 01 00 5A FE 81 FF 88 4F 1F 00 00 FB 9F 7D A0 67 00 00 80 00 80 86 00 00 00 E8 73 00 00 0E 00 00 60 00 00 FB
2019-07-19 23:31:59.716 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2019-07-19 23:31:59.716 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 2: [WAIT_RESPONSE] priority=Controller, requiresResponse=true, callback: 0
2019-07-19 23:31:59.719 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg: ACK
2019-07-19 23:31:59.719 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=SerialApiGetCapabilities[7], type=Response[1], dest=255, callback=0, payload=01 00 00 86 00 01 00 5A FE 81 FF 88 4F 1F 00 00 FB 9F 7D A0 67 00 00 80 00 80 86 00 00 00 E8 73 00 00 0E 00 00 60 00 00
2019-07-19 23:31:59.719 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2019-07-19 23:31:59.720 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2019-07-19 23:31:59.727 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=SerialApiGetCapabilities[7], type=Response[1], dest=255, callback=0, payload=01 00 00 86 00 01 00 5A FE 81 FF 88 4F 1F 00 00 FB 9F 7D A0 67 00 00 80 00 80 86 00 00 00 E8 73 00 00 0E 00 00 60 00 00
2019-07-19 23:31:59.728 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 2: [WAIT_RESPONSE] priority=Controller, requiresResponse=true, callback: 0
2019-07-19 23:31:59.729 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 1
2019-07-19 23:31:59.735 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: TID 2: [WAIT_RESPONSE] priority=Controller, requiresResponse=true, callback: 0
2019-07-19 23:31:59.737 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=SerialApiGetCapabilities[7], type=Response[1], dest=255, callback=0, payload=01 00 00 86 00 01 00 5A FE 81 FF 88 4F 1F 00 00 FB 9F 7D A0 67 00 00 80 00 80 86 00 00 00 E8 73 00 00 0E 00 00 60 00 00
2019-07-19 23:31:59.740 [DEBUG] [SerialApiGetCapabilitiesMessageClass] - API Version = 1.0
2019-07-19 23:31:59.741 [DEBUG] [SerialApiGetCapabilitiesMessageClass] - Manufacture ID = 0x86
2019-07-19 23:31:59.745 [DEBUG] [SerialApiGetCapabilitiesMessageClass] - Device Type = 0x1
2019-07-19 23:31:59.746 [DEBUG] [SerialApiGetCapabilitiesMessageClass] - Device ID = 0x5a
2019-07-19 23:31:59.747 [DEBUG] [e.internal.protocol.ZWaveTransaction] - TID 2: Transaction COMPLETED
2019-07-19 23:31:59.749 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 255: Added 5 to queue - size 3
2019-07-19 23:31:59.752 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2019-07-19 23:31:59.753 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 255: Response processed after 38ms
2019-07-19 23:31:59.754 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 255: TID 2: Transaction completed
2019-07-19 23:31:59.754 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 255: notifyTransactionResponse TID:2 DONE
2019-07-19 23:31:59.755 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2019-07-19 23:31:59.756 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2019-07-19 23:31:59.757 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 05 00 06 96 0F 65
2019-07-19 23:31:59.758 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 255: Sending REQUEST Message = 01 05 00 06 96 0F 65
2019-07-19 23:31:59.759 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 06
2019-07-19 23:31:59.760 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2019-07-19 23:31:59.761 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 05 01 06 96 0F 64
2019-07-19 23:31:59.759 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - Message SENT
2019-07-19 23:31:59.762 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage started: TID 3: [WAIT_RESPONSE] priority=Controller, requiresResponse=true, callback: 0
2019-07-19 23:31:59.763 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 1<>127 : Message: class=SerialApiSetTimeouts[6], type=Response[1], dest=255, callback=0, payload=96 0F
2019-07-19 23:31:59.764 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (1): Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2019-07-19 23:31:59.765 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 3: [WAIT_RESPONSE] priority=Controller, requiresResponse=true, callback: 0
2019-07-19 23:31:59.766 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg: ACK
2019-07-19 23:31:59.767 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=SerialApiSetTimeouts[6], type=Response[1], dest=255, callback=0, payload=96 0F
2019-07-19 23:31:59.768 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 3: [WAIT_RESPONSE] priority=Controller, requiresResponse=true, callback: 0
2019-07-19 23:31:59.769 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 1
2019-07-19 23:31:59.769 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: TID 3: [WAIT_RESPONSE] priority=Controller, requiresResponse=true, callback: 0
2019-07-19 23:31:59.771 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=SerialApiSetTimeouts[6], type=Response[1], dest=255, callback=0, payload=96 0F
2019-07-19 23:31:59.775 [DEBUG] [age.SerialApiSetTimeoutsMessageClass] - Got SerialApiSetTimeouts response. ACK=150, BYTE=15
2019-07-19 23:31:59.776 [DEBUG] [e.internal.protocol.ZWaveTransaction] - TID 3: Transaction COMPLETED
2019-07-19 23:31:59.779 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 255: Response processed after 17ms
2019-07-19 23:31:59.781 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 255: TID 3: Transaction completed
2019-07-19 23:31:59.790 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 255: notifyTransactionResponse TID:3 DONE
2019-07-19 23:31:59.797 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2019-07-19 23:31:59.801 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2019-07-19 23:31:59.802 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 03 00 56 AA
2019-07-19 23:31:59.803 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 255: Sending REQUEST Message = 01 03 00 56 AA
2019-07-19 23:31:59.804 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - Message SENT
2019-07-19 23:31:59.805 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 06
2019-07-19 23:31:59.805 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2019-07-19 23:31:59.805 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage started: TID 4: [WAIT_RESPONSE] priority=Controller, requiresResponse=true, callback: 0
2019-07-19 23:31:59.806 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 04 01 56 01 AD
2019-07-19 23:31:59.807 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=GetSucNodeId[86], type=Response[1], dest=255, callback=0, payload=01
2019-07-19 23:31:59.806 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2019-07-19 23:31:59.808 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 4: [WAIT_RESPONSE] priority=Controller, requiresResponse=true, callback: 0
2019-07-19 23:31:59.809 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg: ACK
2019-07-19 23:31:59.810 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=GetSucNodeId[86], type=Response[1], dest=255, callback=0, payload=01
2019-07-19 23:31:59.811 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 4: [WAIT_RESPONSE] priority=Controller, requiresResponse=true, callback: 0
2019-07-19 23:31:59.811 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 1
2019-07-19 23:31:59.812 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: TID 4: [WAIT_RESPONSE] priority=Controller, requiresResponse=true, callback: 0
2019-07-19 23:31:59.813 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=GetSucNodeId[86], type=Response[1], dest=255, callback=0, payload=01
2019-07-19 23:31:59.813 [DEBUG] [rialmessage.GetSucNodeIdMessageClass] - Got SUC NodeID response.
2019-07-19 23:31:59.814 [DEBUG] [rialmessage.GetSucNodeIdMessageClass] - NODE 1: Node is SUC.
2019-07-19 23:31:59.815 [DEBUG] [e.internal.protocol.ZWaveTransaction] - TID 4: Transaction COMPLETED
2019-07-19 23:31:59.816 [DEBUG] [etControllerCapabilitiesMessageClass] - Creating GET_CONTROLLER_CAPABILITIES message
2019-07-19 23:31:59.817 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 255: Added 6 to queue - size 2
2019-07-19 23:31:59.818 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2019-07-19 23:31:59.818 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 255: Response processed after 13ms
2019-07-19 23:31:59.819 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 255: TID 4: Transaction completed
2019-07-19 23:31:59.820 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 255: notifyTransactionResponse TID:4 DONE
2019-07-19 23:31:59.821 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2019-07-19 23:31:59.821 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
